5 Replies Latest reply on Dec 25, 2017 1:52 PM by jurieh
    image d0es not display
    jurieh
      When I open a photo in photoshop the image does not display. Previously the images did display, but now I find that whatever I try, I cannot see the images. Can some body tell me why this happens?
        • 1. Re: image d0es not display
          Post your Photoshop menu Help>System Info
          • 2. Re: image d0es not display
            magdap98417959
            hi I have same problem my photo is not visible on ps worke space but Ican see its open on right side on layout
            • 3. Re: image d0es not display
              Trevor.Dennis Adobe Community Professional (Moderator)
              If these two posters are seeing black instead of their images, then that would make about a half dozen people with similar problems since the CC2018 update.  We assumed it is related to video card drivers, and I wonder if the people involved had things in common, like an AMD GPU for instance.  Perhapsmagdap98417959 and the thread starter could tell us a bit about their systems, or post the System Info as JJ asked them to.
              • 4. Re: image d0es not display
                jurieh Level 1
                This happens when I open files direct from my laptop, even files that I did
                open previously. Happens with .jpg as well as .psd files. The file is open,
                as can be seen in the Layers block in the bottom right hand corner. In some
                instances I am seeing only black in the workspace, in other instances I
                only see a gray and white 'pixel image'. Whatever I try I cannot change
                this.
                My system is an Dell Inspiron 15 laptop with a Intel Core CPU, 8GB RAM, 64
                bit processor. Operating system is Windows 10.
                Photoshop Help system info is below.
                Thanks for the support.
                Jurie
                Adobe Photoshop Version: 19.0 20171103.r.190 2017/11/03: 1143799  x64
                Number of Launches: 24
                Operating System: Windows 10 64-bit
                Version: 10 or greater 10.0.16299.15
                System architecture: Intel CPU Family:6, Model:14, Stepping:9 with MMX, SSE
                Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                Physical processor count: 2
                Logical processor count: 4
                Processor speed: 2904 MHz
                Built-in memory: 8091 MB
                Free memory: 1748 MB
                Memory available to Photoshop: 6865 MB
                Memory used by Photoshop: 70 %
                Surface Dial: Enabled.
                Alias Layers: Disabled.
                Modifier Palette: Enabled.
                Highbeam: Enabled.
                Image tile size: 128K
                Image cache levels: 4
                Font Preview: Medium
                TextComposer: Latin
                Display: 1
                Display Bounds: top=0, left=0, bottom=768, right=1366
                OpenGL Drawing: Enabled.
                OpenGL Allow Old GPUs: Not Detected.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                AIFCoreInitialized=1
                AIFOGLInitialized=1
                OGLContextCreated=1
                NumGLGPUs=1
                NumCLGPUs=2
                NumNativeGPUs=0
                glgpu[0].GLVersion="4.1"
                glgpu[0].IsIntegratedGLGPU=0
                glgpu[0].GLMemoryMB=1024
                glgpu[0].GLName="Intel(R) HD Graphics 620"
                glgpu[0].GLVendor="Intel"
                glgpu[0].GLVendorID=32902
                glgpu[0].GLDriverVersion="22.20.16.4799"
                glgpu[0].GLRectTextureSize=16384
                glgpu[0].GLRenderer="Intel(R) HD Graphics 620"
                glgpu[0].GLRendererID=22806
                glgpu[0].HasGLNPOTSupport=1
                glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\ki124538.inf_amd64_38801 626506e1429\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki124538.inf_amd 64_38801626506e1429\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki12453 8.inf_amd64_38801626506e1429\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepositor y\ki124538.inf_amd64_38801626506e1429\igd12umd64.dll"
                glgpu[0].GLDriverDate="20170914000000.000000-000"
                glgpu[0].CanCompileProgramGLSL=1
                glgpu[0].GLFrameBufferOK=1
                glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build
                22.20.16.4799"
                glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
                glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
                clgpu[0].CLPlatformVersion="2.0 AMD-APP (2117.13)"
                clgpu[0].CLDeviceVersion="2.0 AMD-APP (2117.13)"
                clgpu[0].IsIntegratedCLGPU=0
                clgpu[0].CLMemoryMB=4096
                clgpu[0].CLName="Iceland"
                clgpu[0].CLVendor="Advanced Micro Devices, Inc."
