Expand my Community achievements bar.
SOLVED
Page continues to freeze when attempting to open it in edit mode in AEM 6.3
Avatar
Level 5
Hi All,
We recently upgraded to AEM 6.3 from 6.1. In 6.3 there are some destination pages are continues to freeze when attempting to open it in edit mode and indicates a Google map search at the bottom of the browser.
I am not seeing any errors in the log, on network tab and did take out and add the components to see if it is because of any components we are having this issue still no use.
But when we create a package with these pages and installed in 6.1 they are working fine, they are not freezing.
Narayana
1 Accepted Solution
Avatar
Correct answer by
Level 9
Hi Narayan,
  One of the possibility is in case you have some component that has loop algorithm going into infinite causes it. In our case we had custom columns controlsin with column controls and was getting the node count.  6.3 was returning -1 due to index timeout caused the issue & fixed our code base.
View solution in original post
Avatar
Correct answer by
Level 9
Hi Narayan,
Avatar
Administrator
In 6.3, can you remove the component using google maps and check?
Kautuk Sahni
Avatar
Level 5
If we take out that component which is working fine but we need to have component on that page. Same page with same components are loaded and working fine in AEM 6.1 though.
Narayana
