19 Replies Latest reply on Jan 29, 2018 8:25 AM by smacdonald2008
    RDB over TarMK in AEM 6.3
    onkarh71407069
      I am trying to use mysql database over TarMk.I made Install folder and dragged mysql-connector-driver and did a configuration file named as org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.config and configure as
      Later I installed instance with command as  java -jar aem-author-4502.jar -r author,crx3,crx3rdb -gui. It stucks in between and having error as
      AuthenticationSupport service missing. Cannot authenticate request. and
      Possible reason is missing Repository service. Check AuthenticationSupport dependencies.
      I am trying it with the help of RDBMS Support in AEM 6.3 .
      How do I solve this problem?
        • 1. Re: RDB over TarMK in AEM 6.3
          Jörg Hoh Adobe Employee
          Can you share more relevant data? There must be ERROR messages in the Oak startup.
          Jörg
          • 2. Re: RDB over TarMK in AEM 6.3
            onkarh71407069 Level 1
            Dear Jörg Hoh,
                 I am using mysql RDB over TarMk.Here is my error.log file.Its giving me error of mongoDb;but I am using Mysql RDB,I dont understand how it happend.
            Regards,
            Onkar Hattekar.
            15.01.2018 12:16:02.049 *INFO* [FelixStartLevel] org.apache.sling.installer.core Service [Apache Sling Bundle Install Task Factory,21, [org.apache.sling.installer.api.tasks.InstallTaskFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:02.050 *INFO* [FelixStartLevel] org.apache.sling.installer.core Service [Apache Sling Installer - Default Resource Transformer,22, [org.apache.sling.installer.api.tasks.ResourceTransformer]] ServiceEvent REGISTERED 15.01.2018 12:16:02.051 *INFO* [FelixStartLevel] org.apache.sling.installer.core Service [Apache Sling Installer Controller Service,23, [org.apache.sling.installer.api.OsgiInstaller, org.apache.sling.installer.api.info.InfoProvider, org.apache.sling.installer.api.ResourceChangeListener, org.apache.sling.installer.api.tasks.RetryHandler]] ServiceEvent REGISTERED 15.01.2018 12:16:02.052 *INFO* [FelixStartLevel] org.apache.sling.installer.core Service [Apache Sling Installer Controller Service,24, [org.apache.sling.installer.api.jmx.InstallerMBean, org.apache.sling.installer.api.event.InstallationListener]] ServiceEvent REGISTERED 15.01.2018 12:16:02.053 *INFO* [FelixStartLevel] org.apache.sling.installer.core BundleEvent STARTED 15.01.2018 12:16:02.053 *INFO* [OsgiInstallerImpl] org.apache.sling.installer.core.impl.OsgiInstallerImpl Apache Sling OSGi Installer Service started. 15.01.2018 12:16:02.093 *INFO* [FelixStartLevel] org.apache.sling.installer.factory.configuration BundleEvent RESOLVED 15.01.2018 12:16:02.094 *INFO* [FelixStartLevel] org.apache.sling.installer.factory.configuration BundleEvent STARTING 15.01.2018 12:16:02.099 *INFO* [FelixStartLevel] org.apache.sling.installer.factory.configuration Service [Apache Sling Configuration Install Task Factory,25, [org.apache.sling.installer.api.tasks.InstallTaskFactory, org.osgi.service.cm.ConfigurationListener, org.apache.sling.installer.api.tasks.ResourceTransformer]] ServiceEvent REGISTERED 15.01.2018 12:16:02.100 *INFO* [FelixStartLevel] org.apache.sling.installer.factory.configuration BundleEvent STARTED 15.01.2018 12:16:02.103 *INFO* [FelixStartLevel] org.apache.sling.settings BundleEvent RESOLVED 15.01.2018 12:16:02.103 *INFO* [FelixStartLevel] org.apache.sling.installer.provider.file BundleEvent RESOLVED 15.01.2018 12:16:02.103 *INFO* [FelixStartLevel] org.apache.sling.installer.provider.file BundleEvent STARTING 15.01.2018 12:16:02.106 *INFO* [FelixStartLevel] org.apache.sling.installer.provider.file BundleEvent STARTED 15.01.2018 12:16:02.109 *INFO* [FelixStartLevel] org.apache.sling.javax.activation BundleEvent RESOLVED 15.01.2018 12:16:02.109 *INFO* [FelixStartLevel] org.apache.sling.javax.activation BundleEvent STARTING 15.01.2018 12:16:02.119 *INFO* [FelixStartLevel] org.apache.sling.javax.activation BundleEvent STARTED 15.01.2018 12:16:02.124 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer BundleEvent RESOLVED 15.01.2018 12:16:02.124 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer BundleEvent STARTING 15.01.2018 12:16:02.126 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer BundleEvent STARTED 15.01.2018 12:16:02.126 *INFO* [FelixStartLevel] org.apache.sling.settings BundleEvent STARTING 15.01.2018 12:16:02.128 *INFO* [FelixStartLevel] org.apache.sling.settings.impl.SlingSettingsServiceImpl Read Sling ID null from file D:\Software\AEM-RDB\crx-quickstart\launchpad\felix\bundle18\data\sling.id.file 15.01.2018 12:16:02.130 *INFO* [FelixStartLevel] org.apache.sling.settings.impl.SlingSettingsServiceImpl Created new Sling ID 06c1ded8-c2e8-45d8-aea6-28bf4b12c6c4 15.01.2018 12:16:02.139 *INFO* [FelixStartLevel] org.apache.sling.settings.impl.SlingSettingsServiceImpl Active run modes: [crx3rdb, crx3, author, samplecontent] 15.01.2018 12:16:02.151 *INFO* [FelixStartLevel] org.apache.sling.installer.provider.file Service [Apache Sling File Installer Controller Service,27, [org.apache.sling.installer.api.UpdateHandler]] ServiceEvent REGISTERED 15.01.2018 12:16:02.152 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer Service [Apache Sling Launchpad Startup Listener,28, [org.apache.sling.installer.api.event.InstallationListener]] ServiceEvent REGISTERED 15.01.2018 12:16:02.153 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer.impl.LaunchpadConfigInstaller Activating launchpad config installer, configuration path=resources/config, install path=resources/install 15.01.2018 12:16:02.231 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService from resource TaskResource(url=fileinstalla56c5dd612ea14055c00c19a60001717:D:\Software\AEM-RDB\crx-quic kstart\install\org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.config, entity=config:org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService], digest=790f042e44a89cfd92301d7bfe2a9913) 15.01.2018 12:16:02.255 *INFO* [OsgiInstallerImpl] mysql-osgi-bundle-5.1.45 BundleEvent INSTALLED 15.01.2018 12:16:02.255 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle mysql-osgi-bundle-5.1.45 [20] from resource TaskResource(url=fileinstalla56c5dd612ea14055c00c19a60001717:D:\Software\AEM-RDB\crx-quic kstart\install\mysql-osgi-bundle-5.1.45_1.0.0.jar, entity=bundle:mysql-osgi-bundle-5.1.45, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=mysql-osgi-bundle-5.1.45, Bundle-Version=1.0.0], digest=1513159070776) 15.01.2018 12:16:02.262 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle mysql-osgi-bundle-5.1.45 [20] 15.01.2018 12:16:03.533 *INFO* [FelixStartLevel] org.apache.sling.launchpad.installer.impl.LaunchpadConfigInstaller 842 resources registered with OsgiInstaller 15.01.2018 12:16:03.533 *INFO* [FelixStartLevel] org.apache.sling.settings Service [Apache Sling Settings Service,26, [org.apache.sling.settings.SlingSettingsService]] ServiceEvent REGISTERED 15.01.2018 12:16:03.536 *INFO* [FelixStartLevel] org.apache.sling.settings Service [Apache Sling Sling Properties Configuration Printer,29, [org.apache.sling.settings.impl.SlingPropertiesPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:03.537 *INFO* [FelixStartLevel] org.apache.sling.settings Service [Apache Sling Sling Settings Configuration Printer,30, [org.apache.sling.settings.impl.SlingSettingsPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:03.540 *INFO* [FelixStartLevel] org.apache.sling.settings Service [org.apache.sling.settings.impl.SlingSettingsServiceImpl,31, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:03.540 *INFO* [FelixStartLevel] org.apache.sling.settings BundleEvent STARTED 15.01.2018 12:16:03.540 *INFO* [FelixStartLevel] slf4j.api BundleEvent STARTING 15.01.2018 12:16:03.540 *INFO* [FelixStartLevel] slf4j.api BundleEvent STARTED 15.01.2018 12:16:03.541 *INFO* [main] org.apache.felix.framework BundleEvent STARTED 15.01.2018 12:16:03.577 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTED 15.01.2018 12:16:03.822 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.aem.upgrade.prechecks.mbean.impl.PreUpgradeTasksMBeanImpl from resource TaskResource(url=launchpad:resources/config/com.adobe.aem.upgrade.prechecks.mbean.impl.Pr eUpgradeTasksMBeanImpl.config, entity=config:com.adobe.aem.upgrade.prechecks.mbean.impl.PreUpgradeTasksMBeanImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.aem.upgrade.prechecks.mbean.impl.PreUpgradeTasksMBeanImpl], digest=1371b717fe81bf7a828220464c3e2b39) 15.01.2018 12:16:03.832 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.cq.experiencelog.impl.ExperienceLogConfigServlet from resource TaskResource(url=launchpad:resources/config/author/com.adobe.cq.experiencelog.impl.Experi enceLogConfigServlet.config, entity=config:com.adobe.cq.experiencelog.impl.ExperienceLogConfigServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.cq.experiencelog.impl.ExperienceLogConfigServlet], digest=af2995db492022d901d5941b4f99671b) 15.01.2018 12:16:03.845 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.cq.hc.ContentPackagesHealthCheck.c4148e63-74b5-4362-aed4-d27a1b7b0817 from resource TaskResource(url=launchpad:resources/config/com.adobe.cq.hc.ContentPackagesHealthCheck-1. config, entity=config:com.adobe.cq.hc.ContentPackagesHealthCheck.1, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.cq.hc.ContentPackagesHealthCheck, service.pid=1], digest=ee68c18ae2749c90a5101952fef628b6) 15.01.2018 12:16:03.855 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.cq.security.hc.packages.impl.ExampleContentHealthCheck from resource TaskResource(url=launchpad:resources/config/com.adobe.cq.security.hc.packages.impl.Exampl eContentHealthCheck.config, entity=config:com.adobe.cq.security.hc.packages.impl.ExampleContentHealthCheck, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.cq.security.hc.packages.impl.ExampleContentHealthCheck], digest=f31c9428415ed6b6f7775e3134f55ed5) 15.01.2018 12:16:03.866 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.a84521e9-4f1a-4136-ac24-8556cde9 2d1b from resource TaskResource(url=launchpad:resources/config/com.adobe.cq.upgrades.cleanup.impl.UpgradeCon tentCleanup-contentpackages.config, entity=config:com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.contentpackages, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup, service.pid=contentpackages], digest=b553f27501327f96afa0bf8a0d99908d) 15.01.2018 12:16:03.876 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.1e346cdc-e924-425b-9cc7-3fbc0573 637c from resource TaskResource(url=launchpad:resources/config/com.adobe.cq.upgrades.cleanup.impl.UpgradeCon tentCleanup-creativecloud.config, entity=config:com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.creativecloud, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup, service.pid=creativecloud], digest=8c40f4123bbf8c942ea26578a3794f2f) 15.01.2018 12:16:03.886 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.apicontroller.FilterResolverHookFactory from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.apicontroller.FilterResolve rHookFactory.config, entity=config:com.adobe.granite.apicontroller.FilterResolverHookFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.apicontroller.FilterResolverHookFactory], digest=76fa8310422457828bcc8337fa244dbe) 15.01.2018 12:16:03.895 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.auth.oauth.impl.helper.ProviderConfigManager from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.auth.oauth.impl.helper.Prov iderConfigManager.config, entity=config:com.adobe.granite.auth.oauth.impl.helper.ProviderConfigManager, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.auth.oauth.impl.helper.ProviderConfigManager], digest=bbc42a37b36ac583548af1d84fbbdd96) 15.01.2018 12:16:03.901 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.csrf.impl.CSRFFilter from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.csrf.impl.CSRFFilter.config , entity=config:com.adobe.granite.csrf.impl.CSRFFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.csrf.impl.CSRFFilter], digest=97fed85cb0debe8f7cadb2e586b2d7fd) 15.01.2018 12:16:03.912 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.distribution.core.impl.CryptoDistributionTransportSecretProvider.f24abc 35-a333-4c2b-aab0-7beddd088978 from resource TaskResource(url=launchpad:resources/config/author.samplecontent/com.adobe.granite.distri bution.core.impl.CryptoDistributionTransportSecretProvider-default.json.config, entity=config:com.adobe.granite.distribution.core.impl.CryptoDistributionTransportSecretP rovider.default.json, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.distribution.core.impl.CryptoDistributionTransportSe cretProvider, service.pid=default.json], digest=ace68c9b63c683d066579f40351653c4) 15.01.2018 12:16:03.921 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.maintenance.crx.impl.DataStoreGarbageCollectionTask from resource TaskResource(url=launchpad:resources/config/crx3/com.adobe.granite.maintenance.crx.impl.D ataStoreGarbageCollectionTask.config, entity=config:com.adobe.granite.maintenance.crx.impl.DataStoreGarbageCollectionTask, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.maintenance.crx.impl.DataStoreGarbageCollectionTask], digest=9051e150e95d9ab4e57c50663fe463c3) 15.01.2018 12:16:03.929 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.maintenance.crx.impl.RevisionCleanupTask from resource TaskResource(url=launchpad:resources/config/crx3/com.adobe.granite.maintenance.crx.impl.R evisionCleanupTask.config, entity=config:com.adobe.granite.maintenance.crx.impl.RevisionCleanupTask, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.maintenance.crx.impl.RevisionCleanupTask], digest=24785ade4f5e09ced88ee42c15bcf419) 15.01.2018 12:16:03.938 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.monitoring.impl.ScriptConfigImpl.4727a9df-2ef9-4cf1-a144-05524799841c from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.monitoring.impl.ScriptConfi gImpl-cpu.config, entity=config:com.adobe.granite.monitoring.impl.ScriptConfigImpl.cpu, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.monitoring.impl.ScriptConfigImpl, service.pid=cpu], digest=9eed1c0fc2d0317d8765126c17c8b011) 15.01.2018 12:16:03.947 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.monitoring.impl.ScriptConfigImpl.5ea15a12-ec54-4734-8858-07f3d2af3df2 from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.monitoring.impl.ScriptConfi gImpl-disk.config, entity=config:com.adobe.granite.monitoring.impl.ScriptConfigImpl.disk, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.monitoring.impl.ScriptConfigImpl, service.pid=disk], digest=e431eb083f2551323b4aad35d72b14fd) 15.01.2018 12:16:03.956 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.offloading.impl.OffloadingJobCloner from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.offloading.impl.Offl oadingJobCloner.config, entity=config:com.adobe.granite.offloading.impl.OffloadingJobCloner, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.offloading.impl.OffloadingJobCloner], digest=1466fd1a74ad814c1d0e0b3cd94bc509) 15.01.2018 12:16:03.962 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.offloading.impl.OffloadingJobOffloader from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.offloading.impl.Offl oadingJobOffloader.config, entity=config:com.adobe.granite.offloading.impl.OffloadingJobOffloader, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.offloading.impl.OffloadingJobOffloader], digest=31539b3845117d83312fb21a2119673e) 15.01.2018 12:16:03.970 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.offloading.impl.transporter.OffloadingAgentManager from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.offloading.impl.tran sporter.OffloadingAgentManager.config, entity=config:com.adobe.granite.offloading.impl.transporter.OffloadingAgentManager, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.offloading.impl.transporter.OffloadingAgentManager], digest=92699262a4f700979d190eb9f06b794f) 15.01.2018 12:16:03.978 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.offloading.impl.transporter.OffloadingDefaultTransporter from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.offloading.impl.tran sporter.OffloadingDefaultTransporter.config, entity=config:com.adobe.granite.offloading.impl.transporter.OffloadingDefaultTransporter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.offloading.impl.transporter.OffloadingDefaultTransporter], digest=1f759b55e874b40c923b5105b0f621cf) 15.01.2018 12:16:03.986 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.optout.impl.OptOutServiceImpl from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.optout.impl.OptOutServiceIm pl.config, entity=config:com.adobe.granite.optout.impl.OptOutServiceImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.optout.impl.OptOutServiceImpl], digest=594a5a6834b283437576e6dbbbcc6485) 15.01.2018 12:16:03.997 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.repository.ServiceUserConfiguration.0f64f3bf-6fe4-4689-9ea2-f7bfa84a035 0 from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.repository.ServiceUserConfi guration-defaultFastPathUsersAssets.config, entity=config:com.adobe.granite.repository.ServiceUserConfiguration.defaultFastPathUsersA ssets, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.repository.ServiceUserConfiguration, service.pid=defaultFastPathUsersAssets], digest=3583565a875717c1e61882ee0e63f523) 15.01.2018 12:16:04.007 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.repository.ServiceUserConfiguration.304949fd-98d5-4d6e-9142-6eb7e62e28f 4 from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.repository.ServiceUserConfi guration-defaultFastPathUsersForCQ.config, entity=config:com.adobe.granite.repository.ServiceUserConfiguration.defaultFastPathUsersF orCQ, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.repository.ServiceUserConfiguration, service.pid=defaultFastPathUsersForCQ], digest=2e3f51a8075e54341cb5142c8e15dc89) 15.01.2018 12:16:04.020 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.repository.ServiceUserConfiguration.458fb765-3ef0-4ee7-a308-718d80d2927 d from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.repository.ServiceUserConfi guration-defaultFastPathUsersGranite.config, entity=config:com.adobe.granite.repository.ServiceUserConfiguration.defaultFastPathUsersG ranite, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.repository.ServiceUserConfiguration, service.pid=defaultFastPathUsersGranite], digest=525b102918ea76596346a06cd6992abf) 15.01.2018 12:16:04.023 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.repository.impl.CommitStatsConfig from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.repository.impl.CommitStats Config.config, entity=config:com.adobe.granite.repository.impl.CommitStatsConfig, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.repository.impl.CommitStatsConfig], digest=f1c2706fdf93e9e6c70df5e0447daad0) 15.01.2018 12:16:04.034 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.resourcestatus.impl.CompositeStatusType.42dafc81-1d8e-4f18-873b-62d9942 1df39 from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.resourcestatus.impl. CompositeStatusType-content-fragments.config.config, entity=config:com.adobe.granite.resourcestatus.impl.CompositeStatusType.content-fragments .config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.resourcestatus.impl.CompositeStatusType, service.pid=content-fragments.config], digest=30db688a20122c4ee80b59d3e3ef8377) 15.01.2018 12:16:04.044 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.resourcestatus.impl.CompositeStatusType.6de38acb-ae94-47d1-91dd-ffbfaa9 56829 from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.resourcestatus.impl.Composi teStatusType-editor.config.config, entity=config:com.adobe.granite.resourcestatus.impl.CompositeStatusType.editor.config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.resourcestatus.impl.CompositeStatusType, service.pid=editor.config], digest=408c6e25c9d625d34bf0352179ce5b90) 15.01.2018 12:16:04.051 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.security.user.UserPropertiesService from resource TaskResource(url=launchpad:resources/config/com.adobe.granite.security.user.UserPropertie sService.config, entity=config:com.adobe.granite.security.user.UserPropertiesService, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.security.user.UserPropertiesService], digest=e69256a0b2388e71c37fd2727b069f2b) 15.01.2018 12:16:04.057 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.ui.clientlibs.impl.HtmlLibraryManagerImpl from resource TaskResource(url=launchpad:resources/config/samplecontent/com.adobe.granite.ui.clientlibs .impl.HtmlLibraryManagerImpl.config, entity=config:com.adobe.granite.ui.clientlibs.impl.HtmlLibraryManagerImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.granite.ui.clientlibs.impl.HtmlLibraryManagerImpl], digest=aef196ab3b0810143c1496a9fb81e5f6) 15.01.2018 12:16:04.067 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.granite.workflow.core.offloading.WorkflowOffloadingJobConsumer.dffee6da-08d9-47 20-9300-0f99b2e3f536 from resource TaskResource(url=launchpad:resources/config/author/com.adobe.granite.workflow.core.offloa ding.WorkflowOffloadingJobConsumer-default.config, entity=config:com.adobe.granite.workflow.core.offloading.WorkflowOffloadingJobConsumer.de fault, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.adobe.granite.workflow.core.offloading.WorkflowOffloadingJobConsum er, service.pid=default], digest=1b08626839deeb3e2471e2bc759692b0) 15.01.2018 12:16:04.074 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.adobe.xmp.worker.files.ncomm.XMPFilesNComm from resource TaskResource(url=launchpad:resources/config/com.adobe.xmp.worker.files.ncomm.XMPFilesNCom m.config, entity=config:com.adobe.xmp.worker.files.ncomm.XMPFilesNComm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.adobe.xmp.worker.files.ncomm.XMPFilesNComm], digest=b7e2c837d891028517caab9d3d4e951b) 15.01.2018 12:16:04.084 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.analytics.testandtarget.impl.PushAuthorCampaignPageListener from resource TaskResource(url=launchpad:resources/config/com.day.cq.analytics.testandtarget.impl.PushA uthorCampaignPageListener.config, entity=config:com.day.cq.analytics.testandtarget.impl.PushAuthorCampaignPageListener, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.analytics.testandtarget.impl.PushAuthorCampaignPageListener], digest=a149808458486c7eeda443935a75d38c) 15.01.2018 12:16:04.093 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.auth.impl.LoginSelectorHandler from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.auth.impl.LoginSelectorHand ler.config, entity=config:com.day.cq.auth.impl.LoginSelectorHandler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.auth.impl.LoginSelectorHandler], digest=97c85a6dc87beb860ce5ac9372606c45) 15.01.2018 12:16:04.100 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.dam.core.impl.jmx.AssetMigrationMBeanImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.dam.core.impl.jmx.AssetMigr ationMBeanImpl.config, entity=config:com.day.cq.dam.core.impl.jmx.AssetMigrationMBeanImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.dam.core.impl.jmx.AssetMigrationMBeanImpl], digest=f117238d141979a84c7f5db51f07405b) 15.01.2018 12:16:04.109 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.dam.scene7.impl.Scene7ConfigurationEventListener from resource TaskResource(url=launchpad:resources/config/com.day.cq.dam.scene7.impl.Scene7Configuratio nEventListener.config, entity=config:com.day.cq.dam.scene7.impl.Scene7ConfigurationEventListener, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.dam.scene7.impl.Scene7ConfigurationEventListener], digest=7e79e368b21e641c6e3b925f4e72a60a) 15.01.2018 12:16:04.115 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.dam.scene7.impl.Scene7DamChangeEventListener from resource TaskResource(url=launchpad:resources/config/com.day.cq.dam.scene7.impl.Scene7DamChangeEve ntListener.config, entity=config:com.day.cq.dam.scene7.impl.Scene7DamChangeEventListener, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.dam.scene7.impl.Scene7DamChangeEventListener], digest=74cb23209ce19f996d7000087ff2989b) 15.01.2018 12:16:04.124 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.dam.video.servlet.VideoTestServlet from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.dam.video.servlet.VideoTest Servlet.config, entity=config:com.day.cq.dam.video.servlet.VideoTestServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.dam.video.servlet.VideoTestServlet], digest=f1c2706fdf93e9e6c70df5e0447daad0) 15.01.2018 12:16:04.135 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.64aa9ffd-768c-4213-adc8-7a7c98d439 17 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-209a0117-b1a5-4a9a-88be-da9dcdea35c1.