• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
weird empty space on the right in mobile breakpoint
Engaged ,
Jan 06, 2018 Jan 06, 2018
I am getting a weird empty space on the right in my mobile breakpoint and it's ruining the entire "full width" design of the website. that dead space is not there in my desktop breakpoint, only in mobile. also, when the page first loads on my iphone is looks great (no white space on the right) but then if I scroll i can see that it's there. I've checked all the padding and page properties but couldn't figure it out. Can someone please help?
Views
811
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 06, 2018 Jan 06, 2018
Normally this issue is caused by elements, which overlap or are positioned outside the defined breakpoint width.
You definitely have to avoid, that elements overlap or are positioned outside your defined page/breakpoint width.
If there are such elements, browser normally shift horizontally of zoom in to make all elements visible.
To control this,
  • zoom out considerably, perform a „Select all“ (Cmd+A) and see, if there are such elements. Do this in every breakpoint on every page, including your maste
Votes
Translate
Translate
LEGEND ,
To control this,
  • zoom out considerably, perform a „Select all“ (Cmd+A) and see, if there are such elements. Do this in every breakpoint on every page, including your master page.
  • set guidelines and frame borders visible and drag the scrubber (this grey, vertical handle top right of the breakpoint bar) slowly inwards to verify, if there are elements bleeding outside the breakpoint/page width like in this example:
If you find something like that, correct it, by setting the elements to fluid width, making them smaller in width or correct pinning.
If none of these hints helps, delete all 3rd party widgets one by one and see, if the issue remains.
If this doesn’t help too, share a small(!!!) .muse file with only one page and some elements with us, to have a look at. Please follow these instructions: https://forums.adobe.com/docs/DOC-8652
Votes
Translate
Translate
Report
Report
Engaged ,
Jan 09, 2018 Jan 09, 2018
Thanks Gunter! That helped. It was my mobile menu that was causing that. It wasn't outside the breakpoint width but the frame was bigger than the menu button so when I made it smaller that fixed the problem.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Fine!
Votes
Translate
Translate
Report
Report
