13 Replies Latest reply on Jun 24, 2018 2:26 PM by keitha87662434
    Photoshop Program Error
    kalep88843409
      After updating to version Photoshop 19.0 I keep getting "File can't open due to program error"I uninstalled and reinstalled 19.0, same thing happened. So I uninstalled again and installed Photoshop version 17.0.2. Same thing continues to happen.
      If you have insight regarding my issue, please please help me!
      Best
        • 1. Re: Photoshop Program Error
          What file can not be open? An Image file, any image file? Post your Photoshop menu Help>system Info. Is it the same erre ib CC 2017 and cc 2018?  What OS are you using.
          Supply pertinent information for quicker answers
          • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
          • 2. Re: Photoshop Program Error
            kalep88843409 Level 1
            I can open image files (JPEG & PNG), but I cannot open a Photoshop PDF. It's happening for both 2017 and 2018, I'm running on Mac OS 10.13.2 (High Sierra). Thoughts?
            System Info:
            Adobe Photoshop Version: 2017.1.2 20171103.r.18 2017/11/03: 1143982  x64
            Number of Launches: 0
            Operating System: Mac OS 10.13.2
            System architecture: Intel CPU Family:6, Model:61, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
            Physical processor count: 2
            Logical processor count: 4
            Processor speed: 1200 MHz
            Built-in memory: 8192 MB
            Free memory: 3847 MB
            Memory available to Photoshop: 6297 MB
            Memory used by Photoshop: 70 %
            History Thumbnails: Enabled.
            Touch Bar: Enabled.
            Alias Layers: Disabled.
            Modifier Palette: Disabled.
            Highbeam: Enabled.
            Image tile size: 128K
            Image cache levels: 4
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Main Display
            High DPI Monitor
            Display Bounds: top=0, left=0, bottom=800, right=1280
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            NumNativeGPUs=1
            glgpu[0].GLVersion="2.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=1536
            glgpu[0].GLName="Intel(R) HD Graphics 5300"
            glgpu[0].GLVendor="Intel Inc."
            glgpu[0].GLVendorID=32902
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="Intel(R) HD Graphics 5300"
            glgpu[0].GLRendererID=16925953
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2 (Oct 31 2017 18:19:43)"
            clgpu[0].CLDeviceVersion="1.2 "
            clgpu[0].IsIntegratedCLGPU=1
            clgpu[0].CLMemoryMB=1536
            clgpu[0].CLName="Intel(R) HD Graphics 5300"
            clgpu[0].CLVendor="Intel Inc."
            clgpu[0].CLVendorID=16925952
            clgpu[0].CLDriverVersion="1.2(Nov  9 2017 18:56:42)"
            clgpu[0].CLBandwidth=1.32179e+10
            clgpu[0].CLCompute=157.656
            nativegpu[0].NativeName="Intel(R) HD Graphics 5300"
            License Type: Subscription
            Serial number: 90970007335335776582
            GUIDBucket:
              bucket: 247
              test: DocumentPanel
            Application folder: /Applications/Adobe Photoshop CC 2017/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 465.6G, 190.7G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-Ins/
            Installed components:
               dvametadata.framework   dvametadata   10.0.0.0
               AdobeXMPScript.framework   AdobeXMPScript   79.159824   79.159824
               ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
               ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
               AdobeCrashReporter.framework   AdobeCrashReporter   7.3.2
               boost_system.framework   boost_system   10.0.0.0
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeACE.framework   AdobeACE   2.20.02.37848   79.579975
               AdobeOwl.framework   AdobeOwl   5.2.11
               mediacoreif.framework   mediacoreif   10.0.0.0
               manta.framework   manta   2.0.00.1   1.
               dvaunittesting.framework   dvaunittesting   10.0.0.0
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
               AIDE.framework   AIDE   1.5.0.36540   79.574279
               dynamiclink.framework   dynamiclink   10.0.0.0
               dvametadataUI.framework   dvametadataUI   10.0.0.0
               UpdaterNotifications.framework   UpdaterNotifications   10.0.0.1   "10.0.0.1"
               AdobeExtendScript.framework   AdobeExtendScript   4.5.6.5   80.1089815
               boost_filesystem.framework   boost_filesystem   10.0.0.0
               AdobeBIB.framework   AdobeBIB   1.2.03.37848   79.579975
               AdobeXMPFiles.framework   AdobeXMPFiles   79.159824   79.159824
               AdobeLinguistic.framework      22175
               dvaplayer.framework   dvaplayer   10.0.0.0
               PlugPlugOwl.framework   PlugPlugOwl   7.0.0.67
               AdobeAGM.framework   AdobeAGM   4.30.87.37848   79.579975
               adobe_caps.framework   adobe_caps   10.0.0.6   1.584361
               AdobeSVGRE.framework   AdobeSVGRE   6.0   88.588432
               AdobePDFL.framework   AdobePDFL   15.0.0.36975   79.195992
               dvacore.framework   dvacore   10.0.0.0
               AdobePIP.framework   AdobePIP   7.4.1.60.45263
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
               dvatransport.framework   dvatransport   10.0.0.0
               Cg.framework   NVIDIA Cg
               boost_signals.framework   boost_signals   10.0.0.0
               AdobeXMP.framework   AdobeXMPCore   79.159824   79.159824
               AdobeJP2K.framework   AdobeJP2K   1.2.2.38234   79.266006
               dvaaudiodevice.framework   dvaaudiodevice   10.0.0.0
               LogSession.framework   LogSession   7.4.1.60.45263
               PlugPlugExternalObject.framework      7.0.0.67
               AdobeScCore.framework   AdobeScCore   4.5.6.5   80.1089815
               AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.39544   88.588432
               dvametadataapi.framework   dvametadataapi   10.0.0.0
               CITThreading.framework
               WRServices.framework
               amtlib.framework   amtlib   10.0.0.119
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.579975
               boost_threads.framework   boost_threads   10.0.0.0
               aif.framework   aif   6.0.00.1   1.
