Hello, I'm having a certain problem with my software, it doesn't star at all.
Everytime I try to open it in the MAC, the loading screen appears and suddenly, it says that it has closed itself unexpectedly.
I don't know what to do to fix this, I already tried reinstalling from scratch and everything and nothing worked.
Here's the error log
Process: After Effects [809]
Path: /Applications/Adobe After Effects CC 2018/Adobe After Effects CC 2018.app/Contents/MacOS/After Effects
Identifier: com.adobe.AfterEffects
Version: 15.0 (15.0)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: After Effects [809]
User ID: 501
Date/Time: 2017-12-08 10:44:10.687 -0600
OS Version: Mac OS X 10.13.1 (17B1003)
Report Version: 12
Anonymous UUID: 20FE31B7-80B3-4848-DE9D-03DCA47FC9B5
Time Awake Since Boot: 4800 seconds
System Integrity Protection: disabled
Crashed Thread: 41
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Thread 0:: Dispatch queue: com.apple.main-thread
0 com.adobe.headlights.LogSessionFramework 0x000000010e6c46ce std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > > > > > > > >::__find_equal_key(std::__1::__tree_node_base<void*>*&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 92
1 com.adobe.headlights.LogSessionFramework 0x000000010e6c14bd std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::map<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const, std::__1::set<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > > > > > > > >::operator[](std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 33
2 com.adobe.headlights.LogSessionFramework 0x000000010e6c09bf EventBlocker::Validate(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >) + 83
3 com.adobe.headlights.LogSessionFramework 0x000000010e6c9e29 LogSession::EventRecTag(char const*, char const*, char const*, char const*, DataCategory) + 223
4 com.adobe.headlights.LogSessionFramework 0x000000010e6d4dbc WRAPPERUTLogEvent + 1194
5 com.adobe.headlights.LogSessionFramework 0x000000010e6c64e8 UTLogEvent + 16
6 com.adobe.AfterEffectsLib.framework 0x000000010be766ff HeadlightsGlue::TelemetryProvider::LogEvent(char const*, char const*, unsigned short const*, dvacore::utility::Guid) + 207
7 U.dylib 0x00000001100e5b23 U::telemetry::LogEvent(char const*, char const*, unsigned short const*, dvacore::utility::Guid) + 67
8 U.dylib 0x00000001100eaf33 Up_ExceptionHandler(int) + 147
9 libsystem_platform.dylib 0x00007fff6a5eff5a _sigtramp + 26
10 ??? 0x000060000102cec0 0 + 105553133227712
11 com.adobe.AfterEffectsLib.framework 0x000000010bec02ec CBartender::InsertMenuCmd(unsigned int, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, short, short) + 908
12 com.adobe.AfterEffectsLib.framework 0x000000010bec00f3 CBartender::InsertMenuCmd(unsigned int, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, short, short) + 403
13 com.adobe.AfterEffectsLib.framework 0x000000010bd4c06e ae_menu_utils::HelpMenu_AppendItemCmd(unsigned int, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 62
14 com.adobe.AfterEffectsLib.framework 0x000000010bd47d86 AMT_HelpMenu_SetOrAdd(AMT_HelpMenuType, int, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool) + 70
15 com.adobe.AfterEffectsLib.framework 0x000000010bd47910 DoSetupAMTMenus() + 160
16 com.adobe.AfterEffectsLib.framework 0x000000010bd47859 DoAMTIdle() + 521
17 com.adobe.AfterEffectsLib.framework 0x000000010bda6a06 CEggApp::Dawdle(int*) + 4134
18 com.adobe.AfterEffectsLib.framework 0x000000010bebc549 CApplication::Idle(EventRecord*) + 1721
19 com.adobe.AfterEffectsLib.framework 0x000000010bed7ef8 CSwitchboard::DoIdle(EventRecord*) + 792
20 com.adobe.AfterEffectsLib.framework 0x000000010bed6b18 CSwitchboard::IdleTimerFunc(CSwitchboard*) + 3160
21 com.adobe.AfterEffectsLib.framework 0x000000010bc17a26 GetAECocoaApplication() + 21494
22 com.adobe.dvacore.framework 0x00000001105c395c int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
23 MEE.dylib 0x000000011902ab1a egg::dvainit::AE_DVA_ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 922
24 com.adobe.dvacore.framework 0x00000001105c3a13 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 99
25 com.adobe.AfterEffectsLib.framework 0x000000010bc17105 GetAECocoaApplication() + 19157
26 com.apple.Foundation 0x00007fff44eb4d99 __NSFireTimer + 83
27 com.apple.CoreFoundation 0x00007fff42d96e34 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
28 com.apple.CoreFoundation 0x00007fff42d96aa7 __CFRunLoopDoTimer + 1095
29 com.apple.CoreFoundation 0x00007fff42d965aa __CFRunLoopDoTimers + 346
30 com.apple.CoreFoundation 0x00007fff42d8dbab __CFRunLoopRun + 2427
31 com.apple.CoreFoundation 0x00007fff42d8cfa3 CFRunLoopRunSpecific + 483
32 com.apple.HIToolbox 0x00007fff420ac866 RunCurrentEventLoopInMode + 286
33 com.apple.HIToolbox 0x00007fff420ac5d6 ReceiveNextEventCommon + 613
