1 2 Previous Next 42 Replies Latest reply on Feb 9, 2018 9:18 AM by jeromiec83223024
    Flash Background Updates from internal server not working
    matts54643606
      We are setting up to receive flash background updates from an internal server for our 5000+ enterprise pcs running windows 7 64bit and Windows 10
      Current mms.cfg
      AutoUpdateDisable=0
      SilentAutoUpdateEnable=1
      SilentAutoUpdateServerDomain=SVRTSTR2
      SilentAutoUpdateVerboseLogging=1
      Note- the server is running server 2016, with IIS, and the website is set up with an SSL certificate and the cab files were extracted to the site with the correct folder structure
      Here is the log:
      2018-1-3+3-4-0.217 [info] 1629 SVRTSTR2
      2018-1-3+3-4-0.220 [info] 1614
      2018-1-3+3-4-0.222 [info] 1615
      2018-1-3+3-4-0.224 [info] 1618
      2018-1-3+3-4-0.226 [info] 1604
      2018-1-3+3-4-0.226 [info] 1608
      2018-1-3+3-4-0.227 [info] 1612
      2018-1-3+3-4-0.232 [info] 1620
      2018-1-3+4-4-0.198 [info] 1629 SVRTSTR2
      2018-1-3+4-4-0.199 [info] 1614
      2018-1-3+4-4-0.201 [info] 1615
      2018-1-3+4-4-0.204 [info] 1618
      2018-1-3+4-4-0.207 [info] 1619 1063
      2018-1-3+4-4-0.228 [info] 1629 SVRTSTR2
      2018-1-3+4-4-0.232 [info] 1614
      2018-1-3+4-4-0.234 [info] 1615
      2018-1-3+4-4-0.236 [info] 1618
      2018-1-3+4-4-0.238 [info] 1604
      2018-1-3+4-4-0.238 [info] 1608
      2018-1-3+4-4-0.238 [info] 1612
      2018-1-3+4-4-0.239 [info] 1620
      2018-1-3+5-4-0.181 [info] 1629 SVRTSTR2
      2018-1-3+5-4-0.181 [info] 1614
      2018-1-3+5-4-0.184 [info] 1615
      2018-1-3+5-4-0.186 [info] 1618
      2018-1-3+5-4-0.190 [info] 1619 1063
      2018-1-3+5-4-0.212 [info] 1629 SVRTSTR2
      2018-1-3+5-4-0.215 [info] 1614
      2018-1-3+5-4-0.217 [info] 1615
      2018-1-3+5-4-0.219 [info] 1618
      2018-1-3+5-4-0.220 [info] 1604
      2018-1-3+5-4-0.220 [info] 1608
      2018-1-3+5-4-0.228 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
      2018-1-3+5-4-0.320 [warning] 1470 12175
      2018-1-3+5-4-0.321 [warning] 1474 183
      2018-1-3+5-4-0.321 [warning] 1475
      2018-1-3+5-4-0.322 [info] 1432
      2018-1-3+5-4-0.322 [info] 1612
      2018-1-3+5-4-0.323 [info] 1620
      2018-1-3+6-4-0.259 [info] 1629 SVRTSTR2
      2018-1-3+6-4-0.260 [info] 1614
      2018-1-3+6-4-0.263 [info] 1615
      2018-1-3+6-4-0.265 [info] 1618
      2018-1-3+6-4-0.268 [info] 1619 1063
      2018-1-3+6-4-0.295 [info] 1629 SVRTSTR2
      2018-1-3+6-4-0.297 [info] 1614
      2018-1-3+6-4-0.299 [info] 1615
      2018-1-3+6-4-0.301 [info] 1618
      2018-1-3+6-4-0.303 [info] 1608
      2018-1-3+6-4-0.303 [info] 1604
      2018-1-3+6-4-0.303 [info] 1612
      2018-1-3+6-4-0.304 [info] 1620
      2018-1-3+7-4-0.328 [info] 1629 SVRTSTR2
      2018-1-3+7-4-0.328 [info] 1614
      2018-1-3+7-4-0.331 [info] 1615
      2018-1-3+7-4-0.333 [info] 1618
      2018-1-3+7-4-0.335 [info] 1619 1063
      Please assist
      NOTE:
      -I have already tried deleting the reg key HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAU\LastUpdateCheck
      -I have imported the Cert to the Trusted Root Certification Authorities store (local computer) on the workstation
      I can view the files on a browser(firefox/chrome/IE11) from the workstation by entering https://svrtstr2/ --I get the IIS landing page, and can navigate the folder strucure all the way through without error
        • 1. Re: Flash Background Updates from internal server not working
          maria__ Adobe Employee
          Thank you for posting the log file with background update verbose logging enabled.  Very helpful.
