Is it possible to directly send the HLS manifest data to the Flash player? I am trying to make use of data uri feature as below.
In my media.html, I have the below code.
var dataUri = "data:,#EXTM3U\r\n"+
"#EXT-X-STREAM-INF:PROGRAM-ID=1, BANDWIDTH=1064960\r\n"+
"http://host1:80/path1/master_stream1.m3u8\r\n"+
"http://host2:80/path1/master_stream1.m3u8";
var parameters = {
src: dataUri`,
autoPlay: "true",
verbose: true,
controlBarAutoHide: "true",
controlBarPosition: "bottom",
poster: "images/poster.png",
javascriptCallbackFunction: "jsbridge",
plugin_hls: "../../bin/debug/flashlsOSMF.swf",
hls_minbufferlength: -1,
hls_maxbufferlength: 30,
hls_lowbufferlength: 3,
hls_seekmode: "KEYFRAME",
hls_startfromlevel: -1,
hls_seekfromlevel: -1,
hls_live_flushurlcache: false,
hls_info: true,
hls_debug: false,
hls_debug2: false,
hls_warn: true,
hls_error: true,
hls_fragmentloadmaxretry : -1,
hls_manifestloadmaxretry : -1,
hls_capleveltostage : false,
hls_maxlevelcappingmode : "downscale"
When I tried the above, it throws the following exception.
Error: LoaderBase unable to handle the given MediaResourceBase
at org.osmf.traits::LoaderBase/validateLoad()
at org.osmf.traits::LoaderBase/load()
at org.osmf.traits::LoadTrait/load()
at org.mangui.osmf.plugins.loader::HLSLoadFromDocumentElement/onLoadStateChange()[XXXXXXXXXX\newFlash\src\org\mangui\osmf\plugins\loader\HLSLoadFromDocumentElement.as:118]
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at org.osmf.elements.proxyClasses::LoadFromDocumentLoadTrait/loadStateChangeEnd()
at org.osmf.traits::LoadTrait/setLoadState()
at org.osmf.traits::LoadTrait/onLoadStateChange()
at org.osmf.traits::LoaderBase/updateLoadTrait()
at org.mangui.osmf.plugins.loader::HLSLoaderBase/_manifestHandler()[XXXXXXXXXX\newFlash\src\org\mangui\osmf\plugins\loader\HLSLoaderBase.as:126]
at org.mangui.hls::HLS/dispatchEvent()[XXXXXXXXXX\newFlash\src\org\mangui\hls\HLS.as:57]
at org.mangui.hls.loader::ManifestLoader/_parseLevelPlaylist()[XXXXXXXXXX\newFlash\src\org\mangui\hls\loader\ManifestLoader.as:176]
at org.mangui.hls.playlist::Manifest/onLoadedData()[XXXXXXXXXX\newFlash\src\org\mangui\hls\playlist\Manifest.as:111]
at org.mangui.hls.playlist::Manifest/_loaderHandler()[XXXXXXXXXX\newFlash\src\org\mangui\hls\playlist\Manifest.as:107]
at flash.net::URLLoader/onComplete()
I really appreciate your help in resolving the above issue?
Or are there any work around to initialize the player with my own custom HLS manifest data?
smsivanesan
