7 Replies Latest reply on Apr 16, 2018 5:27 AM by michal-44680644
    Histogram passed and drawn into a Layer. Done!
    Pedro Cortez Marques Level 3
      Hi, I have made an exercise that can be usefull to someone.
      On a active image, it builds and draws the histograms on several layers.
      This works only on RGB images and if they have more than 8bits/channel, it will reduce to 8bit/channel before proced.
      I used this on windows 10 and CC(2017)
      Enjoy or complete and develop it as you want.
      This next code will build 4 layers
      1 -  the 3 rgb channels coloured histogram
      2 - the Max([R], [G], [B]) Luminosity RGB histogram (gets the max value of each channel)
      3 - the 8bit Lightness channel Lab histogram (the image will be reverted again to RGB afterwards)
      4 - 8bit Luminosity RGB histogram
      addHistogram(true); // this draws a layer with a coloured 8bit RGB histogram
      addHistogram(false, false, true); //  this draws the Max([R], [G], [B]) Luminosity RGB histogram (gets the max value of each channel)
      addHistogram(false, true); // this draws a layer with 8bit Lightness channel Lab histogram
      addHistogram(false, false); // this draws a layer with 8bit Luminosity RGB histogram
      ///////////////////////////////  HISTOGRAM IN LAYER   ///////////////////////////////////
      function addHistogram(RGB, Lab, MaxRGB) {
          ///////////////////////////////////////////////// createProgressWindow
          var createProgressWindow = function(title, message, hasCancelButton) {
            var win;
            if (title == null) title = "Work in progress";
            if (message == null) message = "Please wait...";
            if (hasCancelButton == null) hasCancelButton = false;
            win = new Window("palette", "" + title, undefined);
            win.bar = win.add("progressbar", {x: 20, y: 12, width: 300, height: 20 }, 0, 100);
            win.stMessage = win.add("statictext", { x: 10, y: 36, width: 320, height: 20 }, "" + message);
            win.stMessage.justify = 'center';
            if (hasCancelButton) {
              win.cancelButton = win.add('button', undefined, 'Cancel');
              win.cancelButton.onClick = function() {
                win.close();
                throw new Error('User canceled the pre-processing!');
            this.reset = function(message) {
              win.bar.value = 0;
              win.stMessage.text = message;
              return win.update();
            this.updateProgress = function(perc, message) {
              if (perc != null) win.bar.value = perc;
              if (message != null) win.stMessage.text = message;
            this.close = function() {
              return win.close();
            win.center(win.parent);
            return win.show();
          // the other layer histograms, if exist, should be invisible so the reading is only on the pixels of the image itself
          if (getLayer("RGB histogram")) activeDocument.artLayers.getByName ("RGB histogram").visible = false;
          if (getLayer("Lightness Lab histogram")) activeDocument.artLayers.getByName ("Lightness Lab histogram").visible = false;
          if (getLayer("Luminosity RGB")) activeDocument.artLayers.getByName ("Luminosity RGB").visible = false;
          if (getLayer("Luminosity Max[R][G][B]")) activeDocument.artLayers.getByName ("Luminosity Max[R][G][B]").visible = false;
          var layerName = (RGB) ? "RGB histogram" : ((Lab) ? "Lightness Lab histogram" : ((MaxRGB) ? "Luminosity Max[R][G][B]" : "Luminosity RGB"));
          if (!getLayer(layerName)) {
              // it works only on RGB images
              if (activeDocument.mode == DocumentMode.RGB) {
                  // if the image is 16bit/channel or more it sets 8bits/channel before read the histogram
                  if (!activeDocument.bitsPerChannel == BitsPerChannelType.EIGHT) activeDocument.bitsPerChannel = BitsPerChannelType.EIGHT;
                  $.writeln(layerName);
                  var wasHereLayer = activeDocument.activeLayer;
                  var unitsAntes = app.preferences.rulerUnits;
                  var foregroundPreviousColor = app.foregroundColor;
                  app.preferences.rulerUnits = Units.PIXELS; // importante
                  activeDocument.quickMaskMode = false;
                  activeDocument.selection.deselect();
                  // read histogram:
                  var hL = activeDocument.histogram;
                  var hR = activeDocument.channels["Red"].histogram;
                  var hG = activeDocument.channels["Green"].histogram;
                  var hB = activeDocument.channels["Blue"].histogram;
                  // if you want the Luminosity of Lab, export it to Lab, read it, and revert it to RGB
                  if (Lab) {
                      activeDocument.changeMode (ChangeMode.LAB);
                      // read Lightness channel histogram of Lab
                      var hL = activeDocument.channels["Lightness"].histogram;
                      // revert to RGB
                      activeDocument.changeMode (ChangeMode.RGB);
                  } else {
                      // read Luminosity composite channel histogram of RGB
                  var ww = activeDocument.width.as('px');
                  var hh = activeDocument.height.as('px');
                  var totalPixels = ww*hh;
                  var totalPixels1Col = totalPixels/256;
                  var pBar = new createProgressWindow("Histogram building...", "Please wait", false);
                  activeDocument.artLayers.add();
                  activeDocument.activeLayer.name = layerName;
