I’ve got a script that preps art in a file for later export as an SVG. I have one step that I’d like to remove (cropTiles()) but when I do the script crashes at the very end each time. Really not sure why.
Here’s the large script (and as a more readable Gist😞
#target illustrator
// Base vars
var doc = app.activeDocument;
// Ensure the document is using the expected coordinates
with (doc) {
pageOrigin = [0, doc.height];
rulerOrigin = [0, doc.height];
* Settings
* @type {Object}
var HCo = {
// Action-wide settings
settings: {
// Mutable by user
renameBackgrounds: false,
// Immutable by user
tileCoordinates: [],
backgroundLayerName: 'background',
baseLayer: null,
baseLayerName: 'SOURCE_LAYER',
firstArtboardName: null,
baseArtboard: null,
baseArtboardName: 'SOURCE_ARTBOARD',
docRect: null,
totalTiles: null,
processSteps: 5,
tilesProcessed: 0,
// Form fields that get translated to settings
fields: {
cancelButton: null,
options: null,
progressBar: null,
progressLabel: null,
renameBackgrounds: {
no: {
text: 'I created backgrounds for each tile named “background”',
value: null
yes: {
text: 'Attempt to locate and rename existing objects as backgrounds',
value: true
startButton: null
* Failure message
* @method failure
* @param {String} head Header for the alert
* @param {String} body Body message for the alert
* @return [Boolean] `false` by default
failure: function(head, body) {
alert(' ' + head + ' \n' + body);
return false;
* Check for just one artboard and layer
* @method artboardAndLayerCheck
* @return {Boolean}
artboardAndLayerCheck: function() {
// Ensure there are no extra layers or artboards
if (doc.artboards.length > 1 || doc.layers.length > 1) {
alert('Failed initial check.\nThere should be just 1 artboard and 1 layer.');
return false;
return this;
* Check each group for a background path. If it doesn’t exist and the user has
* requested it, try to find one to repurpose.
* @method checkBackgrounds
checkBackgrounds: function() {
var layer = doc.activeLayer;
var groups = layer.groupItems;
var backgrounds = [];
var failedGroups = [];
var passedGroups = [];
var whichProcess = 'Checking for tile backgrounds…';
this.settings.totalTiles = groups.length;
// Loop through all groups in the layer
for (var i = 0; i < groups.length; i++) {
var group = groups;
var items = group.pathItems;
// Does the group contain pathItems?
if (items.length) {
// Get the last pathItem in the stack
var lastItem = items[items.length - 1];
// If the user chose to rename existing pathItems to “background”
if (HCo.settings.renameBackgrounds === true) {
lastItem.name = this.settings.backgroundLayerName;
backgrounds.push(lastItem);
passedGroups.push(group);
HCo.updateProgress(whichProcess, 1);
// If the user chose to use existing layers named “background”
} else if (HCo.settings.renameBackgrounds === false) {
// … but the last pathItem ISN’T named “background”
if (lastItem.name !== this.settings.backgroundLayerName) {
failedGroups.push(group);
} else {
else failedGroups.push(group);
// Check lengths for both background and groups collections.
// If they don’t match, fail and show a message
if (groups.length !== backgrounds.length || failedGroups.length) {
for (var i = 0; i < passedGroups.length; i++) {
passedGroups.hidden = true;
passedGroups.locked = true;
return HCo.failure('Missing background layer.', 'Every group should have a bottommost layer named “background”.\n\nI’m locking and hiding all passing groups. Please fix those remaining.');
return this;
* Format the name using the file name
* @method nameFromFilename
* @return {String} Formatted name
nameFromFilename: function(index) {
return doc.name.replace('.ai', '').replace(' ', '-').toLowerCase() + '_' + index;
* Select everything on the artboard and outline the text
* @method outlineText
* @return {null}
outlineText: function() {
// Select only artboard
doc.artboards.setActiveArtboardIndex(0);
// Select everything on the artboard
doc.selectObjectsOnActiveArtboard();
// Find all textFrames and outline the text
var textFrames = doc.textFrames;
var textFramesCount = textFrames.length - 1;
for (var t = textFramesCount; t >= 0; t--) {
var text = textFrames
; text.createOutline();
HCo.updateProgress('Outlining all text…', this.settings.totalTiles);
return this;
* Convert groups to layers
* @method convertGroupsToLayers
* @return {null}
convertGroupsToLayers: function() {
var groupsCount = this.settings.baseLayer.groupItems.length;
var whichProcess = 'Converting groups to layers…';
// Cycle through all groups in the layer, create a new
// layer, and move the group to the new layer
for (var i = groupsCount - 1; i >= 0; i--) {
var group = this.settings.baseLayer.groupItems;
var layer = doc.layers.add();
var layerName = HCo.nameFromFilename(i);
if (i === 0) this.settings.firstArtboardName = layerName;
layer.name = layerName;
group.move(layer, ElementPlacement.PLACEATEND);
layer.visible = false;
// Remove the original, now-empty layer
this.settings.baseLayer.remove();
return this;
* Get the “visible” bounds of the group
* @method getBounds
* @return {Array} Array containing the top, left, height, and width values
getBounds: function(group) {
var bounds = [];
for (var i = group.pathItems.length - 1; i >= 0; i--) {
if (group.pathItems.typename === "PathItem" && group.pathItems.clipping) {
bounds = group.pathItems.visibleBounds;
// controlBounds is for groups without a clipping ask and
// visibleBounds is for groups with a clipping mask.