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.209a0117-b1a5-4a9a-8 8be-da9dcdea35c1, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=209a0117-b1a5-4a9a-88be-da9dcdea35c1], digest=33dc3abc86dafa61572b37bb7da3dc8c) 15.01.2018 12:16:04.144 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.b5dccfd3-bb33-4ffc-8276-9511d1767c e3 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-2c98542b-3679-44d4-a9c9-059d177f01aa.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.2c98542b-3679-44d4-a 9c9-059d177f01aa, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=2c98542b-3679-44d4-a9c9-059d177f01aa], digest=a7d1267c5d6f6cfecd88191a3c9b74b4) 15.01.2018 12:16:04.158 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.15729f3a-12cf-48ed-9e7a-7a9001b236 d8 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-3a6aba56-5fbd-409a-8184-75dad2d9adbd.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.3a6aba56-5fbd-409a-8 184-75dad2d9adbd, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=3a6aba56-5fbd-409a-8184-75dad2d9adbd], digest=ccfb5b93071a8814670f6793e1c71306) 15.01.2018 12:16:04.170 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.75726175-0ba8-480c-ae13-18349e2c8d 01 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-6d43d7a6-6fa2-4a26-a9bd-543b2beb6af5.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.6d43d7a6-6fa2-4a26-a 9bd-543b2beb6af5, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=6d43d7a6-6fa2-4a26-a9bd-543b2beb6af5], digest=589c9824ba09c04142465e3955c1f02c) 15.01.2018 12:16:04.180 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.a986f1d8-60ff-41ee-a13c-d558bc229e 20 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-81d36401-8b25-4002-acef-a372e87c697a.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.81d36401-8b25-4002-a cef-a372e87c697a, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=81d36401-8b25-4002-acef-a372e87c697a], digest=24e0983e03f0ba557e395abb34a35a7f) 15.01.2018 12:16:04.191 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.polling.importer.impl.ManagedPollConfigImpl.1731fe42-4496-4a1d-bbfb-67a5ee2040 31 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.polling.importer.impl.Manag edPollConfigImpl-c60774aa-ab9e-4a0e-a130-8508bdd0cf36.config, entity=config:com.day.cq.polling.importer.impl.ManagedPollConfigImpl.c60774aa-ab9e-4a0e-a 130-8508bdd0cf36, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.polling.importer.impl.ManagedPollConfigImpl, service.pid=c60774aa-ab9e-4a0e-a130-8508bdd0cf36], digest=50721c152b203637739fdfc1404113fa) 15.01.2018 12:16:04.201 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.rewriter.linkchecker.impl.LinkInfoStorageImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.rewriter.linkchecker.impl.L inkInfoStorageImpl.config, entity=config:com.day.cq.rewriter.linkchecker.impl.LinkInfoStorageImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.rewriter.linkchecker.impl.LinkInfoStorageImpl], digest=12461177cefdbd9a5014cdf69f607595) 15.01.2018 12:16:04.211 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.searchpromote.impl.PublishSearchPromoteConfigHandler from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.searchpromote.impl.PublishS earchPromoteConfigHandler.config, entity=config:com.day.cq.searchpromote.impl.PublishSearchPromoteConfigHandler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.searchpromote.impl.PublishSearchPromoteConfigHandler], digest=8c0ddeb59f79f150e1bfb1847dd3af2c) 15.01.2018 12:16:04.220 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.searchpromote.impl.SearchPromoteServiceImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.searchpromote.impl.SearchPr omoteServiceImpl.config, entity=config:com.day.cq.searchpromote.impl.SearchPromoteServiceImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.searchpromote.impl.SearchPromoteServiceImpl], digest=1f72e6e40232f4e9c88e711846bc2e2) 15.01.2018 12:16:04.228 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.security.ACLSetup from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.security.ACLSetup.config, entity=config:com.day.cq.security.ACLSetup, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.security.ACLSetup], digest=66e99de08dc032d255e67c244264cc0e) 15.01.2018 12:16:04.237 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.WCMRequestFilter from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.WCMRequestFilter.c onfig, entity=config:com.day.cq.wcm.core.WCMRequestFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.WCMRequestFilter], digest=7154e30ac4d37b26175c728a50294367) 15.01.2018 12:16:04.242 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.impl.AuthoringUIModeServiceImpl from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.core.impl.AuthoringUIModeServi ceImpl.config, entity=config:com.day.cq.wcm.core.impl.AuthoringUIModeServiceImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.impl.AuthoringUIModeServiceImpl], digest=a46b26bb7d9138812a72171a3d340303) 15.01.2018 12:16:04.250 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.impl.WCMDeveloperModeFilter from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.impl.WCMDeveloperM odeFilter.config, entity=config:com.day.cq.wcm.core.impl.WCMDeveloperModeFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.impl.WCMDeveloperModeFilter], digest=8a4477c2a7979de4d3981d2e94066296) 15.01.2018 12:16:04.258 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.impl.event.PageEventAuditListener from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.impl.event.PageEve ntAuditListener.config, entity=config:com.day.cq.wcm.core.impl.event.PageEventAuditListener, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.impl.event.PageEventAuditListener], digest=8a4477c2a7979de4d3981d2e94066296) 15.01.2018 12:16:04.266 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.impl.variants.PageVariantsProviderImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.impl.variants.Page VariantsProviderImpl.config, entity=config:com.day.cq.wcm.core.impl.variants.PageVariantsProviderImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.impl.variants.PageVariantsProviderImpl], digest=857b65c2ad35e6f25a9076ab49487953) 15.01.2018 12:16:04.275 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.impl.warp.TimeWarpFilter from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.impl.warp.TimeWarp Filter.config, entity=config:com.day.cq.wcm.core.impl.warp.TimeWarpFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.impl.warp.TimeWarpFilter], digest=a9f3ff043e19d9e4016ae8e4703c919c) 15.01.2018 12:16:04.283 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.mvt.MVTStatisticsImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.mvt.MVTStatisticsI mpl.config, entity=config:com.day.cq.wcm.core.mvt.MVTStatisticsImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.mvt.MVTStatisticsImpl], digest=84753ef82c6ff58175de45b4d406a83e) 15.01.2018 12:16:04.292 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.core.stats.PageViewStatisticsImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.core.stats.PageViewStat isticsImpl.config, entity=config:com.day.cq.wcm.core.stats.PageViewStatisticsImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.core.stats.PageViewStatisticsImpl], digest=d3b94f2301f8be6f699e0f7bb195cc30) 15.01.2018 12:16:04.302 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.foundation.forms.impl.FormParagraphPostProcessor.0a4a74b5-98be-432e-ae1a-5 b2ffd17a2b1 from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.foundation.forms.impl.F ormParagraphPostProcessor-foundation.config, entity=config:com.day.cq.wcm.foundation.forms.impl.FormParagraphPostProcessor.foundation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.wcm.foundation.forms.impl.FormParagraphPostProcessor, service.pid=foundation], digest=a13a112a0f7437ed18be50cbc0af187d) 15.01.2018 12:16:04.310 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.foundation.forms.impl.MailServlet.c27133cf-ae8e-42fb-9bc2-0f14eaa009f9 from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.foundation.forms.impl.MailServ let-foundation.config, entity=config:com.day.cq.wcm.foundation.forms.impl.MailServlet.foundation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.wcm.foundation.forms.impl.MailServlet, service.pid=foundation], digest=6495d7ee6fb7eb024bb27b38efcbf3c2) 15.01.2018 12:16:04.319 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.foundation.security.impl.SaferSlingPostValidatorImpl from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.foundation.security.impl.Safer SlingPostValidatorImpl.config, entity=config:com.day.cq.wcm.foundation.security.impl.SaferSlingPostValidatorImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.foundation.security.impl.SaferSlingPostValidatorImpl], digest=44df5c86d22bdc2fdd28962723d45e9) 15.01.2018 12:16:04.329 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.9dae400d-633d-4783-84f4-8dc03cbc35 8e from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.mobile.core.impl.MobileEmulato rProvider-exampletemplateconfig.config, entity=config:com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.exampletemplateconfi g, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider, service.pid=exampletemplateconfig], digest=70b39ecc40b2be94686f173ba4f2161) 15.01.2018 12:16:04.338 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.26334696-1f09-454f-b02e-276eca4d26 f1 from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.mobile.core.impl.MobileEmulato rProvider-page-config.config, entity=config:com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.page-config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider, service.pid=page-config], digest=6270b3574916bddc43c2a23fe9539bde) 15.01.2018 12:16:04.347 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.753d156e-440e-4bf8-bc7d-2773be1d1b 63 from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.mobile.core.impl.MobileEmulato rProvider-screens-channels.config.config, entity=config:com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider.screens-channels.con fig, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=com.day.cq.wcm.mobile.core.impl.MobileEmulatorProvider, service.pid=screens-channels.config], digest=136a49a689fbd045fb05cea20b9aa155) 15.01.2018 12:16:04.355 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.mobile.core.impl.device.DeviceInfoTransformerFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.mobile.core.impl.device .DeviceInfoTransformerFactory.config, entity=config:com.day.cq.wcm.mobile.core.impl.device.DeviceInfoTransformerFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.mobile.core.impl.device.DeviceInfoTransformerFactory], digest=d243332c6f3e3dd46e82bbe05e6c1af4) 15.01.2018 12:16:04.363 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.mobile.core.impl.redirect.Redi rectFilter.config, entity=config:com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter], digest=e3d863a1137a30c047370c8bb52805ed) 15.01.2018 12:16:04.371 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.RolloutManagerImpl from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.RolloutManager Impl.config, entity=config:com.day.cq.wcm.msm.impl.RolloutManagerImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.RolloutManagerImpl], digest=8a4477c2a7979de4d3981d2e94066296) 15.01.2018 12:16:04.377 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.ContentCopyActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.Conten tCopyActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.ContentCopyActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.ContentCopyActionFactory], digest=dab744ff3f3357baf0650c997600ca67) 15.01.2018 12:16:04.381 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.ContentDeleteActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.Conten tDeleteActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.ContentDeleteActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.ContentDeleteActionFactory], digest=b29cceb10d409d35b9ddd8ff6263646e) 15.01.2018 12:16:04.390 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.ContentUpdateActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.Conten tUpdateActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.ContentUpdateActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.ContentUpdateActionFactory], digest=7e863e1353674c239136e1725fc0aa8b) 15.01.2018 12:16:04.396 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.OrderChildrenActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.OrderC hildrenActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.OrderChildrenActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.OrderChildrenActionFactory], digest=a5c7a048e60ab5a8ede31c7f56852645) 15.01.2018 12:16:04.405 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.ReferencesUpdateActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.Refere ncesUpdateActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.ReferencesUpdateActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.ReferencesUpdateActionFactory], digest=a5c7a048e60ab5a8ede31c7f56852645) 15.01.2018 12:16:04.414 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.msm.impl.actions.VersionCopyActionFactory from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.msm.impl.actions.Versio nCopyActionFactory.config, entity=config:com.day.cq.wcm.msm.impl.actions.VersionCopyActionFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.msm.impl.actions.VersionCopyActionFactory], digest=a5c7a048e60ab5a8ede31c7f56852645) 15.01.2018 12:16:04.423 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.notification.impl.NotificationManagerImpl from resource TaskResource(url=launchpad:resources/config/com.day.cq.wcm.notification.impl.Notification ManagerImpl.config, entity=config:com.day.cq.wcm.notification.impl.NotificationManagerImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.notification.impl.NotificationManagerImpl], digest=d424838dbc4fda73d3d661d03d20e7c7) 15.01.2018 12:16:04.429 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.cq.wcm.undo.UndoConfig from resource TaskResource(url=launchpad:resources/config/author/com.day.cq.wcm.undo.UndoConfig.config, entity=config:com.day.cq.wcm.undo.UndoConfig, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.cq.wcm.undo.UndoConfig], digest=ed09ca6e758fed446cf03ab983db193b) 15.01.2018 12:16:04.437 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration com.day.crx.security.token.impl.impl.TokenAuthenticationHandler from resource TaskResource(url=launchpad:resources/config/com.day.crx.security.token.impl.impl.TokenAut henticationHandler.config, entity=config:com.day.crx.security.token.impl.impl.TokenAuthenticationHandler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=com.day.crx.security.token.impl.impl.TokenAuthenticationHandler], digest=20ceaf850b06f65fb9cfe45b651f9dc3) 15.01.2018 12:16:04.446 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.aries.jmx.framework.StateConfig from resource TaskResource(url=launchpad:resources/config/org.apache.aries.jmx.framework.StateConfig.co nfig, entity=config:org.apache.aries.jmx.framework.StateConfig, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.aries.jmx.framework.StateConfig], digest=ab6c16033311ddceb85b42c21e707afa) 15.01.2018 12:16:04.455 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.eventadmin.impl.EventAdmin from resource TaskResource(url=launchpad:resources/config/org.apache.felix.eventadmin.impl.EventAdmin.c onfig, entity=config:org.apache.felix.eventadmin.impl.EventAdmin, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.felix.eventadmin.impl.EventAdmin], digest=33741c05a7bf3215a9207e175ac1f413) 15.01.2018 12:16:04.463 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.http from resource TaskResource(url=launchpad:resources/config/org.apache.felix.http.config, entity=config:org.apache.felix.http, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.felix.http], digest=1a63ae1b968a88e809acf73fe23ed2df) 15.01.2018 12:16:04.476 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.jaas.Configuration.factory.848575e7-19f2-4949-b108-e1b98240c9ed from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.felix.jaas.Configuration.fact ory-GuestLoginModule.config, entity=config:org.apache.felix.jaas.Configuration.factory.GuestLoginModule, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.felix.jaas.Configuration.factory, service.pid=GuestLoginModule], digest=e68ccc46f9ace4eb699432fd7559a84b) 15.01.2018 12:16:04.486 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.jaas.Configuration.factory.1051aad1-342c-4d84-aa55-a67a5b034fab from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.felix.jaas.Configuration.fact ory-LoginModuleImpl.config, entity=config:org.apache.felix.jaas.Configuration.factory.LoginModuleImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.felix.jaas.Configuration.factory, service.pid=LoginModuleImpl], digest=2c8cc147543f03326f9336edb6070c72) 15.01.2018 12:16:04.495 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.jaas.Configuration.factory.ede68a3b-b28d-4b44-859b-5866f1b24a67 from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.felix.jaas.Configuration.fact ory-TokenLoginModule.config, entity=config:org.apache.felix.jaas.Configuration.factory.TokenLoginModule, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.felix.jaas.Configuration.factory, service.pid=TokenLoginModule], digest=a6ad69e48c51b26345688a507d4e635a) 15.01.2018 12:16:04.504 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.felix.jaas.ConfigurationSpi from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.felix.jaas.ConfigurationSpi.c onfig, entity=config:org.apache.felix.jaas.ConfigurationSpi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.felix.jaas.ConfigurationSpi], digest=5d21b53a083eebfb467663002be93e58) 15.01.2018 12:16:04.509 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.plugins.index.AsyncIndexerService from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.plugins.index. AsyncIndexerService.config, entity=config:org.apache.jackrabbit.oak.plugins.index.AsyncIndexerService, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.plugins.index.AsyncIndexerService], digest=5a7af1cd5380c9856dbe0775f2ec91a6) 15.01.2018 12:16:04.518 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.plugins.index. lucene.LuceneIndexProviderService.config, entity=config:org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService], digest=bcae43517096233cea77836046f12911) 15.01.2018 12:16:04.527 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.plugins.observation.ChangeCollectorProvider from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.plugins.observ ation.ChangeCollectorProvider.config, entity=config:org.apache.jackrabbit.oak.plugins.observation.ChangeCollectorProvider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.plugins.observation.ChangeCollectorProvider], digest=f1c2706fdf93e9e6c70df5e0447daad0) 15.01.2018 12:16:04.536 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.security.authe ntication.token.TokenConfigurationImpl.config, entity=config:org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationI mpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImp l], digest=e56efb7472c8c6f671720a516380124) 15.01.2018 12:16:04.546 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationImpl from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.security.autho rization.AuthorizationConfigurationImpl.config, entity=config:org.apache.jackrabbit.oak.security.authorization.AuthorizationConfiguration Impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationIm pl], digest=51b2cebe4d4eb91028bd837dc3be4abf) 15.01.2018 12:16:04.555 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.security.inter nal.SecurityProviderRegistration.config, entity=config:org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration], digest=192eeecec1442de50f90e52a04351688) 15.01.2018 12:16:04.562 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.security.user. RandomAuthorizableNodeName.config, entity=config:org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName], digest=dc6eaa901cf36856d8b9026a2ee7ca56) 15.01.2018 12:16:04.571 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.security.user.UserConfigurationImpl from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.security.user. UserConfigurationImpl.config, entity=config:org.apache.jackrabbit.oak.security.user.UserConfigurationImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.security.user.UserConfigurationImpl], digest=6e657c52ca025b4cd0ac0cc8c56b8742) 15.01.2018 12:16:04.579 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.spi.security.a uthorization.cug.impl.CugConfiguration.config, entity=config:org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfigurat ion, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguratio n], digest=2c1d236d0d0894465925e8eeb531a814) 15.01.2018 12:16:04.589 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.jackrabbit.oak.spi.security.u ser.action.DefaultAuthorizableActionProvider.config, entity=config:org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActio nProvider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionP rovider], digest=7afd275af8ca914cfc7ef4a676dd94f2) 15.01.2018 12:16:04.594 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.caconfig.impl.ConfigurationResolverImpl from resource TaskResource(url=launchpad:resources/config/org.apache.sling.caconfig.impl.ConfigurationR esolverImpl.config, entity=config:org.apache.sling.caconfig.impl.ConfigurationResolverImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.caconfig.impl.ConfigurationResolverImpl], digest=f85febb58b8439b7b3737245a4122e7b) 15.01.2018 12:16:04.603 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.caconfig.resource.impl.def.DefaultConfigurationResourceResolvingStrategy from resource TaskResource(url=launchpad:resources/config/org.apache.sling.caconfig.resource.impl.def.D efaultConfigurationResourceResolvingStrategy.config, entity=config:org.apache.sling.caconfig.resource.impl.def.DefaultConfigurationResourceRes olvingStrategy, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.caconfig.resource.impl.def.DefaultConfigurationResourceResol vingStrategy], digest=35b12f6378e3358a9a0ec90701546c99) 15.01.2018 12:16:04.612 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.caconfig.resource.impl.def.DefaultContextPathStrategy from resource TaskResource(url=launchpad:resources/config/org.apache.sling.caconfig.resource.impl.def.D efaultContextPathStrategy.config, entity=config:org.apache.sling.caconfig.resource.impl.def.DefaultContextPathStrategy, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.caconfig.resource.impl.def.DefaultContextPathStrategy], digest=5537c6effefdc6873a4d4a0c0003e002) 15.01.2018 12:16:04.619 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.log.LogManager.confi g, entity=config:org.apache.sling.commons.log.LogManager, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.commons.log.LogManager], digest=6ef1e584be68e6bbb960082018cc70a4) 15.01.2018 12:16:04.632 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.f98f87ab-693c-4f4a-89be-eaee32ce88 51 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.log.LogManager.facto ry.config-access.log.