                  activeDocument.activeLayer.move( activeDocument, ElementPlacement.PLACEATBEGINNING );
                  activeDocument.activeLayer.blendMode = BlendMode.NORMAL; // blending mode "normal"
                  activeDocument.activeLayer.opacity = 60; // opacity 60%
                  var hhGraph = 60;
                  var hY = 400; // base y of graph
                  var hX = 100; // base x of graph
                  // base transparent
                  app.foregroundColor.rgb.red = 0;
                  app.foregroundColor.rgb.green = 0;
                  app.foregroundColor.rgb.blue = 0;
                  drawSelectionScreen (hX-2, hY+2, 258+hX, hY-322);
                  // fill (filltype [, mode] [, opacity] [, preserveTransparency])  // filltype: SolidColor  |  mode: ColorBlendMode  |  opacity: [1..100]
                  app.activeDocument.selection.fill(app.foregroundColor, ColorBlendMode.SCREEN, 40, false);
                  var myHist = [];
                  if (RGB) {
                      for (var a in activeDocument.componentChannels) {
                          //  criar as 3 cores R, G e B e o graph da cada uma
                          (a==0) ? app.foregroundColor.rgb.red = 255 : app.foregroundColor.rgb.red = 0;
                          (a==1) ? app.foregroundColor.rgb.green = 255 : app.foregroundColor.rgb.green = 0;
                          (a==2) ? app.foregroundColor.rgb.blue = 255 : app.foregroundColor.rgb.blue = 0;
                          if (a==0) myHist = hR;
                          if (a==1) myHist = hG;
                          if (a==2) myHist = hB;
                          for ( i = 0; i <= 255; i++ ) {
                              var col = i+hX;
                              var YYY = Math.min(Math.floor(myHist[i]*hhGraph/totalPixels1Col), 320);
                              drawSelectionScreen (col, hY, col+1, hY-YYY);
                              var percent = Math.floor(((i+1)+(a*256))*100/768);
                              pBar.updateProgress (percent, activeDocument.componentChannels[a].name.toUpperCase() + " Channel " + percent+ " % completed");
                          app.activeDocument.selection.fill(app.foregroundColor, ColorBlendMode.SCREEN, 100, false);
                  } else {
                      app.foregroundColor.rgb.red = 255;
                      app.foregroundColor.rgb.green = 255;
                      app.foregroundColor.rgb.blue = 255;
                      myHist = hL;
                          var col = i+hX;
                          if (MaxRGB) {
                              var YYY = Math.min(Math.floor(Math.max(hR[i], hG[i], hB[i])*hhGraph/totalPixels1Col), 320);
                          } else {
                          var percent = Math.floor((i+1)*100/256);
                          pBar.updateProgress (percent, "Luminosity Channel " + percent+ " % completed");
                  pBar.close();
                  // activeDocument.activeLayer = wasHereLayer;
                  app.preferences.rulerUnits = unitsAntes;
                  app.foregroundColor = foregroundPreviousColor;
                  $.gc();
              } else {
                  alert("Must be an RGB image");
          } else {
              alert("Already has created this '" + layerName + "' layer!");
              return;
          function drawSelectionScreen(x1, y1, x2, y2) {
              $.level = 0;
              try {
                  // SelectionType.SELECTEDAREA | DIMINISH | EXTEND | INTERSECT | REPLACE
                  activeDocument.selection.select([[ x1, y1], [x2, y1], [x2, y2], [x1,y2]], SelectionType.EXTEND, 0, false);
              } catch(e) {}
              $.level = 1;
          function drawLineScreen(x1, y1, x2, y2, width, transparency) {
              $.level = 0;
              try {
                  var desc = new ActionDescriptor();
                  var lineDesc = new ActionDescriptor();
                  var startDesc = new ActionDescriptor();
                  startDesc.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), x1 );
                  startDesc.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), y1 );
                  lineDesc.putObject( charIDToTypeID('Strt'), charIDToTypeID('Pnt '), startDesc );
                  var endDesc = new ActionDescriptor();
                  endDesc.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), x2 );
                  endDesc.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), y2 );
                  lineDesc.putObject( charIDToTypeID('End '), charIDToTypeID('Pnt '), endDesc );
                  lineDesc.putUnitDouble( charIDToTypeID('Wdth'), charIDToTypeID('#Pxl'), width ); //
                  desc.putObject( charIDToTypeID('Shp '), charIDToTypeID('Ln  '), lineDesc );
                  desc.putEnumerated( charIDToTypeID( "Md  " ), charIDToTypeID( "BlnM" ), charIDToTypeID( "Scrn" ) ); // mode: Screen
                  desc.putUnitDouble( charIDToTypeID( "Opct" ), charIDToTypeID( "#Prc" ), transparency ); // [0-100] transparency
                  desc.putBoolean( charIDToTypeID('AntA'), false ); // important antialias should be false
                  executeAction( charIDToTypeID('Draw'), desc, DialogModes.NO );
              } catch(e) {}
              $.level = 1;
          function getLayer(layername) {
              var result = false;
              for (var a=0; a<activeDocument.artLayers.length ; a++) {
                  if (String(activeDocument.artLayers[a].name) == layername) {
                      result = true;
                      break;
              return result;