34 com.apple.HIToolbox 0x00007fff420ac354 _BlockUntilNextEventMatchingListInModeWithFilter + 64
35 com.apple.AppKit 0x00007fff403a9a23 _DPSNextEvent + 2085
36 com.apple.AppKit 0x00007fff40b3ee6c -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
37 com.apple.AppKit 0x00007fff4039e831 -[NSApplication run] + 764
38 com.adobe.AfterEffectsLib.framework 0x000000010bdfe5e8 MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int) + 1112
39 com.adobe.AfterEffectsLib.framework 0x000000010bdfe17a EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 58
40 com.adobe.AfterEffects 0x000000010bb7e383 main + 2483
41 com.adobe.AfterEffects 0x000000010bb7d864 start + 52
Thread 1:
0 libsystem_kernel.dylib 0x00007fff6a4bf6da __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff6a5f906a _pthread_wqthread + 1035
2 libsystem_pthread.dylib 0x00007fff6a5f8c4d start_wqthread + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff6a4bee7e __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff6a5fa662 _pthread_cond_wait + 732
2 com.adobe.headlights.LogSessionFramework 0x000000010e739ccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x000000010e7385ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x000000010e6e6059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x000000010e6b4cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x000000010e737969 boost::(anonymous namespace)::thread_proxy(void*) + 185
7 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 3:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff6a4b5e76 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6a4b5390 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff42d8e5d5 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff42d8d927 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff42d8cfa3 CFRunLoopRunSpecific + 483
5 com.apple.CFNetwork 0x00007fff41d05662 +[NSURLConnection(Loader) _resourceLoadLoop:] + 357
6 com.apple.Foundation 0x00007fff44e4b6d8 __NSThread__start__ + 1197
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff6a4bf142 __select + 10
1 com.apple.CoreFoundation 0x00007fff42dc863b __CFSocketManager + 635
2 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
3 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
4 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 5:
Thread 6:
2 com.adobe.dvacore.framework 0x000000011059616b boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
3 com.adobe.dvacore.framework 0x0000000110595e9b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 187
4 com.adobe.dvacore.framework 0x00000001106a7f21 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 145
5 com.adobe.dvacore.framework 0x00000001106a6469 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 153
6 com.adobe.dvacore.framework 0x00000001106a35bf dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
7 com.adobe.boost-threads.framework 0x00000001197333d5 boost::(anonymous namespace)::thread_proxy(void*) + 165
8 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
9 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
10 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 7:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff6a4bf082 __recvfrom + 10
1 VulcanMessage5.dylib 0x00000001289e92b8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x00000001289e867c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x00000001289e7974 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x00000001289e7838 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x00000001289e2477 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x00000001289e2f06 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x00000001289e289f vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x00000001289e6924 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x00000001289e637d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x00000001289e606a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x00000001289e5fbd vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x00000001289d97f8 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x00000001289d8a36 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x00000001289e71bc vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x00000001289e90b9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
17 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
18 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 8:
0 libsystem_kernel.dylib 0x00007fff6a4c003a kevent + 10
1 com.adobe.dvatransport.framework 0x00000001132274bc boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
2 com.adobe.dvatransport.framework 0x0000000113226f6c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
3 com.adobe.dvatransport.framework 0x0000000113226c35 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
