Hello,
I've got a newbie question !
Is it possible to listen events from Illustrator app in extensions ?
I would like to be notified when a user changes the name of a layer or when he moves an item to another group or when he changes the anchor points of a path.
I would like to be able to intercept all these types of events and more.
Is it possible ? Does anyone have an example?
If possible, how can I get a list of all these events?
I saw that there was PlugPlugAddEventListener, is it possible to use it in this way?
Thanks for your help.
Loïc
[moved from Illustrator Scripting by moderator]
CEP doesn’t support events in AI.
However, We can listen a event via plugin that made by Illustrator SDK.
You can download tools and documents from Adobe I/O Console .
Hello,
Thanks for your response ! That's sad !!!
Someone have some code examples for listen events in host app and diffuse to CEP Extensions ???
I don't develop in C++ but if it's not to hard, I'll try !
Thanks in advance.
You can check samples in SDK.
The Marked object sample plugin has some events and you can learn how it works with CEP.
Thanks.
I inspect MarkedObject and Freegrid samples in SDK. I saw Events.
Now I must learn and understand C++ ! A big challenge !
Is it possible to build a very small plugin that listen all events in host app and dispatch them to CEP ?
If anyone have a good tutorial for Illustrator SDK programming, it's perfect.
Have a nice day !
I second that. We need to be able to monitor AI UI events.
