1. Re: Crisis! File destroyed after pasting, any solution?
gener7 Dec 9, 2017 2:07 PM (in response to espegelan)1 person found this helpfulI may be wrong, but it does appear you are using MacOS which has Time Machine. You can Enter Time Machine, go back to when you had the intact copy, select and replace it.
Gene
2. Re: Crisis! File destroyed after pasting, any solution?
josephlavine Dec 9, 2017 3:24 PM (in response to espegelan)1 person found this helpfulI am very sorry this has occurred. As gener7 mentioned, your best bet is if you have some sort of auto backup such as TimeMachine.
I can't tell from your screen capture, but is the issue tide to just one layer? What happens if you systematically turn layers off? Also, have you tried doing a SaveAs and rename plus switch to PSD?
3. Re: Crisis! File destroyed after pasting, any solution?
espegelan Dec 9, 2017 3:30 PM (in response to gener7)Thanks for the tip! But unfortunately I haven´t been connected to Time Machine since I started the illustration.
4. Re: Crisis! File destroyed after pasting, any solution?
espegelan Dec 9, 2017 3:43 PM (in response to josephlavine)It´s very strange. This pattern and white mesh has just been split out on all the layers. Luckily I managed to extract some of the layers with the most heavy work on it and place it in a new file. Some of the pattern followed the layers, and all layers where the clone stamp tool was used was completely damaged.
Do you suspect it could be because it´s a tiff format? I´m going to try save as PSD on a later point, right now I´m leaving this buggy file alone.
5. Re: Crisis! File destroyed after pasting, any solution?
gener7 Dec 9, 2017 5:44 PM (in response to espegelan)Enter Time Machine anyway. It does keep a small amount of History without the External drive. You may be lucky.
I can't say if converting to PSD will help at this point. You can try. I'm superstitious in that I stay with the native file format and that would be PSD/PSB. Flat Tiff to me is best for handing off the final work to a printing company.
Although this comes off as "lock the barndoor" advice, Timemachine and/or Dropbox which supports versioning, or even your own CC Storage.
