2 Replies Latest reply on Jan 3, 2018 7:44 AM by gkaiseril
    Check combo for "empty" fields
    jenniferc11972072 Level 1
      Currently working on a script for the verify empty fields before printing to give a warning.
      what i purloined and modified from the forum was
      // check for empty fields
      var emptyFields = [];
      for (var i=0; i<this.numFields; i++) {
           var f= this.getField(this.getNthFieldName(i));
           if (f.type!="button" && f.required ) {
                if ((f.type=="text" && (f.value=="" || f.value==" ")) || (f.type=="checkbox" && f.value=="Off")) emptyFields.push(f.name);
      if (emptyFields.length>0) {
           app.alert("Important - You must fill in the following fields or your reimburstment will be delayed:\n" + emptyFields.join("\n"));
      } else this.print();
      I need to add for it to check combo boxes for the answer "-" as that the default setting or empty setting.  Is that possible?
        • 1. Re: Check combo for "empty" fields
          Change this part:
          To:
          if (f.valueAsString==f.defaultValue)
          • 2. Re: Check combo for "empty" fields
            One can also use the "defautlValue" property of a field to check for an uncompleted field.
                      if ((f.defaultValue) emptyFields.push(f.name);
            You may have to adjust your code if there is a signature field.
