8 Replies Latest reply on Dec 10, 2018 7:19 AM by PDF EDITING
    Acrobat freezes up when I try to sign a document
    robertc10270214 Level 1
      Everytime I try to use my Acrobat Pro and sign a document it freezes up. How can I fix this?
        • 1. Re: Acrobat freezes up when I try to sign a document
          AnandSri Adobe Employee (Admin)
          Hello Robertc,
          As per the description above, the Acrobat Pro is freezing while you are trying to sign a PDf document, Is that correct?
          The record shows that you are subscribed to a license of Acrobat Pro version 10 on your current Adobe ID, please check for any pending updates of Acrobat Pro 10 from Help menu>Check for updates. You may also repair the installation files of Acrobat Pro from Help menu>Repair installation(only for Windows).
          After the update and repair, please reboot the machine once, and see if this brings any difference. If the issue persists, please share the following details:
          Let us know how it goes.
          Note: Acrobat 10 is declared as an End of Support product, for more information, you may refer to End of support for Acrobat X and Reader X
          Regards,
          Anand Sri.
          • 2. Re: Acrobat freezes up when I try to sign a document
            jlm439488488
            I also cannot sign my documents. I am using Acrobat DC and overtime I click the form to sign, it freezes and I have to force quite Acrobat to make restart.
            I never had this problem until about a year ago.
            • 3. Re: Acrobat freezes up when I try to sign a document
              Hello jlm439488488
              We apologize for the inconvenience caused, please try the suggestions mentioned above, and let us know your findings.
              Regards,
              Anand Sri.
              • 4. Re: Acrobat freezes up when I try to sign a document
                jlm439488488 Level 1
                Anand,
                Of course I had already tried the above before even sending in the request. Why would I not have tried what was written before stating I have the same problem? The above does not provide any solution to my issue.
                Jason
                • 5. Re: Acrobat freezes up when I try to sign a document
                  Hello Jason,
                  Sorry for the inconvenience caused, please share the following details:
                  Please share your  findings.
                  Regards,
                  Anand Sri.
                  • 6. Re: Acrobat freezes up when I try to sign a document
                    • It is a Mac
                    • Adobe Acrobat Pro DC 2018.009.20050
                    • It is with all forms that I try to sign (it freezes and does not release though it does not indicate that it is not responding when I look in Force Quit on Mac)
                    • It is my laptop that I use for teaching
                    • 7. Re: Acrobat freezes up when I try to sign a document
                      Hello Jlm,
                      Sorry for the delayed response and inconvenience caused. Please install the latest update of Acrobat from help>check for updates, reboot the machine after installing the latest update/patch and see if this brings any difference.
                      You can also download the latest update/patch manually from DC Release Notes — Release Notes for Acrobat DC Products
                      Are you using Fill&Sign feature to sign a PDF or are you using Digital ID(Certificate based signature)? Please share a screenshot of the error you are getting, to share the screenshot, please refer to https://forums.adobe.com/docs/DOC-7043#jive_content_id_How_do_I_attach_a_screenshot
                      Let us know how it goes and share your findings.
                      Regards,
                      Anand Sri.
                      • 8. Re: Acrobat freezes up when I try to sign a document
                        PDF EDITING
                        Hi Adobe. I am using the Adobe Acrobat Pro DC, which auto-updates. I have been trying for two days to send a document for signature and everytime Acrobat freezes. I have tried 10 times with same frustrating results. I have confirmed that I am running the most current software. Please fix and credit my account until you do so.
