• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Clipping Mask not working, help
New Here ,
Dec 14, 2017 Dec 14, 2017
Hi, so this is my first time posting here.
I have an illustration completed, with lots of over spilling objects (those tiny white dots that you can see) that are extending past my artboard.
Those white dots are not individually placed but are paths.
Im trying to make a clipping mask in order to clear off the extra bits to have a cleaner file to place into indesign.
I have made the rectangle to be the size of my art board. i then group everything that i want to be effected by the mask. I am then selecting both the rectangle and all grouped objects. the create clipping mask button is highlighted and im able to click on it but nothing happens. Im also trying the long way by going to object>clipping mask> create.
Im not sure why its not working? i have 4 other illustrations and i have gotten this same method to work for all of those.
Any help is appreciated! also i am a beginner 🙂
Views
14.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
be sure that your rectangle is above your dots. Make sure that your objects are not locked by clicking Ctrl+Alt+2
Select the white points that you grouped and your rectangle that above of it then press Ctrl+& (Clipping Mask).
and I'm here to help you.
Votes
Translate
Translate
Report
Report
New Here ,
i did everything you mentioned and its still not working.
Should the rectangle be in its own layer above my dots?
Votes
Translate
Translate
Report
Report
Community Expert ,
you should have all of them in the same layer to  just be easy.
Votes
Translate
Translate
Report
Report
New Here ,
yeah everything is in the same layer, its very odd because every time im create the clipping mask nothing is happening
Votes
Translate
Translate
Report
Report
New Here ,
ok i got it to do something?
When i select both the rectangle and my objects then press Ctrl+& it makes a clipping 'group' but removes all of my work. It seems to be still there but its only visible as paths
Votes
Translate
Translate
Report
Report
Community Expert ,
Good you should select the both rectangle & artwork. don't worry your artwork is grouped in the clipping mask group.
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you take a print screen before making the clipping mask and how did you make the white points ?!
Votes
Translate
Translate
Report
Report
Community Expert ,
1. first make sure that the object you want to clip in is on the top.
2. make sure that you select the group and the rectangle above in selection tool.
3. last thing if you want to create the clipping mask at the same size of the artboard?
if you want to insert it on InDesign you don't need to create this clipping mask because when you place it on InDesign and show import options you can choose the crop to options.
Votes
Translate
Translate
Report
Report
New Here ,
but what if im trying to clip multiple objects? im trying to delete everything outside the board
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 15, 2017 Dec 15, 2017
To delete everything out side the board
You can check by View>Outline, you'll see everything on the pasteboard.
delete un wanted objects. you can use Group selection tool to select and delete objects within group without ungroup.
Votes
Translate
Translate
Report
Report
Community Expert ,
You just want to do this for placing the file into InDesign?
InDesign doesn't care for anything that's outside the artboard, so there's no need for a clipping mask.
Votes
Translate
Translate
Report
Report
New Here ,
My professor wants our files to be ‘clean’ so thats why im doing this.
and i cant just select all the obects outside of it because they are all connected by paths, so if i delet one it will delete all the white dots that i want to stay visible
Votes
Translate
Translate
Report
Report
Community Expert ,
Doesn't make a lot of sense, but OK ...
Draw a rectangle in the layer that has all the object. The rectangle needs to be the size of the artboard and at the top of everything.
Then click on the layer in the layers panel, so that it's highlighted.
Then click on the button "Make clipping mask" in the bottom of the layers panel.
This will generate a layer based clipping mask. Advantage: you can still work with objects as usual. You won't create a clipping group.
Votes
Translate
Translate
Report
Report
New Here ,
did this and it did not work 😕
Votes
Translate
Translate
Report
Report
New Here ,
So i expanded the paths and have my rectangle at the top above everything i want to be effected by the mask.
im clicking the create mask button at the bottom of the layers panel multiple times and nothing is happening im also trying the long way through the menu panels
Votes
Translate
Translate
Report
Report
New Here ,
Ok so i solved it on my own i just played around with placing the layers in different orders and somehow got it to clip everything!
Thanks for all your help i will be back if i have more questions 🙂
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 16, 2017 Dec 16, 2017
LATEST
Please mark this thread solved.
You need to select one of the answers as correct.
Votes
Translate
Translate
Report
Report
Community Expert ,
Please show a screenshot of the layers panel.
Please describe exactly what did not work.
Step one (this is the layers panel):
Then highlight layer and click button (slightly highlighted in this image)
Result
Votes
Translate
Translate
Report
Report
Community Expert ,
Expand the path
Edite> expand or expand appearance.
Votes
Translate
Translate
Report
Report
Community Expert ,
https://forums.adobe.com/people/manal+shanableh  schrieb
Expand the path
In order to deliver a "clean" file?
Then maybe "clean" should be redefined.
Votes
Translate
Translate
Report
Report
Community Expert ,
sorry I mean Object> expand
not edit
expand the path with dots. to delete unwanted dots.
Votes
Translate
Translate
Report
Report
Community Expert ,
not edit
Not a good idea, because you can't edit it afterwards.
What sense is there in a so-called "clean" file, if you're unable to do some last minute edits?
Votes
Translate
Translate
Report
Report
Community Expert ,
it is an optional choice dear.
but, every time i do expand for an object i do have a copy by hidden layer. the same as text outlined, always we have a copy not created outline!
Votes
Translate
Translate
Report
Report
Community Expert ,
Funny...some would consider a clipping mask to be "dirt" by nature.
A "cleaner" approach, by some ways of thinking, would be to Place in InDesign, then use its frame to crop out the unwanted stuff.
Votes
Translate
Translate
Report
Report
