Hello , I want to save variables during the execution of the program (.exe) done with Animate in version 18.0.1, in order to save the game locally (offline) the progress of the player, but I do not know how to write file is it even possible ?
Can you teach me or enlighten me on how to create a game save with Animate ?
Hi.
Besides of what Colin suggested, if you want to use AIR, here is an example:
...import flash.filesystem.File;
import flash.events.Event;
import flash.events.FocusEvent;
import flash.events.IOErrorEvent;
import flash.utils.ByteArray;
import flash.events.MouseEvent;
import flash.text.TextField;
// save
function save(filePath:String, saveString:String, completeFunction:Function, errorFunction:Function):void
var file:File = File.applicationStorageDirectory.resolvePath(filePath);
file.addEventListen
The simplest solution is to use a SharedObject. Could you please read this article to get the general idea?:
SharedObject - Adobe ActionScript® 3 (AS3 ) API Reference
There are some lengthy examples at the end of the page, in reality it can be a lot less lines.
Hi.
// save
file.addEventListener(Event.COMPLETE, completeFunction);
file.addEventListener(IOErrorEvent.IO_ERROR, errorFunction);
file.save(saveString);
function fileSaved(e:Event):void
trace("Data saved.");
function fileSavingError(e:IOErrorEvent):void
trace(e.text);
// load
function load(filePath:String, completeFunction:Function, errorFunction:Function):void
file.load();
function fileLoaded(e:Event):void
var file:File = e.target as File;
var bytes:ByteArray = file.data as ByteArray;
var str:String = bytes.readUTFBytes(bytes.length);
loadText.text = str;
trace("Data loaded: " + str);
function fileLoadingError(e:IOErrorEvent):void
trace(e.text);
function saveHandler(e:FocusEvent):void
save("test.txt", (e.currentTarget as TextField).text, fileSaved, fileSavingError);
function loadHandler(e:MouseEvent):void
load("test.txt", fileLoaded, fileLoadingError);
saveText.addEventListener(FocusEvent.FOCUS_OUT, saveHandler);
loadText.addEventListener(MouseEvent.CLICK, loadHandler);
Change the text field on the left to save its text and click on the text field on the right to load the saved text.
FLA download: save_and_load.zip - Google Drive
Official reference: Adobe AIR 1.5 * Using the load() and save() methods