                        Here is the latest report (partial) that was generated:
                        Date/Time:       2018-12-10 10:17:50 -0500
                        End time:        2018-12-10 10:17:51 -0500
                        OS Version:      Mac OS X 10.14.1 (Build 18B75)
                        Architecture:    x86_64
                        Report Version:  27
                        Data Source:     Stackshots
                        Shared Cache:    0x10909000 72E12A5A-B25A-3233-8F71-724BCCA6DD9F
                        Shared Cache:    0 A8B71603-B692-33E6-ACAE-415A1D552F41
                        Command:         AdobeAcrobat
                        Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                        Identifier:      com.adobe.Acrobat.Pro
                        Version:         19.008.20080 (19.008.20080)
                        PID:             6749
                        Event:           hang
                        Duration:        1.09s
                        Steps:           11 (100ms sampling interval)
                        Hardware model:  MacBookPro9,2
                        Active cpus:     4
                        Time Awake Since Boot: 270000s
                        Time Since Wake: 7500s
                        Fan speed:       4665 rpm
                        Timeline format: stacks are sorted chronologically
                        Use -i and -heavy to re-report with count sorting
                        Heaviest stack for the main thread of the target process:
                          11  start + 1 (libdyld.dylib + 94349) [0x7fff6801b08d]
                          11  main + 86 (AdobeAcrobat + 3903) [0x101c4cf3f]
                          11  RunAcrobat + 243 (Acrobat + 28602) [0x101c5efba]
                          11  ??? (Acrobat + 34472) [0x101c606a8]
                          11  -[NSApplication run] + 699 (AppKit + 81081) [0x7fff382e5cb9]
                          11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1362 (AppKit + 105558) [0x7fff382ebc56]
                          11  _DPSNextEvent + 997 (AppKit + 110263) [0x7fff382eceb7]
                          11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 42472) [0x7fff3a0305e8]
                          11  ReceiveNextEventCommon + 618 (HIToolbox + 43115) [0x7fff3a03086b]
                          11  RunCurrentEventLoopInMode + 293 (HIToolbox + 43829) [0x7fff3a030b35]
                          11  CFRunLoopRunSpecific + 467 (CoreFoundation + 240614) [0x7fff3ada4be6]
                          11  __CFRunLoopRun + 2187 (CoreFoundation + 243396) [0x7fff3ada56c4]
                          11  __CFRunLoopDoTimers + 333 (CoreFoundation + 368925) [0x7fff3adc411d]
                          11  __CFRunLoopDoTimer + 871 (CoreFoundation + 370152) [0x7fff3adc45e8]
                          11  __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 371253) [0x7fff3adc4a35]
                          11  __NSFireDelayedPerform + 433 (Foundation + 417813) [0x7fff3d173015]
                          11  ??? (Acrobat + 1365963) [0x101da57cb]
                          11  ??? (Acrobat + 21368860) [0x1030b901c]
                          11  ??? (Acrobat + 21367730) [0x1030b8bb2]
                          11  ??? (SendMail + 10269) [0x1246ac81d]
                          11  ??? (SendMail + 1662174) [0x12483fcde]
                          11  ??? (SendMail + 1665757) [0x124840add]
                          9   ??? (SendMail + 1665652) [0x124840a74]
                          9   FSGetCatalogInfoBulk + 69 (CarbonCore + 148475) [0x7fff3c0e93fb]
