when I apply the blend effect a "progress PNG" window appears and does not finish loading
Would be good to report it (with a link to this discussion) here:
Which version, which system?
How large is the file?
To what kind of object do you apply the blend mode?
When did you last restart the computer?
adobe illustrator cc 2018, windows 10 32bits
Please describe exactly the steps you’re doing to make a blend. You mentioned a progress png. Are you trying to create a blend within a png? You can only create blends as part of lllustrator vector objects. Also, please tell us what version of Illustrator and what OS you’re using.
And you have done exactly what with these words?
after that I go to Object > Blend > Blend Options, then I enable preview and change the spacing mode to 'Specified Distance'
after I did this a loading box appeared but did not complete
dont load:(
Does that also happen when you blend just two rectangles?
yep
It seems repeatable. This is on Mac OS Sierrra 10.12.6
First time it gave the Progress Box: Saving Data Recovery Information.
Canceled and crashed Illustrator.
The second time:
Canceled and crashed.
I thought it was just me
I voted for a similar bug here:
Strange. I can't reproduce that on 10.12.6 with Illustrator CC 2018
(already running the 22.0.2 version) Critical Bug fixes for Illustrator CC 22.0.x available on prerelease
Just redownloaded the 22.0.2 version (the previous one was removed by an "update").
Blend options > Specified Distance > 4 px
Same system, same problem.
I'm beginning to get the impression that this is hardware-related.
My ancient hardware seems to be somewhat robust.
Not the latest:
MacBook Pro (Retina, 13-inch, Late 2013)
Processor 2,4 GHz Intel Core i5
Memory: 16 GB 1600 MHz DDR3
Graphics Intel Iris 1536 MB
Oh, mine is a newer one (which doesn't happen too often).
And it works fine in CC 2017
