First,I would like to introduce myself.I am a front-end web developer from Taiwan.My English is not really good,so if you can't understand what I said,tell me the detail to let me know what words let you understand.
I started Adobe Animate cc just for few days.I think I can use it to learn html5.
My question is "How do I use my code to call the export file(html5) to control the animate?"
It means,when I finished the animation.I want to add this animation to my website(I watched this video Adobe Animate CC: Add to HTML web page (Updated Version) - YouTube to know how to merge my codes).
Now,I would like to use a plugin,such like Scroll Magic to control the animation's frame(you can see this example[ Image Sequence - Examples - ScrollMagic ] to know how the scroll magic control a parameter to his purpose) .I want to control the export file to control the animation's timeline with my other funtion is my codes,such like controling the animation to stop.when I scroll 100 pixel.
I have no idea to do this.because I can't call the inner code's frame.
I tested a idea that is using my code to control the animation.When the animation begin after 1 second,it stoped in the frame 7.This is not use Adobe Animate Inner code.It is use my js to control.
this is the way I had tride:
In Adobe Animate CC.I declared a global function which is
globalFunc= function(stopFrame){};
and then add a scirpt in a timeline's frame,it's code is:
var _this=this;
globalFunc=function(stopFrame)
_this.gotoAndStop(stopFrame);
And then I export the files.change the htmls.add my js code:
var tmpTime = setTimeout(function()
globalFunc(7);
}, 1000);
It worked. the animation stopped in the frame 7 after one second.So,I could use this way to control the animation's parameter.But you know.It's not a good way.
and not my purpose.Because It stared after one second. I want it execute immediately.
So If I want to use this way. I must find out where the animation's first initial place to add "globalFunc(7);".
I am not familiar with CreateJS.So I tried a lot of ways,I still could not find out.
But it is not the best way to control the animation's parameter.If you have a better idea,tell me,thanks.
Finally I found the answer from canvas - How to communicate 'externally' between Adobe Animate CC animations? - Stack Overflow
Just use
exportRoot.gotoAndStop(7);
But I just have a problem here.
If the animation only has one time line .It works immediately.(just add the code after "fnStartAnimation();"))
but if you have a symbol object.We know if we want to stop it.we should stop the symbol object's timeline.not the root stage's time line.
So I use:
exportRoot.obj1.gotoAndStop(7);
"obj1" is the symbo
...Copy link to clipboard
Just use
So I use:
"obj1" is the symbol object's instance name.
It not works.
but I found,I used setTimer,let it called after one second,It worked.
well,I think I don't have to call it immediately.
Because if I want to use scroll magic to control the object's time line.It not needed to call it immediately.
but I am curious about this problem...