          The request to the /pub/flashplayer/update/current/sau/currentmajor.xml is failing, due to Microsoft error code 12175.  From Error Messages (Windows) :
          ERROR_WINHTTP_SECURE_FAILURE
          12175
          One or more errors were found in the Secure Sockets Layer (SSL) certificate sent by the server. To determine what type of error was encountered, check for a WINHTTP_CALLBACK_STATUS_SECURE_FAILURE notification in a status callback function. For more information, see WINHTTP_STATUS_CALLBACK.
          A few things to check:
          • Ensure you have opened port 443 for HTTPS requests
          • Ensure the SSL certificate matches the domain you are attempting to use it on
          • In your mms.cfg file, is the local server configured as just SVRTSTR2, or is it in your.server.com format?  If not in your.server.com format, please change it to this format.
          • Attempt to access the currentmajor.xml file from a web browser.  It should be accessible.
          Note that Flash Player ActiveX will not install on Windows 10 as Microsoft integrates Flash Player ActiveX in IE and Edge browsers and all Flash Player ActiveX for IE/Edge are released by Microsoft via Windows Update.
          <EDIT>
          Not sure if I missed the screenshots, or if you posted them after.  According to the screenshots, the SSL cert is issued to flashupdates.kaplanic.com but this is not what you have in the mms.cfg file.
          <EDIT_2>
          The IE screenshot also shows a certificate error.  This is most likely the culprit. Please resolve the certificate error and try again.
          • 2. Re: Flash Background Updates from internal server not working
            matts54643606 Level 1
            Hello,
            I have a new cert with the correct domain:
            I deleted the reg key:
            I set the 443 bindings on the server:
            I'm still not getting updated:
            2018-1-12+14-29-18.383 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
            2018-1-12+14-29-18.476 [warning] 1470 12175
            2018-1-12+14-29-18.476 [warning] 1474 183
            2018-1-12+14-29-18.477 [warning] 1475
            2018-1-12+14-29-18.477 [info] 1432
            2018-1-12+14-29-18.479 [info] 1612
            2018-1-12+14-29-18.479 [info] 1620
            2018-1-12+14-51-55.75 [info] 1629 SVRTSTR2.charlie.kaplaninc.com
            2018-1-12+14-51-55.76 [info] 1614
            2018-1-12+14-51-55.78 [info] 1615
            2018-1-12+14-51-55.81 [info] 1618
            2018-1-12+14-51-55.84 [info] 1619 1063
            2018-1-12+14-51-55.111 [info] 1629 SVRTSTR2.charlie.kaplaninc.com
            2018-1-12+14-51-55.113 [info] 1614
            2018-1-12+14-51-55.115 [info] 1615
            2018-1-12+14-51-55.117 [info] 1618
            2018-1-12+14-51-55.119 [info] 1604
            2018-1-12+14-51-55.119 [info] 1608
            2018-1-12+14-51-55.134 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
            2018-1-12+14-51-55.191 [warning] 1470 12175
            2018-1-12+14-51-55.191 [warning] 1474 183
            2018-1-12+14-51-55.192 [warning] 1475
            2018-1-12+14-51-55.192 [info] 1432
            2018-1-12+14-51-55.194 [info] 1612
            2018-1-12+14-51-55.195 [info] 1620
            • 3. Re: Flash Background Updates from internal server not working
              It's failing due to the same reason as before.
              Your most recent screenshot indicates the certificate is assigned to flashupdates.charlie.kaplaninc.com, but the log file has SVRTSTR2.charlie.kaplaninc.com  The server domain names are not the same.  Please use flashupdates.charlie.kaplaninc.com in the mms.cfg file instead of SVRTSTR2.charlie.kaplaninc.com.  If you need to use SVRTSTR2.charlie.kaplaninc.com, then you'll need to get a certificate with that name.
              • 4. Re: Flash Background Updates from internal server not working
                Hello,
                Thank you for your response. Am I to understand that the server name must match the certificate name?
                I thought just the domain names must match. I do not see anywhere in the documentation instructions that the server name and the certificate name must match?
