1 Reply Latest reply on Jul 7, 2008 11:23 PM by SujitG
    Login Box
    wkolcz
      Can anyone tell me what to look at when I want to create a login box over an app and 'gray out' / disable the background components until the login. Thanks.
        • 1. Re: Login Box
          SujitG Level 2
          You can try using PopupManager and display a modal pop up. I created a very simple sample which will display a login box. When user enters valid credentials the login window is removed. Please check out the sample attached and see if that helps.
          You can also try using view states, detailed in the URL below, instead of displaying a pop up to the user.
          Hope this helps.
