5 Replies Latest reply on Dec 9, 2017 7:00 AM by justynam53995294
    Photoshop doesn't open or crashes after launch
    justynam53995294
      I have updated Windows 4days ago, and since then Photoshop either crashes at launch or most times simply fails to open (the screen freezes when the "initialising shields" command appears.)
      I have since updated Photoshop, reinstalled both Photoshop and Creative Suite , checked the software with a new Windows user account, reinstalled Windows, tried the printer settings trick, nothing seems to help.
      The Adobe Support was able to get Photoshop running when they disabled the Intel 530 graphic card, but that means I can't use the second screen (I work on setup with  a laptop and a screen connected by a hdmi cable), so it's not really a solution.
      Any suggestions what else should I try?
      Thank you
        • 1. Re: Photoshop doesn't open or crashes after launch
          You have not offered any exact system info, so there isn't really much anyone can tell you beyond the obvious "there's an issue with your graphics hardware and driver", but I guess you already figured as much...
          Mylenium
          • 2. Re: Photoshop doesn't open or crashes after launch
            justynam53995294 Level 1
            Thank you- rookie mistake..
            System: Windows 10 64bit
            Graphic Card: Intel 530HD  graphics (this is the card the monitor is plugged in)
            NVIDIA GeForce GTX960M
            I have tried to revert to CC2017 but it now crashes too. I have a total of 5 error logs from today's time I tried to run these versions, some Intel-related so I suppose they might be a help?
            1.
            Intel(R) Dynamic Platform and Thermal Framework : ESIF(8.2.10900.330) TYPE: ERROR MODULE: DPTF TIME 46413712 ms
            DPTF Build Version:  8.2.10900.330
            DPTF Build Date:  May 16 2016 11:32:37
            Source File:  ..\..\..\Sources\Manager\WIPolicyActiveRelationshipTableChanged.cpp @ line 52
            Executing Function:  WIPolicyActiveRelationshipTableChanged::execute
            Message:  Unhandled exception caught during execution of work item
            Framework Event:  PolicyActiveRelationshipTableChanged [44]
            Policy:  Active Policy [0]
            Exception Function:  Policy::executePolicyActiveRelationshipTableChanged
            Exception Text:
            Source File:  ..\..\..\Sources\Manager\EsifServices.cpp @ line 457
            Executing Function:  EsifServices::primitiveExecuteGet
            Message:  Error returned from ESIF services interface function call
            Participant:  NoParticipant
            Domain:  NoDomain
            ESIF Primitive:  GET_ACTIVE_RELATIONSHIP_TABLE [89]
            ESIF Instance:  255
            ESIF Return Code:  ESIF_E_UNSUPPORTED_ACTION_TYPE [1202]
            2.
            Intel(R) Dynamic Platform and Thermal Framework : ESIF(8.2.10900.330) TYPE: ERROR MODULE: DPTF TIME 46482051 ms
            Exception Text:
            Domain:  NoDomain
            ESIF Instance:  255
            3.
            Nazwa aplikacji powodującej błąd: Photoshop.exe, wersja: 18.1.2.29870, sygnatura czasowa: 0x59fccbe7
            Nazwa modułu powodującego błąd: ig9icd64.dll, wersja: 22.20.16.4771, sygnatura czasowa: 0x59913d69
            Kod wyjątku: 0xc0000005
            Przesunięcie błędu: 0x000000000055e889
            Identyfikator procesu powodującego błąd: 0x53a0
            Godzina uruchomienia aplikacji powodującej błąd: 0x01d3702c12a7c886
            Ścieżka aplikacji powodującej błąd: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
            Ścieżka modułu powodującego błąd: C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_453d2af85bf95078\ig9icd6 4.dll
            Identyfikator raportu: 19f5ad85-25e8-41b2-8462-40188e050ef0
            Pełna nazwa pakietu powodującego błąd:
            Identyfikator aplikacji względem pakietu powodującego błąd:
            4.
            Nazwa aplikacji powodującej błąd: Adobe Spaces Helper.exe, wersja: 0.0.0.0, sygnatura czasowa: 0x59fccd23
            Nazwa modułu powodującego błąd: libcef.dll, wersja: 3.2924.1537.0, sygnatura czasowa: 0x584a4ed5
            Przesunięcie błędu: 0x0000000000147fc5
            Identyfikator procesu powodującego błąd: 0x5938
            Godzina uruchomienia aplikacji powodującej błąd: 0x01d3702c1cd446c6
            Ścieżka aplikacji powodującej błąd: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\Adobe Spaces Helper.exe
            Ścieżka modułu powodującego błąd: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\Spaces\libcef.dll
            Identyfikator raportu: f32a5d61-3ca9-4073-a03c-2ec43f4b81f2
            5.
            Identyfikator procesu powodującego błąd: 0x21f4
            Godzina uruchomienia aplikacji powodującej błąd: 0x01d3702c1cd3f378
            Identyfikator raportu: 98f9e0b6-45a7-49e8-bac8-d73b803e9921
            Please let me know if I should give any other info?
            • 3. Re: Photoshop doesn't open or crashes after launch
              davescm Adobe Community Professional
              Photoshop is known to have issues if it can see two GPUs with conflicting drivers (which is why the Adobe tech used one).
              See section 7 of this guide for steps you can take :
              Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
              Dave
              • 4. Re: Photoshop doesn't open or crashes after launch
                Ged Traynor Adobe Community Professional
                Try disabling Show Messages in Preferences
                Also take a look here
                Photoshop crashing due to libcef.dll
                There's also this thread
                Photoshop CC 2017: Adobe Spaces Helper crash | Photoshop Family Customer Community
                • 5. Re: Photoshop doesn't open or crashes after launch
                  I tried the troubleshooting guide, starting by an attempt to re-update the graphic cards drivers. After an attempt to download the Intel drivers straight from the website it pretty much got way worse.
                  Right now, not only Photoshop doesn't launch, any attempt to launch the Creative Suite app shows it as faulty and won't launch, even after re-installing the software. When I try to uninstall any Adobe software, a message says the software has already been uninstalled, but after restart appears in the start menu again.
                  The image is displayed on only one screen (despite attempts of setting it on both) and keeps refreshing by going pitch black.
                  The computer was checked for viruses etc..