                I have a server with computername: SVRTSTR2
                it is on the Domain: Charlie.Kaplaninc.com
                Are you saying that I must name the certificate: SVRTSTR2.charlie.kaplaninc.com
                Or, alternatively, could I rename the computername of the server : flashupdates
                • 5. Re: Flash Background Updates from internal server not working
                  Yes they must match.
                  Which ever one will work for you.
                  I'll ensure the Admin Guide is updated with this information.
                  • 6. Re: Flash Background Updates from internal server not working
                    Hello,
                    I renamed the server--still no joy
                    2018-1-15+19-57-47.953 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+19-57-47.956 [info] 1614
                    2018-1-15+19-57-47.958 [info] 1615
                    2018-1-15+19-57-47.960 [info] 1618
                    2018-1-15+19-57-47.962 [info] 1604
                    2018-1-15+19-57-47.963 [info] 1608
                    2018-1-15+19-57-47.976 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                    2018-1-15+19-57-48.276 [warning] 1474 12044
                    2018-1-15+19-57-48.280 [warning] 1475
                    2018-1-15+19-57-48.283 [info] 1432
                    2018-1-15+19-57-48.288 [info] 1612
                    2018-1-15+19-57-48.289 [info] 1620
                    2018-1-15+20-4-0.339 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-4-0.340 [info] 1614
                    2018-1-15+20-4-0.343 [info] 1615
                    2018-1-15+20-4-0.345 [info] 1618
                    2018-1-15+20-4-0.348 [info] 1619 1063
                    2018-1-15+20-4-0.378 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-4-0.380 [info] 1614
                    2018-1-15+20-4-0.383 [info] 1615
                    2018-1-15+20-4-0.385 [info] 1618
                    2018-1-15+20-4-0.386 [info] 1604
                    2018-1-15+20-4-0.386 [info] 1608
                    2018-1-15+20-4-0.395 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                    2018-1-15+20-4-5.696 [info] 1622 4
                    2018-1-15+20-4-5.703 [info] 1622 4
                    2018-1-15+20-4-21.395 [warning] 1470 12002
                    2018-1-15+20-4-21.395 [warning] 1474 183
                    2018-1-15+20-4-21.399 [warning] 1475
                    2018-1-15+20-4-21.403 [info] 1432
                    2018-1-15+20-4-21.408 [info] 1612
                    2018-1-15+20-4-21.409 [info] 1620
                    2018-1-15+20-5-53.494 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-5-53.494 [info] 1614
                    2018-1-15+20-5-53.497 [info] 1615
                    2018-1-15+20-5-53.500 [info] 1618
                    2018-1-15+20-5-53.503 [info] 1619 1063
                    2018-1-15+20-5-53.519 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-5-53.523 [info] 1614
                    2018-1-15+20-5-53.529 [info] 1615
                    2018-1-15+20-5-53.531 [info] 1618
                    2018-1-15+20-5-53.536 [info] 1604
                    2018-1-15+20-5-53.536 [info] 1608
                    2018-1-15+20-5-53.537 [info] 1612
                    2018-1-15+20-5-53.550 [info] 1620
                    2018-1-15+20-6-10.534 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-6-10.534 [info] 1614
                    2018-1-15+20-6-10.537 [info] 1615
                    2018-1-15+20-6-10.539 [info] 1618
                    2018-1-15+20-6-10.541 [info] 1619 1063
                    2018-1-15+20-6-10.574 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-6-10.574 [info] 1614
                    2018-1-15+20-6-10.577 [info] 1615
                    2018-1-15+20-6-10.580 [info] 1618
                    2018-1-15+20-6-10.583 [info] 1604
                    2018-1-15+20-6-10.583 [info] 1608
                    2018-1-15+20-6-10.599 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                    2018-1-15+20-6-10.789 [warning] 1474 12044
                    2018-1-15+20-6-10.795 [warning] 1475
                    2018-1-15+20-6-10.799 [info] 1432
                    2018-1-15+20-6-10.802 [info] 1612
                    2018-1-15+20-6-10.803 [info] 1620
                    2018-1-15+20-9-45.175 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-9-45.175 [info] 1614
                    2018-1-15+20-9-45.178 [info] 1615
                    2018-1-15+20-9-45.180 [info] 1618
                    2018-1-15+20-9-45.183 [info] 1619 1063
                    2018-1-15+20-9-45.221 [info] 1629 flashupdates.charlie.kaplaninc.com
                    2018-1-15+20-9-45.224 [info] 1614
                    2018-1-15+20-9-45.226 [info] 1615
                    2018-1-15+20-9-45.233 [info] 1618
                    2018-1-15+20-9-45.235 [info] 1604
                    2018-1-15+20-9-45.236 [info] 1608
                    2018-1-15+20-9-45.251 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                    2018-1-15+20-9-45.349 [warning] 1474 12044
                    2018-1-15+20-9-45.349 [warning] 1475
                    2018-1-15+20-9-45.350 [info] 1432
                    2018-1-15+20-9-45.351 [info] 1612
                    2018-1-15+20-9-45.352 [info] 1620
                    I get this if I try to go to the pub folder:
                    • 7. Re: Flash Background Updates from internal server not working
                      Robert Mc Dowell Level 3
                      did you try to reboot everything? just a silly but sometimes useful option
                      • 8. Re: Flash Background Updates from internal server not working
                        So, it sounds like the certificate issue has been resolved, but now you have a file system permissions issue.  The entire directory path to the files, and the files themselves, need to be accessible.  As per the screenshot you currently don't have access to the required directory path.  You need to troubleshoot the file system permissions issue on your server and fix that.