4 com.adobe.dvatransport.framework 0x000000011321c042 SkyConnectionEnv::MainLoop() + 162
5 com.adobe.dvatransport.framework 0x000000011321b9f9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost-threads.framework 0x00000001197333d5 boost::(anonymous namespace)::thread_proxy(void*) + 165
Thread 9:
2 com.adobe.dvatransport.framework 0x0000000113226ef7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 263
4 com.adobe.dvatransport.framework 0x0000000113231e1a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_io_service_runner>::run() + 42
5 com.adobe.dvacore.framework 0x000000011064ddf3 boost_asio_detail_posix_thread_function + 19
Thread 10:
Thread 11:
Thread 12:
2 0x000000013d1f5ae8 void boost::condition_variable_any::wait<boost::mutex>(boost::mutex&) + 72
3 0x000000013d2069df RequestManager::decodeFunc(void*) + 255
4 com.adobe.boost-threads.framework 0x00000001197333d5 boost::(anonymous namespace)::thread_proxy(void*) + 165
5 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
6 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
7 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 13:
Thread 14:
2 com.adobe.ImporterFlash.framework 0x000000013da6f151 void boost::condition_variable_any::wait<boost::unique_lock<boost::recursive_mutex> >(boost::unique_lock<boost::recursive_mutex>&) + 65
3 com.adobe.ImporterFlash.framework 0x000000013da6ebda ImporterFlash::SingleThreadExecutor::ThreadProcedure() + 122
4 com.adobe.dvacore.framework 0x00000001106a35bf dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
5 com.adobe.boost-threads.framework 0x00000001197333d5 boost::(anonymous namespace)::thread_proxy(void*) + 165
Thread 15:
Thread 16:
0 libsystem_kernel.dylib 0x00007fff6a4b5eca semaphore_timedwait_trap + 10
1 com.apple.CoreServices.CarbonCore 0x00007fff43f39f18 MPWaitOnSemaphore + 74
2 REDR3D.dylib 0x000000013bc171be R3D_BAI + 106382
3 REDR3D.dylib 0x000000013bbe4e5f 0x13bb0d000 + 884319
4 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 17:
2 REDR3D.dylib 0x000000013bc16fae R3D_BAI + 105854
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
5 com.apple.AVCVideoServices 0x0000000142e2cad2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
Thread 26:
1 libsystem_pthread.dylib 0x00007fff6a5f926f _pthread_wqthread + 1552
Thread 27:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff42803bea HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 124
3 com.apple.audio.CoreAudio 0x00007fff42803b5d HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff42800bc9 HALC_ProxyIOContext::IOWorkLoop() + 977
5 com.apple.audio.CoreAudio 0x00007fff4280062c HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fff4280036e HALB_IOThread::Entry(void*) + 72
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:: cr_scratch
2 com.adobe.CameraRaw 0x0000000155e4904c 0x1553fd000 + 10797132
3 com.adobe.CameraRaw 0x0000000155dbc83b 0x1553fd000 + 10221627
4 com.adobe.CameraRaw 0x0000000155ae1b21 0x1553fd000 + 7228193
Thread 41 Crashed:
0 com.adobe.AfterEffects.Scripting 0x000000015d3ef4f7 ScObjects::BridgeTalkThread::runLocked() + 39
1 com.adobe.AfterEffects.Scripting 0x000000015d3ef3df ScObjects::BridgeTalkThread::run() + 207
2 com.adobe.AfterEffects.Scripting 0x000000015d3c2d81 ScObjects::Thread::go(void*) + 161
3 libsystem_pthread.dylib 0x00007fff6a5f96c1 _pthread_body + 340
4 libsystem_pthread.dylib 0x00007fff6a5f956d _pthread_start + 377
5 libsystem_pthread.dylib 0x00007fff6a5f8c5d thread_start + 13
Thread 42:
Thread 43:
0 libsystem_kernel.dylib 0x00007fff6a4bf1d2 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff6a43a754 nanosleep + 199
2 libsystem_c.dylib 0x00007fff6a43a648 usleep + 53
3 0x000000015eca2caa melange::IpKillThread::Main() + 58
4 0x000000015ec93d78 melange::BaseThread::Action() + 88
5 0x000000015ec93c59 0x15ebfb000 + 625753
Thread 44:
Thread 45:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fff404e72d1 _NSEventThread + 184
Thread 41 crashed with X86 Thread State (64-bit):
rax: 0x5d59a8f0002e7265 rbx: 0x00007fd2f9f845e0 rcx: 0x0000000000012068 rdx: 0x0000000000000008
rdi: 0x00006080001d8d80 rsi: 0x0000000000000000 rbp: 0x0000700008c8de70 rsp: 0x0000700008c8db50
r8: 0x000000000000cb25 r9: 0x000060c000684620 r10: 0x0000000000000001 r11: 0x0000000000000247
r12: 0x000000015d3c2ce0 r13: 0x00007fd2f9f845e0 r14: 0x0000700008c8de88 r15: 0x000000015d59ad40
rip: 0x000000015d3ef4f7 rfl: 0x0000000000010202 cr2: 0x000000010bbff000
Logical CPU: 6
Error Code: 0x00000000
Trap Number: 13
Thanks for the help, I hope this can be fixed quickly
BernCas,
Your error was with Adobe Bridgetalk script. Try running After Effects without the script. Is it working now?
Kevin
How do I get in contact with an actual person that can help me? Ive done everything that's been suggested and I just keep getting put back in the same rotation of forums.
