7 Replies Latest reply on Dec 9, 2017 11:25 AM by Thom Parker
    Using script to count dropdowns... two scripts
    jcbarker74 Level 1
      I have two sets of dropdowns... one set is numbered D1 - D64 with all of the selections the same. The other set is E1 - E64 all with the same selections but not the same as set D.
      I have a script for each set that will calculate how many times a selection was made and it places the total in a text field automatically.
      The problem is I place both scripts as document level scripts. When I do this, I can only get one to function. If I place either script in by itself, it functions. Is there a way to combine these scripts or some way to make both work at the same time?
      function countDropdowns(v) {
          var total = 0;
          for (var i=1; i<=64; i++) {
              var f = this.getField("D"+i);
              if (f.valueAsString==v) total++;
          event.value = total?total:"";
          var total = 0;
        • 1. Re: Using script to count dropdowns... two scripts
          Thom Parker Adobe Community Professional
          Are these the actual functions, or did you accidentally copy the same one twice?
          You cannot define two functions with the same name. They must have different function names, and they have to be written to operate on different sets of fields. Note that the second copy is still looking at the "D" fields.
          Like this:
          function countDropdownsD(v) {
              var total = 0;
          function countDropdownsE(v) {
              var total = 0;
                  var f = this.getField("E"+i);
          • 2. Re: Using script to count dropdowns... two scripts
            jcbarker74 Level 1
            My mistake. Thank you for catching that... Here are the correct scripts I have as of now. How do I change them?
                var total = 0;
                var total = 0;
                for (var i=1; i<=16; i++) {
            • 3. Re: Using script to count dropdowns... two scripts
              jcbarker74 Level 1
              Thom,
              I did a copy and paste from your response with the different function names. I still only get one script to work at a time.
              Could this have something to do with the calculation from the text field that should be counting them?
              This is what I have:
              Two Document JavaScripts
              The first I named countDropdownsD
                  var total = 0;
              The second is named countDropdownsE
                  var total = 0;
              In the text fields where I want the selections counted, I have this:
              countDropdowns("selection name");
              • 4. Re: Using script to count dropdowns... two scripts
                I provided the solution in your original thread. Why are you not implementing it?
                • 5. Re: Using script to count dropdowns... two scripts
                  jcbarker74 Level 1
                  I couldn't find that thread. You did provide some great solutions but I added another set of dropdowns with different values contained in them.
                  You can see above that I've tried a couple of different ways to get both scripts to work at the same time. I can only seem to get one to work at a time.
                  • 6. Re: Using script to count dropdowns... two scripts
                    There's a link to in any email you get, and it's also accessible under your profile.
                    For future reference: Calcuculating the number of times an item is selected from a dropdown list
                    • 7. Re: Using script to count dropdowns... two scripts
                      Since you changed the function names, You also have to change the names where the functions are called.
                      Details are really important with any kind of programming.
                      Perhaps you should consider hiring a professional.