                        • 9. Re: Flash Background Updates from internal server not working
                          Interesting...because if you notice my screenshot in my original post- I did have access to the full path from the browser....
                          • 10. Re: Flash Background Updates from internal server not working
                            The first screenshot was for a different server, https://svrtstr2/pub/flashplayer/update/current/sau .
                            The most recent screenshots shows 'error 403 - access denied' when attempting to access https://flashupdates.charlie.kaplaninc.com/pub , which is the server name in the mms.cfg file, as indicated by the log file.
                            • 11. Re: Flash Background Updates from internal server not working
                              same server- just that I renamed it per instruction
                              • 12. Re: Flash Background Updates from internal server not working
                                The physical server is the same, but now the name is different.  Something in your configuration setting is now resulting in the error.  Are you able to access the XML file itself?
                                Do you have directory browsing enabled on the server?  disabled directory browsing does result in the 403 error when attempting to view the directory contents.
                                • 14. Re: Flash Background Updates from internal server not working
                                  directory browsing enabled on the server---please provide instructions to get this working--I have done all the required steps and have never gotten it to work
                                  • 15. Re: Flash Background Updates from internal server not working
                                    I can't provide instructions on how to troubleshoot your server configuration.  You'll need to do that.  The issues you are encountering are not at all related to Background Updates, they are related to the server configuration.
                                    After checking which server to use (local or Adobe), Background Update process checks the mms.cfg file to see if the client is opted into Background Updates, if it is, it then checks the currentmajor.xml file to see if there is an update available.  The request tom and/or response from, the currentmajor.xml file is failing due to server configuration issues.  There are 2 numbers in the log file, after the info/warning column.  The first number is the Background Update code.  The second number is the corresponding Windows Error code.
                                    Pertinent Background Update codes in the log file are:
                                    • 1631 = Create an HTTP request handle for currentmajor.xml
                                    • 1470 = WinHttpSendRequest call to currentmajor.xml failed
                                    • 1474 = WinHttpReceiveResponse call to currentmajor.xml failed
                                    • 1475 = Could not retrieve currentmajor.xml
                                    Looking through the log file, there are various Windows Error codes associated with codes 1470 and 1474.  The Windows error codes are available at WinHttpReceiveResponse function (Windows) .  Here is a summary of the Windows Error codes I'm seeing in the most recent log file you posted:
                                    ERROR_WINHTTP_TIMEOUT
                                    12002
                                    The request has timed out.
                                    ERROR_WINHTTP_CLIENT_AUTH_CERT_NEEDED
                                    12044
                                    Returned by WinHttpReceiveResponse when the server requests client authentication.
                                    Windows Server 2003 with SP1 and Windows XP with SP2:  This error is not supported.
                                    12175
                                    The request timing out is that it took too long to get a response.  This could be network related (firewall, proxy server, something else).