                          9   PBGetCatalogInfoBulkSync + 853 (CarbonCore + 149391) [0x7fff3c0e978f]
                          8   FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 1944 (CarbonCore + 151742) [0x7fff3c0ea0be]
                          6   FSMount::getIndexedDirectoryItem(unsigned int, unsigned int, unsigned int, char*, unsigned char*) + 1778 (CarbonCore + 253920) [0x7fff3c102fe0]
                          6   FileIDTreeAddEnumerationCacheEntry + 92 (CarbonCore + 254436) [0x7fff3c1031e4]
                          6   FileIDTreeAddEnumerationCacheEntryBridge + 78 (CarbonCore + 254551) [0x7fff3c103257]
                          6   FileIDTree_AddEnumerationCacheEntry_rpc + 172 (CarbonCore + 254748) [0x7fff3c10331c]
                          6   mach_msg_trap + 10 (libsystem_kernel.dylib + 3114) [0x7fff68153c2a]
                        *6   ipc_mqueue_receive_continue + 0 (kernel + 1642960) [0xffffff80003911d0]
                        Process:         AdobeAcrobat (Acrobat Pro DC) [6749]
                        UUID:            B0E5A575-1F00-3838-8534-139840444702
                        Footprint:       226.51 MB
                        Start time:      2018-12-10 10:17:50 -0500
                        Num samples:     11 (1-11)
                        CPU Time:        0.707s (1992.6M cycles, 1174.4M instructions, 1.70c/i)
                        Note:            2 idle work queue threads omitted
                          Thread 0x2cb9c2           DispatchQueue 1           11 samples (1-11)         priority 46 (base 46)     cpu time 0.706s (1989.5M cycles, 1173.7M instructions, 1.70c/i)
                          <thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [142], IO tier 0>
                          11  start + 1 (libdyld.dylib + 94349) [0x7fff6801b08d] 1-11
                            11  main + 86 (AdobeAcrobat + 3903) [0x101c4cf3f] 1-11
                              11  RunAcrobat + 243 (Acrobat + 28602) [0x101c5efba] 1-11
                                11  ??? (Acrobat + 34472) [0x101c606a8] 1-11
                                  11  -[NSApplication run] + 699 (AppKit + 81081) [0x7fff382e5cb9] 1-11
                                    11  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1362 (AppKit + 105558) [0x7fff382ebc56] 1-11
                                      11  _DPSNextEvent + 997 (AppKit + 110263) [0x7fff382eceb7] 1-11
                                        11  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 42472) [0x7fff3a0305e8] 1-11
                                          11  ReceiveNextEventCommon + 618 (HIToolbox + 43115) [0x7fff3a03086b] 1-11
                                            11  RunCurrentEventLoopInMode + 293 (HIToolbox + 43829) [0x7fff3a030b35] 1-11
                                              11  CFRunLoopRunSpecific + 467 (CoreFoundation + 240614) [0x7fff3ada4be6] 1-11
                                                11  __CFRunLoopRun + 2187 (CoreFoundation + 243396) [0x7fff3ada56c4] 1-11
                                                  11  __CFRunLoopDoTimers + 333 (CoreFoundation + 368925) [0x7fff3adc411d] 1-11
                                                    11  __CFRunLoopDoTimer + 871 (CoreFoundation + 370152) [0x7fff3adc45e8] 1-11
                                                      11  __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation + 371253) [0x7fff3adc4a35] 1-11
                                                        11  __NSFireDelayedPerform + 433 (Foundation + 417813) [0x7fff3d173015] 1-11