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.access.log, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=access.log], digest=524d5c71807a0a7667a916b5d016d1e) 15.01.2018 12:16:04.655 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.9051ba64-1fdc-4bec-b3b3-7ede0c4ad5 e0 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.log.LogManager.facto ry.config-asyncjssightly.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.asyncjssightly, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=asyncjssightly], digest=d91b6afb5505acbf43413dbbc061cd57) 15.01.2018 12:16:04.675 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.22748ebb-1c93-4c72-ab1a-e9a9a93ff5 9c from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.log.LogManager.facto ry.config-audit.log.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.audit.log, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=audit.log], digest=19cf181e4bc1e8bb4bcb84f58eba0bda) 15.01.2018 12:16:04.691 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.d442f21f-db7a-43d0-ba32-8accf514fc d5 from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.commons.log.Lo gManager.factory.config-auditlog.log.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.auditlog.log, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=auditlog.log], digest=3d971a73014430c7dd1e2d689ddbea4c) 15.01.2018 12:16:04.709 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.0ae9176d-5d10-4041-8571-59e189ddd6 98 from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.commons.log.Lo gManager.factory.config-history.config.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.history.config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=history.config], digest=464d181f2c164ebbefdf61a8d431f71e) 15.01.2018 12:16:04.731 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.5812c1f2-0575-414a-a774-b65c73f872 b2 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.log.LogManager.facto ry.config-request.log.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.request.log, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=request.log], digest=c8f73387454ae1d795405bc82860f30d) 15.01.2018 12:16:04.745 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.config.39e53341-e5e5-4d11-8983-d77c90421b 2b from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.commons.log.Lo gManager.factory.config-upgrade.config.config, entity=config:org.apache.sling.commons.log.LogManager.factory.config.upgrade.config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.config, service.pid=upgrade.config], digest=108e37e2f6f1a907fc35a928d2d6cbee) 15.01.2018 12:16:04.761 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.log.LogManager.factory.writer.1967eaa0-f58a-44a6-b6cc-01f0bca8c0 5a from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.commons.log.Lo gManager.factory.writer-upgrade.config.config, entity=config:org.apache.sling.commons.log.LogManager.factory.writer.upgrade.config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.log.LogManager.factory.writer, service.pid=upgrade.config], digest=3663a5173ae10ec8b19dfe37fd2f50b4) 15.01.2018 12:16:04.775 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.scheduler.impl.QuartzScheduler from resource TaskResource(url=launchpad:resources/config/org.apache.sling.commons.scheduler.impl.Quart zScheduler.config, entity=config:org.apache.sling.commons.scheduler.impl.QuartzScheduler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.commons.scheduler.impl.QuartzScheduler], digest=67a40ae36570fd2b261619713233ade2) 15.01.2018 12:16:04.785 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.8240fa9b-7288-43cb-b4d1-e 6098b27c82e from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.sling.commons.threads.impl.De faultThreadPool.factory-cq-polling-importer.config, entity=config:org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.cq-polling- importer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.threads.impl.DefaultThreadPool.factory, service.pid=cq-polling-importer], digest=1f6bcffdf329d8dedeabf4b2cbca7b86) 15.01.2018 12:16:04.794 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.141af3df-0519-477d-a797-1 b48bb800fa2 from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.sling.commons.threads.impl.De faultThreadPool.factory-oak.config, entity=config:org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.oak, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.threads.impl.DefaultThreadPool.factory, service.pid=oak], digest=a66b6e3782a3322fc69076144748e07f) 15.01.2018 12:16:04.804 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.6154b7b3-4e5c-47fc-8dfc-5 8a00fbd4ac4 from resource TaskResource(url=launchpad:resources/config/crx3/org.apache.sling.commons.threads.impl.De faultThreadPool.factory-oak-observation.config, entity=config:org.apache.sling.commons.threads.impl.DefaultThreadPool.factory.oak-observa tion, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.commons.threads.impl.DefaultThreadPool.factory, service.pid=oak-observation], digest=994369a208a7e63d6a629b23ac9a0ca2) 15.01.2018 12:16:04.812 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.discovery.oak.Config from resource TaskResource(url=launchpad:resources/config/author.samplecontent/org.apache.sling.discove ry.oak.Config.config, entity=config:org.apache.sling.discovery.oak.Config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.discovery.oak.Config], digest=1fa567b18d140670bc10d79df88412) 15.01.2018 12:16:04.822 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.agent.impl.ForwardDistributionAgentFactory.928173d2-b481-49 5b-9b0e-75786c2e73a3 from resource TaskResource(url=launchpad:resources/config/author/org.apache.sling.distribution.agent.im pl.ForwardDistributionAgentFactory-publish.config, entity=config:org.apache.sling.distribution.agent.impl.ForwardDistributionAgentFactory.pu blish, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.agent.impl.ForwardDistributionAgentFacto ry, service.pid=publish], digest=71b9eed4a8ba7d5de3467d34ca635be9) 15.01.2018 12:16:04.831 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestAuthorizationStrateg yFactory.0b01f705-fdf7-4348-8292-df508939c3ae from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.agent.impl.Priv ilegeDistributionRequestAuthorizationStrategyFactory-default.config, entity=config:org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestAuthor izationStrategyFactory.default, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestA uthorizationStrategyFactory, service.pid=default], digest=7e77f47a58ab619d4834ddeb5298c1e8) 15.01.2018 12:16:04.840 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestAuthorizationStrateg yFactory.5aed2ed4-1ca4-4524-ba92-e7cc8a148026 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.agent.impl.Priv ilegeDistributionRequestAuthorizationStrategyFactory-privilegeReplicate.config, entity=config:org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestAuthor izationStrategyFactory.privilegeReplicate, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.agent.impl.PrivilegeDistributionRequestA uthorizationStrategyFactory, service.pid=privilegeReplicate], digest=bd56a1f71cb9d59cfeaadd51f6a26574) 15.01.2018 12:16:04.850 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.resources.impl.DistributionConfigurationResourceProviderFac tory.6bf0ff23-e978-40b2-ac56-2685f4a4ea90 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.resources.impl. DistributionConfigurationResourceProviderFactory-agents.config, entity=config:org.apache.sling.distribution.resources.impl.DistributionConfigurationResou rceProviderFactory.agents, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.resources.impl.DistributionConfiguration ResourceProviderFactory, service.pid=agents], digest=473af1418621765320225be4ecbfdff4) 15.01.2018 12:16:04.859 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.resources.impl.DistributionServiceResourceProviderFactory.b 45e4673-39de-4165-8af0-84c6350b92b5 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.resources.impl. DistributionServiceResourceProviderFactory-agents.config, entity=config:org.apache.sling.distribution.resources.impl.DistributionServiceResourcePro viderFactory.agents, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.resources.impl.DistributionServiceResour ceProviderFactory, service.pid=agents], digest=a23ceb346ede1de232b31ab1b15815f2) 15.01.2018 12:16:04.868 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.resources.impl.DistributionServiceResourceProviderFactory.3 84a764d-ef94-4373-a394-660569c5109e from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.resources.impl. DistributionServiceResourceProviderFactory-exporters.config, entity=config:org.apache.sling.distribution.resources.impl.DistributionServiceResourcePro viderFactory.exporters, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.resources.impl.DistributionServiceResour ceProviderFactory, service.pid=exporters], digest=8f9a9493e7faf16208ec6bf6d4527ff5) 15.01.2018 12:16:04.877 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.resources.impl.DistributionServiceResourceProviderFactory.0 e2a862b-0b9d-4f35-9ca6-b91908e26134 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.resources.impl. DistributionServiceResourceProviderFactory-importers.config, entity=config:org.apache.sling.distribution.resources.impl.DistributionServiceResourcePro viderFactory.importers, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.resources.impl.DistributionServiceResour ceProviderFactory, service.pid=importers], digest=9e2f3ef2f0d7b50cfc1f71744368fabd) 15.01.2018 12:16:04.887 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.distribution.serialization.impl.vlt.VaultDistributionPackageBuilderFacto ry.22a5380f-d2b0-4697-a992-ae3663b98ac4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.distribution.serialization.i mpl.vlt.VaultDistributionPackageBuilderFactory-default.config, entity=config:org.apache.sling.distribution.serialization.impl.vlt.VaultDistributionPacka geBuilderFactory.default, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.distribution.serialization.impl.vlt.VaultDistribution PackageBuilderFactory, service.pid=default], digest=ac57ed384e702990b8226699dafd33cf) 15.01.2018 12:16:04.897 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.engine.impl.SlingMainServlet from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.engine.impl.Sl ingMainServlet.config, entity=config:org.apache.sling.engine.impl.SlingMainServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.engine.impl.SlingMainServlet], digest=c63d6de9a5312503abc0b20c93409c44) 15.01.2018 12:16:04.905 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.engine.impl.auth.SlingAuthenticator from resource TaskResource(url=launchpad:resources/config/author/org.apache.sling.engine.impl.auth.Slin gAuthenticator.config, entity=config:org.apache.sling.engine.impl.auth.SlingAuthenticator, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.engine.impl.auth.SlingAuthenticator], digest=5e99f43a958519e21b9bc8d5d0cb046a) 15.01.2018 12:16:04.911 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.engine.impl.log.RequestLogger from resource TaskResource(url=launchpad:resources/config/org.apache.sling.engine.impl.log.RequestLogge r.config, entity=config:org.apache.sling.engine.impl.log.RequestLogger, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.engine.impl.log.RequestLogger], digest=a475207c9e345f2a0e987500d3df7fc4) 15.01.2018 12:16:04.920 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.impl.jobs.JobConsumerManager from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.impl.jobs.JobConsumerM anager.config, entity=config:org.apache.sling.event.impl.jobs.JobConsumerManager, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.event.impl.jobs.JobConsumerManager], digest=19fb85e811853eec4672ba3c3b79958) 15.01.2018 12:16:04.928 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.impl.jobs.jcr.PersistenceHandler from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.impl.jobs.jcr.Persiste nceHandler.config, entity=config:org.apache.sling.event.impl.jobs.jcr.PersistenceHandler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.event.impl.jobs.jcr.PersistenceHandler], digest=2012203feb4496321620e1c306a4d517) 15.01.2018 12:16:04.938 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.5a6d9f6b-7877-4beb-b767-c7d66554b13a from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-cfm.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.cfm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=cfm], digest=d39eebeddf8c8be5e7d147756def8fa2) 15.01.2018 12:16:04.948 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.aeecdae1-312f-4ad2-a278-e665edd2245b from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-colllectionupdate.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.colllectionupdate, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=colllectionupdate], digest=3efa6535d925bd9a3ed17bc2bc33a92f) 15.01.2018 12:16:04.958 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.026e741a-8357-4141-92ff-ba871f4b4f7a from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-distribution.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.distribution, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=distribution], digest=9e15af5bc932254955378e90dc915292) 15.01.2018 12:16:04.967 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.723fef09-7072-4b0d-b070-c96486ee58a1 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-ids.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.ids, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=ids], digest=93ab5bdfeae71adca02b11996e950e3b) 15.01.2018 12:16:04.977 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.9e7e2c2f-35be-4cec-b1e3-fbcbd32269e7 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-maintenance.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.maintenance, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=maintenance], digest=38d4ade53548a97e34eb8c4fb1a0ca83) 15.01.2018 12:16:04.985 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.800c8fcb-2c2f-440e-8ffa-cf735e496eb6 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-preupgradecheck.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.preupgradecheck, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=preupgradecheck], digest=1329cb2faca8ae46b5004e278377e61f) 15.01.2018 12:16:04.994 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.1ee8aeaa-ad07-473c-ac8f-c825b9a5520d from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-unzip.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.unzip, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=unzip], digest=86e65e29e985592c63e781b334659a3e) 15.01.2018 12:16:05.003 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.51ef0cdb-f14e-4ea4-a1e7-730f3f20d0e2 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-workflow.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.workflow, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=workflow], digest=888a17d3f5e60d974203908028fd0424) 15.01.2018 12:16:05.013 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.041e7512-b9f1-4d01-bc4d-cfa2fb524231 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-workflow-external.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.workflow-external, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=workflow-external], digest=cb03cde0a6189eb1c828873c633eea9a) 15.01.2018 12:16:05.022 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.d29c0b50-7f3a-4d2c-811a-c2d59d4c6830 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-workflow-external-process-polling.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.workflow-external-process-po lling, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=workflow-external-process-polling], digest=c93cc52faa820b4660bc7c4f0a44c480) 15.01.2018 12:16:05.030 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.ddec891f-111a-47ed-a96f-ec7d6ccdc301 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-workflow-timeout.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.workflow-timeout, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=workflow-timeout], digest=ff764db77000218bae20befce34bde80) 15.01.2018 12:16:05.041 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.event.jobs.QueueConfiguration.b329288a-7d9f-4f50-a8ec-aefbd0585d80 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.event.jobs.QueueConfiguratio n-workflow-transient.config, entity=config:org.apache.sling.event.jobs.QueueConfiguration.workflow-transient, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.event.jobs.QueueConfiguration, service.pid=workflow-transient], digest=57970467d739d11b84cf1b1312043a52) 15.01.2018 12:16:05.052 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.hc.core.impl.CompositeHealthCheck.7e220698-66aa-4691-94ca-c5e82e8cd462 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.hc.core.impl.CompositeHealth Check-security.config, entity=config:org.apache.sling.hc.core.impl.CompositeHealthCheck.security, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.hc.core.impl.CompositeHealthCheck, service.pid=security], digest=95a0935d4596d2993fbf4632baaeecfe) 15.01.2018 12:16:05.062 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.hc.core.impl.CompositeHealthCheck.3adf92b2-44b6-4a3d-b2d3-04880c6ac082 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.hc.core.impl.CompositeHealth Check-system.config, entity=config:org.apache.sling.hc.core.impl.CompositeHealthCheck.system, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.hc.core.impl.CompositeHealthCheck, service.pid=system], digest=c6a5e887aa367d003d784ddadb921a5b) 15.01.2018 12:16:05.071 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.hc.support.DefaultLoginsHealthCheck.ddfc83d2-7ed9-46b6-a621-c02f1990d799 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.hc.support.DefaultLoginsHeal thCheck-1.config, entity=config:org.apache.sling.hc.support.DefaultLoginsHealthCheck.1, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.hc.support.DefaultLoginsHealthCheck, service.pid=1], digest=5120b597915399a01621534d86ba3500) 15.01.2018 12:16:05.080 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.hc.support.SlingRequestStatusHealthCheck.79e13c41-035b-40db-9fd1-0d810a7 0540b from resource TaskResource(url=launchpad:resources/config/org.apache.sling.hc.support.SlingRequestStatu sHealthCheck-1.config, entity=config:org.apache.sling.hc.support.SlingRequestStatusHealthCheck.1, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.hc.support.SlingRequestStatusHealthCheck, service.pid=1], digest=88a2484bdd161118c4199dfcdbc3536e) 15.01.2018 12:16:05.089 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.i18n.impl.JcrResourceBundleProvider from resource TaskResource(url=launchpad:resources/config/org.apache.sling.i18n.impl.JcrResourceBundleP rovider.config, entity=config:org.apache.sling.i18n.impl.JcrResourceBundleProvider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.i18n.impl.JcrResourceBundleProvider], digest=277df1b1259299316bce1b25b444aa8f) 15.01.2018 12:16:05.096 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.installer.provider.jcr.impl.JcrInstaller from resource TaskResource(url=launchpad:resources/config/org.apache.sling.installer.provider.jcr.impl. JcrInstaller.config, entity=config:org.apache.sling.installer.provider.jcr.impl.JcrInstaller, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.installer.provider.jcr.impl.JcrInstaller], digest=aaa553e50dbe4e35b47bdee8cb64dbc6) 15.01.2018 12:16:05.106 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.3f87bee4-5643-4ad0-be6c-2 398d982523b from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-cq-assets.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cq-assets, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=cq-assets], digest=b6bdbba729aa3646b1dcd104cc151d7a) 15.01.2018 12:16:05.115 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.df1246d9-22ef-4925-b650-f 590b6a97ac6 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-cq-integrations.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cq-integrat ions, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=cq-integrations], digest=c4282b1edb2c7d6a9d4e5cbdcfffccb3) 15.01.2018 12:16:05.124 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.e616d9a8-b1bc-4526-a986-4 0215fc9dceb from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-cq-platform.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cq-platform , state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=cq-platform], digest=eb23f11a1e9f907b4526376217433a21) 15.01.2018 12:16:05.132 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.7488eef6-1937-43b9-aa57-7 890289e2291 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-cq-upgrade.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cq-upgrade, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=cq-upgrade], digest=9c472c32548d50c9b081b8a3dc13dcfa) 15.01.2018 12:16:05.142 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cae930f2-d2b6-4abe-944d-b 683a97877bd from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-cq-wcm.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cq-wcm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=cq-wcm], digest=ee1bb8aa478d8a25cfacb55afec3e929) 15.01.2018 12:16:05.151 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cd20bd1f-c694-475b-81fa-1 c0bfd7ce963 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-granite.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.granite, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=granite], digest=b3b92a50f64f5c6de003d0d6552acb15) 15.01.2018 12:16:05.161 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.fd7d1973-5e21-42e2-9d69-b 6210165832b from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-quickstart.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.quickstart, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=quickstart], digest=8167e7c65df6dafedeeadb2f4b1eaf59) 15.01.2018 12:16:05.170 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.8531486d-fca9-4270-a779-c 6d4afeaeba7 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-sling.