Unfortunately I had to upgrade to the horrible disaster that is Premiere Pro 12.0.
1) Is there any way to change this terrible default font inside the project that was clearly chosen by a blind man?
2) Is it possible to have an open tab being pushed forward and the ones that are not in use pushed to the back as it was? The ones right now are on the same level and they change is only due to pretty horrible highlight.
1) Are you talking about the base UI font, one that pops up for the EGP or Legacy Titler, what?
2) I've no clue what you're talking about here, tgat description doesn't sound like anything I've seen I've any version since CS6. Would need screen grabs or a better description.
Neil
1) You can change the font size by clicking on the drop down menu:
2) You can control the behavior of double clicking on a bin to opening in a new window by going to Preferences > General and changing the Bins> Double Click setting:
MtD
Above is the horrible font that I'm talking about. The font that was used in previous Premiere Pro versions was a different one while this one is extremely heavy on the eyes.
Now, onto the tabs issue:
Why there are no distinctive lines between tabs? Just the one that is open is highlighted but I need lines between them or the opened tab being "pushed" to the front while the others being "pushed" to the back. Now they are on the same level which is, to put it simply, mess.
Plus the font on the clips on timeline is horrendous, it looks like taken from some bootleg website.
