i'm using the standalone version of adobe flash player 28
i'm on windows 10
i'd like for the player to scale the swf to exactfit
this image is from another flash player
Here's the flash projector 28 version
as you can see in the pic, you can see outside the border of the flash movie
unlike the above flash player in which you can use exactfit to fix this issue
the flash projector 28 only has the show all scaling option
so how can i access the exactfit scaling settings on the flash player?
What version of Flash Player is being used in the first screenshot?
it's not an adobe flash player
it's a different software
now you're saying
Are you comparing the output from 2 completely different products, expecting the same result?
What is the 'other flash player' software you are using?
I recommend filing a bug at https://tracker.adobe.com for the behaviour you are observing.. And please post the exact software you are using. There's only one Flash Player, saying you're using "another flash player" implies a different version. You'll also need to provide test content that displays the behaviour in your bug report.
sorry my bad, i've mistakenly called different swf player as flash player too
it's a different software called baka.loader
so, is there any way to scale it to exactfit?
or at least hide the items that's outside the border
