I'm having an issue updating Bridge CC 2018 during the installation the following error is being encountered.
Exit Code: 145
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 1 warnings(s)
FATAL: Error (Code = 145) executing in command 'MoveDirectoryCommand' for package: 'AdobeBridge8.0-mul', version:8.0.1.282
FATAL: Error occurred in install of package (Name: AdobeBridge8.0-mul Version: 8.0.1.282). Error code: '145'
WARN: Destination path is file or already used "/System/Library/Components/IOFWDVComponents.component/Contents/Resources/IOFWDVComponents.rsrc/Adobe Bridge CC 2018"
I have followed the uninstall and cleaner advice and even when I completely remove all the apps and the CC app control panel on reinstalling I encounter the same problem, other than wiping the OS (High Sierra 10.13.1) I cannot seem be able to complete the update.
I think I've found a workaround for this error.
To get the Bridge installation to complete, you must temporarily rename the file IOFWDVComponents.rsrc which is located in the folder /System/Library/Components/IOFWDVComponents.component/Contents/Resources. However, this file is protected by a feature in MacOS called System Integrity Protection (SIP). SIP can be temporarily disabled in Recovery Mode (I found out how to do this here: macos - "restricted" folder/files in OS X El Capitan - Stack Overflow
...Copy link to clipboard
Hi William,
Thanks for posting on Adobe forums,
Please try these steps:
- Open FInder
- Click on Go menu
- Go To Folder
- Type in the box - /Library
- Go To this path Components/IOFWDVComponents.component/Contents/Resources/IOFWDVComponent s.rsrc
- rename Adobe Bridge CC 2018 folder to Adobe Bridge CC 2018.old
Try to update the Application again.
Please do let me know if the issue gets resolved.
Regards,
Sandeep
Hi Sandeep,
When I get to the end of the path it looks like the IOFWDVComponents.rsrc-file is corrupted or locked.
Any suggestions?
Thanks in advance.
Regards,
Erik
Same issue with me. I can't browse inside the file IOFWDVComponents.rsrc.
Adobe? Please help!
I decided to do a complete OS reinstall and after this I could install the updates, thank you for your assistance.
I don't see how having to reinstall the entire OS is "helpful" as Sandeep/Adobe hasn't responded back to the original issue.
I was really pushed to have this fixed and decided to do a reinstall of the OS it might not help but it solved my immediate problem.
Hi @Sandeep,
I have the same issue as mentioned in this thread but I cannot seem to resolve it after trying all of the steps on Adobe's Help page for this particular error and reinstalling the OS
To get the Bridge installation to complete, you must temporarily rename the file IOFWDVComponents.rsrc which is located in the folder /System/Library/Components/IOFWDVComponents.component/Contents/Resources. However, this file is protected by a feature in MacOS called System Integrity Protection (SIP). SIP can be temporarily disabled in Recovery Mode (I found out how to do this here: macos - "restricted" folder/files in OS X El Capitan - Stack Overflow​).
These are the steps that I followed to complete the Bridge installation:
Part I. Temporarily disable SIP:
Part II. Temporarily rename IOFWDVComponents.rsrc
Part III. Install Bridge using the Adobe Creative Cloud application. (For me, normal installation completed without errors at this point.)
Part IV. Revert temporary changes
@stafbulp, Kudos to youdos -- it worked for me.
Unfortunately, it worked after I naively fell for the "we wrote a magical, fix-all, utility" articles.
WHAT NOT TO DO: (in 5 simple steps)
1) Uninstall all of the Adobe software from your computer
2) Download and run a special tool we accio'd into existence that will magically fix every problem that exists (or ever will exist) in our software. (remember, it does magic, so time travel is also yes)
3) Reinstall all of the software (glitches and all, minus several various random workspace customizations you spent hours getting just right)
4) While the software installs, take a long weekend and spend some quality time with your family or friends. Allot approx. 1 hour... I mean 3 hours... I mean 5 hours... I mean just a few moments... I mean 3.5 days for the software to complete its installation
5) Use your muggle eyes to observe with the I knew it wasn't going to work, deep and smoldering frustration that, alas, the problem still exists.
Thanks Adob-ama.
I encountered the same problem with Bridge CC, Animate CC and Character Animator CC all 2018.
System is High Sierra 10.13.2
I tried (most) of the suggestions with no luck. I did NOT go down the route of < csrutil disable/enable > so can't comment on whether that works or not.
What did work for me was to Uninstall the app using its own uninstaller.
Download the app from here: Download Creative Cloud apps
When I did this I noticed that the only available download was the same version of the one I just uninstalled.
Anyway, install the .dmg.
Refresh the Creative Cloud app from the menu next to your sign in logo. 'Check for app updates'
This will change the status of the app concerned from 'Install' to 'Update'
Click Update and now it installs properly.
No reboots required.
Exit Code 145: Error was corrected for me using the reinstall link that swe_derekeh provided and then following his instructions. Make sure you wait long enough for the download to happen. Refresh the cloud app and the install worked. Seems like the Retry button would work by itself but it does not. Thanks swe.
I am too.
I tried all suggestions and the only one that worked was the doabling of the SIP as described earlier in this thread by Stafbulb
I had the installer issue for Adobe Bridge and Adobe Animate CC (2018), and this work around (thank you for the very detailed instructions!!!), worked for me. It's happily installed both of these applications without issues.
I'd tried other things which resulted in my CC Desktop app turning into 'Start Trial' mode... which led to complete system wipe and reinstall... which fixed the 'Start Trial' issue, but didn't resolve the installation issues of Bridge and Animate...
Creative Cloud Desktop v 4.3.0.256
Mac OSX High Sierra 10.13.2
The question remains though:
This fixed my Bridge install problem. Thank you. Though I just had to type in Terminal by faith because I had no idea what commands I was using. But it worked!
