1 Reply Latest reply on Jan 9, 2018 10:44 PM by Markoh75
    Icon for tracker not working, getting syntax error
    Markoh75 Level 1
      Hi!
      Last weeks I had problems with the tracker icon. It says that I have new items in the tracker.
      I double click on the icon and then i get error: "Error while opening document, document cannot be found."
      If I press OK on that and next error shows: "there was an error opening this document. The filename, directory name, or volume label syntax is incorrect"
      Here is the twist, if I now click OK and directly on the tracker icon again it works.
      So this syntax error seems to be shown only when I am starting the tracker when acrobat is closed.
      I have Acrobat Pro DC Version 2018.009.20050 and i have uninstalled it and reinstalled without solving the issue.
      Acrobat is running on a Windows 10 Enterprise
      Version 1709
      OS-version 16299.98
      I do not remember if this problem started after the install of the windows creators update...?
      Any ideas?
      /Marko !