return bounds.length === 0 ? group.controlBounds : bounds;
* Gets the position for all four group points and writes
* them to a textBox in the layer
* @method addPositionDataToGroup
* @return {Boolean}
addPositionDataToGroup: function(layer) {
// Must be working in a layer with only one group
var group = layer.groupItems[0];
// Get the dimensions of the active group and push to the tileCoordinates
// array for later use with generating a background layer
var currentGroupRect = HCo.getBounds(group);
this.settings.tileCoordinates.push(currentGroupRect);
// JSON-formatted string to write
var top = Math.round(currentGroupRect[1]);
var left = Math.round(currentGroupRect[0]);
var width = Math.round(currentGroupRect[2] - currentGroupRect[0]);
var height = Math.round(currentGroupRect[1] - currentGroupRect[3]);
// Create and add the caption to the layer
var pathRef = layer.pathItems.rectangle(top - 10, left + 10, width - 20, height - 20);
var caption = layer.textFrames.areaText(pathRef);
var tileData = 'name:' + layer.name + '-top:' + Math.abs(top) + '-left:' + left + '-width:' + width + '-height:' + height;
caption.name = 'data';
caption.contents = tileData;
caption.textRange.hyphenation = false;
caption.textRange.size = 15;
caption.textRange.leading = 18;
caption.textRange.characterAttributes.textFont = app.textFonts.getByName("OperatorMonoSSm-Book");
caption.move(layer, ElementPlacement.PLACEATBEGINNING);
return true;
* Find an artboard using its name
* @method setActiveArtboardBy
* @param {null}
setActiveArtboardBy: function(name) {
var ab = doc.artboards.getByName(name);
for (i = 0; i < doc.artboards.length; i++) {
if (doc.artboards === ab) {
doc.artboards.setActiveArtboardIndex(i);
break;
* Convert all layers to and artboard while retaining position
* @method layersToArtboard
* @return {null}
layersToArtboard: function() {
if (app.documents.length === 0) { return; }
var layerCount = doc.layers.length;
var whichProcess = 'Converting layers to artboards and adding position data…';
for (var i = 0; i < layerCount; i++) {
var layer = doc.layers;
var layerIsBackground = layer.name === this.settings.backgroundLayerName;
// Show the layer if necessary
layer.visible = true;
// Select everything in the layer
layer.hasSelectedArtwork = true;
if (doc.visibleBounds[2] === 0) {
// ignore empty layers ** Tricks by David Deraedt
continue;
// Add the textBox with position data
if (!layerIsBackground) HCo.addPositionDataToGroup(layer);
// Create and resize the artboard
var newArtboard = doc.artboards.add([0, 0, 100, -100]);
var indexAB = doc.artboards.getActiveArtboardIndex();
newArtboard.name = layerIsBackground ? this.settings.backgroundLayerName : HCo.nameFromFilename(i);
doc.fitArtboardToSelectedArt(indexAB);
layer.hasSelectedArtwork = false;
// Run some cleanup once the loop has completed
if (i === layerCount - 1) {
$.sleep(100);
// Remove the original now-empty artboard
this.settings.baseArtboard.remove();
HCo.setActiveArtboardBy(this.settings.firstArtboardName);
var firstAB = doc.artboards.getActiveArtboardIndex();
doc.layers[0].hasSelectedArtwork = true;
doc.fitArtboardToSelectedArt(firstAB);
return this;
return false;
* Creates a new artboard matching the size of the original and fills it with
* boxes that match the size and position of the original tiles.