                                    This MSDN article may be of assistance SSL in WinHTTP (Windows)
                                    • 16. Re: Flash Background Updates from internal server not working
                                      I can access the directory structure now:
                                      but here is the log from running FlashPlayerUpdateService.exe
                                      018-1-17+18-1-47.883 [info] 1629 flashupdates.charlie.kaplaninc.com
                                      2018-1-17+18-1-47.885 [info] 1614
                                      2018-1-17+18-1-47.886 [info] 1615
                                      2018-1-17+18-1-47.886 [info] 1618
                                      2018-1-17+18-1-47.887 [info] 1619 1063
                                      2018-1-17+18-1-47.903 [info] 1629 flashupdates.charlie.kaplaninc.com
                                      2018-1-17+18-1-47.905 [info] 1614
                                      2018-1-17+18-1-47.906 [info] 1615
                                      2018-1-17+18-1-47.908 [info] 1618
                                      2018-1-17+18-1-47.910 [info] 1604
                                      2018-1-17+18-1-47.910 [info] 1608
                                      2018-1-17+18-1-47.931 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
                                      2018-1-17+18-1-48.5 [warning] 1474 12044
                                      2018-1-17+18-1-48.6 [warning] 1475
                                      2018-1-17+18-1-48.6 [info] 1432
                                      2018-1-17+18-1-48.7 [info] 1612
                                      2018-1-17+18-1-48.8 [info] 1620
                                      • 17. Re: Flash Background Updates from internal server not working
                                        It's still failing due to Error 12044:
                                        12044
                                        What happens when you navigate directly to the https://flashupdates.charlie.kaplaninc.com/pub/flashplayer/update/current/sau/currentmajor.xml using a web browser?  Does it display a security warning before loading the page contents?  Please describe the exact behaviour you observe when navigating directly to the page.
                                        • 18. Re: Flash Background Updates from internal server not working
                                          Goes straight to it:
                                          If I click the lock:
                                          • 19. Re: Flash Background Updates from internal server not working
                                            Are you using a self-signed certificate or a certificate from a trusted certificate authority, such as DigiCert?
                                            If so, have you installed the certificate to the root certificate store on the client system?  It's not clear to me if all of your screenshots are from the same system (the server) or from a server and client, and would like to confirm how your test environment is set up.
                                            • 20. Re: Flash Background Updates from internal server not working
                                              I'm using a self signed certificate build in house by our infosec team.
                                              I install the certificate to the trusted Root Certification Authorities store on the client computer
                                              The screenshots are from the client
                                              exept for the screenshots showing IIS- those are from the server:
                                              • 21. Re: Flash Background Updates from internal server not working
                                                I would recommend using a cert signed by a trusted certificate authority.  The error is coming from a Windows API (WinHTTPReceiveResponse, referring to client authentication), not Flash Player code.  See links I posted previously to Microsoft documentation.
                                                • 22. Re: Flash Background Updates from internal server not working
                                                  Can you please provide a certificate?
                                                  • 23. Re: Flash Background Updates from internal server not working
                                                    No, Adobe is not a certificate authority and cannot provide that.  There are numerous certificate authorities (e.g. DigiCert) you can use.
                                                    • 24. Re: Flash Background Updates from internal server not working
                                                      OK- so for clarification- you are saying that this internal server solution for distributing adobe flash updates only works if the customer buys a certificate from a third party certificate authority? It will not work with a self signed certificate?
                                                      • 25. Re: Flash Background Updates from internal server not working
                                                        The Background Update service uses the WinHTTP API.  Based on the API documentation, self-signed certs should work, but it's not working in your environment as it keeps returning error 12044 (server requesting client authentication).  You can continue to troubleshoot the error and attempt to resolve it.  As an alternative you can try using a cert from trusted third party certificate authority.  Assuming everything is configured correctly, it should work.
                                                        • 26. Re: Flash Background Updates from internal server not working
                                                          jeromiec83223024 Adobe Employee
                                                          If you're self-signing certificates, every client connecting to that SSL server needs to have your self-issued public CA certificate installed and trusted in their system keychain.  It's not enough to just self-sign a cert and put it on the server.  Something in that key's trust chain has to already be trusted by the local system.  Otherwise, it's just like a stranger walking up and saying "Oh hey, give me your car keys for a minute.  It's cool though.  I'm trustworthy, because I have this piece of paper I printed at home that says I'm cool, and I'm totally not going to steal your car."
                                                          The thing that you're paying for when you buy a certificate, is for a trusted, independent authority say that you're cool.  Depending on the type of certificate they issue, there are varying levels of trust expressed in that relationship.  The reason that you don't have to install anything in the client in that instance, is because their public keys are already built into the operating system.  They're established, trusted authorities that the operating system vendor recognizes as such, and so the vendor distributes their keys as part of the OS (and updates them periodically through OS updates).
