does anyone know if there is a shortcut for the grid?
thanx
judy
Here's a list of all the shortcuts for Camera Raw
Hi ,
On Windows the grid in camera raw can be toggled with Shift+G, as long as the transform panel is visible (I'm not sure if it is the same on Mac)
Dave
thanx. that definitely works. where did you see that? i have been looking for a while and couldn't find it. does work on mac.
judy
If you have Photoshop tooltips turned on (Preferences >Tools) and in Camera raw you hover the mouse over the grid checkbox, you will see the shortcut. Same with several other tools. It is a good way to pick up several shortcuts.
Dave
i had turned off the tips because i had found them annoying - i knew all the shortcuts i needed to know. then of course i forgot that i could turn it back on to get information i wanted after adobe updated the transform panel.
thank you for your answer.
judy
You're welcome
Dave
