9 Replies Latest reply on Dec 18, 2017 12:00 PM by stepheng54012748
    Writing a validation script to javascript......
      I wrote a Javascript in Acrobat for a form that I'm working on.  The result could be either a positive number or a negative number that populates as my answer. I30 is supposed to yield the difference between I28 less I29.  If I28 populates a number $1,000 and nothing shows in I29 then the result in I30 would be $1,000.  This is correct.  If nothing shows in I28 and $1,000 populates in I29 then I30 is supposed to show as (1,000) because I28 less I29 would equal (1,000).  This result is not showing up.  I cannot figure out why.  I'm wondering if my validation script is the issue.  I've included this below the script.  Any suggestions?  Thank you so much for any input.  (Note:  I am learning and trying to figure out how to write this code)
      var theField = this.getField("l28");
      var theValue = theField.value;
      var theField2 = this.getField("l29");
      var theValue2 = theField2.value;
      if (+theValue - +theValue2 > -10000000000.01) {
          this.getField("l30").value = (+theValue - +theValue2);
      else {
           this.getField("l30").value = "";
      Custom validation script as follows:
      if (event.value < .00001) event.value = "";