                clgpu[0].CLVendorID=4098
                clgpu[0].CLDriverVersion="2117.13 (VM)"
                clgpu[0].CLBandwidth=2.63839e+10
                clgpu[0].CLCompute=272.704
                clgpu[1].CLPlatformVersion="2.1 "
                clgpu[1].CLDeviceVersion="2.1 "
                clgpu[1].IsIntegratedCLGPU=1
                clgpu[1].CLMemoryMB=3228
                clgpu[1].CLName="Intel(R) HD Graphics 620"
                clgpu[1].CLVendor="Intel(R) Corporation"
                clgpu[1].CLVendorID=32902
                clgpu[1].CLDriverVersion="22.20.16.4799"
                clgpu[1].CLBandwidth=1.15272e+10
                clgpu[1].CLCompute=175.767
                License Type: Subscription
                Serial number: 96040179292496329776
                GUIDBucket:
                Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                Temporary file path: C:\Users\dell\AppData\Local\Temp\
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  Startup, 919.0G, 705.2G free
                Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC
                2018\Required\Plug-Ins\
                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC
                2018\Plug-Ins\
                Installed components:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
                   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                   AdobeOwl.dll   Adobe Owl   5.2.11
                   AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
                   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                   AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
                   AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                   AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924
                79.160924
                   AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924
                79.160924
                   adobe_caps.dll   Adobe CAPS   10,0,0,6
                   AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
                   ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                   amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate:
                Tue Aug 1 2017 8:28:8)   1.000000
                   ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
                   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390
                79.562390
                   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                   Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
                   BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
                   boost_date_time.dll   photoshopdva   11.1.0
                   boost_filesystem.dll   photoshopdva   11.1.0
                   boost_signals.dll   photoshopdva   11.1.0
                   boost_system.dll   photoshopdva   11.1.0
                   boost_threads.dll   photoshopdva   11.1.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                   CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
                   CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
                   dnssd.dll   Bonjour   3,0,0,2
                   dvaaudiodevice.dll   photoshopdva   11.1.0
                   dvacore.dll   photoshopdva   11.1.0
                   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                   dvamarshal.dll   photoshopdva   11.1.0
                   dvamediatypes.dll   photoshopdva   11.1.0
                   dvametadata.dll   photoshopdva   11.1.0
                   dvametadataapi.dll   photoshopdva   11.1.0
                   dvametadataui.dll   photoshopdva   11.1.0
                   dvaplayer.dll   photoshopdva   11.1.0
                   dvatransport.dll   photoshopdva   11.1.0
                   dvaui.dll   photoshopdva   11.1.0
                   dvaunittesting.dll   photoshopdva   11.1.0
                   dynamiclink.dll   photoshopdva   11.1.0
                   ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690
                81.1133690
                   icucnv40.dll   International Components for Unicode
                2014/10/31-16:52:45    Build gtlib_6.0.21339
                   icudt40.dll   International Components for Unicode
                   icuuc40.dll   International Components for Unicode
                   igestep30.dll   IGES Reader   9.3.0.113
                   imslib.dll   IMSLib DLL   10.0.0.22
                   JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                   libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                   LogSession.dll   LogSession   7.4.1.60.45263
                   mediacoreif.dll   photoshopdva   11.1.0
                   MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CC 2018   19.0
                   Plugin.dll   Adobe Photoshop CC 2018   19.0
                   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject
                Standard Dll (64 bit)   8.0.0
                   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)
                8.0.0.55
                   PSArt.dll   Adobe Photoshop CC 2018   19.0
                   PSCloud.dll                                                   1.0.0.1
                   PSViews.dll   Adobe Photoshop CC 2018   19.0
                   SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
                   SVGRE.dll   SVGRE   79.586793   79.586793
                   svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0,
                2017, 0118
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017,
                0, 2017, 0118
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library
                10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960
                0.21960
                   wu3d.dll   U3D Writer   9.3.0.113
                Required plug-ins:
                   3D Studio 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “U3D.8bi”
                   Accented Edges 19.0 - from the file “Filter Gallery.8bf”
