5 Replies Latest reply on Jan 5, 2018 10:45 AM by kglad
    Remove allChilds created with a ticker
    Marampazú Level 1
      Hello again.
      I'm doing a kind of chronometer using a graph that is drawing lines from the same axis to form a circle.
      These lines are drawn with a ticker, with which the effect is as if it were filling the circle.
      This exercise is a kind of evaluation, where the user will have limited time to answer a question.
      At the moment it works, the chronometer is painted while the conditional I put my ticker lasts.
      When the user responds, I have to delete this element from the screen, not the buttons or graphics that the scenario has. If I use removeAllChildren (), in effect, it erases everything on the screen which does not help.
      If I put it removeChild (line) it does, however it only deletes the last drawn line. That's why I ask for your help, I do not know how I can erase from the screen the traced lines (which in this case are 360) to launch another question and start again.
      I enclose the code used, the same and can serve someone with a similar exercise.
      root = this;
      var miTicker = createjs.Ticker.on ("tick", rotateDraw);
      var color = "# 0fe";
      var increment = 0;
      function rotateDraw () {
      //Process to draw line: Create, origin, properties, increase to paint in another position, turn, paint in stage, define index
      line = new createjs.Shape ();
      line.x = line.y = 150;
      linea.graphics.beginStroke (color)
      .setStrokeStyle (10, "round")
      .moveTo (0, 0)
      .lineTo (0, -145)
      root.addChild (line);
      root.setChildIndex (line, 0);
      // Increment to turn
      increment = increment + .5;
      // Turn for the line
      linea.rotation = increment;
      if (increment == 360) {
      createjs.Ticker.off ("tick", miTicker);
      Thanks as always.
        • 1. Re: Remove allChilds created with a ticker
          instead of use root=this, use a movieclip to add your lines to.  then you can just remove the movieclip with you want to remove the lines.
          p.s. you have some errors in your code. the first i see is linea is undefined
          • 2. Re: Remove allChilds created with a ticker
            Marampazú Level 1
            I put all the code with google translate, I did not realize the error in the translation.
            I put the correct code again.
            line.graphics.beginStroke (color)
            .moveTo (0, 0)
            .lineTo (0, -145)
            line.rotation = increment;
            Thanks for the help, however I do not know exactly how to generate that movieclip you mention. Is it to generate a movieclip on the stage and inside it to put the code that I wrote and only make the movie invisible? Or is it to generate this movieclip dynamically and likewise remove it from the screen?
            Again, thank you very much.
            • 3. Re: Remove allChilds created with a ticker
              either way.  with code:
              root = this;
              var mc = new createjs.MovieClip();
              root.addChild(mc);
              var miTicker = createjs.Ticker.on("tick", rotateDraw);
              var increment = 0;
              function rotateDraw() {
              line = new createjs.Shape();
              line.graphics.beginStroke(color).setStrokeStyle(10, "round").moveTo(0, 0).lineTo(0, -145)
              mc.addChild(line);
              mc.setChildIndex(line, 0);
              createjs.Ticker.off("tick", miTicker);
              // call this when you want to remove the lines
              function removeLinesF(){
              root.removeChild(mc);
              • 4. Re: Remove allChilds created with a ticker
                Marampazú Level 1
                It works!
                Thanks a lot!
                • 5. Re: Remove allChilds created with a ticker
                  you're welcome.
