3 Replies Latest reply on Dec 20, 2017 11:32 AM by Thom Parker
    Addition with negative numbers in a form
    dylant72973562 Level 1
      Hello, I am trying to add a column of positive and negative numbers on an electronically created form as shown below:
      For some reason, the "Above Totals" field is treating the negative as a positive number, resulting in a total of 3 instead of 1. Once I finish typing in the next row; however, the field correctly treats the negative as a negative number as it should be calculated:
      There seems to be some type of delay with this calculation that does not get corrected  until the user manually enters an additional piece of data. Is there a reason why this calculation is not happening automatically? Thanks so much.
