14 Replies Latest reply on Aug 10, 2018 8:11 AM by ChicagRoe
    Glitch when trying to use a custom LUT .cube
    HelloBenNugent
      I am trying to export couple of color grade edit (a curves color edit,  color balance, and second curves adjustment--3 adjustment layers total) into a .cube LUT file to use on future photos.
      When I export it, and then try to use it, I end up getting this effect:
      I have successfully exported 1 test LUT, that actually works, but every other time I try to export a custom setting into a .cube file, I get the effect above.  I have no idea what the difference was in settings I used to get the working file.
      Any help would be appreciated as I have a fairly complicated color grading job coming up and I need to use this feature to keep things consistent.
      Thank you!
