8 Replies Latest reply on Jan 11, 2009 12:07 PM by kjsperl
    Unable to create source...
    kjsperl
      I get this message when attempting to embed an SWF file into FLEX as follows:
      [Embed (source='assets/advertdemoleft.swf')]
      private var adl:Class;
      the swf is built with Interactive Designer in Quark and exported as SWF.
      Help??
        • 1. Re: Unable to create source...
          Level 7
          "kjsperl" <webforumsuser@macromedia.com> wrote in message
          news:gkasmu$cb9$1@forums.macromedia.com...
          >follows:
          > Help??
          I think you forgot to include the message.
          • 2. Re: Unable to create source...
            kjsperl Level 1
            Why yes, I did. The message is:
            "unable to create source for <swf object name>"
            • 3. Re: Unable to create source...
              Level 7
              news:gkcss6$1je$1@forums.macromedia.com...
              Where in your post was that?
              Anyway, have you verified that the path is correct?
              • 4. Re: Unable to create source...
                kjsperl Level 1
                Sorry, Amy.
                When I wrote, Why, yes I did, I meant that I had forgotten to include the error. Sorry. Yes, I have verified that the path is correct.
                Anyway, here is more complete info:
                The SWF that I am using was created by Quark Interactive Designer:
                Here is the mxml file:
                <mx:Application
                xmlns:mx=" http://www.adobe.com/2006/mxml"
                xmlns:rs="com.rubenswieringa.book.*"
                layout="absolute"
                backgroundColor="#000000"
                viewSourceURL="source/index.html">
                <rs:Book x="25" y="25" width="800" height="400" openAt="1">
                <rs:Page><mx:Image source="@Embed('assets/advertdemoleft.swf')" /></rs:Page>
                <rs:Page><mx:Image source="@Embed('assets/advertdemoright.swf')" /></rs:Page>
                </rs:Book>
                </mx:Application>
                Here is the compiler errors:
                G:\Lakes_Region_Spirit\TheMagazine\MarketingDemo\FLEX_SimpleDemo>mxmlc simple.mxml
                Loading configuration file C:\Program Files\FLEXSDK2.0\frameworks\flex-config.xml
                G:\Lakes_Region_Spirit\TheMagazine\MarketingDemo\FLEX_SimpleDemo\simple.mxml(13)
                : Error: Unable to create source simple__embed_mxml_assets_advertdemoleft_swf_184785095.
                <rs:Page><mx:Image source="@Embed('assets/advertdemoleft.swf')"/></rs:Page>
                G:\Lakes_Region_Spirit\TheMagazine\MarketingDemo\FLEX_SimpleDemo\simple.mxml(14)
                : Error: Unable to create source simple__embed_mxml_assets_advertdemoright_swf_1037795143.
                I apppreciate your responding and I hope you can help.
                • 5. Re: Unable to create source...
                  Level 7
                  news:gkd3fn$96f$1@forums.macromedia.com...
                  > Sorry, Amy.
                  > <mx:Application
                  > layout="absolute"
                  > /></rs:Page>
                  > /></rs:Page>
                  > </rs:Book>
                  > </mx:Application>
                  > simple.mxml
                  > <rs:Page><mx:Image
                  > /></rs:Page>
                  If you try embedding a swf created in a more conventional tool, like Flash,
                  do you get the same error?
                  • 6. Re: Unable to create source...
                    kjsperl Level 1
                    I thought of that and modified the FLEX app to embed SWF not generated by Quark ID and it appears to work. I can use the Quark ID generated SWF in other ways outside of FLEX. I can double click the SWF file and it runs, I can embed it in HTML and it runs. It just does not appear to work via FLEX. Does that imply there are other resources, and paths, needed?
                    I just don't know.
                    • 7. Re: Unable to create source...
                      Level 7
                      news:gkd62b$c93$1@forums.macromedia.com...
                      > other
                      > embed
                      > that
                      > I just don't know.
                      I don't know much about what Quark does these days. Does seem like it's a
                      problem with the swf, though.
                      • 8. Re: Unable to create source...
                        kjsperl Level 1
                        I had a feeling that attempting to get Quark and Adobe to talk to each other was going to be a futile endeavor. Also gives both sides the opportunity to point the finger at the other side.
                        Am I the only person trying to use Quark SWF in the FLEX world?
                        I don't understand why the Quark SWF is not simply treated as a simple "black box" by Flex.
                        Thanks anyway, Amy, I appreciate your willingness to help.
