• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Help: A simple Text input and dynamic output (HTML5)
Community Beginner ,
Jan 09, 2018 Jan 09, 2018
Hey guys! I'm looking for codes to input text and output it on another frame. I'm not a coder but I tried and made it work on .fla format using this code:
Input:
var nameTXT:String;
nameTXT_button.addEventListener(MouseEvent.CLICK, nextClick);
function captureText(): void
{nameTXT=name_TXT.text
function nextClick(e:MouseEvent):
    void
        captureText(); nextFrame();
Output:
nameoutputTXT.text=nameTXT;
platform_button.addEventListener(MouseEvent.CLICK, platformClick);
function platformClick(e:MouseEvent):
    void
        nextFrame();
products_button.addEventListener(MouseEvent.CLICK, productClick);
function productClick(e:MouseEvent):
    void
        gotoAndStop(15);
And its working perfectly fine. But i require this same function on HTML framework. Can someone please write this short code for me? Again, I'm not at all a coder but open to learn more as i proceed. i have seen people doing it using java and other languages but it's all going over my head.
Views
705
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 09, 2018 Jan 09, 2018
Hi.
Notice that I had to put each text field inside of a Movie Clip because I was getting reference errors on the second frame. I'm not pretty sure why.
Frame 1:
var that = this;
this.nameTXT = 2;
    that.nameTXT = that.text1.name_TXT.text;
function nextClick(e)
    captureText();
    that.gotoAndStop(that.timeline.position + 1);
this.stop();
this.nameTXT_button.addEventListener("click", nextClick);
Frame 2:
var that = this;
function platformClick(e)
Votes
Translate
Translate
Community Expert ,
Hi.
Frame 1:
var that = this;
this.nameTXT = 2;
    captureText();
this.stop();
Frame 2:
var that = this;
function productClick(e)
    that.gotoAndStop(14); // Frame numbers in EaselJS start at 0 instead of 1
this.text2.nameoutputTXT.text = this.nameTXT;
this.platform_button.addEventListener("click", platformClick);
this.products_button.addEventListener("click", productClick);
Anyway, you could just extend your text field until the frame 15 (14) and you wouldn't have to worry about this text input and output thing.
Regards,
JC
Votes
Translate
Translate
Report
Report
Thanks for the code Cesar! That was really a good help, appreciate it! I can read and understand the flow it is making but unfortunately it doesn't work with the current frames i designed and moved ahead. these are the frame codes i have in the current flow.
Frame 1:
this.stop();
this.nameTXT_button.addEventListener("click", fl_ClickToGoToAndStopAtFrame_4.bind(this));
function fl_ClickToGoToAndStopAtFrame_4()
    this.gotoAndStop(1);
Frame 2:
this.stop();
this.products_btn.addEventListener("click", fl_ClickToGoToAndStopAtFrame.bind(this));
function fl_ClickToGoToAndStopAtFrame() {
    this.gotoAndPlay(2);
I know it may look like a joke but as i said, not a coder. Just going ahead on path i get lol. Do you think you can add a few text to these codes to make text field work?
Regards.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 10, 2018 Jan 10, 2018
Hi again!
I'm glad it helped you!
Here is:
Frame 1:
var that = this;
this.nameTXT = "";
    captureText();
this.stop();
Frame 2:
Once again, please notice it that I put each text field inside of Movie Clips, called "text1" and "text2".
Please don't hesitate to ask if you stil have any further question.
Regards,
JC
Votes
Translate
Translate
Report
Report
Jan 12, 2018 Jan 12, 2018
Hey JC! Thanks so much again for coding down completely for me. Unfortunately i'm not able to get the output as needed. I understood your code and seems perfect to me but still not happening.
This code in Frame 1:
is that 'name_TXT' on purpose or a typo? i can't figure out why '_' is between nameTXT element. If i keep it that way, i'm not able to go to frame 2. Although changing it back from 'name_TXT' to 'nameTXT' lets me get through but no output in the Frame 2. In Frame 2, i created a dynamic text box, named it as nameoutputTXT and made it a movie clip named text2 (similarly done in Frame 1 for Text Input field i.e. nameTXT and created it movie clip naming text1). Am i doing this the right way?
Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 13, 2018 Jan 13, 2018
LATEST
Hi again.
nameTXT is a variable to store the text field's text.
name_TXT is the text filed on the stage.
And these are the names that you assigned. I just followed. rs
Anyway, here is a working FLA to clariy your doubts: text_input_output.zip - Google Drive .
Votes
Translate
Translate
Report
Report
