• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How do I convert white into a color using Photoshop Elements?
Community Beginner ,
Dec 11, 2017 Dec 11, 2017
[Moderator moved from Photoshop for Beginners to Photoshop Elements.]
I have an image which is simply black text on white background. I want to change the white background to a light blue. For the life of me I cannot figure out how to do this. I tried Replace Color, but remarkably, having read other posts, that feature doesn't seem to work when the color is white. I am using Photoshop Elements 2018.
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 11, 2017 Dec 11, 2017
Add a light blue solid color layer in darker color mode.
Votes
Translate
Translate
Community Expert ,
This can be a challenge. Is the text large and spaced, or is it small and crowded?
It would help if you posted the file (or similar).
Votes
Translate
Translate
Report
Report
Community Expert ,
With black text and white background, you could use the multiply blending mode with layers.
Create a layer with the background colour you want, put it in the background and use the multiplay blending mode for the foreground.
The mathematics behind is simple: White is full colour in RGB (so ONE). Multiply that with any other colour, and you will get that colour. Black is no colour (so ZERO) in RGB. Multiply that with any colour and you will get black.
ABAMBO | Hard- and Software Engineer | Photographer
Votes
Translate
Translate
Report
Report
Abambo, your method of using the multiply blending method worked perfectly as well. I gave MichaelBParis' answer as the correct answer simply because I got his method to work first. Thank you very much for your ingenious correct answer.
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 12, 2017 Dec 12, 2017
You're welcome.
Votes
Translate
Translate
Report
Report
I'm not able to post an image right now, but the text is fairly dense with over 200 words.
Votes
Translate
Translate
Report
Report
Community Expert ,
You could probably produce a dummy picture with dummy text...
Votes
Translate
Translate
Report
Report
Community Expert ,
Using the magic wand as in my previous post.
As you can see:
- the pale blue added to the background is different from the blue text
- what appears as near white is unchanged, it was not pure white.
See the original text:
Mouse cursor not visible or menus not opening in Adobe Elements Organizer
Votes
Translate
Translate
Report
Report
Community Expert ,
This is Photoshop, but Elements should be similar...
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
McihaelBParis, your suggestion to do a New Fill Layer in Darker Color mode using my chosen background color worked perfectly! It was brilliant. I never could have come up with that on my own. Thank you so so so much for your knowledge.
Your other suggestion to use the Magic Wand also worked, but not quite as well because there was a slight grey/off-white surrounding the letters in my image, and so those areas did not get the color. However, because of your explanation, I knew exactly why those areas did not receive the color.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I shall disappoint you...
That discovery was purely accidental. I found another blend mode to get the desired effect... but with a transparent background instead of a white one. Then I scrolled through the other blend modes with my scroll wheel... and the darker color worked!
Note: the best tutorial about blend modes I have bookmarked is from Ron Bidgelow. It's a bit old and does not mention the darker color mode.
Using Blend Modes in Photoshop-- Part I
Maybe some one can enlighten me about what that blend mode does...
Edit:
Found in Photoshop Blend Modes Explained - Photo Blog Stop
"Darker Color Similar to the Darken blend mode, but darkens on the composite channel, instead of separate RGB color channels."
Votes
Translate
Translate
Report
Report
Community Expert ,
A more usual way would be to select the white pixels of the image with the magic wand tool.
tool option : tolerance 0, contiguous NOT checked, antialiasing checked
Then, with the selection active (marching ants visible) menu Edit >> Fill selection >> With color (blue...)
That works even on a colour background, provided its color is not in the text.
Votes
Translate
Translate
Report
Report