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.sling, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=sling], digest=229a3362de889299d2fccfc957f877b8) 15.01.2018 12:16:05.179 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.e72661f9-cdc4-429c-bb84-e 40fb8731b49 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.base.internal.LoginAdmin Whitelist.fragment-sling-junit.config, entity=config:org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.sling-junit , state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment, service.pid=sling-junit], digest=132875c2a5e553601c65730837d402e2) 15.01.2018 12:16:05.185 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.davex.impl.servlets.SlingDavExServlet from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.jcr.davex.impl .servlets.SlingDavExServlet.config, entity=config:org.apache.sling.jcr.davex.impl.servlets.SlingDavExServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.jcr.davex.impl.servlets.SlingDavExServlet], digest=f370bbb470f0148c538c224038875cab) 15.01.2018 12:16:05.194 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.repoinit.impl.RepositoryInitializer from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.repoinit.impl.Repository Initializer.config, entity=config:org.apache.sling.jcr.repoinit.impl.RepositoryInitializer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.jcr.repoinit.impl.RepositoryInitializer], digest=62590adee787f806d60b246345ae4991) 15.01.2018 12:16:05.203 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.resource.internal.JcrResourceResolverFactoryImpl from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.resource.internal.JcrRes ourceResolverFactoryImpl.config, entity=config:org.apache.sling.jcr.resource.internal.JcrResourceResolverFactoryImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.jcr.resource.internal.JcrResourceResolverFactoryImpl], digest=1c4cca0d70f9ad98713c6404661fc8c0) 15.01.2018 12:16:05.213 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.resourcesecurity.impl.ResourceAccessGateFactory.e87b13a2-d1ca-461e-8 9e8-aae3436ed228 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.jcr.resourcesecurity.impl.Re sourceAccessGateFactory-jmx.config, entity=config:org.apache.sling.jcr.resourcesecurity.impl.ResourceAccessGateFactory.jmx, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.jcr.resourcesecurity.impl.ResourceAccessGateFactory, service.pid=jmx], digest=46f5569680ce00485b7c2a6ec8d1ba0c) 15.01.2018 12:16:05.220 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.jcr.webdav.impl.servlets.SimpleWebDavServlet from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.jcr.webdav.imp l.servlets.SimpleWebDavServlet.config, entity=config:org.apache.sling.jcr.webdav.impl.servlets.SimpleWebDavServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.jcr.webdav.impl.servlets.SimpleWebDavServlet], digest=ef3739875d7e6a4ab289c67f5268c8cc) 15.01.2018 12:16:05.231 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.resource.inventory.impl.ResourceInventoryPrinterFactory.b6375217-ab9f-4d 2e-b0df-3dfa1d20fcfc from resource TaskResource(url=launchpad:resources/config/org.apache.sling.resource.inventory.impl.Reso urceInventoryPrinterFactory-jmx.config, entity=config:org.apache.sling.resource.inventory.impl.ResourceInventoryPrinterFactory.jm x, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.resource.inventory.impl.ResourceInventoryPrinterFacto ry, service.pid=jmx], digest=779c8b4fe54be9d881677b0c081c65fd) 15.01.2018 12:16:05.240 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.resourcemerger.picker.overriding from resource TaskResource(url=launchpad:resources/config/org.apache.sling.resourcemerger.picker.overri ding.config, entity=config:org.apache.sling.resourcemerger.picker.overriding, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.resourcemerger.picker.overriding], digest=8a4477c2a7979de4d3981d2e94066296) 15.01.2018 12:16:05.249 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.scripting.core.impl.ScriptCacheImpl from resource TaskResource(url=launchpad:resources/config/org.apache.sling.scripting.core.impl.ScriptCa cheImpl.config, entity=config:org.apache.sling.scripting.core.impl.ScriptCacheImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.scripting.core.impl.ScriptCacheImpl], digest=13b57519a048a6c8873ed61949d013f6) 15.01.2018 12:16:05.258 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.scripting.java.impl.JavaScriptEngineFactory from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.scripting.java .impl.JavaScriptEngineFactory.config, entity=config:org.apache.sling.scripting.java.impl.JavaScriptEngineFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.scripting.java.impl.JavaScriptEngineFactory], digest=e611ded9a62e6cec2171dec698918c86) 15.01.2018 12:16:05.267 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.scripting.jsp.JspScriptEngineFactory from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.scripting.jsp. JspScriptEngineFactory.config, entity=config:org.apache.sling.scripting.jsp.JspScriptEngineFactory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.scripting.jsp.JspScriptEngineFactory], digest=dccf4d92f297e247082107841c73d246) 15.01.2018 12:16:05.277 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.scripting.sightly.js.impl.jsapi.SlyBindingsValuesProvider from resource TaskResource(url=launchpad:resources/config/org.apache.sling.scripting.sightly.js.impl.js api.SlyBindingsValuesProvider.config, entity=config:org.apache.sling.scripting.sightly.js.impl.jsapi.SlyBindingsValuesProvider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.scripting.sightly.js.impl.jsapi.SlyBindingsValuesProvider], digest=dd324c155a7a3a1b761508fc3297c4bf) 15.01.2018 12:16:05.284 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.security.impl.ContentDispositionFilter from resource TaskResource(url=launchpad:resources/config/org.apache.sling.security.impl.ContentDisposi tionFilter.config, entity=config:org.apache.sling.security.impl.ContentDispositionFilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.security.impl.ContentDispositionFilter], digest=29389a07802287c454b838be5e004d3f) 15.01.2018 12:16:05.293 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl], digest=a9cf4b4bec2fc90e68098127cb9fc266) 15.01.2018 12:16:05.304 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.5152051c-2bb2-49e8 -9d50-ac8bbc47406f from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-activitystreams.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.acti vitystreams, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=activitystreams], digest=d0108def26c59e0059598c8fb82f1cb0) 15.01.2018 12:16:05.313 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.be1a6938-ab0c-4729 -935d-e59c48fe481f from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-af.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.af, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=af], digest=9a6b582bd39621251146804fd22554ac) 15.01.2018 12:16:05.322 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c8fbe2a5-b2fc-4028 -8bbb-05d348e56ada from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-analytics.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.anal ytics, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=analytics], digest=388c7167a3dfcf6e16aa49a4f19cd53) 15.01.2018 12:16:05.331 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3968f32a-8e4b-44b4 -ad01-97e00b6dbb45 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-analytics-content-updater.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.anal ytics-content-updater, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=analytics-content-updater], digest=6b1f0500d11d32d2ce352a6b1ccbd765) 15.01.2018 12:16:05.340 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.569440f1-5879-4c47 -9b4c-ca388f8020d4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-authcert.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.auth cert, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=authcert], digest=cd0ffea3f81051f4a854b5764e4b3bf) 15.01.2018 12:16:05.349 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.d670a670-3d31-40e6 -a844-2f7e31232776 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-authoauth.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.auth oauth, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=authoauth], digest=c35cd9709fd4cbbaf6db78c5cd3872f2) 15.01.2018 12:16:05.359 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.341b5455-aa3e-4f9e -9a2f-4bc1f29ac507 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-authsaml.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.auth saml, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=authsaml], digest=d6cf254ba846a2e3f40fbb6c02ce638a) 15.01.2018 12:16:05.368 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.a7e5b84d-1282-4d55 -bfa7-f6ef1f295038 from resource TaskResource(url=launchpad:resources/config/author/org.apache.sling.serviceusermapping.im pl.ServiceUserMapperImpl.amended-cdn-integration.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cdn- integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cdn-integration], digest=fcdcb53ae652dc088fe52904a7430015) 15.01.2018 12:16:05.377 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.239f46fa-fe6f-4c9c -b323-8d16c930fa7f from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-clientlibs.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.clie ntlibs, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=clientlibs], digest=85068dfc12006d2f64815b8e56875b17) 15.01.2018 12:16:05.388 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.143f9583-246a-4c30 -833f-77c2c2410652 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-com.adobe.dam.cq-dam-cfm-impl.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.com. adobe.dam.cq-dam-cfm-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=com.adobe.dam.cq-dam-cfm-impl], digest=7a1e9ebdcee460ac68cca1d18dc3f68f) 15.01.2018 12:16:05.400 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.5c8b8056-57b7-4a68 -b838-718605814c82 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-commerce.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.comm erce, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=commerce], digest=2989e17cab0628f5faed592e27e95a8b) 15.01.2018 12:16:05.410 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6f122b33-17db-418e -bda8-0c15e3528123 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-compat-codeupgrade.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.comp at-codeupgrade, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=compat-codeupgrade], digest=af999e8c3b30cb16d403bfd27ee3738) 15.01.2018 12:16:05.419 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3d1ee316-72fe-4eca -800a-177abeb47dfa from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-contentsync.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cont entsync, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=contentsync], digest=a4ceb9088296e73cb100fc749aae9a33) 15.01.2018 12:16:05.429 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.794a8e6f-7d5f-4d70 -9022-1420a4a7d5a2 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-contextaware-config-webconsole.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cont extaware-config-webconsole, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=contextaware-config-webconsole], digest=b14fd6957c7e670c2b78b431c5f63b8e) 15.01.2018 12:16:05.439 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.fb49b179-4515-4e80 -b324-56b043363678 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-cq-dtm.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cq-d tm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cq-dtm], digest=31c3dfe51954dd5050ba28a430050b8b) 15.01.2018 12:16:05.448 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.4ccd7a51-07fd-4b51 -8ce6-a142d3eaa21d from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-cq-experience-fragments.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cq-e xperience-fragments, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cq-experience-fragments], digest=5f31de3477bde560152a091d6a261758) 15.01.2018 12:16:05.458 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.613c54ac-4287-400b -a375-96c5f5c28366 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-cq-searchpromote.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cq-s earchpromote, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cq-searchpromote], digest=2dce3b7047b8637a9eac4e663e5af9cf) 15.01.2018 12:16:05.468 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.00c2e906-a62a-46ab -aed7-180975e406f5 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-cryptoservice.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cryp toservice, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cryptoservice], digest=94df13106e15cab2aa523a3a7f12ffac) 15.01.2018 12:16:05.477 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1d83466d-3931-49f2 -817a-cdfa087a20f3 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-cugservice.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.cugs ervice, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=cugservice], digest=f39568511d4c3ae3255b5b80ff044353) 15.01.2018 12:16:05.487 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.94f497e8-9ff3-4b75 -9048-9694a4211aa4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-dam.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.dam, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=dam], digest=290cee17bb05616ad23c7516399fd1ae) 15.01.2018 12:16:05.495 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.68246c6b-49dd-46fc -b715-de9684b0281a from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-distribution-defaultAgentService.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.dist ribution-defaultAgentService, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=distribution-defaultAgentService], digest=6d256ea94d98c568b87c003b80130491) 15.01.2018 12:16:05.504 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.090e77f6-dd1a-4609 -b0ac-71944009ca48 from resource TaskResource(url=launchpad:resources/config/author/org.apache.sling.serviceusermapping.im pl.ServiceUserMapperImpl.amended-dpsapps.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.dpsa pps, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=dpsapps], digest=261b688ac1b78943e342cd1310aa2ecd) 15.01.2018 12:16:05.514 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9878420b-428f-4c0a -b790-454b3881951c from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-fd.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.fd, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=fd], digest=f81032fa33e3f824b540c6bbf09a90ee) 15.01.2018 12:16:05.523 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2c456444-c01a-4863 -9037-951d0b071b67 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-foundation.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.foun dation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=foundation], digest=c29e4d68d2bb654fdbbbe2b308344633) 15.01.2018 12:16:05.532 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1f9d2f6-546f-4438 -b051-d8b235aa06f7 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-fp.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.fp, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=fp], digest=f98cbfb92afbd062a1789f9b5be6771c) 15.01.2018 12:16:05.542 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.31d53c12-58ed-4ea6 -a1a8-ff8d670b9566 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-i18n.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.i18n , state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=i18n], digest=5ca453becbd0de7378d7d5707823f9a8) 15.01.2018 12:16:05.551 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1b6d4f08-aa08-44d1 -8112-425b4c387e36 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-inbox-content.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.inbo x-content, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=inbox-content], digest=10f7d0e40c635fcaad4d16f75e738459) 15.01.2018 12:16:05.560 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.8e848940-20cd-47f7 -91a8-daa771f87e9e from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-jcr-install.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.jcr- install, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=jcr-install], digest=c54b829f7b7740a799d99e251af020c9) 15.01.2018 12:16:05.570 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.040e2c0c-3e1b-4020 -b404-a6915a6c484f from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-jetty-ssl.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.jett y-ssl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=jetty-ssl], digest=4720baed103498abe05232986b31b962) 15.01.2018 12:16:05.579 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.0ba8f83a-9400-4130 -ae19-9958a2400fee from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-keystoreservice.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.keys toreservice, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=keystoreservice], digest=1519b2b67554388038e3a0f9196cba14) 15.01.2018 12:16:05.588 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.91e95d6c-e6bc-4c7f -9082-7873299c771d from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-mcm-campaign.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.mcm- campaign, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=mcm-campaign], digest=280e7e39bb82deaf2e38923206554fcc) 15.01.2018 12:16:05.597 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3b2063ef-315d-44d1 -a3e6-fe7bc97c797c from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-media.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.medi a, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=media], digest=6534dff9c61483b5db29cb6981d6b6a2) 15.01.2018 12:16:05.606 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9e1a4e62-c527-4b74 -b795-e8d826a68b97 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-mf.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.mf, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=mf], digest=c862b11276ee1ca2b53da1f1065aefda) 15.01.2018 12:16:05.615 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.e32ce7b9-721d-4daa -a2db-f33dc3c4ced0 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-mobile.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.mobi le, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=mobile], digest=be78e9349581b4c769f1959bdec9dcb3) 15.01.2018 12:16:05.624 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1b34a99-346a-42f9 -82bf-aa1609ff7aba from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-monitoringScripts.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.moni toringScripts, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=monitoringScripts], digest=2cec2b338b36b003f3ff2ab491776371) 15.01.2018 12:16:05.633 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1425718-5f88-41eb -99c7-fc1af7819a14 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-msm.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.msm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=msm], digest=ce76eb399adfd3cccc3099355be86a83) 15.01.2018 12:16:05.643 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.29ba025c-0a4a-4df6 -800f-3dfe74064d91 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-observation.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.obse rvation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=observation], digest=b358fca04fc5775b5fee0983520f157b) 15.01.2018 12:16:05.652 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.e4d09b98-ae17-4b5d -88f5-de87acc8552a from resource TaskResource(url=launchpad:resources/config/author/org.apache.sling.serviceusermapping.im pl.ServiceUserMapperImpl.amended-offloading.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.offl oading, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=offloading], digest=1ca3c67ce91b0b9644ed950bb41b0f06) 15.01.2018 12:16:05.662 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f5245b1b-d0ee-425b -97f1-519fa834dd38 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-packagelist-service.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.pack agelist-service, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=packagelist-service], digest=fba3273cdf327aba529f187c08bfc97b) 15.01.2018 12:16:05.671 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.a1204272-2ba3-4de4 -9e3e-aa77807b75eb from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-projects.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.proj ects, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=projects], digest=162f961f31993716da99980c42e97d08) 15.01.2018 12:16:05.680 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.501e87b6-a917-4001 -99d4-20f762b3c357 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-replication.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.repl ication, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=replication], digest=42262abf9b44299fa6d358280ca325e9) 15.01.2018 12:16:05.689 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.631aca08-e2ba-4480 -a1aa-8318836eeb2b from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-resourceresolver.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.reso urceresolver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=resourceresolver], digest=d317bcbc20315e21bdbb0480199d7a55) 15.01.2018 12:16:05.699 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f47a17a3-3615-4d5b -a70a-92d019267d63 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-screens.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.scre ens, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=screens], digest=d8d64f07679d076d2f2bdb2225ba51c2) 15.01.2018 12:16:05.709 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6bf3083a-ce8b-4412 -8470-6e6dd5ed71d4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-security.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.secu rity, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=security], digest=674b79e559576b260db1c895da454577) 15.01.2018 12:16:05.718 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.bb11e0a1-efcf-44f8 -8e76-db04201b8e43 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-security-userproperties.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.secu rity-userproperties, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=security-userproperties], digest=7219346b29ee94bc7414d320ffc955b7) 15.01.2018 12:16:05.727 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.7d0f49b9-fd4a-41ab -9c34-f7ee8e30cf4d from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling-installer.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g-installer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling-installer], digest=40f3004be81fd6aac8c10f8f6357819f) 15.01.2018 12:16:05.736 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.89c46e54-fb0a-4753 -b48d-60250718d6c1 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling-scripting.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g-scripting, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling-scripting], digest=1f5c73d6ed851ef2a24ed773f0dbef3e) 15.01.2018 12:16:05.745 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.b7c693b6-4cfa-4203 -9ab3-e4bc55702eb0 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling-scripting-wcm.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g-scripting-wcm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling-scripting-wcm], digest=7a932d7be38912251fbbe95ee4572fa0) 15.01.2018 12:16:05.754 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.b8333d27-ff44-46b2 -83f8-f07e76238f45 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling-xss.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g-xss, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling-xss], digest=b06e9403f281f674e2a20727ddc09874) 15.01.2018 12:16:05.763 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c3593723-47f8-48a8 -9695-d95c846dc1f5 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling.discovery.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g.discovery, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling.discovery], digest=49f8c02a6e35568185d429678b3264ee) 15.01.2018 12:16:05.773 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.01ae22cf-d74a-4203 -95d4-f9b0252ad384 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling.event.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g.event, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling.event], digest=93dccd670f84159c69e74973251b7371) 15.01.2018 12:16:05.784 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2e24940e-6946-4667 -9044-c03e2bbd9043 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-sling.rewriter.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.slin g.rewriter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=sling.rewriter], digest=c7c3e9687418a017c3af30812bc43ce) 15.01.2018 12:16:05.794 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1855d1b7-38c9-42a5 -b903-28486ad04763 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-ssl-service.