Hi
Since I got CC18, I can't open the window allowing me to modify the curve tool. Same thing for all other layer tools. I double click on the ico and nothing happens: I can't modify any sliders/parameters since the corresponding window does not open. I have tried to reinstall CC18 but still does not work. Is that a bug?
It sounds like the properties window is not opening or is hidden. Is it shown as open on the Windows menu?
What happens if you right click on the adjustment layer and choose Edit Adjustments?
If the properties window is shown as open but it can't be seen, you could try resetting your workspace from the dropdown at the top right of the options bar.
Dave
How are you applying the adjustment, as an adjustment layer, or directly to the image layer? Can you post a screen capture of the curves dialog box, including the layers panel?
Thanks. My workspace needed a reset!
No bugs that I am aware of. As Theresa has said, how are you accessing the adjustment layers?
Adjustment and fill layers in Photoshop
This icon at the bottom of the Layers panel is one way.
But I suspect most of us use the Adjustments panel
Dave