* @method makeBackground
makeBackground: function() {
// Current artboard’s dimensions
var ax1 = this.settings.docRect[0];
var ay1 = this.settings.docRect[1];
var ax2 = this.settings.docRect[2];
var ay2 = this.settings.docRect[3];
// Settings for artboard positioning
var artboardGutter = 48;
var positionDifference = (ax2 - ax1) + artboardGutter;
// New artboard’s positioning
var bx1 = ax1 - positionDifference;
var by1 = ay1;
var bx2 = ax2 - positionDifference;
var by2 = ay2;
var coordinates = [ bx1 , by1 , bx2 , by2 ];
// Add new artboard using coordinates from above
var bgArtboard = doc.artboards.add(coordinates);
bgArtboard.name = this.settings.backgroundLayerName;
// And a new layer to place the tiles on…
var bgLayer = doc.layers.add();
bgLayer.name = this.settings.backgroundLayerName;
bgLayer.move(doc, ElementPlacement.PLACEATEND);
// Loop through `tileCoordinates` and add tiles for each coordinate
var tiles = this.settings.tileCoordinates;
var totalTiles = tiles.length;
for (var i = 0; i < totalTiles; i++) {
// Shrinking the tile background by one pixel on all sides in order to
// ensure that there is no background peeking out
var top = Math.round(tiles[1] - 1);
var left = Math.round(tiles[0] - positionDifference + 1);
var width = Math.round(tiles[2] - tiles[0] - 2);
var height = Math.round(tiles[1] - tiles[3] - 2);
// Add the tile using the above coordinates
var tile = bgLayer.pathItems.rectangle(top, left, width, height);
var tileColor = new RGBColor;
tile.fillColor = tileColor;
return this;
* Get all children of any type
* @method getChildAll
* @param {Node} obj The parent node to start with
* @return [Array]
getChildAll: function(obj) {
var childsArr = new Array();
if (obj.pageItems && obj.pageItems.length) {
for (var i = 0; i < obj.pageItems.length; i++) childsArr.push(obj.pageItems);
return childsArr;
return null;
* Upgroup everything below the focused node
* @method ungroup
* @param {Node} obj The node to start with
ungroup: function(obj) {
var elements = HCo.getChildAll(obj);
if (elements.length < 1) {
obj.remove();
return;
} else {
for (var i = 0; i < elements.length; i++) {
try {
if (elements.parent.typename != "Layer") elements.moveBefore(obj);
if (elements.typename == "GroupItem") HCo.ungroup(elements);
} catch(e) {}
* Toggle on or off all layers’ visibility
* @method toggleAllLayerVisibility
* @param {Boolean} isVisible
toggleAllLayerVisibility: function(isVisible) {
var layers = doc.layers;
var layerCount = layers.length;
for (var i = 0; i < layerCount; i++) layers.visible = isVisible;
* Find the closes parent `Layer`
* @method getParentLayer
* @param {Node} node The node to start with
* @return [Node]
getParentLayer: function(node) {
var escapeHatch = 10;
while (node.parent && escapeHatch > 0) {
node = node.parent;
if (node.typename === 'Layer')
return node;
return null;
* Crop all tiles with clipping masks
* @method cropTiles
cropTiles: function() {
var whichProcess = 'Cropping the tiles…';
// Load the action file relative to the location of this script
var thisFile = new File($.fileName);
var basePath = thisFile.path;
app.loadAction(new File(basePath + '/actions/H&Co.aia'));
HCo.toggleAllLayerVisibility(true);
doc.selection = null;
app.executeMenuCommand("Clipping Masks menu item");
var clippingPath;
var escapeHatch = 100;
while (doc.selection.length != 0 && escapeHatch > 0) {
escapeHatch--;
// Reference the clipping mask
clippingPath = doc.selection[0];
if (!clippingPath.clipping === true) continue;
clippingPath.name = 'clipping';
// Release the clipping mask
clippingPath.clipping = false;
// Parent layer
var layer = HCo.getParentLayer(clippingPath);
layer.selected = true;
// Ungroup all groups and subgroups
HCo.ungroup(layer);
// Create group to move all art to and place it in order above the background
var artGroup = layer.groupItems.add();
artGroup.name = 'art';
artGroup.moveAfter(clippingPath);
// Loop through all layer contents and move art into the artGroup
var items = HCo.getChildAll(layer);
var itemsLength = items.length;
for (var i = 0; i < itemsLength; i++) {
try {
var item = items;
if (item.name !== this.settings.backgroundLayerName && item.name !== 'clipping' && item.name !== 'data') {
item.move(artGroup, ElementPlacement.PLACEATBEGINNING);
} catch(e) {}
// Select the artGroup and clippingGroup
artGroup.selected = true;
clippingPath.selected = true;
app.doScript('Crop gallery tile', 'H&Co');
// Rename cropped group
doc.selection[0].name = 'art';
