I have had this problem since downloading Premiere Pro CC 2018 recently.
I can import any clip from my files (mostly .mp4 and .mov files) and I match up settings with the project and sequence but when I try to play the video in the program, it is incredibly choppy/laggy or it just freezes. However, the audio plays fine.
I don't think this is a problem with storage or disk speed as I have plenty of RAM and the latest gpu for my laptop (Windows 8 PC).
I have tried looking at many other forums from people with similar issues, but nothing seems to work for me.
I've tried making proxies/changing the file type/rendering the video etc. but no significant changes on the playback.
Here are the properties on the file I'm trying to edit:
Type: MPEG Movie
File Size: 179.47 MB
Image Size: 1280 x 720
Frame Rate: 30.00
Source Audio Format: 48000 Hz - compressed - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:04:02:10
Pixel Aspect Ratio: 1.0
VR Projection: None
Computer specs:
Processor: Intel(R) Core(TM) i5-4200 CPU @ 1.60GHz 2.30 GHz
Installed memory (RAM): 6.00 GB (5.78 GB usable)
System type: 64-bit Operating System, x-64-based processor
Any input helps, thanks.
Computer specs:
You don't' have enough RAM. It doesn't even meet the minimum requirements:
Adobe Premiere Pro System Requirements
Also, your processor is not at all adequate for Premiere Pro.
That is why Jim i
...Copy link to clipboard
The details matter. Create Cineform proxies.
Computer specs:
That is why Jim is recommending the use of proxies.
Having same problem with timeline playback and scrubbing..
4k DJI Phantom 4Pro Video.
H.264
My Spec
UserBenchmarks: Game 93%, Desk 71%, Work 74%
CPU: AMD Ryzen 7 2700X - 99.8%
GPU: Nvidia GTX 1070 - 100%
SSD: Kingston SA1000M8240G 240GB - 158.1%
HDD: WD WD5000AZLX-00K4KA0 500GB - 99%
HDD: WD RE4 500GB (2010) - 61.5%
RAM: Unknown IM48GU88N24-FFFHMB 1x8GB - 49.4%
MBD: Gigabyte X470 AORUS ULTRA GAMING
New build, Freshly install OS and software.
Please help. I am at lost......
H.264
You want at ;east 32 GB Ram for that.
Even then, you may need to use proxies.
Still need to use proxy if upgrade to 32Gb? Why is that, may i know?
My Processor? Gpu? or there is no way to edit 4k without proxy?
Your HDDs wil likely be a bottleneck.
In Premiere Pro? No. Create Cineform proxies for all H.264 media.
