10 Replies Latest reply on Jan 10, 2019 8:16 AM by mary c mg27762556
    Error: The file may be a read only, or another user has it open.
    jessicaf60018425 Level 1
      After my computer did the adobe update on monday, it stopped letting me save. I get the error message, " The file may be a read only, or another user has it open. Please save the document with a different name or in a different location." It is not read only no one else has it open, and I tried all of the above. It also gives me an error, "The document could not be saved. This file could not be found."  I have been using these same files, and they worked fine until the new adobe update. I have tried disabling the detail pane and preview pane under file explorer with no resolution. Everything else on my computer works, its just when I am trying to save an adobe file, and I did not have this issue until the new adobe update on monday. I also tried to install the patch for the nov update, and that did not help either. I have also went under properties - general - and made sure that anything that said could storage was disabled. I have tried everything in the adobe forums and anything I could find on the internet and still can not save like I could, before the adobe update. I just now tried Edit>Preferences>Documents - uncheck "Save As optimizes for Fast Web View", and that did not help either. I have also tried Tried Edit/Preferences/Security(Enhanced) unchecked Enable Enhanced Security. I am not using Details View.
        • 1. Re: The file may be a read only, or another user has it open. Please save the document with a different name or in a different location /The document could not be saved. This file could not be found
          meenakshin83966505 Adobe Employee
          Hi Jessicaf,
          Sorry for the delay in response.
          As you have mentioned that you get an error while saving the file, it is an issue with all the files?
          The file that you open in the application, is it saved on your system or on a server?
          What is the dot version of the application you are using on your system? Take help of the steps mentioned here Identify the product and its version for Acrobat and Reader DC to check that.
          Also, share the exact steps you do that results in the error message.
          Please share the information asked above.
          Let us know if you have any question.
          Regards,
          Meenakshi
          • 2. Re: Error: The file may be a read only, or another user has it open.
            shaynap38592263
            I have this exact same problem. Except that, after I exited out of the error message, my whole document was deleted, and I have lost close to 20 hours of work. I am devastated and so very angry. This file had been saving just fine until I tried to save it today (1/17/18). The file no longer exists. I have a MacBook Air and I am operating on Sierra 10.12.6. I had been saving onto Microsoft One Drive. And of course, as soon as Adobe lost my document, that damn cloud began to sync with my computer, and voila, now the document doesn't exist in my cloud either. Absolutely gone. I have three more open documents on Adobe. I tried to save them also, and I also got the error message for each of them, "The file may be a read only, or another user has it open. Please save the document with a different name or in a different location." After I exited this message, my entire document went blank, all the text gone with only the yellow highlight remaining. To reiterate I had just a blank document with lines of yellow in the areas where the text used to be. I clicked revert and was able to "fix" the documents (although I am still unable to save them). But the one large file, the one I lost, when I tried to click revert on that one (seeing as it was able to restore the other documents) is when it completely disappeared. My OneDrive has all these documents, but all the comments and highlight (the actual work invested in them) are gone and they have all been reverted to the day I first downloaded them (even though reverting is supposed to revert to the last save point). The last three remaining documents are still open on my computer, but I am unable to save them and my One Drive doesn't have them saved. So for me, any and all pdf files open in Adobe refuse to save. I have the Adobe Acrobat Reader DC 2017 Release Version: 2017.012.20098. Sorry for hijacking this question. I have never used the forums before and I don't know how to make my own post. I am just encountering the exact same problem.
            • 3. Re: Error: The file may be a read only, or another user has it open.
              mik_se18
              I work for an academy and I'm having the same issue with one user, the user is on a brand new HP windows 10 pro laptop and was setup and working until the beginning of last week when outlook started to stop sending attachments without corrupting them, the solution was to disable Adobe send and track, but at the same time adobe DC pro wouldn't let the user save the document with the same error as these posts read only or open by another user.
              I looked online and one solution was to check folder permissions where the file is located and where you want it saved and this user has full permissions to that folder so this isn't the solution for us.
              Next I completely removed Adobe DC Pro via control panel and reinstalled the latest version on Friday 20th April 2018 and still the same issue has happened.
              the user is accessing the PDF on a network drive so my next step is to eliminate this as a cause but would really appreciate a solution from Adobe asap!
              thanks
              Michael
              • 4. Re: Error: The file may be a read only, or another user has it open.
                mik_se18 Level 1
                The error seems to be isolated to the network, if I move the document to the local computer the user can edit it and save it without issue.
                I have since tried changing all permissions on the network folder, I have also copied the folder to a new drive with new permissions but still getting the same message.
                I have run out of options now as it only appears to be Adobe DC Pro that has issues editing the documents and saving them to the network I must conclude Adobe DC Pro is the problem accessing the network, other programs such word and excel have no issues editing and saving to the same location.
                Can Adobe give me a solution after all we are paying for your solution to edit PDF's
                thanks
                Michael
                • 5. Re: Error: The file may be a read only, or another user has it open.
                  germanop96209349 Level 1
                  same problem here. Now, when i pick up a document and try to save it, all i can do is to give another name to the document, which is very annoying! Anibody here to help?
                  Thank you
                  Germano
                  • 6. Re: Error: The file may be a read only, or another user has it open.
                    Adorobat Adobe Employee
                    Hi Germano,
                    As per the issue description mentioned above, you are facing issue when trying to save a pdf file in Acrobat, is that correct?
                    Try disabling preview pane using the steps given in the following thread and check if that resolves the issue:
                    Can't save after edits in Acrobat 10. "File may be read-only or another user may have it open" (Edit PDF)
                    If the file is on server drive , please move that to the local drive & then check.
                    If issue still persists, try disabling Protected mode using the steps given in the following help document and disabling preview pane again:
                    Refer to the following help document for more info: Protected View feature for PDFs (Windows), Adobe Reader
                    Let us know if you need any help.
                    Shivam
                    2 people found this helpful
                    • 7. Re: Error: The file may be a read only, or another user has it open.
                      hemanth.majji Level 1
                      When you get this message "The file may be a read-only, or another user has it open. Please save the document with a different name or in a different location.", just close that window and do "Save as", the job is done.
                      • 8. Re: Error: The file may be a read only, or another user has it open.
                        Hi hemanth.majji,
                        Thank you for sharing your findings with us. It will surely help other users facing the similar issue.
                        Shivam
                        • 9. Re: Error: The file may be a read only, or another user has it open.
                          willd79222299
                          Are you including full points in the file (PDF) name your saving with? I had this problem saving files ending with dates like this:-
                          Example document 30.11.2018
                          This worked:-
                          Example document 30-11-2018
                          This happened to me saving PDFs for the first time from the web. However, once I had saved them to my computer and opened them to save again, for filing else where, I found I could use 'full points' towards the end of the document name!!
                          To summarise, If I saved the same document (PDF) from the web for the first time (not tried other sources) without the full points, saves fine. The issue may be due the full points at the end of files/documents being intended to tell the operating system, Windows/Mac etc, that its the end of the user document name and the file extension type follows (this tells the computer what type of file it is and what program will open it). For example:-
                          You may not see the file extension type abbreviation, as you need to change the "document view" settings as an option to see them. Not sure I have explained myself well, but this cured my problem. Hope this helps someone!
                          • 10. Re: Error: The file may be a read only, or another user has it open.
                            mary c mg27762556
                            I have tried this numerous times but it still doesn't work.