// Ensure everything is deselected for the next command
HCo.ungroup(layer);
// Now just make sure we prepped all clipping masks
if (doc.selection.length === 0) {
app.unloadAction('H&Co','');
return this;
return false;
updateProgress: function(whichProcess, tilesProcessed) {
this.settings.fields.progressLabel.text = whichProcess;
this.settings.tilesProcessed = this.settings.tilesProcessed + tilesProcessed;
this.settings.fields.progressBar.value = this.settings.tilesProcessed / (this.settings.totalTiles * this.settings.processSteps) * 100;
this.dialog.update();
setup: function() {
this.settings.baseLayer = doc.layers[0];
this.settings.firstArtboardName = null;
this.settings.baseArtboard = doc.artboards[0];
this.settings.docRect = this.settings.baseArtboard.artboardRect;
// Set the current artboard and layer name so we can identify later
this.settings.baseArtboard.name = this.settings.baseArtboardName;
this.settings.baseLayer.name = this.settings.baseLayerName;
return this;
* Save the options set by the user in `settingsWindow`
* @method saveSettings
saveSettings: function() {
this.settings.renameBackgrounds = !this.settings.fields.renameBackgrounds.no.value;
* Settings window presetned for user input
* @method settingsWindow
settingsWindow: function() {
this.dialog = new Window('dialog', 'H&Co Gallery Prep');
var rowHeight = 30;
var labelWidth = 85;
var fieldWidth = 300;
var progressBarWidth = 400;
// Rename backgrounds
this.settings.fields.options = this.dialog.add('group', undefined, '');
this.settings.fields.options.margins = [12, 12, 12, 12];
this.settings.fields.options.orientation = 'column';
this.settings.fields.options.alignChildren = ['left', 'top'];
// Tile backgrounds label
var backgroundLabel = this.settings.fields.options.add('statictext', undefined, 'Tile backgrounds:');
backgroundLabel.size = [progressBarWidth, rowHeight];
// Tile backgrounds radio group
var radios = this.settings.fields.options.add('group', undefined, '');
radios.alignChildren = 'left';
radios.orientation = 'column';
// Tile backgrounds options
this.settings.fields.renameBackgrounds.yes = radios.add('radiobutton', undefined, this.settings.fields.renameBackgrounds.yes.text);
this.settings.fields.renameBackgrounds.yes.value = true;
this.settings.fields.renameBackgrounds.no = radios.add('radiobutton', undefined, this.settings.fields.renameBackgrounds.no.text);
// PROGRESS BAR
this.settings.fields.progressView = this.dialog.add('group', undefined, '');
this.settings.fields.progressView.orientation = 'column';
this.settings.fields.progressView.alignChildren = 'left';
this.settings.fields.progressView.maximumSize.height = 0;
// Text
this.settings.fields.progressLabel = this.settings.fields.progressView.add('statictext', undefined, '');
this.settings.fields.progressLabel.size = [progressBarWidth, rowHeight];
// Progress bar
this.settings.fields.progressBar = this.settings.fields.progressView.add('progressbar', undefined, 0, 100);
this.settings.fields.progressBar.size = [progressBarWidth, 12];
// BUTTONS
var buttons = HCo.dialog.add('group', undefined, '');
buttons.orientation = 'row';
// Cancel button
this.settings.fields.cancelButton = buttons.add('button', undefined, 'Cancel', { name: 'cancel' });
this.settings.fields.cancelButton.onClick = function() { HCo.dialog.close(); };
// Start button
this.settings.fields.startButton = buttons.add('button', undefined, 'Start', { name: 'ok' });
this.settings.fields.startButton.active = true;
this.settings.fields.startButton.onClick = function() {
HCo.saveSettings();
try {
HCo.run();
} catch(e) {
alert(e);
HCo.dialog.show();
* Get the file preparation process running…
* @method run
run: function () {
this.settings.fields.options.maximumSize.height = 0;
this.settings.fields.progressView.maximumSize.height = 100;
this.settings.fields.startButton.enabled = false;
this.dialog.layout.layout(true);
HCo
.artboardAndLayerCheck()
.checkBackgrounds()
.setup()
.outlineText()
.convertGroupsToLayers()
.layersToArtboard()
.cropTiles()
.makeBackground();
HCo.dialog.close();
init: function() {
this.settingsWindow();
HCo.init();
If I only remove the app.doScript('Crop gallery tile', 'H&Co'); line it crashes.
The only thing I can think of right now is that the result of the action, such as an artwork structure expected by the lines further down the script, is not being formed when the doScript line is removed, causing a crash. But, still, I'd only expect an error and not a complete crash..
