I need to add more than one email address to to my 'Submit Form' button in Indesign. This is probably a code thing and can be done easily but I haven't a clue. Any ideas?
If you want to always use the same addresses you just need to specify them in the target URL of your submit button, using the correct syntax, like this:
mailto:me@server.com,you@server.com
If you want to use values from field, for example, then it would require using a script.
It's not something that can be done in InDesign.
Ask in the Acrobat PDF forum to see if it can be edited there or accomplished with JavaScript.
