• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Muse - Image placed on header in Master page showing in wrong place in the child page.
New Here ,
Dec 12, 2017 Dec 12, 2017
its not on another layer
its not locked
i still can’t get rid of it (the image under the mouse)
Someone help!
Message was edited by: Ankush Rao
Views
758
Translate
Translate
Report
Report
Community guidelines
community guidelines
Hi samuel,
Looks like you have copied and pasted the logo, so along with logo their properties also copied. Select the logo in header from your master page and see on top right (Footer) check mark is there.
You simply have to uncheck it as a footer and issue will be resolved. As it was checked as footer, the image was getting placed in the bottom.
Hope This helps.
Ankush
Votes
Translate
Translate
Guest
I almost think it should be emblazed before entering this forum that simple .muse file of your problem should be uploaded for others to check out. In some cases forum members can figure out your problem without a file but it sure helps to have it. Strip away all unnecessary elements and pages except the ones needed to show your problem. If you are not sure what is needed or not leave it.
Im sure someone will help you Sooner than later.
Votes
Translate
Translate
Report
Report
LEGEND ,
Wow! A 4 MB image posted in this forum! I think, that is the record up to now!
Since the image has a red outline, while your other images have a blue outline, it is placed on a different (the outline colour indicates that). Thy this:
  1. Open the „Layers“ panel and check, if there is a locked layer (= padlock icon to the left) Click onto this padlock, to unlock the layer.
  2. It is possible as well that this image is placed on a different layer on your master page. Since you can’t access a master page element on a layout page, go to your master page and try to delete the image.
  3. It is possible as well, that 1. and 2. is true at the same time.
If this doesn’t help, delete all pages (except the one with the image), delete all elements (except the image, which you can’t delete ) and share this small .muse file with us. Please refer to these instructions: https://forums.adobe.com/docs/DOC-8652
Votes
Translate
Translate
Report
Report
New Here ,
Hi, thanks for the help.
Its near the bottom of the home page (next to the contact form)
here is is the file: Dropbox - The Tree Agency Newest.muse
Votes
Translate
Translate
Report
Report
LEGEND ,
You have read my post above? Tried it at least? Don’t think so:
  • I wrote: "It is possible as well that this image is placed on a different layer on your master page. Since you can’t access a master page element on a layout page, go to your master page and try to delete the image.“ And exactly that is issue. Go to „plan mode“, double click the master page, delete the image. Ready.
  • I wrote: "If this doesn’t help, delete all pages (except the one with the image), delete all elements (except the image, which you can’t delete)“ The file you uploaded has 2 pages and tons of elements and assets.
Thank you so much for cooperating with solving your „urgent" issue and make me waiting until your large file is downloaded!
Votes
Translate
Translate
Report
Report
New Here ,
I did actually try to do that but it isn’t there. How am I meant to show you. How about you delete it and send it back to me. Because I can’t
Votes
Translate
Translate
Report
Report
Hi samuel,
Hope This helps.
Ankush
Votes
Translate
Translate
Report
Report
LEGEND ,
Ankushr, according to the caption and content of his initial post, he wants to „remove“ (delete) or „get rid of“ the image, not to move it. And this is simply possible by deleting in on the master page.
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 13, 2017 Dec 13, 2017
As Günter Heißenbüttel​ wrote three times:
on Master: delete this. Nothing more simple.
Best Regards,
Uwe
Votes
Translate
Translate
Report
Report
I understand, at first even I thought so.
Later I had live interaction with Samuel on Twitter where he cleared that the logo was showing at worng place and he wants it to be on header.
It was placed on header in the master page, however maked as footer, which caused the logo to move down.
Ankush
Votes
Translate
Translate
Report
Report
LEGEND ,
I see
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Ok, that explains the problems …
Votes
Translate
Translate
Report
Report
