Hi there
I am using a new high-end PC and Photoshop CC does not work on it, always Bluescreen after starting.
PC Configuration:
- Intel i9 Extreme
- 128 GB Memory
- Samsung 960 PRO Sequential (Read/Write 3500 MB/s/2100 MB/s)
- 1 x GeForce GTX 1080 Ti
- 1 x GeForce GTX 1050 Ti
- 6 x 27" Monitors
- Windows 10 64bit english
I have tried to install different versions of drivers, still the same problem.
I have also add settings in "NVIDIA 3D Settings" to make sure Photoshop only uses GTX 1080, still the same problem.
What can I do to make Photoshop running ?
Thanks and best regards
Frank Uray
Hi
I'm not sure if this is related to you but have a look here
Intel 7820x Core CPU (Turbo Boost) and Adobe Photoshop CC BSOD's
Intel 7820x Core CPU BSOD's |Intel Communities
Also check out this
Photoshop graphics processor (GPU) card FAQ
I don't think PS plays well with dual GPU's
And what does the crash report actually say? Check your event viewer.
Mylenium
Hi there
I have just made some more tests on this, I had this situations:
- Photoshop was able to open a file, after closing Photoshop, Lightroom was not starting for about 4 times with crash report.
After a while I was able to start Lightroom and than I started Photoshop and got Bluescreen right away:
PAGE_FAULT_IN_NONPAGED_AREA
- After reboot I started Photoshop and got Bluescreen right away:
WHEA_UNCORRECTABLE_ERROR
EventViewer does not really show explicit error, I got some of these:
"The computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xfffff80255614680, 0x0000000000000000, 0xfffff80155336166, 0x0000000000000002). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 3ebe061d-70ef-479d-a182-b4e9d03d94e5."
"The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID"
Thanks for your help and best regards
Frank Uray
Does anybody has an idea what the problem would be ?
Thanks for any comments.
Hi
Also check out this
