1. Re: Toggle between brush blending modes (normal and clear)
MikeGondek Jan 2, 2018 11:45 AM (in response to roisinhahessy)1 person found this helpfulYes is same key as for toggling through Layer blend modes. You just need to first make sure you have the paintbrush selected.
Shift + cycles forwards through blend modes
Shift - cycles backwards through blend modes
To go between normal and clear you will need to hit the shortcut 3 times.
Our you can use "b" & "e" to toggle between the brush and eraser tool
2. Re: Toggle between brush blending modes (normal and clear)
roisinhahessy Jan 3, 2018 8:10 AM (in response to MikeGondek)Thanks for your reply, didn't know about shift + and shift - it helps!
I'd still love if there was something a bit quicker though, like going from eraser to brush but I don't use eraser as I want to keep the same settings of my brush.
3. Re: Toggle between brush blending modes (normal and clear)
MikeGondek Jan 9, 2018 7:15 AM (in response to roisinhahessy) -
4. Re: Toggle between brush blending modes (normal and clear)
sho.w.off Jan 31, 2018 1:29 AM (in response to roisinhahessy)I have complete same need as rousinhahessy. I wish adobe let us edit shortcut keys and/or the list of blending modes. Hiding modes except Normal and Clear would be great. It would speed up my production drastically.
5. Re: Toggle between brush blending modes (normal and clear)
Trevor.Dennis Jan 31, 2018 2:24 AM (in response to roisinhahessy)It turns out that there are direct shortcuts for brush blend modes, including for Clear and Behind
Blend Mode Shortcuts in Photoshop « Julieanne Kost's Blog
Almost all of the blend modes in Photoshop have their own keyboard shortcut. They all begin with Option + Shift + a letter (Mac)/ Alt + Shift + a letter (Win). Most often the letter is the first letter of the name, but not always!
Normal + N
Dissolve + I
Behind + Q (Brush tool only)
Clear + R( Brush tool only)
Darken + K
Multiply + M
Color Burn + B
Linear Burn + A
Lighten + G
Screen + S
Color Dodge + D
Linear Dodge + W
Overlay + O
Soft Light + F
Hard Light + H
Vivid Light + V
Linear Light + J
Pin Light + Z
Hard Mix + L
Difference + E
Exclusion + X
Hue + U
Saturation + T
Color + C
Luminosity + Y
I couldn’t find a shortcut for Subtract or Divide, but if you know of one, please add it in the comments! If you want to quickly cycle through the painting tool’s blend modes, hold the Shift key and hit the “+” (plus) or “-” (minus) to move forward or backwards. Careful: f you have a tool selected that is not a painting tool, these shortcuts will affect the blend modes on the Layers panel.
I don't use them myself, but I do use the G-Keys on my G910 with either key sequences or macros to trigger Photoshop multi key shortcuts and Actions.
Regular poster JJMack has one of those very nifty Logitech G13 keypads which he has made full use of by assigning all three banks of all 27 G-keys
Re: Short Cuts - Step Forward & Step Backward
With credit to JJ, this is his GIF, and I am in awe of it. You can assign any of those keys to trigger shortcuts regardless of how many keys it uses. I have actually used my G910 G-keys to insert long and frequently used URLs into forum threads (but not at the moment because I am in between systems)
I am not sure of the G13 status nowadays. They can appear to be hard to find. Amazon shows them in the USA, and I have just asked if they ship to NZ, because I'd love to have one.
6. Re: Toggle between brush blending modes (normal and clear)
roisinhahessy Feb 2, 2018 10:57 AM (in response to MikeGondek)Thanks for your reply but I don't use the eraser, I need clear as it keeps the same brush atributes as when I'm adding colour as removing.
7. Re: Toggle between brush blending modes (normal and clear)
roisinhahessy Feb 2, 2018 11:01 AM (in response to Trevor.Dennis)Thanks for your reply, I already found these shortcuts, as well as Shift +/- to scroll through them all, but they are still a little awkward and slow down my process. Something like E to B (eraser to brush) would be perfect because they are just one button and I don't even need to look at the keyboard, but I don't use the eraser, I only use clear as it keeps the same attributes as the brush I am using. Shift +/- is working for now but its a bit slower than I would like, hopefully soon Adobe will introduce this, or at least make it possible for us to change this shortcut