                                                          That said, you don't even need to pay for an SSL certificate if cost is an issue.  You can get a free one at letsencrypt.org.  It's so much better than messing around with self-signed stuff.
                                                          • 27. Re: Flash Background Updates from internal server not working
                                                            Hello! Thanks for the good advise. I did try to use the letsEncrypt certificate- but ran into this problem:
                                                            I think maybe the issue is that the website is not accessible publicly--it's only accessible within our closed corp network.....
                                                            any ideas?
                                                            • 28. Re: Flash Background Updates from internal server not working
                                                              I found this answer:
                                                              # re: Using Let's Encrypt with IIS on Windows
                                                              @Vicky - Lets Encrypt uses domain validation which means the domain has to be visible to the public to verify ownership. Basically you have to run LE on a server that responds to that domain.
                                                              So you can't use it unless you expose your IP to the Internet. Perhaps you can do it temporarily to get the certificate and then close if off again, but then Updates also won't work (unless you open it up again).
                                                              https://weblog.west-wind.com/posts/2016/Feb/22/Using-Lets-Encrypt-with-IIS-on-Windows
                                                              so.......I guess I'm confused- whats the point of hosting the updates on a public internet server--- if that was the goal I could simply ask for the updates straight from adobe servers? I thought this was a solution for hosting the updates and serving them out in a closed - private- network?
                                                              • 29. Re: Flash Background Updates from internal server not working
        Lets Encrypt was just a suggestion because it was free, and you didn't want to pay for something.  I didn't realize that it had the public requirement.  Sorry about leading you down a dead end.
        There are definitely commercial CA services that will work behind an Intranet (Verisign Intranet Certs come to mind).  You should also be able to use a self-signed SSL cert, as long as you want to deploy your signed CA cert to your clients as a prerequisite.  That seems like way more work than is worth it compared to just buying an SSL Certificate, but it's not my budget.
        • 30. Re: Flash Background Updates from internal server not working
        Thanks for the info---I'm wondering why my original signed cert is not working- I imported it into the trusted store on the client....anyways- I guess I'll just have to ask for a paid SSL and try it that way.
        • 31. Re: Flash Background Updates from internal server not working
        The quick sanity check is to just see if your browser will show the lock icon when you go to the offending URL:
        If it does, and the browser throws up the contents of the xml file (you may have to view source), then we should really be loading it too.  If you have the TLS configuration really tight, like you're only allowing a small subset of protocols and ciphers, it would be interesting to know what those are.  I'd be interested in trying to replicate it.
        In Flash Player proper, we're usually delegating all of that to the browser, but in the auto-updater, we may be missing support for a particular TLS feature or something that you're using.  I can't think of a lot of other good reasons for why it would be failing only in our installation toolchain.
        If you go to the URL and the browser throws an error, then you probably have a problem that needs to be fixed.  The browser might also give you some more useful feedback about what's failing (e.g. whether it's your webserver configuration or your certificates).  Check the detailed errors, and/or the console and/or seceurity tab in the developer tools. They usually have pretty explicit errors.
        For what it's worth, self-signing is obnoxiously complicated.  I've been playing with this stuff since the late '90s, and I do it just infrequently enough to not remember exactly how I did it the last time.  My workflow usually involves a lot of cussing and reading the OpenSSL docs while I'm regenerating the appropriate keys for the third time.
        • 32. Re: Flash Background Updates from internal server not working
        Maria clued me into what's going on.  I didn't catch it when I skimmed the thread, sorry.
        The error being returned is from WinHTTP:
        You can configure a webserver to require a certificate for client authentication.  (e.g. instead of having the client log in via username/password to get to a page, they provide a certificate that you issue, and that they install).
        It sounds like you have client certificate authentication enabled in your IIS configuration, and you don't want to do that.
        In step 3 here, set it to Ignore or Allow, not Require:
        https://blogs.msdn.microsoft.com/asiatech/2014/02/12/how-to-configure-iis-client-certifica te-mapping-authentication-for-iis7/
        • 33. Re: Flash Background Updates from internal server not working
        Here is a screen of the settings as they were
        Also- I can pull up the xml in the browser with no error message:
        and here is some other info:
        • 34. Re: Flash Background Updates from internal server not working
        Here is the latest from the log---any ideas?