                   Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
                   Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
                   Average 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Average.8bf”
                   Bas Relief 19.0 - from the file “Filter Gallery.8bf”
                   BMP 19.0 - from the file “Standard MultiPlugin.8bf”
                   Camera Raw 10.1 - from the file “Camera Raw.8bi”
                   Camera Raw Filter 10.1 - from the file “Camera Raw.8bi”
                   Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
                   Chrome 19.0 - from the file “Filter Gallery.8bf”
                   Cineon 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Cineon.8bi”
                   Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Clouds.8bf”
                   Collada 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “U3D.8bi”
                   Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
                   Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
                   CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
                   Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
                   Craquelure 19.0 - from the file “Filter Gallery.8bf”
                   Crop and Straighten Photos 19.0 (20171103.r.190 2017/11/03: 1143799) -
                from the file “CropPhotosAuto.8li”
                   Crop and Straighten Photos Filter 19.0 - from the file “Standard
                MultiPlugin.8bf”
                   Crosshatch 19.0 - from the file “Filter Gallery.8bf”
                   Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
                   Cutout 19.0 - from the file “Filter Gallery.8bf”
                   Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
                   De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
                   Dicom 19.0 - from the file “Dicom.8bi”
                   Difference Clouds 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “Clouds.8bf”
                   Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
                   Displace 19.0 - from the file “Standard MultiPlugin.8bf”
                   Dry Brush 19.0 - from the file “Filter Gallery.8bf”
                   Eazel Acquire 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “EazelAcquire.8ba”
                   Entropy 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Export Color Lookup Tables 19.0 (20171103.r.190 2017/11/03: 1143799) -
                from the file “Export3DLUT.8be”
                   Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
                   FastCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “FastCore.8bx”
                   Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
                   Film Grain 19.0 - from the file “Filter Gallery.8bf”
                   Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
                   Flash 3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “U3D.8bi”
                   Fresco 19.0 - from the file “Filter Gallery.8bf”
                   Glass 19.0 - from the file “Filter Gallery.8bf”
                   Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
                   Google Earth 4 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “U3D.8bi”
                   Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
                   Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
                   Halide Bottlenecks 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “HalideBottlenecks.8bx”
                   HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
                   HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
                   IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
                   IGES 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
                   Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
                   JPEG 2000 19.0 - from the file “JPEG2000.8bi”
                   Kurtosis 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Lens Blur 19.0 - from the file “Lens Blur.8bf”
                   Lens Correction 19.0 - from the file “Lens Correction.8bf”
                   Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
                   Liquify 19.0 - from the file “Liquify.8bf”
                   Matlab Operation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “ChannelPort.8bf”
                   Maximum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Mean 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Measurement Core 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “MeasurementCore.8me”
                   Median 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
                   Minimum 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   MMXCore Routines 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “MMXCore.8bx”
                   Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
                   Multiprocessor Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from
                the file “MultiProcessor Support.8bx”
                   Neon Glow 19.0 - from the file “Filter Gallery.8bf”
                   Note Paper 19.0 - from the file “Filter Gallery.8bf”
                   NTSC Colors 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “NTSC Colors.8bf”
                   Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
                   OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
                   Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
                   Palette Knife 19.0 - from the file “Filter Gallery.8bf”
                   Patchwork 19.0 - from the file “Filter Gallery.8bf”
                   Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
                   PCX 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “PCX.8bi”
                   Photocopy 19.0 - from the file “Filter Gallery.8bf”
                   Photoshop 3D Engine 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “Photoshop3DEngine.8bi”
