3 Replies Latest reply on Jan 12, 2018 7:29 AM by Suicide
    Pen tool shapes: How to change the default fill and stroke settings?
    Suicide Level 1
      Every time I make a new layer to draw a new shape, the fill and stoke settings always revert to these really strange default colors (a red gradiated fill + a huge black and white stripey stroke). No matter how many times I change these settings, they always come back whenever I make a new layer.
      How can I change these defaults? (Ideally I want the default to be no fill and no stroke - so I can see what I'm drawing first, then add the color later.)
      Better still, is there any way to simply stop Photoshop from changing the settings when I make a new layer, and to just keep the settings I was already using before I made the new layer.
        • 1. Re: Pen tool shapes: How to change the default fill and stroke settings?
          c.pfaffenbichler Level 9
          You could set the Tool to »Path« instead of »Shape« and create the Shape Layer only after having edited the Path.
          With no Shape Layer selected and the Tool selected you should be able to change the Fill and Stroke.
          2 people found this helpful
          • 2. Re: Pen tool shapes: How to change the default fill and stroke settings?
            Ares Hovhannesyan Adobe Community Professional
            Try reseting preferences
            • Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (Mac OS) as you start Photoshop. You are prompted to delete the current settings. The new preferences files are created the next time you start Photoshop.
            • 3. Re: Pen tool shapes: How to change the default fill and stroke settings?
              Suicide Level 1
              Resetting prefs makes me nervous as I have all the prefs set up just the way I want it. I'm also not sure if it would affect my panel positions or keyboard shortcuts.
              Not a bad idea, but then I'd have to keep constantly switching between Path and Shape, and when I switched to Shape, I would have the same problem of having to fix the stroke and fill settings.
              Oh! To my total surprise, that worked! All I had to do was select a non-shape layer, open the pen tool, change the settings, and these settings become the new default!
              By the way, does anyone know why the formatting has been broken on the above quotes? It looked fine when I created the message.
