Hi, I downloaded photoshop yesterday so I am a total newbie. So wanted to use photoshop basically only for drawing. My problem is that when I draw a line is in 'low quality' and by low quality I mean it's really pixelated when I zoom in (only a little). When I watch all of the tutorials on yt for how to draw on photoshop there is no such problem.
idk what to do pls help
It sounds like you are working on a Low resolution 72 Pixels/Inch file, so when you zoom in even once the images become pixelated.
Try the following
Create a New File: File> New
Set the Document type to Art and Illustration and then this will by default set the resolution to 300ppi.
Now once you begin drawing the quality will be much sharper.
Here is a link to help you understand pixel resolution:Photoshop image size and resolution
I hope this helps!
A couple of comments:
If you zoom in more than 100% you will always see pixels. That is how Photoshop works at 200% for example, it uses 2x2 = 4 screen pixels for every image pixel. So if you need a larger image, rather than zooming above 100%, start with a larger image (in pixel dimensions)
Although you are drawing - use one of the brushes , rather than the pencil tool. These have a softer edge and simulate a real pencil much better than the very hard pixels of the pencil tool.
I hope that helps you.
Dave
Yep. Sounds like you are using the Pencil, and not the Brush tool. I almost _never_ use the pencil. A fully hard brush makes a much nicer stroke.
Black is brush, red is pencil
Try the following
I hope this helps!
In Photoshop, the ppi setting is irrelevant to the file. It's not a file property, only metadata to set a print size.
You just need to make sure you have enough pixels for a decently resolved file. It can be 1 ppi for all Photoshop cares, it can still be a high resolution file. But if it's going to print, you use the ppi equation to decide how many pixels you need. Pixels per inch of print!
But again, to Photoshop it's all just pixels.
Hi D Fosse,
I was referring to the resolution and the fact that macmacierz said when they zoomed into the brush it became pixelated.
This is why I made the suggestion of using a high resolution file.
I am very aware that Photoshop is a pixel based program, as I am equally aware that Illustrator is a vector based program.
