Hello All,
I'm using CF 8. I'm trying to
access EJBs from jboss4.2.0. And I'm getting this error.
Could not access a java object field called TRACE.
I have no problem with CF 8 and jboss4.2. When I did some
research on the
error, it says the issue could be log4j version and it should
be later than
1.2.10. CF 8 comes with 1.2.12 which is valid. I searched in
my machine and I
have 1.2.9 used in cfeclipse but I don't see that in my
classpath. I even
checked in CF admin and that jar file is not in CF server
class path as well as
java class path. So I'm confused. Any help?.
Error happens in the line where I'm accessing the reference
to home object
Here's my code
<!--- Create the Context object to get at the static
fields. --->
<CFOBJECT
action=create
name=ctx
type="JAVA"
class="javax.naming.Context">
<!--- Create the Properties object and call an explicit
constructor--->
<CFOBJECT
action=create
name=prop
type="JAVA"
class="java.util.Properties">
<!--- Call the init method (provided by cfobject)
to invoke the Properties object constructor. --->
<cfset prop.init()>
<!--- Specify the properties These are required for a
remote server only --->
<cfset prop.put(ctx.INITIAL_CONTEXT_FACTORY,
"org.jnp.interfaces.NamingContextFactory")>
<cfset prop.put(ctx.URL_PKG_PREFIXES,
"org.jboss.naming:org.jnp.interfaces")>
<cfset prop.put(ctx.PROVIDER_URL,
"jnp://servername:port")>
<!--- Create the InitialContext --->
<CFOBJECT
action=create
name=initContext
type="JAVA"
class="javax.naming.InitialContext">
<!--- Call the init method (provided through cfobject)
to pass the properties to the InitialContext constructor.
<cfset initContext.init(prop)>
<!--- Get reference to home object. --->
<cfset home =
initContext.lookup("TravelAgentBean/remote")>
<!--- Create new instance of entity bean.
(hard-wired account number). Alternatively,
you would use a find method to locate an existing entity
bean. --->
<cfset myMessage = home.create()>
<!--- Call a method in the entity bean. --->
<cfset customers = myMessage.getAllCustomers()>
<cfoutput>
Record Count is : #customers#<br>
</cfoutput>
<!--- Close the context. --->
<cfset initContext.close()>
Thanks in Advance,
Surendra.
