I have a creative cloud account, and with that access to all the desktop apps. I just downloaded Adobe Draw--and while I can export all drawn images from Adobe Draw into my Illustrator/Photoshop, I can't import back from my Creative Cloud library into Adobe Draw. I've tried going into settings --> Import Ideas Files --> Import Individual Files from Adobe Ideas, but when I click on that all my assets appear but I can't click on any of them. Any idea how to access assets from Draw otherwise? I can't import photos from my iPad either
Hi Maitreyi
Sorry you're having trouble. Are these the steps you're using?
1. Tap the + just above the Background Layer to open a pop-up menu with the choices Draw Layer and Image Layer
2. Tap Image Layer
3. Then choose from where you'd like to import the image (On my iPad, Take a Photo, My CC Files, From Market, From [Adobe] Stock, Paste Image). My CC Files is what you want to choose if you've dropped your assets in that folder on the desktop.
If this is what you're doing, and it's not working ple
...Copy link to clipboard
Hi Maitreyi
2. Tap Image Layer
If this is what you're doing, and it's not working please let me know at which point the process is failing and what's happening so I can try to figure out what's going wrong.
Sue.
Hi Sue,
Thank you for your help! This worked
Maitreyi.
You're welcome. Thanks for letting me know things are working.
Sue.
Hi Maitreyi,
I am experiencing the same problem with my new Ipad pro. I used to have an Ipad air and it worked perfektly, but now with the Ipad Pro I cannot import an image in a layer in adobe draw or adobe sketch.
I hope, there is a solution, because it is a very important feature.
Celia
Hi! I was redirected here from an Adobe Customer Care and this is what they thought my problem is. However, whenever I try to upload an image into an image layer, it wont load up ( evidence: https://twitter.com/lovelytheollie/status/1155950218245898241 ) i just wanna be able to trace multiple images to make one big image but its not working !!
Hi Ollie.
I responded on your other post but just in case you don't see it, I wanted to put the answer here too:
This is an issue with Draw and Sketch and the iOS 13 beta.
The team does know about it and will resolve any issues prior to the public release of iOS 13 but for the time being this feature is not working.
Is reverting back to iOS 12 an option for you?
Sue.
Hi Sue, I wanted to ask what should I do if the picture never loads? I am able to make an image layer, and pick the image I want to add there, but whenever I choose my picture, it just loads. It just shows me the Importing Image from Gallery pop-up. After that, nothing happens. I've waited for at least 30 minutes, and nothing has happened. This has become a recent problem. Can you please help?
Thank you,
Darrell
Darrell.
If you're using Draw on a device running iOS 14, make sure that you've given Draw adequate permissions for Photos.
Sue,
I'm not using iOS 14. I'm using a lenovo chromebook.
Sorry if that sounded harsh. I just read over it. There is no rudeness intened though.
Thank you!
Hi Default.
Didn't sound harsh at all.
Nothing's changed on Android as far as I know but will you check something: Drop a couple of images into https://assets.adobe.com/files and see if you're able to import to an Image Layer from CC Assets.
If that works, double-check the Gallery permissions for Draw and also make sure to check a couple of other images to see if it's every image.
Let me know what happens.
Sue.