               AdobeCoolType.framework   AdobeCoolType   5.15.00.37848   79.579975
               dvamediatypes.framework   dvamediatypes   10.0.0.0
               AdbePM.framework   AdbePM   2.5.00.377243   1.578146
               boost_date_time.framework   boost_date_time   10.0.0.0
               AdobeMPS.framework   AdobeMPS   5.8.1.37174   79.577269
               dvaui.framework   dvaui   10.0.0.0
               ahclient.framework   ahclient   2.2.0.1
               ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
               dvamarshal.framework   dvamarshal   10.0.0.0
            Required plug-ins:
               3D Studio 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 18.1.2, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 10.1 (864), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 18.1.2  ©2002-2017 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 18.1.2  Copyright © 2003-2017 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 18.1.2  Copyright © 2007-2017 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Entropy 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Export Color Lookup Tables 18.1.2  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
               Extrude 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 18.1.2  ©1990-2017 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               HSB/HSL 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               IFF Format 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               IGES 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Ink Outlines 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 18.1.2  Copyright © 2001-2017 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 18.1.2, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 18.1.2, Copyright © 2002-2017 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 18.1.2, Copyright © 2001-2017 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 18.1.2  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 18.1.2  ©1990-2017 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 18.1.2  Copyright © 1990-2017 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               OpenEXR 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 18.1.2  ©1989-2017 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch Copyright ©2013-2017 Adobe Systems Incorporated - from the file “PSDX.plugin”
               Picture Package Filter 18.1.2  ©1993-2017 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 18.1.2  ©1989-2017 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PLY 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               PNG 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 18.1.2  ©1989-2017 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PRC 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Radial Blur 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 18.1.2  ©2003-2017 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Render Color Lookup Grid 18.1.2  Copyright ©2012-2017 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
               Reticulation 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 18.1.2, Copyright © 1999-2017 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 18.1.2, Copyright © 2017 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shake Reduction 18.1.2, Copyright © 2014-2017 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
               Shear 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 18.1.2  Copyright © 1993-2017 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spaces 18.1.2, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
               Spatter 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               U3D 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Underpainting 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 18.1.2, Copyright © 2003-2017 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “statistics.plugin”
               Virtual Reality Modeling Language | VRML 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Water Paper 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 18.1.2, Copyright © 1991-2017 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 18.1.2  ©2006-2017 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 18.1.2  ©1989-2017 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 18.1.2, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins: NONE
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions:
               com.adobe.inapp.purchase  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
               Libraries  2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
               New Document  2.0.1 - from the file “/Users/kalepaulsen/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
               Start  2.0.1 - from the file “/Users/kalepaulsen/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
               com.adobe.experimentation.extension  2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
               Adobe Color Themes  6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
               Export As  3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
               Device Preview  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
               com.adobe.preview.loader  1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
            Installed TWAIN devices: NONE
            • 3. Re: Photoshop Program Error
              Can acrobat open the PDF? If it can upload the pdf and post a link to it I'll see if I can open it win Windows Photoshop.
              Does Photoshop Import PDF dialog open?
              • 4. Re: Photoshop Program Error
                I can try. 9/10 times acrobat will crash on me (and of course, it's the newest version as well)... How/where exactly would I upload?
                • 5. Re: Photoshop Program Error
                  Yes, it will give me that dialog box when opening... I switched to a PDF from a long time ago and it opened fine... but still won't open my files that I was working on last week... if that helps at all
                  • 6. Re: Photoshop Program Error
                    Some file sharing site like dropbox.
                    • 7. Re: Photoshop Program Error
                      I could not open your PDF files in Photshop CS6, CC 2-14 oor CC 2018 I did not get the Import PDF dialog just got an program error.. Acrobat Reader was able to open them and save them. Evem the PDF save by acrobat could not be open in Photoshop.
                      • 8. Re: Photoshop Program Error
                        dang... Any advice where I should go from here?
                        • 9. Re: Photoshop Program Error
                          If all you use was Adobe's software report it as a bug.
                          • 10. Re: Photoshop Program Error
                            keitha87662434
                            Adobe has recently upgraded my Adobe Cloud version of Photoshop CC to the 2018 version. I also now get the error intermittent error 'could not complete your request because of program error' , This never happened with the previous version. I run Windows 7 and have made no changes to the operating system. My old  version of Photoshop has no problems and works satisfactorily so the problem must be associated with this latest download.
                            Can anybody help?
                            • 11. Re: Photoshop Program Error
                              When do you get that error? Are you always doing the same operation?
                              • 12. Re: Photoshop Program Error
                                keitha87662434 Level 1
                                I get the 'could not complete your request because of program error' message when I try to open any image (.jpeg, .RAF or any RAW) .I am using Windows 7 and Photoshop CC 2018 via Adobe Creative Cloud. The program appears to work once after initial startup of my PC and then I get the error message on each subsequent attempt to open a new image, This never occurred with the previous version of Photoshop CC 2017.
                                • 13. Re: Photoshop Program Error
                                  See my recent reply in the forum.
                                  There appears to be a program error in the latest version of Photoshop CC 2018 for use with Windows 7