                                                          11  ??? (Acrobat + 1365963) [0x101da57cb] 1-11
                                                            11  ??? (Acrobat + 21368860) [0x1030b901c] 1-11
                                                              11  ??? (Acrobat + 21367730) [0x1030b8bb2] 1-11
        11  ??? (SendMail + 10269) [0x1246ac81d] 1-11
        11  ??? (SendMail + 1662174) [0x12483fcde] 1-11
        11  ??? (SendMail + 1665757) [0x124840add] 1-11
        1   ??? (SendMail + 1665821) [0x124840b1d] 1
        1   FSDeleteObject + 27 (CarbonCore + 256222) [0x7fff3c1038de] 1
        1   PBRemoveObjectInternal(FSRefParam*, unsigned char) + 156 (CarbonCore + 256435) [0x7fff3c1039b3] 1
        1   GetFSRefAttributes(FSMount*, FSRef const*, unsigned int, FSAttributeInfo*, unsigned int, char*) + 123 (CarbonCore + 38850) [0x7fff3c0ce7c2] 1
        1   FSMount::getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 224 (CarbonCore + 25658) [0x7fff3c0cb43a] 1
        1   FSMount::_getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 350 (CarbonCore + 26080) [0x7fff3c0cb5e0] 1
        1   FSMount::getattrscore(bool, char const*, unsigned int, char const*, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 1560 (CarbonCore + 29448) [0x7fff3c0cc308] 1
        1   FileIDTreeGetEntryInfoFromFileID + 108 (CarbonCore + 25016) [0x7fff3c0cb1b8] 1
        1   FileIDTreeGetInfoFromFileIDInternal + 87 (CarbonCore + 25235) [0x7fff3c0cb293] 1
        1   __get_remove_counter + 3 (libsystem_kernel.dylib + 20084) [0x7fff68157e74] (running) 1
        3   ??? (SendMail + 1665652) [0x124840a74] 2-4
        3   FSGetCatalogInfoBulk + 69 (CarbonCore + 148475) [0x7fff3c0e93fb] 2-4
        3   PBGetCatalogInfoBulkSync + 853 (CarbonCore + 149391) [0x7fff3c0e978f] 2-4
        1   FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 1944 (CarbonCore + 151742) [0x7fff3c0ea0be] 2
        1   FSMount::getIndexedDirectoryItem(unsigned int, unsigned int, unsigned int, char*, unsigned char*) + 1778 (CarbonCore + 253920) [0x7fff3c102fe0] 2
        1   FileIDTreeAddEnumerationCacheEntry + 92 (CarbonCore + 254436) [0x7fff3c1031e4] 2
        1   FileIDTreeAddEnumerationCacheEntryBridge + 78 (CarbonCore + 254551) [0x7fff3c103257] 2
        1   FileIDTree_AddEnumerationCacheEntry_rpc + 172 (CarbonCore + 254748) [0x7fff3c10331c] 2
        1   mach_msg_trap + 10 (libsystem_kernel.dylib + 3114) [0x7fff68153c2a] 2
        *1   ipc_mqueue_receive_continue + 0 (kernel + 1642960) [0xffffff80003911d0] 2
        1   FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 2429 (CarbonCore + 152227) [0x7fff3c0ea2a3] 3
        1   __getattrlist + 10 (libsystem_kernel.dylib + 10902) [0x7fff68155a96] 3
        *1   hndl_unix_scall64 + 22 (kernel + 1418342) [0xffffff800035a466] 3
        *1   unix_syscall64 + 619 (kernel + 8084139) [0xffffff80009b5aab] 3
        *1   getattrlist + 112 (kernel + 4020432) [0xffffff80005d58d0] 3
        *1   ??? (kernel + 4020679) [0xffffff80005d59c7] 3
        *1   nameiat + 114 (kernel + 4225778) [0xffffff8000607af2] 3
        *1   namei + 2773 (kernel + 4123445) [0xffffff80005eeb35] 3
        *1   lookup + 175 (kernel + 4126303) [0xffffff80005ef65f] 3
        *1   cache_lookup_path + 58 (kernel + 4064298) [0xffffff80005e042a] (running) 3
        1   FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 1944 (CarbonCore + 151742) [0x7fff3c0ea0be] 4
        1   FSMount::getIndexedDirectoryItem(unsigned int, unsigned int, unsigned int, char*, unsigned char*) + 1778 (CarbonCore + 253920) [0x7fff3c102fe0] 4
