• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Object in the left resizing different that object in the right
Explorer ,
Dec 13, 2017 Dec 13, 2017
  In doing my page I have a part where there are to groups of objects next to each other in a responsive breakpoint, there should be resizing the same way but for some reason the group in the right goes up at the moment of making small the browser, even copying and pasting the same object but on the right part of the browser makes the same behheaivor, I don't know if it has to do with the locked pin of the group that for some reason appears on the left when it is a group even that each element is supposed to ve pinned to the right before it is on a group but this is weird.
Yo can check the page here: Artículos
this is what happens
this is how I have it in muse
Views
448
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Dec 14, 2017 Dec 14, 2017
To add some details to Ussnorway’s post:
It is a very difficult process for Muse, to decide, which elements should influence which others (push downwards/upwards for example). This requires a considerable amount of artificial intelligence.
On your 768 px breakpoint you have introduced these three little icons top right, which are aligned vertically. Muse correctly assumes, that these 3 images are the reference point, which influences the elements below. Muse tries to do it correctly and pushes dow
Votes
Translate
Translate
Hey Juan,
It will be very helpful if you can provide the same Muse page so we can have a look at.
Please refer to this link for instructions on sharing the file.
Ankush
Votes
Translate
Translate
Report
Report
Explorer ,
hi thanks... you didn't send the link.. can I only send the page that I am talking about or would it have to be the whole site ?
Votes
Translate
Translate
Report
Report
LEGEND ,
The page is enough.
Please follow these instructions: https://forums.adobe.com/docs/DOC-8652
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
LEGEND ,
the small breakpoint of your A-master is the cause of this issue... redisign it to fit within the canvas
Votes
Translate
Translate
Report
Report
Explorer ,
Hi I deleted almast all the other pages of the site and uploaded to dropobox
Dropbox - isuuetest1.muse
Is the first page at 768 width where I have the issue.
Votes
Translate
Translate
Report
Report
LEGEND ,
On your 768 px breakpoint you have introduced these three little icons top right, which are aligned vertically. Muse correctly assumes, that these 3 images are the reference point, which influences the elements below. Muse tries to do it correctly and pushes down the elements below. If you want something else, you should try to make it more clear for Muse.
The first option:
Place a rectangle above the two boxes. Take care, that it includes the images and doesn’t overlap the 2 boxes below. This will cause Muse to accept this element as a reference object for the elements below:
The second option:
Simply group the two boxes, what will cause Muse, to push them downwards/upwards together.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
https://forums.adobe.com/people/G%C3%BCnter+Hei%C3%9Fenb%C3%BCttel  wrote
The first option:
Place a rectangle above the two boxes. Take care, that it includes the images and doesn’t overlap the 2 boxes below. This will cause Muse to accept this element as a reference object for the element below:
that is an eloquent solution but he will need to not cover the 3 right top buttons... make the div a little shorter on the right side
Votes
Translate
Translate
Report
Report
