1. Re: How I can find the seamless pattern tile size?
JJMack Jan 10, 2018 9:06 PM (in response to nataliar61795563)1 person found this helpful -
2. Re: How I can find the seamless pattern tile size?
nataliar61795563 Jan 10, 2018 11:58 PM (in response to JJMack) -
3. Re: How I can find the seamless pattern tile size?
c.pfaffenbichler Jan 11, 2018 1:22 AM (in response to nataliar61795563)Would that not have to be (short side + long side) by (short side + long side)?
4. Re: How I can find the seamless pattern tile size?
nataliar61795563 Jan 11, 2018 2:01 AM (in response to c.pfaffenbichler)No, doest work either.
I also have tried several different options: for example long side*2 (3, 4, 5 etc.) by short side*2 (3, 4, 5 etc.). Also didn't work ( -
5. Re: How I can find the seamless pattern tile size?
c.pfaffenbichler Jan 11, 2018 2:07 AM (in response to nataliar61795563)Then you may want to start giving some relevant information:
Did you change the Scale from 1?
Did you set some Spacing?
What are the Pattern’s exact dimensions (as indicated by hovering over the Pattern like JJMack showed)?
Could you please post a screenshot taken at View > 100% of the result?
6. Re: How I can find the seamless pattern tile size?
c.pfaffenbichler Jan 11, 2018 2:12 AM (in response to nataliar61795563)I also have tried several different options: for example long side*2 (3, 4, 5 etc.) by short side*2 (3, 4, 5 etc.).
As the weave combines short and long side in both directions those approaches would probably only work if the long side was a integer-multiple of the short side.
7. Re: How I can find the seamless pattern tile size?
nataliar61795563 Jan 11, 2018 2:34 AM (in response to c.pfaffenbichler) -
8. Re: How I can find the seamless pattern tile size?
c.pfaffenbichler Jan 11, 2018 2:50 AM (in response to nataliar61795563)1280px x 1280px?
Could you please post a screenshot of the resulting pattern taken at View > 100%?
9. Re: How I can find the seamless pattern tile size?
davescm Jan 11, 2018 3:49 AM (in response to nataliar61795563)2 people found this helpfulHi
If a pattern is tiling on your image you can find it fairly easily by duplicating the layer - setting the blend mode of the top layer to difference then dragging the top layer across and down until it turns completely black. At that point it is repeating
Then drag across a couple of guides and read the tile size from the ruler (see example below)
However , the script does not have to tile across the layer. Each small sub pattern in the example you gave can be in any of 2 rotations in a block of 4. So if your layer only has room for a block of 2x2 as below then there are 2x2x2x2 = 16 different ways of arranging those sub tiles.
If you have room for 16 across x 16 down then that can be arranged in 2^256 =1.15 x10^77 (i.e. approx. 1 with 77 zeros after it). So that pattern may well not repeat i.e. be tiled on your layer.
The numbers get even bigger use the random brightness and color options.Of course if you need to make a tile for use elsewhere you can do so by cutting the pattern where it is a close fit. Using Filter > Other >Offset to move the layer 50% down and 50% to the right, which moves the edges to the centre, then repairing any edges that do not match with the clone tool.
I hope that helps you
Dave
10. Re: How I can find the seamless pattern tile size?
c.pfaffenbichler Jan 11, 2018 7:14 AM (in response to davescm)I had not noticed the flipping …
11. Re: How I can find the seamless pattern tile size?
nataliar61795563 Jan 11, 2018 7:37 AM (in response to c.pfaffenbichler)Wow, thanks so much!
I would never figure that out by myself
12. Re: How I can find the seamless pattern tile size?
nataliar61795563 Jan 11, 2018 7:39 AM (in response to c.pfaffenbichler)So I guess everything ok now, many thanks for your help!
13. Re: How I can find the seamless pattern tile size?
davescm Jan 11, 2018 7:52 AM (in response to nataliar61795563)You're welcome
Dave
14. Re: How I can find the seamless pattern tile size?
davescm Jan 11, 2018 8:06 AM (in response to c.pfaffenbichler)c.pfaffenbichler wrote
I must admit I had assumed it would be simply tiling groups of 4 or 16 or whatever - but when I tried the difference method and couldn't get it to go black, I looked closely and realised it was better than that
Dave
15. Re: How I can find the seamless pattern tile size?
JJMack Jan 11, 2018 10:26 AM (in response to nataliar61795563)