                   Photoshop Touch 19.0 - from the file “PSDX.8bi”
                   Picture Package Filter 19.0 (20171103.r.190 2017/11/03: 1143799) - from
                the file “ChannelPort.8bf”
                   Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
                   Pixar 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Pixar.8bi”
                   Plaster 19.0 - from the file “Filter Gallery.8bf”
                   Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
                   PLY 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
                   Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
                   Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
                   Portable Bit Map 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “PBM.8bi”
                   Poster Edges 19.0 - from the file “Filter Gallery.8bf”
                   PRC 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
                   Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
                   Radiance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Radiance.8bi”
                   Range 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Render Color Lookup Grid 19.0 (20171103.r.190 2017/11/03: 1143799) -
                   Reticulation 19.0 - from the file “Filter Gallery.8bf”
                   Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
                   Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
                   Save for Web 19.0 - from the file “Save for Web.8be”
                   ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
                   Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
                   Shear 19.0 - from the file “Standard MultiPlugin.8bf”
                   Skewness 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
                   Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
                   Solarize 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “Solarize.8bf”
                   Spaces 19.0 - from the file “Spaces.8li”
                   Spatter 19.0 - from the file “Filter Gallery.8bf”
                   Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
                   Sponge 19.0 - from the file “Filter Gallery.8bf”
                   Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
                   Stained Glass 19.0 - from the file “Filter Gallery.8bf”
                   Stamp 19.0 - from the file “Filter Gallery.8bf”
                   Standard Deviation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “statistics.8ba”
                   STL 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
                   Sumi-e 19.0 - from the file “Filter Gallery.8bf”
                   Summation 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Targa 19.0 - from the file “Standard MultiPlugin.8bf”
                   Texturizer 19.0 - from the file “Filter Gallery.8bf”
                   Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
                   Torn Edges 19.0 - from the file “Filter Gallery.8bf”
                   Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
                   U3D 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file “U3D.8bi”
                   Underpainting 19.0 - from the file “Filter Gallery.8bf”
                   Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
                   Variance 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “statistics.8ba”
                   Virtual Reality Modeling Language | VRML 19.0 (20171103.r.190
                   Water Paper 19.0 - from the file “Filter Gallery.8bf”
                   Watercolor 19.0 - from the file “Filter Gallery.8bf”
                   Wave 19.0 - from the file “Standard MultiPlugin.8bf”
                   Wavefront|OBJ 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “U3D.8bi”
                   WIA Support 19.0 (20171103.r.190 2017/11/03: 1143799) - from the file
                “WIASupport.8li”
                   Wind 19.0 - from the file “Standard MultiPlugin.8bf”
                   Wireless Bitmap 19.0 (20171103.r.190 2017/11/03: 1143799) - from the
                file “WBMP.8bi”
                   ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
                Optional and third party plug-ins: NONE
                Duplicate and Disabled plug-ins: NONE
                Plug-ins that failed to load: NONE
                Extensions:
                   com.adobe.Butler.backend  2.0.0 - from the file “C:\Program
                2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                   com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files
                (x86)\Common
                Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\purchase.html”
                   New Document  2.1.0 - from the file “C:\Program Files\Adobe\Adobe
                Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
                   Libraries  2.11.27 - from the file “C:\Program Files (x86)\Common
                Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\index.html”
                   Start  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC
                2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
                   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe
                Photoshop CC
                2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                   Export As  3.0.13 - from the file “C:\Program Files\Adobe\Adobe
                Photoshop CC
                2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                Photoshop CC
                Installed TWAIN devices: NONE
                On Tue, Dec 26, 2017 at 5:02 AM, Trevor.Dennis <forums_noreply@adobe.com>
                • 5. Re: image d0es not display
                  jurieh Level 1
                  Add to the above info. When I open the files from Bridge (accidentaly done
                  this,  am a novice at Photoshop) the files seems to display normally.
                  Jurie.