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.ssl- service, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=ssl-service], digest=b30e1de8f89a8cad9c6d055c92690b44) 15.01.2018 12:16:05.804 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.55b3d89f-6725-4cca -bcd8-c9b05c133096 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-statistics-service.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.stat istics-service, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=statistics-service], digest=c7969f52e50551c2abce14898aaea432) 15.01.2018 12:16:05.813 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f0450926-5c30-412e -b034-65e36997a20e from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-target.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.targ et, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=target], digest=21a57e2865bf233927da4a6a4d1d0eb0) 15.01.2018 12:16:05.823 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.87671407-ce38-496b -8e60-05abaa177304 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-targeted-content.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.targ eted-content, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=targeted-content], digest=72d6c5027978fa1d413d775b50b81582) 15.01.2018 12:16:05.834 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.03bf9e41-9d6f-4a6d -82db-493700eba29e from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-targetrecs-deleted-listener.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.targ etrecs-deleted-listener, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=targetrecs-deleted-listener], digest=66482e584deee5d284a29d00f9440e35) 15.01.2018 12:16:05.843 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.8ae923af-6580-4a93 -9dd7-9fcc29cf4347 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-taskmanagement.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.task management, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=taskmanagement], digest=c5d74dfb615e4ab9c21c0ad5f7131d50) 15.01.2018 12:16:05.852 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.985a0264-8da7-4ad8 -b9ea-b1e7d37714a4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-tenant.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.tena nt, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=tenant], digest=32495be204d8f8dd514d4479360ee60) 15.01.2018 12:16:05.862 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.aec6a034-ed86-4b4a -9aa8-754ff27ed8c5 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-translation-config.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.tran slation-config, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=translation-config], digest=c31cbfd6d685f0e3ee7de7891a3a0880) 15.01.2018 12:16:05.871 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2d44c26c-30b0-4acc -beb4-88d8ab933456 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-translation-job.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.tran slation-job, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=translation-job], digest=1b4481bd4dbe29bb3277f61b22be194c) 15.01.2018 12:16:05.881 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6fca6e5e-5dd0-4f5f -b74f-b7a0f6c535df from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-wcm-core.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.wcm- core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=wcm-core], digest=8b0bb1e8ad92a3688af3541cde57a959) 15.01.2018 12:16:05.891 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.ab4f09f0-65ab-45b8 -8ffb-169b793fbde4 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-wcm-designimporter.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.wcm- designimporter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=wcm-designimporter], digest=6f72311167ada3e8d7b09060299d2dd4) 15.01.2018 12:16:05.901 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.84593fdf-9c7d-466f -864d-4300e0709045 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-wcm-launches-core.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.wcm- launches-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=wcm-launches-core], digest=9da41ddb73985d82ed1e1beef8190621) 15.01.2018 12:16:05.910 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9f9fe721-c9ce-4aed -be57-0804f425b4cd from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-wcm-notification.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.wcm- notification, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=wcm-notification], digest=953c77c93bcecd8878647f091141877) 15.01.2018 12:16:05.920 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.53ac22f2-2127-4f14 -a453-56634190a259 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-webservice-support.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.webs ervice-support, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=webservice-support], digest=cbcecf9ed5772c24470e7e03e416babe) 15.01.2018 12:16:05.929 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.dd3524fe-e132-46b5 -b275-bdcc6e3d41a7 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-workflow.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.work flow, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=workflow], digest=2a92fca0cb3e7aa5b2d1c5b59bcf5614) 15.01.2018 12:16:05.939 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3b255a96-b268-4736 -a1a7-7e4f559e6cd9 from resource TaskResource(url=launchpad:resources/config/org.apache.sling.serviceusermapping.impl.Serv iceUserMapperImpl.amended-wurfl-service.config, entity=config:org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.wurf l-service, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.factoryPid=org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended , service.pid=wurfl-service], digest=7a586a8ce55934f1954646f1ce88c107) 15.01.2018 12:16:05.949 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.servlets.get.DefaultGetServlet from resource TaskResource(url=launchpad:resources/config/samplecontent/org.apache.sling.servlets.get.D efaultGetServlet.config, entity=config:org.apache.sling.servlets.get.DefaultGetServlet, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.servlets.get.DefaultGetServlet], digest=d95714013bec89f7988fe0fc8aae4846) 15.01.2018 12:16:05.958 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed configuration org.apache.sling.servlets.resolver.SlingServletResolver from resource TaskResource(url=launchpad:resources/config/org.apache.sling.servlets.resolver.SlingServl etResolver.config, entity=config:org.apache.sling.servlets.resolver.SlingServletResolver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:, service.pid=org.apache.sling.servlets.resolver.SlingServletResolver], digest=716aef24a0a1b1c82e37df00abf6d901) 15.01.2018 12:16:06.094 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall BundleEvent INSTALLED 15.01.2018 12:16:06.095 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-deserialization-firewall [21] from resource TaskResource(url=launchpad:resources/install/1/cq-deserialization-firewall-1.0.16.jar, entity=bundle:com.adobe.cq.cq-deserialization-firewall, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-deserialization-firewall, Bundle-Version=1.0.16], digest=1515998757000) 15.01.2018 12:16:06.098 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.cq.cq-deserialization-firewall [21] to 1 15.01.2018 12:16:06.157 *INFO* [OsgiInstallerImpl] com.day.cq.cq-compat-configupdate BundleEvent INSTALLED 15.01.2018 12:16:06.157 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-compat-configupdate [22] from resource TaskResource(url=launchpad:resources/install/2/cq-compat-configupdate-3.0.0.jar, entity=bundle:com.day.cq.cq-compat-configupdate, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-compat-configupdate, Bundle-Version=3.0.0], digest=1515998757000) 15.01.2018 12:16:06.161 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-compat-configupdate [22] to 2 15.01.2018 12:16:06.264 *INFO* [OsgiInstallerImpl] org.apache.aries.jmx.api BundleEvent INSTALLED 15.01.2018 12:16:06.264 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.aries.jmx.api [23] from resource TaskResource(url=launchpad:resources/install/2/org.apache.aries.jmx.api-1.1.5.jar, entity=bundle:org.apache.aries.jmx.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.aries.jmx.api, Bundle-Version=1.1.5], digest=1515998757000) 15.01.2018 12:16:06.267 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.aries.jmx.api [23] to 2 15.01.2018 12:16:06.279 *INFO* [OsgiInstallerImpl] org.apache.aries.jmx.core BundleEvent INSTALLED 15.01.2018 12:16:06.279 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.aries.jmx.core [24] from resource TaskResource(url=launchpad:resources/install/2/org.apache.aries.jmx.core-1.1.5.jar, entity=bundle:org.apache.aries.jmx.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.aries.jmx.core, Bundle-Version=1.1.5], digest=1515998757000) 15.01.2018 12:16:06.282 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.aries.jmx.core [24] to 2 15.01.2018 12:16:06.350 *INFO* [OsgiInstallerImpl] org.apache.aries.jmx.whiteboard BundleEvent INSTALLED 15.01.2018 12:16:06.350 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.aries.jmx.whiteboard [25] from resource TaskResource(url=launchpad:resources/install/2/org.apache.aries.jmx.whiteboard-1.1.5.jar, entity=bundle:org.apache.aries.jmx.whiteboard, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.aries.jmx.whiteboard, Bundle-Version=1.1.5], digest=1515998757000) 15.01.2018 12:16:06.353 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.aries.jmx.whiteboard [25] to 2 15.01.2018 12:16:06.365 *INFO* [OsgiInstallerImpl] org.apache.aries.transaction.manager BundleEvent INSTALLED 15.01.2018 12:16:06.365 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.aries.transaction.manager [26] from resource TaskResource(url=launchpad:resources/install/2/org.apache.aries.transaction.manager-1.2.0 .jar, entity=bundle:org.apache.aries.transaction.manager, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.aries.transaction.manager, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:06.369 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.aries.transaction.manager [26] to 2 15.01.2018 12:16:06.432 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.api BundleEvent INSTALLED 15.01.2018 12:16:06.432 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.discovery.api [27] from resource TaskResource(url=launchpad:resources/install/2/org.apache.sling.discovery.api-1.0.4.jar, entity=bundle:org.apache.sling.discovery.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.discovery.api, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:06.435 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.discovery.api [27] to 2 15.01.2018 12:16:06.446 *INFO* [OsgiInstallerImpl] org.apache.sling.provisioning.model BundleEvent INSTALLED 15.01.2018 12:16:06.446 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.provisioning.model [28] from resource TaskResource(url=launchpad:resources/install/2/org.apache.sling.provisioning.model-1.8.0. jar, entity=bundle:org.apache.sling.provisioning.model, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.provisioning.model, Bundle-Version=1.8.0], digest=1515998757000) 15.01.2018 12:16:06.450 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.provisioning.model [28] to 2 15.01.2018 12:16:06.461 *INFO* [OsgiInstallerImpl] org.apache.felix.eventadmin BundleEvent INSTALLED 15.01.2018 12:16:06.461 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.eventadmin [29] from resource TaskResource(url=launchpad:resources/install/4/org.apache.felix.eventadmin-1.4.8.jar, entity=bundle:org.apache.felix.eventadmin, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.eventadmin, Bundle-Version=1.4.8], digest=1515998757000) 15.01.2018 12:16:06.464 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.eventadmin [29] to 4 15.01.2018 12:16:06.475 *INFO* [OsgiInstallerImpl] org.apache.felix.metatype BundleEvent INSTALLED 15.01.2018 12:16:06.476 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.metatype [30] from resource TaskResource(url=launchpad:resources/install/4/org.apache.felix.metatype-1.1.2.jar, entity=bundle:org.apache.felix.metatype, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.metatype, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:06.479 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.metatype [30] to 4 15.01.2018 12:16:06.493 *INFO* [OsgiInstallerImpl] org.apache.felix.scr BundleEvent INSTALLED 15.01.2018 12:16:06.493 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.scr [31] from resource TaskResource(url=launchpad:resources/install/4/org.apache.felix.scr-2.1.0-B001.jar, entity=bundle:org.apache.felix.scr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.scr, Bundle-Version=2.1.0.B001], digest=1515998757000) 15.01.2018 12:16:06.497 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.scr [31] to 4 15.01.2018 12:16:06.512 *INFO* [OsgiInstallerImpl] com.adobe.granite.joda-time BundleEvent INSTALLED 15.01.2018 12:16:06.512 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.joda-time [32] from resource TaskResource(url=launchpad:resources/install/5/com.adobe.granite.joda-time-2.9.1.jar, entity=bundle:com.adobe.granite.joda-time, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.joda-time, Bundle-Version=2.9.1], digest=1515998757000) 15.01.2018 12:16:06.516 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.joda-time [32] to 5 15.01.2018 12:16:06.584 *INFO* [OsgiInstallerImpl] com.adobe.granite.webconsole.plugins BundleEvent INSTALLED 15.01.2018 12:16:06.584 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.webconsole.plugins [33] from resource TaskResource(url=launchpad:resources/install/5/com.adobe.granite.webconsole.plugins-1.0.1 0.jar, entity=bundle:com.adobe.granite.webconsole.plugins, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.webconsole.plugins, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:06.587 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.webconsole.plugins [33] to 5 15.01.2018 12:16:06.599 *INFO* [OsgiInstallerImpl] org.apache.commons.fileupload BundleEvent INSTALLED 15.01.2018 12:16:06.599 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.fileupload [34] from resource TaskResource(url=launchpad:resources/install/5/commons-fileupload-1.3.2.jar, entity=bundle:org.apache.commons.fileupload, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.fileupload, Bundle-Version=1.3.2], digest=1515998757000) 15.01.2018 12:16:06.602 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.commons.fileupload [34] to 5 15.01.2018 12:16:06.617 *INFO* [OsgiInstallerImpl] org.apache.commons.lang3 BundleEvent INSTALLED 15.01.2018 12:16:06.617 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.lang3 [35] from resource TaskResource(url=launchpad:resources/install/5/commons-lang3-3.5.jar, entity=bundle:org.apache.commons.lang3, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.lang3, Bundle-Version=3.5.0], digest=1515998757000) 15.01.2018 12:16:06.620 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.commons.lang3 [35] to 5 15.01.2018 12:16:06.641 *INFO* [OsgiInstallerImpl] org.apache.httpcomponents.httpclient BundleEvent INSTALLED 15.01.2018 12:16:06.641 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.httpcomponents.httpclient [36] from resource TaskResource(url=launchpad:resources/install/5/httpclient-osgi-4.5.2.jar, entity=bundle:org.apache.httpcomponents.httpclient, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.httpcomponents.httpclient, Bundle-Version=4.5.2], digest=1515998757000) 15.01.2018 12:16:06.644 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.httpcomponents.httpclient [36] to 5 15.01.2018 12:16:06.660 *INFO* [OsgiInstallerImpl] org.apache.httpcomponents.httpcore BundleEvent INSTALLED 15.01.2018 12:16:06.660 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.httpcomponents.httpcore [37] from resource TaskResource(url=launchpad:resources/install/5/httpcore-osgi-4.4.5.jar, entity=bundle:org.apache.httpcomponents.httpcore, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.httpcomponents.httpcore, Bundle-Version=4.4.5], digest=1515998757000) 15.01.2018 12:16:06.663 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.httpcomponents.httpcore [37] to 5 15.01.2018 12:16:06.774 *INFO* [OsgiInstallerImpl] com.adobe.granite.bundles.json BundleEvent INSTALLED 15.01.2018 12:16:06.774 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.bundles.json [38] from resource TaskResource(url=launchpad:resources/install/5/json-20090211_1.jar, entity=bundle:com.adobe.granite.bundles.json, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.bundles.json, Bundle-Version=20090211.0.0.1], digest=1515998757000) 15.01.2018 12:16:06.778 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.bundles.json [38] to 5 15.01.2018 12:16:06.805 *INFO* [OsgiInstallerImpl] org.apache.felix.http.jetty BundleEvent INSTALLED 15.01.2018 12:16:06.805 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.http.jetty [39] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.http.jetty-3.4.0-B002.jar , entity=bundle:org.apache.felix.http.jetty, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.http.jetty, Bundle-Version=3.4.0.B002], digest=1515998757000) 15.01.2018 12:16:06.808 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.http.jetty [39] to 5 15.01.2018 12:16:06.822 *INFO* [OsgiInstallerImpl] org.apache.felix.http.servlet-api BundleEvent INSTALLED 15.01.2018 12:16:06.822 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.http.servlet-api [40] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.http.servlet-api-1.1.2.ja r, entity=bundle:org.apache.felix.http.servlet-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.http.servlet-api, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:06.826 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.http.servlet-api [40] to 5 15.01.2018 12:16:06.990 *INFO* [OsgiInstallerImpl] org.apache.felix.http.whiteboard BundleEvent INSTALLED 15.01.2018 12:16:06.990 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.http.whiteboard [41] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.http.whiteboard-3.0.0.jar , entity=bundle:org.apache.felix.http.whiteboard, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.http.whiteboard, Bundle-Version=3.0.0], digest=1515998757000) 15.01.2018 12:16:06.994 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.http.whiteboard [41] to 5 15.01.2018 12:16:07.005 *INFO* [OsgiInstallerImpl] org.apache.felix.inventory BundleEvent INSTALLED 15.01.2018 12:16:07.005 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.inventory [42] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.inventory-1.0.4.jar, entity=bundle:org.apache.felix.inventory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.inventory, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:07.008 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.inventory [42] to 5 15.01.2018 12:16:07.089 *INFO* [OsgiInstallerImpl] org.apache.felix.org.apache.felix.threaddump BundleEvent INSTALLED 15.01.2018 12:16:07.090 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.org.apache.felix.threaddump [43] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.threaddump-1.0.0.jar, entity=bundle:org.apache.felix.org.apache.felix.threaddump, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.org.apache.felix.threaddump, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:07.094 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.org.apache.felix.threaddump [43] to 5 15.01.2018 12:16:07.111 *INFO* [OsgiInstallerImpl] org.apache.felix.webconsole BundleEvent INSTALLED 15.01.2018 12:16:07.111 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.webconsole [44] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.webconsole-4.2.18.jar, entity=bundle:org.apache.felix.webconsole, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.webconsole, Bundle-Version=4.2.18], digest=1515998757000) 15.01.2018 12:16:07.115 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.webconsole [44] to 5 15.01.2018 12:16:07.273 *INFO* [OsgiInstallerImpl] org.apache.felix.webconsole.plugins.ds BundleEvent INSTALLED 15.01.2018 12:16:07.273 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.webconsole.plugins.ds [45] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.webconsole.plugins.ds-2.0 .6.jar, entity=bundle:org.apache.felix.webconsole.plugins.ds, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.webconsole.plugins.ds, Bundle-Version=2.0.6], digest=1515998757000) 15.01.2018 12:16:07.278 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.webconsole.plugins.ds [45] to 5 15.01.2018 12:16:07.290 *INFO* [OsgiInstallerImpl] org.apache.felix.webconsole.plugins.event BundleEvent INSTALLED 15.01.2018 12:16:07.290 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.webconsole.plugins.event [46] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.webconsole.plugins.event- 1.1.4.jar, entity=bundle:org.apache.felix.webconsole.plugins.event, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.webconsole.plugins.event, Bundle-Version=1.1.4], digest=1515998757000) 15.01.2018 12:16:07.294 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.webconsole.plugins.event [46] to 5 15.01.2018 12:16:07.306 *INFO* [OsgiInstallerImpl] org.apache.felix.webconsole.plugins.memoryusage BundleEvent INSTALLED 15.01.2018 12:16:07.306 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.webconsole.plugins.memoryusage [47] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.webconsole.plugins.memory usage-1.0.6.jar, entity=bundle:org.apache.felix.webconsole.plugins.memoryusage, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.webconsole.plugins.memoryusage, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:07.310 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.webconsole.plugins.memoryusage [47] to 5 15.01.2018 12:16:07.460 *INFO* [OsgiInstallerImpl] org.apache.felix.webconsole.plugins.packageadmin BundleEvent INSTALLED 15.01.2018 12:16:07.460 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.webconsole.plugins.packageadmin [48] from resource TaskResource(url=launchpad:resources/install/5/org.apache.felix.webconsole.plugins.packag eadmin-1.0.2.jar, entity=bundle:org.apache.felix.webconsole.plugins.packageadmin, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.webconsole.plugins.packageadmin, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:07.465 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.webconsole.plugins.packageadmin [48] to 5 15.01.2018 12:16:07.621 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.log.webconsole BundleEvent INSTALLED 15.01.2018 12:16:07.621 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.log.webconsole [49] from resource TaskResource(url=launchpad:resources/install/5/org.apache.sling.commons.log.webconsole-1. 