        Also-I'll note that the cert I have is a .pfx file
        2018-1-31+11-30-1.15 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+11-30-1.15 [info] 1614
        2018-1-31+11-30-1.15 [info] 1615
        2018-1-31+11-30-1.30 [info] 1618
        2018-1-31+11-30-1.30 [info] 1604
        2018-1-31+11-30-1.30 [info] 1608
        2018-1-31+11-30-1.30 [info] 1612
        2018-1-31+11-30-1.30 [info] 1620
        2018-1-31+12-30-0.904 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+12-30-0.936 [info] 1614
        2018-1-31+12-30-0.951 [info] 1615
        2018-1-31+12-30-0.967 [info] 1618
        2018-1-31+12-30-0.982 [info] 1619 1063
        2018-1-31+12-30-1.14 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+12-30-1.14 [info] 1614
        2018-1-31+12-30-1.14 [info] 1615
        2018-1-31+12-30-1.29 [info] 1618
        2018-1-31+12-30-1.29 [info] 1604
        2018-1-31+12-30-1.29 [info] 1608
        2018-1-31+12-30-1.29 [info] 1612
        2018-1-31+12-30-1.29 [info] 1620
        2018-1-31+13-30-0.903 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+13-30-0.935 [info] 1614
        2018-1-31+13-30-0.950 [info] 1615
        2018-1-31+13-30-0.966 [info] 1618
        2018-1-31+13-30-0.982 [info] 1619 1063
        2018-1-31+13-30-1.13 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+13-30-1.13 [info] 1614
        2018-1-31+13-30-1.13 [info] 1615
        2018-1-31+13-30-1.13 [info] 1618
        2018-1-31+13-30-1.13 [info] 1604
        2018-1-31+13-30-1.13 [info] 1608
        2018-1-31+13-30-1.13 [info] 1612
        2018-1-31+13-30-1.13 [info] 1620
        2018-1-31+14-30-0.911 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+14-30-0.942 [info] 1614
        2018-1-31+14-30-0.958 [info] 1615
        2018-1-31+14-30-0.974 [info] 1618
        2018-1-31+14-30-0.989 [info] 1619 1063
        2018-1-31+14-30-1.20 [info] 1629 flashupdates.charlie.kaplaninc.com
        2018-1-31+14-30-1.20 [info] 1614
        2018-1-31+14-30-1.20 [info] 1615
        2018-1-31+14-30-1.36 [info] 1618
        2018-1-31+14-30-1.36 [info] 1604
        2018-1-31+14-30-1.36 [info] 1608
        2018-1-31+14-30-1.36 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
        2018-1-31+14-30-1.255 [warning] 1474 12044
        2018-1-31+14-30-1.255 [warning] 1475
        2018-1-31+14-30-1.270 [info] 1432
        2018-1-31+14-30-1.270 [info] 1612
        2018-1-31+14-30-1.270 [info] 1620
        • 35. Re: Flash Background Updates from internal server not working
        From your logs:
        12044 is Microsoft’s ‘ERROR_WINHTTP_CLIENT_AUTH_CERT_NEEDED’ code
        Your IIS server is requiring a client certificate for the file at /pub/flashplayer/update/current/sau/currentmajor.xml.  Those SSL Settings can be applied at the directory level, so you might not be requiring a client cert at the site level, but my guess is that it gets enabled somewhere along this path.  I'd just walk down each directory and check the SSL settings on each.
        • 36. Re: Flash Background Updates from internal server not working
        They were all set to Accept-- except for the top Default website- which was set to Ignore- I changed it to Accept
        I cant help thinking its something in IIS?
        From a client machine I can browse to the xml file- if I click the lock icon I get this:
        • 37. Re: Flash Background Updates from internal server not working
        could it be something in my network blocking it? I have installed wireshark and can run a capture - would that be helpful?
        • 38. Re: Flash Background Updates from internal server not working
        I don't know enough about your environment.  It's a Windows API throwing the SSL handshake error about the missing client SSL certificate.  I tend to believe that we're getting the request for that client certificate, especially since it's the underlying Windows API that's throwing the error about it.
        If you guys proxy all of your browser traffic through a security appliance or something, that might explain it.
        You might get a sense of it from looking at Wireshark, e.g. is the response to the HTTPS request actually coming from the IP that you expect.  Is it coming from the same IP when you hit it in the browser vs. when you hit it with the installer, etc.
        1 2 Previous Next