        1   FileIDTreeAddEnumerationCacheEntry + 92 (CarbonCore + 254436) [0x7fff3c1031e4] 4
        1   FileIDTreeAddEnumerationCacheEntryBridge + 78 (CarbonCore + 254551) [0x7fff3c103257] 4
        1   FileIDTree_AddEnumerationCacheEntry_rpc + 172 (CarbonCore + 254748) [0x7fff3c10331c] 4
        1   mach_msg_trap + 10 (libsystem_kernel.dylib + 3114) [0x7fff68153c2a] 4
        *1   ipc_mqueue_receive_continue + 0 (kernel + 1642960) [0xffffff80003911d0] 4
        1   ??? (SendMail + 1665821) [0x124840b1d] 5
        1   FSDeleteObject + 27 (CarbonCore + 256222) [0x7fff3c1038de] 5
        1   PBRemoveObjectInternal(FSRefParam*, unsigned char) + 156 (CarbonCore + 256435) [0x7fff3c1039b3] 5
        1   GetFSRefAttributes(FSMount*, FSRef const*, unsigned int, FSAttributeInfo*, unsigned int, char*) + 123 (CarbonCore + 38850) [0x7fff3c0ce7c2] 5
        1   FSMount::getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 224 (CarbonCore + 25658) [0x7fff3c0cb43a] 5
        1   FSMount::_getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 350 (CarbonCore + 26080) [0x7fff3c0cb5e0] 5
        1   FSMount::getattrscore(bool, char const*, unsigned int, char const*, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 1594 (CarbonCore + 29482) [0x7fff3c0cc32a] 5
        1   FileIDTreeGetEntryInfoFromFileID + 49 (CarbonCore + 24957) [0x7fff3c0cb17d] 5
        1   geteuid + 10 (libsystem_kernel.dylib + 6870) [0x7fff68154ad6] (running) 5
        6   ??? (SendMail + 1665652) [0x124840a74] 6-11
        6   FSGetCatalogInfoBulk + 69 (CarbonCore + 148475) [0x7fff3c0e93fb] 6-11
        6   PBGetCatalogInfoBulkSync + 853 (CarbonCore + 149391) [0x7fff3c0e978f] 6-11
        6   FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 1944 (CarbonCore + 151742) [0x7fff3c0ea0be] 6-11
        1   FSMount::getIndexedDirectoryItem(unsigned int, unsigned int, unsigned int, char*, unsigned char*) + 204 (CarbonCore + 252346) [0x7fff3c1029ba] 6
        1   __opendir2$INODE64 + 71 (libsystem_c.dylib + 176435) [0x7fff68092133] 6
        1   fstatfs$INODE64 + 10 (libsystem_kernel.dylib + 10430) [0x7fff681558be] 6
        *1   hndl_unix_scall64 + 22 (kernel + 1418342) [0xffffff800035a466] 6
        *1   unix_syscall64 + 619 (kernel + 8084139) [0xffffff80009b5aab] 6
        *1   fstatfs64 + 168 (kernel + 4224040) [0xffffff8000607428] 6
        *1   vfs_update_vfsstat + 76 (kernel + 4145148) [0xffffff80005f3ffc] 6
        *1   apfs_vfs_getattr + 712 (apfs + 338194) [0xffffff7f819b5912] 6
        *1   spaceman_info + 62 (apfs + 761943) [0xffffff7f81a1d057] 6
        *1   spaceman_size_info + 138 (apfs + 761493) [0xffffff7f81a1ce95] 6
        *1   ??? (kernel + 2948872) [0xffffff80004cff08] 6
        *1   lck_mtx_lock_wait_x86 + 500 (kernel + 2951124) [0xffffff80004d07d4] 6
        *1   thread_block_reason + 175 (kernel + 1867151) [0xffffff80003c7d8f] 6
        *1   ??? (kernel + 1872080) [0xffffff80003c90d0] 6
        *1   machine_switch_context + 195 (kernel + 2963427) [0xffffff80004d37e3] (blocked by kernel mutex owned by Google Chrome [266] thread 0x2cf46a) 6
        1   FSMount::getIndexedDirectoryItem(unsigned int, unsigned int, unsigned int, char*, unsigned char*) + 1778 (CarbonCore + 253920) [0x7fff3c102fe0] 7
        1   FileIDTreeAddEnumerationCacheEntry + 92 (CarbonCore + 254436) [0x7fff3c1031e4] 7
        1   FileIDTreeAddEnumerationCacheEntryBridge + 78 (CarbonCore + 254551) [0x7fff3c103257] 7
        1   FileIDTree_AddEnumerationCacheEntry_rpc + 172 (CarbonCore + 254748) [0x7fff3c10331c] 7
        1   mach_msg_trap + 10 (libsystem_kernel.dylib + 3114) [0x7fff68153c2a] 7
