16 Replies Latest reply on Jul 10, 2008 5:22 AM by Newsgroup_User
    Can i view code in Fireworks CS3?
    Akermay Level 1
      Hi
      I want to add a custom font to my pop-up menu for my navigation bar so it fits in with my website, and isnt a boring default. How can i do this? Also is it possible to view code and here: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_16423#menu_item_font
      It says: fnt Menu item font
      (Determines the font group that will be used in the menu being addressed. You can use custom font groups here if you wish. Standard web fonts are recommended.) "Arial, Helvetica, sans-serif"
      Is that not a change you make in code? If not where can i change this? Thanks.
        • 1. Re: Can i view code in Fireworks CS3?
          Level 7
          FW is not an HTML authoring application. If you want to view code, you
          should do that work in DW.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "Josh.K" <webforumsuser@macromedia.com> wrote in message
          news:g528e8$s7m$1@forums.macromedia.com...
          > Hi
          > Also is
          > t
          > You
          > Thanks.
          • 2. Re: Can i view code in Fireworks CS3?
            Akermay Level 1
            Ok, thanks. But does anyone know what to do about the custom font?
            • 3. Re: Can i view code in Fireworks CS3?
              Level 7
              Which FW are you using?
              news:g52d1f$3n9$1@forums.macromedia.com...
              • 5. Re: Can i view code in Fireworks CS3?
                Level 7
                Thank goodness for small favors!
                Are your desired menu fonts installed on your system? Do you see them in
                the font list in FW? If you do not, then you will not be able to use them.
                news:g52fvr$6q4$1@forums.macromedia.com...
                > CS3
                • 6. Re: Can i view code in Fireworks CS3?
                  Akermay Level 1
                  Really? I want to use Apple Chancery as a font in my pop-up menu, it appears in normal things (installed on system) and i can use it in Fireworks, just not for pop-ups. The only fonts it says on the list for pop-ups are like 4 default ones, like Verdana and stuff.
                  • 7. Re: Can i view code in Fireworks CS3?
                    Level 7
                    Sorry - I can't take you any further.
                    I don't regard using FW pop-up menus as a viable tool for websites, so I
                    don't use them at all. Perhaps someone who does use them can help you with
                    this.
                    news:g52hgs$8dh$1@forums.macromedia.com...
                    > appears
                    > not
                    > default
                    • 8. Can i view code in Fireworks CS3?
                      Gayle Duncan Level 1
                      I believe Fireworks is trying to "help" you, by only allowing you to choose web-safe fonts, of which Apple Chancery is not. Fireworks would allow you to use that font in an image file, but not in a popup menu.
                      If you were dead-set on using it (despite the fact that some people would not be able to see it, given their browsers,) you could export the menu to an HTML-editing program such as Dreamweaver, then edit the code yourself. It's not recommended...but given the circumstances you could try it. I'd just make sure you had a backup, web-safe font coded in there as well.
                      • 9. Re: Can i view code in Fireworks CS3?
                        Akermay Level 1
                        Ok, thanks. So when i export it and take it into Dreamweaver which ill use to make the site. I just select the tab or whichever bit i need to on the nav bar and it will show me the code?
                        • 10. Re: Can i view code in Fireworks CS3?
                          JoeDaSilva Level 4
                          If you use anything other than a web-safe font (the defaults), people without that font, which would be anyone with a Windows or Linux based machine for example, will get something entirely different and out of your control.
                          This is why every dropdown/fly-out menu on the internet uses the same small pool of fonts. It's not due to a lack of creativity ;-)
                          • 11. Re: Can i view code in Fireworks CS3?
                            Level 7
                            Unless they use images for the menu elements, or some form of image
                            replacement....
                            "JoeyD1978" <webforumsuser@macromedia.com> wrote in message
                            news:g52to7$lhn$1@forums.macromedia.com...
                            > without
                            > small
                            • 12. Re: Can i view code in Fireworks CS3?
                              quote:
                              In theory, yes. However I'm not sure if it will highlight the exact bit of code you need to change the font. You may have to go to code view and hunt around in the head of the HTML document, where the javascript menu code should be. Or it might be written separately in the MM_MENU.JS file, which will be exported with your HTML. To be honest, I'm not a huge fan of Fireworks' HTML-writing capabilities...so I'm grasping at straws, here. I've never broken apart the code that Fireworks writes for popup menus. It may put the font tags inline, but if I'm reading that tech-note correctly, it's probably writing the font information in the MM_MENU.JS file, which you will have to open and edit separately in Dreamweaver.
                              Additionally, I'd like to stress that although your idea is creative...it might not be the best one, given that a lot of people that view your website won't be able to read Apple Chancery font. In the end, those people's browsers will default to a websafe-font, thus defeating your purpose.
                              • 13. Re: Can i view code in Fireworks CS3?
                                JoeDaSilva Level 4
                                quote:
                                Apple's market share is at about 20% right now, so that's about how many people will see your font.
                                • 14. Re: Can i view code in Fireworks CS3?
                                  Level 7
                                  Maybe.
                                  news:g534g0$sk9$1@forums.macromedia.com...
                                  > Apple
                                  • 15. Re: Can i view code in Fireworks CS3?
                                    pixlor Level 4
                                    quote:
                                    According to the
                                    Code Style font sampler survey, Apple Chancery is installed on about 90% of all Mac systems surveyed. On Windows, a similar font is Monotype Corsiva.
                                    Apple Chancery graphic
                                    Monotype Corsiva graphic
                                    However, Monotype Corsiva is only installed on about 83% of Windows machines surveyed by that site, so you'd still need to find an alternative to add to the font list, before the final, default "cursive."
                                    There's some more good Web typography info at Web Space Works (six linked pages, including one that gets you the Vista C fonts for free - yes, legally) and ampsoft Web Design Tips & Tricks
                                    • 16. Re: Can i view code in Fireworks CS3?
                                      Level 7
                                      I really like the Vista C fonts....
                                      "pixlor" <webforumsuser@macromedia.com> wrote in message
                                      news:g53vjf$qbf$1@forums.macromedia.com...
                                      > According to the
                                      > http://www.codestyle.org/css/font-family/, Apple Chancery is installed on
                                      > Monotype
                                      > Corsiva.
                                      > http://www.codestyle.org/servlets/FontSampler?image=mac-AppleChancery&class=Appl
                                      > eChancery&font=Apple%20Chancery
                                      > http://www.codestyle.org/servlets/FontSampler?image=win-MonotypeCorsiva&class=Mo
                                      > notypeCorsiva&font=Monotype%20Corsiva
                                      > machines
                                      > to the
                                      > http://www.webspaceworks.com/resources/fonts-web-typography/74/ (six
                                      > linked
                                      > legally)
                                      > and http://www.ampsoft.net/webdesign-l/WindowsMacFonts.html
