How did I get this error code? Does it have to do with my motion menu that I am using?
Thanks for your help.
Duane
This error is probably from multiple sources, and there has been no consistent fix reported. It can be media or drive. It can be permissions. A reinstall of Encore has fixed it in at least one situation, and reducing burn speed in another. Reducing bitrate/project size may avoid the error. Make sure you are running Encore "as administrator."
Test the workflow up to the point of actually burning a disk by a) building to an image and b) burning with an alternate software such as ImgBurn for PC or T
...Copy link to clipboard
Test the workflow up to the point of actually burning a disk by a) building to an image and b) burning with an alternate software such as ImgBurn for PC or Toast for Mac.
The problem ended up with my BD drive failing. I tried downloading ImgBurn and my Norton software blocked it every time. I transferred my image file to another computer. I then found another image burning software that worked just fine. The BD I created worked just fine. Now I need to purchase another BD recorder. Not sure I will get ASUS any more as this play has hardly been used. It should not have failed so early on.
Thank you for your help.