0.0.jar, entity=bundle:org.apache.sling.commons.log.webconsole, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.log.webconsole, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:07.625 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.log.webconsole [49] to 5 15.01.2018 12:16:07.687 *INFO* [OsgiInstallerImpl] org.apache.sling.installer.console BundleEvent INSTALLED 15.01.2018 12:16:07.687 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.installer.console [50] from resource TaskResource(url=launchpad:resources/install/5/org.apache.sling.installer.console-1.0.2.j ar, entity=bundle:org.apache.sling.installer.console, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.installer.console, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:07.690 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.installer.console [50] to 5 15.01.2018 12:16:07.799 *INFO* [OsgiInstallerImpl] org.apache.sling.security BundleEvent INSTALLED 15.01.2018 12:16:07.799 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.security [51] from resource TaskResource(url=launchpad:resources/install/5/org.apache.sling.security-1.1.2.jar, entity=bundle:org.apache.sling.security, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.security, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:07.803 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.security [51] to 5 15.01.2018 12:16:07.878 *INFO* [OsgiInstallerImpl] org.apache.sling.startupfilter BundleEvent INSTALLED 15.01.2018 12:16:07.878 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.startupfilter [52] from resource TaskResource(url=launchpad:resources/install/6/org.apache.sling.startupfilter-0.0.1-Rev17 64482.jar, entity=bundle:org.apache.sling.startupfilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.startupfilter, Bundle-Version=0.0.1.Rev1764482], digest=1515998757000) 15.01.2018 12:16:07.882 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.startupfilter [52] to 6 15.01.2018 12:16:07.894 *INFO* [OsgiInstallerImpl] org.apache.felix.jaas BundleEvent INSTALLED 15.01.2018 12:16:07.894 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.jaas [53] from resource TaskResource(url=launchpad:resources/install.crx3/9/org.apache.felix.jaas-1.0.2.jar, entity=bundle:org.apache.felix.jaas, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.jaas, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:07.898 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.jaas [53] to 9 15.01.2018 12:16:07.911 *INFO* [OsgiInstallerImpl] org.apache.sling.datasource BundleEvent INSTALLED 15.01.2018 12:16:07.911 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.datasource [54] from resource TaskResource(url=launchpad:resources/install.crx3/9/org.apache.sling.datasource-1.0.2.jar , entity=bundle:org.apache.sling.datasource, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.datasource, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:07.914 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.datasource [54] to 9 15.01.2018 12:16:07.926 *INFO* [OsgiInstallerImpl] com.adobe.granite.dropwizard.metrics BundleEvent INSTALLED 15.01.2018 12:16:07.926 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.dropwizard.metrics [55] from resource TaskResource(url=launchpad:resources/install/9/com.adobe.granite.dropwizard.metrics-3.1.0 .jar, entity=bundle:com.adobe.granite.dropwizard.metrics, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.dropwizard.metrics, Bundle-Version=3.1.0], digest=1515998757000) 15.01.2018 12:16:07.931 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.dropwizard.metrics [55] to 9 15.01.2018 12:16:07.944 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.commons-lang2 BundleEvent INSTALLED 15.01.2018 12:16:07.944 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.osgi.wrapper.commons-lang2 [56] from resource TaskResource(url=launchpad:resources/install/9/com.day.commons.osgi.wrapper.commons-lang2 -2.5-0001.jar, entity=bundle:com.day.commons.osgi.wrapper.commons-lang2, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.osgi.wrapper.commons-lang2, Bundle-Version=2.5.0.0001], digest=1515998757000) 15.01.2018 12:16:07.948 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.commons.osgi.wrapper.commons-lang2 [56] to 9 15.01.2018 12:16:07.964 *INFO* [OsgiInstallerImpl] org.apache.commons.collections BundleEvent INSTALLED 15.01.2018 12:16:07.965 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.collections [57] from resource TaskResource(url=launchpad:resources/install/9/commons-collections-3.2.2.jar, entity=bundle:org.apache.commons.collections, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.collections, Bundle-Version=3.2.2], digest=1515998757000) 15.01.2018 12:16:07.970 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.commons.collections [57] to 9 15.01.2018 12:16:08.037 *INFO* [OsgiInstallerImpl] com.day.cq.cq-compat-runmode BundleEvent INSTALLED 15.01.2018 12:16:08.037 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-compat-runmode [58] from resource TaskResource(url=launchpad:resources/install/9/cq-compat-runmode-0.2.0.jar, entity=bundle:com.day.cq.cq-compat-runmode, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-compat-runmode, Bundle-Version=0.2.0], digest=1515998757000) 15.01.2018 12:16:08.041 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-compat-runmode [58] to 9 15.01.2018 12:16:08.053 *INFO* [OsgiInstallerImpl] com.day.cq.cq-licensebranding BundleEvent INSTALLED 15.01.2018 12:16:08.054 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-licensebranding [59] from resource TaskResource(url=launchpad:resources/install/9/cq-licensebranding-6.4.2.jar, entity=bundle:com.day.cq.cq-licensebranding, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-licensebranding, Bundle-Version=6.4.2], digest=1515998757000) 15.01.2018 12:16:08.057 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-licensebranding [59] to 9 15.01.2018 12:16:08.070 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-pre-upgrade-backup BundleEvent INSTALLED 15.01.2018 12:16:08.070 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-pre-upgrade-backup [60] from resource TaskResource(url=launchpad:resources/install/9/cq-pre-upgrade-backup-6.3.16.jar, entity=bundle:com.adobe.cq.cq-pre-upgrade-backup, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-pre-upgrade-backup, Bundle-Version=6.3.16], digest=1515998757000) 15.01.2018 12:16:08.073 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.cq.cq-pre-upgrade-backup [60] to 9 15.01.2018 12:16:08.141 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-pre-upgrade-cleanup BundleEvent INSTALLED 15.01.2018 12:16:08.141 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-pre-upgrade-cleanup [61] from resource TaskResource(url=launchpad:resources/install/9/cq-pre-upgrade-cleanup-6.2.6.jar, entity=bundle:com.adobe.cq.cq-pre-upgrade-cleanup, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-pre-upgrade-cleanup, Bundle-Version=6.2.6], digest=1515998757000) 15.01.2018 12:16:08.145 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.cq.cq-pre-upgrade-cleanup [61] to 9 15.01.2018 12:16:08.152 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-product-info-provider BundleEvent INSTALLED 15.01.2018 12:16:08.152 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-product-info-provider [62] from resource TaskResource(url=launchpad:resources/install/9/cq-product-info-provider-6.3.2.jar, entity=bundle:com.adobe.cq.cq-product-info-provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-product-info-provider, Bundle-Version=6.3.2], digest=1515998757000) 15.01.2018 12:16:08.156 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.cq.cq-product-info-provider [62] to 9 15.01.2018 12:16:08.260 *INFO* [OsgiInstallerImpl] org.apache.felix.http.sslfilter BundleEvent INSTALLED 15.01.2018 12:16:08.260 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.felix.http.sslfilter [63] from resource TaskResource(url=launchpad:resources/install/9/org.apache.felix.http.sslfilter-1.2.0.jar, entity=bundle:org.apache.felix.http.sslfilter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.felix.http.sslfilter, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:08.264 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.felix.http.sslfilter [63] to 9 15.01.2018 12:16:08.276 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.metrics BundleEvent INSTALLED 15.01.2018 12:16:08.277 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.metrics [64] from resource TaskResource(url=launchpad:resources/install/9/org.apache.sling.commons.metrics-1.2.0.jar , entity=bundle:org.apache.sling.commons.metrics, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.metrics, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:08.281 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.metrics [64] to 9 15.01.2018 12:16:08.410 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.osgi BundleEvent INSTALLED 15.01.2018 12:16:08.410 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.osgi [65] from resource TaskResource(url=launchpad:resources/install/9/org.apache.sling.commons.osgi-2.4.0.jar, entity=bundle:org.apache.sling.commons.osgi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.osgi, Bundle-Version=2.4.0], digest=1515998757000) 15.01.2018 12:16:08.413 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.osgi [65] to 9 15.01.2018 12:16:08.586 *INFO* [OsgiInstallerImpl] org.apache.sling.serviceusermapper BundleEvent INSTALLED 15.01.2018 12:16:08.586 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.serviceusermapper [66] from resource TaskResource(url=launchpad:resources/install/9/org.apache.sling.serviceusermapper-1.2.4.j ar, entity=bundle:org.apache.sling.serviceusermapper, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.serviceusermapper, Bundle-Version=1.2.4], digest=1515998757000) 15.01.2018 12:16:08.590 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.serviceusermapper [66] to 9 15.01.2018 12:16:08.729 *INFO* [OsgiInstallerImpl] com.adobe.granite.infocollector BundleEvent INSTALLED 15.01.2018 12:16:08.729 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.infocollector [67] from resource TaskResource(url=launchpad:resources/install/12/com.adobe.granite.infocollector-1.0.6.jar , entity=bundle:com.adobe.granite.infocollector, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.infocollector, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:08.734 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.infocollector [67] to 12 15.01.2018 12:16:08.751 *INFO* [OsgiInstallerImpl] com.adobe.granite.license BundleEvent INSTALLED 15.01.2018 12:16:08.751 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.license [68] from resource TaskResource(url=launchpad:resources/install/12/com.adobe.granite.license-1.2.6.jar, entity=bundle:com.adobe.granite.license, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.license, Bundle-Version=1.2.6], digest=1515998757000) 15.01.2018 12:16:08.755 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.license [68] to 12 15.01.2018 12:16:08.769 *INFO* [OsgiInstallerImpl] org.apache.sling.api BundleEvent INSTALLED 15.01.2018 12:16:08.769 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.api [69] from resource TaskResource(url=launchpad:resources/install/12/org.apache.sling.api-2.16.2.jar, entity=bundle:org.apache.sling.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.api, Bundle-Version=2.16.2], digest=1515998757000) 15.01.2018 12:16:08.773 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.api [69] to 12 15.01.2018 12:16:08.807 *INFO* [OsgiInstallerImpl] afe BundleEvent INSTALLED 15.01.2018 12:16:08.807 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle afe [70] from resource TaskResource(url=launchpad:resources/install/14/afe-1.0.1326433.2.jar, entity=bundle:afe, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=afe, Bundle-Version=1.0.1326433.2], digest=1515998757000) 15.01.2018 12:16:08.811 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle afe [70] to 14 15.01.2018 12:16:08.833 *INFO* [OsgiInstallerImpl] AGL_min BundleEvent INSTALLED 15.01.2018 12:16:08.833 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle AGL_min [71] from resource TaskResource(url=launchpad:resources/install/14/aglj40-1.5.698416.2.jar, entity=bundle:AGL_min, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=AGL_min, Bundle-Version=1.5.698416.2], digest=1515998757000) 15.01.2018 12:16:08.837 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle AGL_min [71] to 14 15.01.2018 12:16:08.893 *INFO* [OsgiInstallerImpl] com.adobe.granite.gibson BundleEvent INSTALLED 15.01.2018 12:16:08.893 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.gibson [72] from resource TaskResource(url=launchpad:resources/install/14/com.adobe.granite.gibson-1.1.2.jar, entity=bundle:com.adobe.granite.gibson, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.gibson, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:08.897 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.gibson [72] to 14 15.01.2018 12:16:09.024 *INFO* [OsgiInstallerImpl] com.adobe.granite.poi BundleEvent INSTALLED 15.01.2018 12:16:09.024 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.poi [73] from resource TaskResource(url=launchpad:resources/install/14/com.adobe.granite.poi-2.0.8.jar, entity=bundle:com.adobe.granite.poi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.poi, Bundle-Version=2.0.8], digest=1515998757000) 15.01.2018 12:16:09.027 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.poi [73] to 14 15.01.2018 12:16:09.040 *INFO* [OsgiInstallerImpl] com.adobe.granite.rngom BundleEvent INSTALLED 15.01.2018 12:16:09.040 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.rngom [74] from resource TaskResource(url=launchpad:resources/install/14/com.adobe.granite.rngom-20120531.0.0.jar, entity=bundle:com.adobe.granite.rngom, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.rngom, Bundle-Version=20120531.0.0], digest=1515998757000) 15.01.2018 12:16:09.043 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.rngom [74] to 14 15.01.2018 12:16:09.054 *INFO* [OsgiInstallerImpl] com.adobe.granite.tagsoup BundleEvent INSTALLED 15.01.2018 12:16:09.054 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.tagsoup [75] from resource TaskResource(url=launchpad:resources/install/14/com.adobe.granite.tagsoup-1.2.1.jar, entity=bundle:com.adobe.granite.tagsoup, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.tagsoup, Bundle-Version=1.2.1], digest=1515998757000) 15.01.2018 12:16:09.058 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.tagsoup [75] to 14 15.01.2018 12:16:09.071 *INFO* [OsgiInstallerImpl] org.apache.commons.codec BundleEvent INSTALLED 15.01.2018 12:16:09.071 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.codec [76] from resource TaskResource(url=launchpad:resources/install/14/commons-codec-1.10.jar, entity=bundle:org.apache.commons.codec, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.codec, Bundle-Version=1.10.0], digest=1515998757000) 15.01.2018 12:16:09.075 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.commons.codec [76] to 14 15.01.2018 12:16:09.090 *INFO* [OsgiInstallerImpl] org.apache.commons.compress BundleEvent INSTALLED 15.01.2018 12:16:09.090 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.compress [77] from resource TaskResource(url=launchpad:resources/install/14/commons-compress-1.13.jar, entity=bundle:org.apache.commons.compress, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.compress, Bundle-Version=1.13.0], digest=1515998757000) 15.01.2018 12:16:09.094 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.commons.compress [77] to 14 15.01.2018 12:16:09.106 *INFO* [OsgiInstallerImpl] com.adobe.xmp.core BundleEvent INSTALLED 15.01.2018 12:16:09.106 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.core [78] from resource TaskResource(url=launchpad:resources/install/14/core-1.0.4.jar, entity=bundle:com.adobe.xmp.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.core, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:09.109 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.xmp.core [78] to 14 15.01.2018 12:16:09.275 *INFO* [OsgiInstallerImpl] com.adobe.xmp.schema.model BundleEvent INSTALLED 15.01.2018 12:16:09.276 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.schema.model [79] from resource TaskResource(url=launchpad:resources/install/14/model-1.0.9.jar, entity=bundle:com.adobe.xmp.schema.model, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.schema.model, Bundle-Version=1.0.9], digest=1515998757000) 15.01.2018 12:16:09.279 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.xmp.schema.model [79] to 14 15.01.2018 12:16:09.294 *INFO* [OsgiInstallerImpl] pdfcore BundleEvent INSTALLED 15.01.2018 12:16:09.294 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle pdfcore [80] from resource TaskResource(url=launchpad:resources/install/14/pdfcore-3.0.577161.jar, entity=bundle:pdfcore, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=pdfcore, Bundle-Version=3.0.577161], digest=1515998757000) 15.01.2018 12:16:09.298 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle pdfcore [80] to 14 15.01.2018 12:16:09.313 *INFO* [OsgiInstallerImpl] pdfencryption BundleEvent INSTALLED 15.01.2018 12:16:09.313 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle pdfencryption [81] from resource TaskResource(url=launchpad:resources/install/14/pdfencryption_high-3.0.577161.jar, entity=bundle:pdfencryption, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=pdfencryption, Bundle-Version=3.0.577161], digest=1515998757000) 15.01.2018 12:16:09.317 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle pdfencryption [81] to 14 15.01.2018 12:16:09.347 *INFO* [OsgiInstallerImpl] PDFServices_extraction BundleEvent INSTALLED 15.01.2018 12:16:09.347 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle PDFServices_extraction [82] from resource TaskResource(url=launchpad:resources/install/14/pdfservices_extraction-3.0.577161.jar, entity=bundle:PDFServices_extraction, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=PDFServices_extraction, Bundle-Version=3.0.577161], digest=1515998757000) 15.01.2018 12:16:09.351 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle PDFServices_extraction [82] to 14 15.01.2018 12:16:09.362 *INFO* [OsgiInstallerImpl] rideau BundleEvent INSTALLED 15.01.2018 12:16:09.362 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle rideau [83] from resource TaskResource(url=launchpad:resources/install/14/rideau-3.0.1349992.jar, entity=bundle:rideau, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=rideau, Bundle-Version=3.0.0], digest=1515998757000) 15.01.2018 12:16:09.365 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle rideau [83] to 14 15.01.2018 12:16:09.377 *INFO* [OsgiInstallerImpl] com.adobe.xmp.schema.rngparser BundleEvent INSTALLED 15.01.2018 12:16:09.377 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.schema.rngparser [84] from resource TaskResource(url=launchpad:resources/install/14/rngparser-1.0.7.jar, entity=bundle:com.adobe.xmp.schema.rngparser, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.schema.rngparser, Bundle-Version=1.0.7], digest=1515998757000) 15.01.2018 12:16:09.380 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.xmp.schema.rngparser [84] to 14 15.01.2018 12:16:09.391 *INFO* [OsgiInstallerImpl] com.adobe.xmp.schema.service BundleEvent INSTALLED 15.01.2018 12:16:09.391 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.schema.service [85] from resource TaskResource(url=launchpad:resources/install/14/service-2.0.0.jar, entity=bundle:com.adobe.xmp.schema.service, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.schema.service, Bundle-Version=2.0.0], digest=1515998757000) 15.01.2018 12:16:09.395 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.xmp.schema.service [85] to 14 15.01.2018 12:16:09.410 *INFO* [OsgiInstallerImpl] org.apache.tika.core BundleEvent INSTALLED 15.01.2018 12:16:09.410 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.tika.core [86] from resource TaskResource(url=launchpad:resources/install/14/tika-core-1.14.jar, entity=bundle:org.apache.tika.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-ActivationPolicy=lazy, Bundle-SymbolicName=org.apache.tika.core, Bundle-Version=1.14.0], digest=1515998757000) 15.01.2018 12:16:09.413 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.tika.core [86] to 14 15.01.2018 12:16:09.432 *INFO* [OsgiInstallerImpl] org.apache.tika.parsers BundleEvent INSTALLED 15.01.2018 12:16:09.432 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.tika.parsers [87] from resource TaskResource(url=launchpad:resources/install/14/tika-parsers-1.14.jar, entity=bundle:org.apache.tika.parsers, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.tika.parsers, Bundle-Version=1.14.0], digest=1515998757000) 15.01.2018 12:16:09.435 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.tika.parsers [87] to 14 15.01.2018 12:16:09.449 *INFO* [OsgiInstallerImpl] com.adobe.xmp.xmpcore BundleEvent INSTALLED 15.01.2018 12:16:09.449 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.xmpcore [88] from resource TaskResource(url=launchpad:resources/install/14/xmpcore-6.2.6.jar, entity=bundle:com.adobe.xmp.xmpcore, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.xmpcore, Bundle-Version=6.2.6], digest=1515998757000) 15.01.2018 12:16:09.453 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.xmp.xmpcore [88] to 14 15.01.2018 12:16:09.480 *INFO* [OsgiInstallerImpl] com.adobe.granite.osgi.wrapper.guava BundleEvent INSTALLED 15.01.2018 12:16:09.480 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.osgi.wrapper.guava [89] from resource TaskResource(url=launchpad:resources/install.crx3/15/com.adobe.granite.osgi.wrapper.guava -15.0.0-0002.jar, entity=bundle:com.adobe.granite.osgi.wrapper.guava, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.osgi.wrapper.guava, Bundle-Version=15.0.0.0002], digest=1515998757000) 15.01.2018 12:16:09.484 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.osgi.wrapper.guava [89] to 15 15.01.2018 12:16:09.495 *INFO* [OsgiInstallerImpl] com.adobe.granite.repository BundleEvent INSTALLED 15.01.2018 12:16:09.496 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.repository [90] from resource TaskResource(url=launchpad:resources/install.crx3/15/com.adobe.granite.repository-1.3.130 .jar, entity=bundle:com.adobe.granite.repository, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.repository, Bundle-Version=1.3.130], digest=1515998757000) 15.01.2018 12:16:09.499 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.repository [90] to 15 15.01.2018 12:16:09.511 *INFO* [OsgiInstallerImpl] org.h2.mvstore BundleEvent INSTALLED 15.01.2018 12:16:09.511 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.h2.mvstore [91] from resource TaskResource(url=launchpad:resources/install.crx3/15/h2-mvstore-1.4.193.jar, entity=bundle:org.h2.mvstore, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.h2.mvstore, Bundle-Version=1.4.193], digest=1515998757000) 15.01.2018 12:16:09.515 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.h2.mvstore [91] to 15 15.01.2018 12:16:09.527 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-data BundleEvent INSTALLED 15.01.2018 12:16:09.527 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-data [92] from resource TaskResource(url=launchpad:resources/install.crx3/15/jackrabbit-data-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-data, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-data, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:09.530 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-data [92] to 15 15.01.2018 12:16:09.552 *INFO* [OsgiInstallerImpl] org.mongodb.mongo-java-driver BundleEvent INSTALLED 15.01.2018 12:16:09.552 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.mongodb.mongo-java-driver [93] from resource TaskResource(url=launchpad:resources/install.crx3/15/mongo-java-driver-3.4.0.jar, entity=bundle:org.mongodb.mongo-java-driver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.mongodb.mongo-java-driver, Bundle-Version=3.4.0], digest=1515998757000) 15.01.2018 12:16:09.555 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.mongodb.mongo-java-driver [93] to 15 15.01.2018 12:16:09.568 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-auth-external BundleEvent INSTALLED 15.01.2018 12:16:09.568 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-auth-external [94] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-auth-external-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-auth-external, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-auth-external, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.572 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-auth-external [94] to 15 15.01.2018 12:16:09.593 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-auth-ldap BundleEvent INSTALLED 15.01.2018 12:16:09.593 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-auth-ldap [95] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-auth-ldap-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-auth-ldap, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-auth-ldap, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.597 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-auth-ldap [95] to 15 15.01.2018 12:16:09.611 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-authorization-cug BundleEvent INSTALLED 15.01.2018 12:16:09.611 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-authorization-cug [96] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-authorization-cug-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-authorization-cug, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-authorization-cug, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.615 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-authorization-cug [96] to 15 15.01.2018 12:16:09.627 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-blob BundleEvent INSTALLED 15.01.2018 12:16:09.627 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-blob [97] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-blob-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-blob, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-blob, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.631 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-blob [97] to 15 15.01.2018 12:16:09.642 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-commons BundleEvent INSTALLED 15.01.2018 12:16:09.642 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-commons [98] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-commons-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-commons, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.645 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-commons [98] to 15 15.01.2018 12:16:09.679 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-core BundleEvent INSTALLED 15.01.2018 12:16:09.679 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-core [99] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-core-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-core, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.683 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-core [99] to 15 15.01.2018 12:16:09.698 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-jcr BundleEvent INSTALLED 15.01.2018 12:16:09.698 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-jcr [100] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-jcr-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-jcr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-jcr, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.702 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-jcr [100] to 15 15.01.2018 12:16:09.754 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-lucene BundleEvent INSTALLED 15.01.2018 12:16:09.754 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-lucene [101] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-lucene-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-lucene, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-lucene, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.758 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-lucene [101] to 15 15.01.2018 12:16:09.778 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-segment-tar BundleEvent INSTALLED 15.01.2018 12:16:09.778 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-segment-tar [102] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-segment-tar-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-segment-tar, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-segment-tar, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.783 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-segment-tar [102] to 15 15.01.2018 12:16:09.878 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.oak-solr-osgi BundleEvent INSTALLED 15.01.2018 12:16:09.878 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.oak-solr-osgi [103] from resource TaskResource(url=launchpad:resources/install.crx3/15/oak-solr-osgi-1.6.1.jar, entity=bundle:org.apache.jackrabbit.oak-solr-osgi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.oak-solr-osgi, Bundle-Version=1.6.1], digest=1515998757000) 15.01.2018 12:16:09.882 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.oak-solr-osgi [103] to 15 15.01.2018 12:16:09.894 *INFO* [OsgiInstallerImpl] com.adobe.granite.jmx BundleEvent INSTALLED 15.01.2018 12:16:09.894 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.jmx [104] from resource TaskResource(url=launchpad:resources/install/15/com.adobe.granite.jmx-0.3.2.jar, entity=bundle:com.adobe.granite.jmx, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.jmx, Bundle-Version=0.3.2], digest=1515998757000) 15.01.2018 12:16:09.898 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.jmx [104] to 15 15.01.2018 12:16:09.982 *INFO* [OsgiInstallerImpl] com.day.crx.crx-api BundleEvent INSTALLED 15.01.2018 12:16:09.982 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.crx.crx-api [105] from resource TaskResource(url=launchpad:resources/install/15/crx-api-2.6.6.jar, entity=bundle:com.day.crx.crx-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.crx.crx-api, Bundle-Version=2.6.6], digest=1515998757000) 15.01.2018 12:16:09.988 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.crx.crx-api [105] to 15 15.01.2018 12:16:10.009 *INFO* [OsgiInstallerImpl] com.day.commons.day-commons-text BundleEvent INSTALLED 15.01.2018 12:16:10.009 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.day-commons-text [106] from resource TaskResource(url=launchpad:resources/install/15/day-commons-text-1.1.10.jar, entity=bundle:com.day.commons.day-commons-text, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.day-commons-text, Bundle-Version=1.1.10], digest=1515998757000) 15.01.2018 12:16:10.013 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.commons.day-commons-text [106] to 15 15.01.2018 12:16:10.092 *INFO* [OsgiInstallerImpl] com.adobe.forms.foundation-forms-foundation-base BundleEvent INSTALLED 15.01.2018 12:16:10.092 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.forms.foundation-forms-foundation-base [107] from resource TaskResource(url=launchpad:resources/install/15/forms-foundation-base-2.0.56.jar, entity=bundle:com.adobe.forms.foundation-forms-foundation-base, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.forms.foundation-forms-foundation-base, Bundle-Version=2.0.56], digest=1515998757000) 15.01.2018 12:16:10.096 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.forms.foundation-forms-foundation-base [107] to 15 15.01.2018 12:16:10.363 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-api BundleEvent INSTALLED 15.01.2018 12:16:10.363 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-api [108] from resource TaskResource(url=launchpad:resources/install/15/jackrabbit-api-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-api, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:10.367 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-api [108] to 15 15.01.2018 12:16:10.380 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-jcr-commons BundleEvent INSTALLED 15.01.2018 12:16:10.380 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-jcr-commons [109] from resource TaskResource(url=launchpad:resources/install/15/jackrabbit-jcr-commons-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-jcr-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-jcr-commons, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:10.384 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-jcr-commons [109] to 15 15.01.2018 12:16:10.397 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-jcr-rmi BundleEvent INSTALLED 15.01.2018 12:16:10.398 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-jcr-rmi [110] from resource TaskResource(url=launchpad:resources/install/15/jackrabbit-jcr-rmi-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-jcr-rmi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-jcr-rmi, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:10.401 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-jcr-rmi [110] to 15 15.01.2018 12:16:10.412 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.json BundleEvent INSTALLED 15.01.2018 12:16:10.413 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.json [111] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.commons.json-2.0.20.jar, entity=bundle:org.apache.sling.commons.json, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.json, Bundle-Version=2.0.20], digest=1515998757000) 15.01.2018 12:16:10.416 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.json [111] to 15 15.01.2018 12:16:10.518 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.mime BundleEvent INSTALLED 15.01.2018 12:16:10.518 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.mime [112] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.commons.mime-2.1.10.jar, entity=bundle:org.apache.sling.commons.mime, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.mime, Bundle-Version=2.1.10], digest=1515998757000) 15.01.2018 12:16:10.521 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.mime [112] to 15 15.01.2018 12:16:10.645 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.threads BundleEvent INSTALLED 15.01.2018 12:16:10.645 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.threads [113] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.commons.threads-3.2.6.ja r, entity=bundle:org.apache.sling.commons.threads, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.threads, Bundle-Version=3.2.6], digest=1515998757000) 15.01.2018 12:16:10.648 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.threads [113] to 15 15.01.2018 12:16:10.723 *INFO* [OsgiInstallerImpl] org.apache.sling.extensions.webconsolesecurityprovider BundleEvent INSTALLED 15.01.2018 12:16:10.723 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.extensions.webconsolesecurityprovider [114] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.extensions.webconsolesec urityprovider-1.2.0.jar, entity=bundle:org.apache.sling.extensions.webconsolesecurityprovider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.extensions.webconsolesecurityprovider, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:10.726 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.extensions.webconsolesecurityprovider [114] to 15 15.01.2018 12:16:10.777 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.api BundleEvent INSTALLED 15.01.2018 12:16:10.777 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.api [115] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.jcr.api-2.4.0.jar, entity=bundle:org.apache.sling.jcr.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.api, Bundle-Version=2.4.0], digest=1515998757000) 15.01.2018 12:16:10.780 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.api [115] to 15 15.01.2018 12:16:10.792 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.base BundleEvent INSTALLED 15.01.2018 12:16:10.792 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.base [116] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.jcr.base-3.0.0.jar, entity=bundle:org.apache.sling.jcr.base, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.base, Bundle-Version=3.0.0], digest=1515998757000) 15.01.2018 12:16:10.795 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.base [116] to 15 15.01.2018 12:16:10.805 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.jcr-wrapper BundleEvent INSTALLED 15.01.2018 12:16:10.805 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.jcr-wrapper [117] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.jcr.jcr-wrapper-2.0.0.ja r, entity=bundle:org.apache.sling.jcr.jcr-wrapper, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.jcr-wrapper, Bundle-Version=2.0.0], digest=1515998757000) 15.01.2018 12:16:10.809 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.jcr-wrapper [117] to 15 15.01.2018 12:16:10.939 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.registration BundleEvent INSTALLED 15.01.2018 12:16:10.939 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.registration [118] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.jcr.registration-1.0.2.j ar, entity=bundle:org.apache.sling.jcr.registration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.registration, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:10.943 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.registration [118] to 15 15.01.2018 12:16:11.062 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.repoinit BundleEvent INSTALLED 15.01.2018 12:16:11.062 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.repoinit [119] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.jcr.repoinit-1.1.2.jar, entity=bundle:org.apache.sling.jcr.repoinit, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.repoinit, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:11.065 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.repoinit [119] to 15 15.01.2018 12:16:11.076 *INFO* [OsgiInstallerImpl] org.apache.sling.repoinit.parser BundleEvent INSTALLED 15.01.2018 12:16:11.076 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.repoinit.parser [120] from resource TaskResource(url=launchpad:resources/install/15/org.apache.sling.repoinit.parser-1.1.0.ja r, entity=bundle:org.apache.sling.repoinit.parser, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.repoinit.parser, Bundle-Version=1.1.0], digest=1515998757000) 15.01.2018 12:16:11.080 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.repoinit.parser [120] to 15 15.01.2018 12:16:11.146 *INFO* [OsgiInstallerImpl] com.adobe.granite.installer.factory.packages BundleEvent INSTALLED 15.01.2018 12:16:11.146 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.installer.factory.packages [121] from resource TaskResource(url=launchpad:resources/install/16/com.adobe.granite.installer.factory.packa ges-1.0.10.jar, entity=bundle:com.adobe.granite.installer.factory.packages, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.installer.factory.packages, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:11.149 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.installer.factory.packages [121] to 16 15.01.2018 12:16:11.222 *INFO* [OsgiInstallerImpl] com.day.cq.cq-jcrclustersupport BundleEvent INSTALLED 15.01.2018 12:16:11.222 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-jcrclustersupport [122] from resource TaskResource(url=launchpad:resources/install/16/com.adobe.granite.jcrclustersupport-0.7.2 .jar, entity=bundle:com.day.cq.cq-jcrclustersupport, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-jcrclustersupport, Bundle-Version=0.7.2], digest=1515998757000) 15.01.2018 12:16:11.225 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-jcrclustersupport [122] to 16 15.01.2018 12:16:11.378 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-spi BundleEvent INSTALLED 15.01.2018 12:16:11.378 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-spi [123] from resource TaskResource(url=launchpad:resources/install/16/jackrabbit-spi-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-spi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-spi, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:11.381 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-spi [123] to 16 15.01.2018 12:16:11.396 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-spi-commons BundleEvent INSTALLED 15.01.2018 12:16:11.397 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-spi-commons [124] from resource TaskResource(url=launchpad:resources/install/16/jackrabbit-spi-commons-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-spi-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-spi-commons, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:11.400 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.jackrabbit-spi-commons [124] to 16 15.01.2018 12:16:11.418 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.vault BundleEvent INSTALLED 15.01.2018 12:16:11.418 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.vault [125] from resource TaskResource(url=launchpad:resources/install/16/org.apache.jackrabbit.vault-3.1.38.jar, entity=bundle:org.apache.jackrabbit.vault, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.vault, Bundle-Version=3.1.38], digest=1515998757000) 15.01.2018 12:16:11.422 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.jackrabbit.vault [125] to 16 15.01.2018 12:16:11.433 *INFO* [OsgiInstallerImpl] org.apache.sling.installer.provider.jcr BundleEvent INSTALLED 15.01.2018 12:16:11.433 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.installer.provider.jcr [126] from resource TaskResource(url=launchpad:resources/install/17/org.apache.sling.installer.provider.jcr-3 .1.22.jar, entity=bundle:org.apache.sling.installer.provider.jcr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.installer.provider.jcr, Bundle-Version=3.1.22], digest=1515998757000) 15.01.2018 12:16:11.437 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.installer.provider.jcr [126] to 17 15.01.2018 12:16:11.449 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.contentloader BundleEvent INSTALLED 15.01.2018 12:16:11.449 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.contentloader [127] from resource TaskResource(url=launchpad:resources/install/17/org.apache.sling.jcr.contentloader-2.1.10 .jar, entity=bundle:org.apache.sling.jcr.contentloader, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.contentloader, Bundle-Version=2.1.10], digest=1515998757000) 15.01.2018 12:16:11.452 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.contentloader [127] to 17 15.01.2018 12:16:11.467 *INFO* [OsgiInstallerImpl] com.adobe.granite.workflow.core BundleEvent INSTALLED 15.01.2018 12:16:11.467 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.workflow.core [128] from resource TaskResource(url=launchpad:resources/install/19/com.adobe.granite.workflow.core-2.0.100.j ar, entity=bundle:com.adobe.granite.workflow.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.workflow.core, Bundle-Version=2.0.100], digest=1515998757000) 15.01.2018 12:16:11.471 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.adobe.granite.workflow.core [128] to 19 15.01.2018 12:16:11.483 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.commons-httpclient BundleEvent INSTALLED 15.01.2018 12:16:11.483 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.osgi.wrapper.commons-httpclient [129] from resource TaskResource(url=launchpad:resources/install/19/com.day.commons.osgi.wrapper.commons-http client-3.1.0.018.jar, entity=bundle:com.day.commons.osgi.wrapper.commons-httpclient, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.osgi.wrapper.commons-httpclient, Bundle-Version=3.1.0.018], digest=1515998757000) 15.01.2018 12:16:11.486 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.commons.osgi.wrapper.commons-httpclient [129] to 19 15.01.2018 12:16:11.573 *INFO* [OsgiInstallerImpl] org.apache.sling.adapter BundleEvent INSTALLED 15.01.2018 12:16:11.573 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.adapter [130] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.adapter-2.1.8.jar, entity=bundle:org.apache.sling.adapter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.adapter, Bundle-Version=2.1.8], digest=1515998757000) 15.01.2018 12:16:11.577 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.adapter [130] to 19 15.01.2018 12:16:11.588 *INFO* [OsgiInstallerImpl] org.apache.sling.auth.core BundleEvent INSTALLED 15.01.2018 12:16:11.588 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.auth.core [131] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.auth.core-1.3.24.jar, entity=bundle:org.apache.sling.auth.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.auth.core, Bundle-Version=1.3.24], digest=1515998757000) 15.01.2018 12:16:11.592 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.auth.core [131] to 19 15.01.2018 12:16:11.675 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.classloader BundleEvent INSTALLED 15.01.2018 12:16:11.675 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.classloader [132] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.commons.classloader-1.3. 8.jar, entity=bundle:org.apache.sling.commons.classloader, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.classloader, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:11.678 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.classloader [132] to 19 15.01.2018 12:16:11.690 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.scheduler BundleEvent INSTALLED 15.01.2018 12:16:11.690 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.scheduler [133] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.commons.scheduler-2.5.2. jar, entity=bundle:org.apache.sling.commons.scheduler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.scheduler, Bundle-Version=2.5.2], digest=1515998757000) 15.01.2018 12:16:11.693 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.commons.scheduler [133] to 19 15.01.2018 12:16:11.703 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.base BundleEvent INSTALLED 15.01.2018 12:16:11.703 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.discovery.base [134] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.discovery.base-1.1.6.jar , entity=bundle:org.apache.sling.discovery.base, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.discovery.base, Bundle-Version=1.1.6], digest=1515998757000) 15.01.2018 12:16:11.706 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.discovery.base [134] to 19 15.01.2018 12:16:11.716 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.commons BundleEvent INSTALLED 15.01.2018 12:16:11.716 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.discovery.commons [135] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.discovery.commons-1.0.18 .jar, entity=bundle:org.apache.sling.discovery.commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.discovery.commons, Bundle-Version=1.0.18], digest=1515998757000) 15.01.2018 12:16:11.719 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.discovery.commons [135] to 19 15.01.2018 12:16:11.729 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.oak BundleEvent INSTALLED 15.01.2018 12:16:11.729 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.discovery.oak [136] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.discovery.oak-1.2.16.jar , entity=bundle:org.apache.sling.discovery.oak, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.discovery.oak, Bundle-Version=1.2.16], digest=1515998757000) 15.01.2018 12:16:11.732 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.discovery.oak [136] to 19 15.01.2018 12:16:11.784 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.support BundleEvent INSTALLED 15.01.2018 12:16:11.784 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.discovery.support [137] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.discovery.support-1.0.0. jar, entity=bundle:org.apache.sling.discovery.support, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.discovery.support, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:11.787 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.discovery.support [137] to 19 15.01.2018 12:16:11.873 *INFO* [OsgiInstallerImpl] org.apache.sling.featureflags BundleEvent INSTALLED 15.01.2018 12:16:11.873 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.featureflags [138] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.featureflags-1.2.0.jar, entity=bundle:org.apache.sling.featureflags, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.featureflags, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:11.878 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.featureflags [138] to 19 15.01.2018 12:16:11.891 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.resource BundleEvent INSTALLED 15.01.2018 12:16:11.891 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.resource [139] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.jcr.resource-2.9.2.jar, entity=bundle:org.apache.sling.jcr.resource, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.resource, Bundle-Version=2.9.2], digest=1515998757000) 15.01.2018 12:16:11.894 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.jcr.resource [139] to 19 15.01.2018 12:16:11.996 *INFO* [OsgiInstallerImpl] org.apache.sling.resourceaccesssecurity BundleEvent INSTALLED 15.01.2018 12:16:11.996 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.resourceaccesssecurity [140] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.resourceaccesssecurity-1 .0.0.jar, entity=bundle:org.apache.sling.resourceaccesssecurity, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.resourceaccesssecurity, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:11.999 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.resourceaccesssecurity [140] to 19 15.01.2018 12:16:12.012 *INFO* [OsgiInstallerImpl] org.apache.sling.resourceresolver BundleEvent INSTALLED 15.01.2018 12:16:12.012 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.resourceresolver [141] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.resourceresolver-1.5.22. jar, entity=bundle:org.apache.sling.resourceresolver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.resourceresolver, Bundle-Version=1.5.22], digest=1515998757000) 15.01.2018 12:16:12.016 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.resourceresolver [141] to 19 15.01.2018 12:16:12.092 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.api BundleEvent INSTALLED 15.01.2018 12:16:12.092 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.api [142] from resource TaskResource(url=launchpad:resources/install/19/org.apache.sling.scripting.api-2.1.12.jar , entity=bundle:org.apache.sling.scripting.