4 Replies Latest reply on Dec 13, 2017 11:42 AM by ralphmce
    First-time InDesign Plugin Developer - Some basic questions
    ralphmce
      Hello All,
      I'm an experienced plugin developer for Adobe products but am new to InDesign. I've downloaded the InDesign plugin_sdk_125.zip, extracted it and compiled the sample plugins, I've got some newbie questions :
      1. When I placed the debug builds into the Plugins folder InDesign said I needed a debug build of InDesign to run them. Seriously? Do I have to get a special build for debugging? The release build plugins ran OK, or some of them, only tested a few so far. Am I missing something really obvious as to why the debug one's failed?
      2. On the SDK download page there were links to both the 2017 SDK and 2018 SDK. Can I assume if I work to the 2017 SDK the plugins will work in 2018. I don't need to build a version of my plugin per binary do I?
      Excuse the super-newbie questions.
      R
        • 1. Re: First-time InDesign Plugin Developer - Some basic questions
          Manan Joshi Adobe Community Professional
          Hey Ralph,
          Welcome to the community of InDesign plugin development. Well your questions are justified as they seem to confuse a person when starting. So here are the answers
          • InDesign application is shipped with a special version called the debug build for developers. This build is really helpful while debugging as it gives a lot more debugging help like asserts on things coded wrong or failing stuff. This aids in the development process. You can get hold of the debug build by joining the prerelease program. With all this said, if one is decently experienced with plugin development of InDesign he can always debug his code using the release version of InDesign (the version that is released for all to use). You just need to build your plugins with debug symbols generated. However if you are stuck on an issue that seems to be beyond your comprehension, debug build of InDesign would surely aid in debugging such issue.
          • Adobe releases a new SDK version with every major release of InDesign. The plugins created with these sdk's are not compatible with each other, i.e. plugin compiled with one version of SDK say 2017 would not load on InDesign 2018. The major reason for this is that generally with each major release of InDesign version and corresponding sdk, the IDE along with the libraries are changed and hence it becomes incompatible with the older version. Also each new version of sdk also has changes in the api and/or also the way things were done, so it might be a case that the api you were using does not exist anymore or an interface has been removed altogether. Hence with each major release of InDesign we need to port our plugins using the new sdk, this can be a time consuming process in itself depending upon the complexity of your plugin, the way your project is setup and also the magnitude of changes done in the new version of sdk
          Hope this clears out your confusion
          -Manan
          • 2. Re: First-time InDesign Plugin Developer - Some basic questions
            ralphmce Level 1
            Hi Manan,
            firstly, thanks for the both swift and detailed response. Very helpful!
            There is one extra question based on your first answer.
            I don't think I'll need the debug build from what you said, but I like to have all the weapons I can to hand before I start.
            I am a member of the prerelease program so I went here Adobe Prerelease and was redirected from there to Adobe I/O Console - I see the SDK, Scripting, ITK, but no debug build. Do I need to copy the .dSYM files from the ITK download into the current 2018 build to make it debuggable? If so, where should they be going? I wrote a bash script to place each dSYM file beside its corresponding file inside the InDesign install but that didn't help - I got the same error message about needing a debug build when using the SDK samples. Any guidance you can provide is greatly appreciated!
            Thanks again,
            R
            • 3. Re: First-time InDesign Plugin Developer - Some basic questions
              If you are a member of Adobe Prerelease then join the InDesign CC Developers Prerelease program. There you would have access to the latest Debug builds right on the landing page.
              -Manan
              • 4. Re: First-time InDesign Plugin Developer - Some basic questions
                ralphmce Level 1
                Hi Manan,
                thank you very much for giving up your time, I am able to access :
                InDesign CC Prerelease
                InDesign Family SDK Download Program
                but I am awaiting authentication for :
                and that is where I will be able to get the debug build I gather.
                OK, this is making more sense now.
                Thanks again.
                R