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.api, Bundle-Version=2.1.12], digest=1515998757000) 15.01.2018 12:16:12.095 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.scripting.api [142] to 19 15.01.2018 12:16:12.107 *INFO* [OsgiInstallerImpl] com.day.cq.cq-compat-codeupgrade BundleEvent INSTALLED 15.01.2018 12:16:12.107 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-compat-codeupgrade [143] from resource TaskResource(url=launchpad:resources/install/23/cq-compat-codeupgrade-1.6.84.jar, entity=bundle:com.day.cq.cq-compat-codeupgrade, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-compat-codeupgrade, Bundle-Version=1.6.84], digest=1515998757000) 15.01.2018 12:16:12.110 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-compat-codeupgrade [143] to 23 15.01.2018 12:16:12.157 *INFO* [OsgiInstallerImpl] com.day.cq.cq-upgrades-executor BundleEvent INSTALLED 15.01.2018 12:16:12.157 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-upgrades-executor [144] from resource TaskResource(url=launchpad:resources/install/25/cq-upgrades-executor-1.5.14.jar, entity=bundle:com.day.cq.cq-upgrades-executor, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-upgrades-executor, Bundle-Version=1.5.14], digest=1515998757000) 15.01.2018 12:16:12.160 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.cq-upgrades-executor [144] to 25 15.01.2018 12:16:12.327 *INFO* [OsgiInstallerImpl] com.day.cq.pre-upgrade-tasks BundleEvent INSTALLED 15.01.2018 12:16:12.327 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.pre-upgrade-tasks [145] from resource TaskResource(url=launchpad:resources/install/25/pre-upgrade-tasks-1.0.44.jar, entity=bundle:com.day.cq.pre-upgrade-tasks, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.pre-upgrade-tasks, Bundle-Version=1.0.44], digest=1515998757000) 15.01.2018 12:16:12.332 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle com.day.cq.pre-upgrade-tasks [145] to 25 15.01.2018 12:16:12.379 *INFO* [OsgiInstallerImpl] org.apache.sling.startupfilter.disabler BundleEvent INSTALLED 15.01.2018 12:16:12.379 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.startupfilter.disabler [146] from resource TaskResource(url=launchpad:resources/install/30/org.apache.sling.startupfilter.disabler-0 .0.1-Rev1758544.jar, entity=bundle:org.apache.sling.startupfilter.disabler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.startupfilter.disabler, Bundle-Version=0.0.1.Rev1758544], digest=1515998757000) 15.01.2018 12:16:12.383 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Set start level for bundle org.apache.sling.startupfilter.disabler [146] to 30 15.01.2018 12:16:12.400 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-dps BundleEvent INSTALLED 15.01.2018 12:16:12.400 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-dps [147] from resource TaskResource(url=launchpad:resources/install.author/0/cq-mobile-dps-1.1.62.jar, entity=bundle:com.adobe.cq.mobile.cq-mobile-dps, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-dps, Bundle-Version=1.1.62], digest=1515998757000) 15.01.2018 12:16:12.473 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-index-builder BundleEvent INSTALLED 15.01.2018 12:16:12.473 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-index-builder [148] from resource TaskResource(url=launchpad:resources/install.author/0/cq-mobile-index-builder-1.0.4.jar, entity=bundle:com.adobe.cq.mobile.cq-mobile-index-builder, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-index-builder, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:12.618 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-phonegap-build BundleEvent INSTALLED 15.01.2018 12:16:12.618 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-phonegap-build [149] from resource TaskResource(url=launchpad:resources/install.author/0/cq-mobile-phonegap-build-5.10.4.jar , entity=bundle:com.adobe.cq.mobile.cq-mobile-phonegap-build, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-phonegap-build, Bundle-Version=5.10.4], digest=1515998757000) 15.01.2018 12:16:12.661 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-ui BundleEvent INSTALLED 15.01.2018 12:16:12.661 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-ui [150] from resource TaskResource(url=launchpad:resources/install.author/0/cq-mobile-ui-6.2.4.jar, entity=bundle:com.adobe.cq.mobile.cq-mobile-ui, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-ui, Bundle-Version=6.2.4], digest=1515998757000) 15.01.2018 12:16:12.742 *INFO* [OsgiInstallerImpl] com.adobe.granite.maintenance.oak BundleEvent INSTALLED 15.01.2018 12:16:12.742 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.maintenance.oak [151] from resource TaskResource(url=launchpad:resources/install.crx3/0/com.adobe.granite.maintenance.oak-1.0 .36.jar, entity=bundle:com.adobe.granite.maintenance.oak, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.maintenance.oak, Bundle-Version=1.0.36], digest=1515998757000) 15.01.2018 12:16:12.753 *INFO* [OsgiInstallerImpl] com.adobe.granite.oauth.server BundleEvent INSTALLED 15.01.2018 12:16:12.753 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.oauth.server [152] from resource TaskResource(url=launchpad:resources/install.crx3/0/com.adobe.granite.oauth.server-1.1.22 .jar, entity=bundle:com.adobe.granite.oauth.server, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.oauth.server, Bundle-Version=1.1.22], digest=1515998757000) 15.01.2018 12:16:12.847 *INFO* [OsgiInstallerImpl] org.apache.oltu.oauth2.authzserver BundleEvent INSTALLED 15.01.2018 12:16:12.847 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.oauth2.authzserver [153] from resource TaskResource(url=launchpad:resources/install.crx3/0/org.apache.oltu.oauth2.authzserver-1. 0.0.jar, entity=bundle:org.apache.oltu.oauth2.authzserver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.oauth2.authzserver, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:12.858 *INFO* [OsgiInstallerImpl] org.apache.oltu.oauth2.common BundleEvent INSTALLED 15.01.2018 12:16:12.858 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.oauth2.common [154] from resource TaskResource(url=launchpad:resources/install.crx3/0/org.apache.oltu.oauth2.common-1.0.1.j ar, entity=bundle:org.apache.oltu.oauth2.common, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.oauth2.common, Bundle-Version=1.0.1], digest=1515998757000) 15.01.2018 12:16:12.937 *INFO* [OsgiInstallerImpl] org.apache.oltu.oauth2.resourceserver BundleEvent INSTALLED 15.01.2018 12:16:12.937 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.oauth2.resourceserver [155] from resource TaskResource(url=launchpad:resources/install.crx3/0/org.apache.oltu.oauth2.resourceserver -1.0.0.jar, entity=bundle:org.apache.oltu.oauth2.resourceserver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.oauth2.resourceserver, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:12.951 *INFO* [OsgiInstallerImpl] org.apache.abdera.client BundleEvent INSTALLED 15.01.2018 12:16:12.951 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.client [156] from resource TaskResource(url=launchpad:resources/install/0/abdera-client-1.0-R783018.jar, entity=bundle:org.apache.abdera.client, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.client, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:12.962 *INFO* [OsgiInstallerImpl] org.apache.abdera.core BundleEvent INSTALLED 15.01.2018 12:16:12.962 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.core [157] from resource TaskResource(url=launchpad:resources/install/0/abdera-core-1.0-R783018.jar, entity=bundle:org.apache.abdera.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.core, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.093 *INFO* [OsgiInstallerImpl] org.apache.abdera.extensions-media BundleEvent INSTALLED 15.01.2018 12:16:13.093 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.extensions-media [158] from resource TaskResource(url=launchpad:resources/install/0/abdera-extensions-media-1.0-R783018.jar, entity=bundle:org.apache.abdera.extensions-media, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.extensions-media, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.215 *INFO* [OsgiInstallerImpl] org.apache.abdera.extensions-opensearch BundleEvent INSTALLED 15.01.2018 12:16:13.215 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.extensions-opensearch [159] from resource TaskResource(url=launchpad:resources/install/0/abdera-extensions-opensearch-1.0-R783018.j ar, entity=bundle:org.apache.abdera.extensions-opensearch, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.extensions-opensearch, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.232 *INFO* [OsgiInstallerImpl] org.apache.abdera.i18n BundleEvent INSTALLED 15.01.2018 12:16:13.232 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.i18n [160] from resource TaskResource(url=launchpad:resources/install/0/abdera-i18n-1.0-R783018.jar, entity=bundle:org.apache.abdera.i18n, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.i18n, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.252 *INFO* [OsgiInstallerImpl] org.apache.abdera.parser BundleEvent INSTALLED 15.01.2018 12:16:13.252 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.parser [161] from resource TaskResource(url=launchpad:resources/install/0/abdera-parser-1.0-R783018.jar, entity=bundle:org.apache.abdera.parser, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.parser, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.267 *INFO* [OsgiInstallerImpl] org.apache.abdera.server BundleEvent INSTALLED 15.01.2018 12:16:13.267 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.abdera.server [162] from resource TaskResource(url=launchpad:resources/install/0/abdera-server-1.0-R783018.jar, entity=bundle:org.apache.abdera.server, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.abdera.server, Bundle-Version=1.0.0.R783018], digest=1515998757000) 15.01.2018 12:16:13.285 *INFO* [OsgiInstallerImpl] com.adobe.aemds.formsmanager.adobe-aemds-formsanddocuments-core BundleEvent INSTALLED 15.01.2018 12:16:13.285 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.aemds.formsmanager.adobe-aemds-formsanddocuments-core [163] from resource TaskResource(url=launchpad:resources/install/0/adobe-aemds-formsanddocuments-core-6.0.48. jar, entity=bundle:com.adobe.aemds.formsmanager.adobe-aemds-formsanddocuments-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.aemds.formsmanager.adobe-aemds-formsanddocuments-core, Bundle-Version=6.0.48], digest=1515998757000) 15.01.2018 12:16:13.379 *INFO* [OsgiInstallerImpl] com.day.cq.dam.adobe-dam-idsprint BundleEvent INSTALLED 15.01.2018 12:16:13.379 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.adobe-dam-idsprint [164] from resource TaskResource(url=launchpad:resources/install/0/adobe-dam-idsprint-0.2.42.jar, entity=bundle:com.day.cq.dam.adobe-dam-idsprint, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.adobe-dam-idsprint, Bundle-Version=0.2.42], digest=1515998757000) 15.01.2018 12:16:13.392 *INFO* [OsgiInstallerImpl] com.adobe.livecycle.formsportal-bundle BundleEvent INSTALLED 15.01.2018 12:16:13.392 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.livecycle.formsportal-bundle [165] from resource TaskResource(url=launchpad:resources/install/0/adobe-formsportal-services-6.0.36.jar, entity=bundle:com.adobe.livecycle.formsportal-bundle, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.livecycle.formsportal-bundle, Bundle-Version=6.0.36], digest=1515998757000) 15.01.2018 12:16:13.403 *INFO* [OsgiInstallerImpl] com.adobe.forms.common.adobe-xfaforms-common BundleEvent INSTALLED 15.01.2018 12:16:13.403 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.forms.common.adobe-xfaforms-common [166] from resource TaskResource(url=launchpad:resources/install/0/adobe-xfaforms-common-6.0.44.jar, entity=bundle:com.adobe.forms.common.adobe-xfaforms-common, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.forms.common.adobe-xfaforms-common, Bundle-Version=6.0.44], digest=1515998757000) 15.01.2018 12:16:13.414 *INFO* [OsgiInstallerImpl] com.day.cq.dam.adobe-xmp BundleEvent INSTALLED 15.01.2018 12:16:13.414 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.adobe-xmp [167] from resource TaskResource(url=launchpad:resources/install/0/adobe-xmp-5.9.4.jar, entity=bundle:com.day.cq.dam.adobe-xmp, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.adobe-xmp, Bundle-Version=5.9.4], digest=1515998757000) 15.01.2018 12:16:13.428 *INFO* [OsgiInstallerImpl] com.adobe.aemds.guide.aemds-guide-core BundleEvent INSTALLED 15.01.2018 12:16:13.428 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.aemds.guide.aemds-guide-core [168] from resource TaskResource(url=launchpad:resources/install/0/aemds-guide-core-4.0.94.jar, entity=bundle:com.adobe.aemds.guide.aemds-guide-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.aemds.guide.aemds-guide-core, Bundle-Version=4.0.94], digest=1515998757000) 15.01.2018 12:16:13.443 *INFO* [OsgiInstallerImpl] com.adobe.aemds.guide.aemds-guide-core-impl BundleEvent INSTALLED 15.01.2018 12:16:13.443 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.aemds.guide.aemds-guide-core-impl [169] from resource TaskResource(url=launchpad:resources/install/0/aemds-guide-core-impl-4.0.94.jar, entity=bundle:com.adobe.aemds.guide.aemds-guide-core-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.aemds.guide.aemds-guide-core-impl, Bundle-Version=4.0.94], digest=1515998757000) 15.01.2018 12:16:13.505 *INFO* [OsgiInstallerImpl] com.adobe.aemfd.expeditor.aemfd-expeditor-utils-bundle BundleEvent INSTALLED 15.01.2018 12:16:13.505 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.aemfd.expeditor.aemfd-expeditor-utils-bundle [170] from resource TaskResource(url=launchpad:resources/install/0/aemfd-expeditor-utils-bundle-3.0.40.jar, entity=bundle:com.adobe.aemfd.expeditor.aemfd-expeditor-utils-bundle, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.aemfd.expeditor.aemfd-expeditor-utils-bundle, Bundle-Version=3.0.40], digest=1515998757000) 15.01.2018 12:16:13.518 *INFO* [OsgiInstallerImpl] afml BundleEvent INSTALLED 15.01.2018 12:16:13.518 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle afml [171] from resource TaskResource(url=launchpad:resources/install/0/afml-3.0.573297.jar, entity=bundle:afml, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=afml, Bundle-Version=3.0.573297], digest=1515998757000) 15.01.2018 12:16:13.613 *INFO* [OsgiInstallerImpl] com.adobe.cq.cdn.cdn-rewriter BundleEvent INSTALLED 15.01.2018 12:16:13.614 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cdn.cdn-rewriter [172] from resource TaskResource(url=launchpad:resources/install/0/cdn-rewriter-1.10.jar, entity=bundle:com.adobe.cq.cdn.cdn-rewriter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cdn.cdn-rewriter, Bundle-Version=1.10.0], digest=1515998757000) 15.01.2018 12:16:13.625 *INFO* [OsgiInstallerImpl] org.apache.cocoon.cocoon-xml BundleEvent INSTALLED 15.01.2018 12:16:13.625 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.cocoon.cocoon-xml [173] from resource TaskResource(url=launchpad:resources/install/0/cocoon-xml-2.0.2.jar, entity=bundle:org.apache.cocoon.cocoon-xml, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.cocoon.cocoon-xml, Bundle-Version=2.0.2], digest=1515998757000) 15.01.2018 12:16:13.715 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.editor BundleEvent INSTALLED 15.01.2018 12:16:13.715 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.editor [174] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.editor-1.0.18.jar, entity=bundle:com.adobe.cq.com.adobe.cq.editor, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.editor, Bundle-Version=1.0.18], digest=1515998757000) 15.01.2018 12:16:13.726 *INFO* [OsgiInstallerImpl] com.adobe.cq.gson BundleEvent INSTALLED 15.01.2018 12:16:13.726 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.gson [175] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.gson-2.3.jar, entity=bundle:com.adobe.cq.gson, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.gson, Bundle-Version=2.3], digest=1515998757000) 15.01.2018 12:16:13.789 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.msm.ui BundleEvent INSTALLED 15.01.2018 12:16:13.789 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.msm.ui [176] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.msm.ui-0.0.6.jar, entity=bundle:com.adobe.cq.com.adobe.cq.msm.ui, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.msm.ui, Bundle-Version=0.0.6], digest=1515998757000) 15.01.2018 12:16:13.839 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.projects.api BundleEvent INSTALLED 15.01.2018 12:16:13.839 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.projects.api [177] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.projects.api-0.2.2.jar, entity=bundle:com.adobe.cq.com.adobe.cq.projects.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.projects.api, Bundle-Version=0.2.2], digest=1515998757000) 15.01.2018 12:16:13.851 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.projects.core BundleEvent INSTALLED 15.01.2018 12:16:13.851 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.projects.core [178] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.projects.core-0.3.62.jar, entity=bundle:com.adobe.cq.com.adobe.cq.projects.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.projects.core, Bundle-Version=0.3.62], digest=1515998757000) 15.01.2018 12:16:13.931 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.projects.ui BundleEvent INSTALLED 15.01.2018 12:16:13.932 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.projects.ui [179] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.projects.ui-0.2.2.jar, entity=bundle:com.adobe.cq.com.adobe.cq.projects.ui, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.projects.ui, Bundle-Version=0.2.2], digest=1515998757000) 15.01.2018 12:16:13.992 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.projects.wcm.core BundleEvent INSTALLED 15.01.2018 12:16:13.992 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.projects.wcm.core [180] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.projects.wcm.core-0.3.2.jar, entity=bundle:com.adobe.cq.com.adobe.cq.projects.wcm.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.projects.wcm.core, Bundle-Version=0.3.2], digest=1515998757000) 15.01.2018 12:16:14.004 *INFO* [OsgiInstallerImpl] com.adobe.cq.screens.com.adobe.cq.screens BundleEvent INSTALLED 15.01.2018 12:16:14.004 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.screens.com.adobe.cq.screens [181] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.screens-1.2.22.jar, entity=bundle:com.adobe.cq.screens.com.adobe.cq.screens, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.screens.com.adobe.cq.screens, Bundle-Version=1.2.22], digest=1515998757000) 15.01.2018 12:16:14.053 *INFO* [OsgiInstallerImpl] com.adobe.cq.screens.com.adobe.cq.screens.dcc BundleEvent INSTALLED 15.01.2018 12:16:14.053 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.screens.com.adobe.cq.screens.dcc [182] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.screens.dcc-1.2.4.jar, entity=bundle:com.adobe.cq.screens.com.adobe.cq.screens.dcc, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.screens.com.adobe.cq.screens.dcc, Bundle-Version=1.2.4], digest=1515998757000) 15.01.2018 12:16:14.176 *INFO* [OsgiInstallerImpl] com.adobe.cq.screens.com.adobe.cq.screens.sessions BundleEvent INSTALLED 15.01.2018 12:16:14.176 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.screens.com.adobe.cq.screens.sessions [183] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.screens.sessions-1.2.4.jar, entity=bundle:com.adobe.cq.screens.com.adobe.cq.screens.sessions, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.screens.com.adobe.cq.screens.sessions, Bundle-Version=1.2.4], digest=1515998757000) 15.01.2018 12:16:14.291 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.sites.ui BundleEvent INSTALLED 15.01.2018 12:16:14.291 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.sites.ui [184] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.sites.ui-0.1.14.jar, entity=bundle:com.adobe.cq.com.adobe.cq.sites.ui, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.sites.ui, Bundle-Version=0.1.14], digest=1515998757000) 15.01.2018 12:16:14.360 *INFO* [OsgiInstallerImpl] com.adobe.cq.com.adobe.cq.ui.commons BundleEvent INSTALLED 15.01.2018 12:16:14.360 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.com.adobe.cq.ui.commons [185] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.cq.ui.commons-1.0.12.jar, entity=bundle:com.adobe.cq.com.adobe.cq.ui.commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.com.adobe.cq.ui.commons, Bundle-Version=1.0.12], digest=1515998757000) 15.01.2018 12:16:14.372 *INFO* [OsgiInstallerImpl] com.adobe.granite.activitystreams BundleEvent INSTALLED 15.01.2018 12:16:14.372 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.activitystreams [186] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.activitystreams-0.0.44.j ar, entity=bundle:com.adobe.granite.activitystreams, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.activitystreams, Bundle-Version=0.0.44], digest=1515998757000) 15.01.2018 12:16:14.416 *INFO* [OsgiInstallerImpl] com.adobe.granite.apicontroller BundleEvent INSTALLED 15.01.2018 12:16:14.416 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.apicontroller [187] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.apicontroller-1.0.2.jar, entity=bundle:com.adobe.granite.apicontroller, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.apicontroller, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:14.478 *INFO* [OsgiInstallerImpl] com.adobe.granite.asset.api BundleEvent INSTALLED 15.01.2018 12:16:14.478 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.asset.api [188] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.asset.api-2.0.6.jar, entity=bundle:com.adobe.granite.asset.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.asset.api, Bundle-Version=2.0.6], digest=1515998757000) 15.01.2018 12:16:14.490 *INFO* [OsgiInstallerImpl] com.adobe.granite.asset.core BundleEvent INSTALLED 15.01.2018 12:16:14.490 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.asset.core [189] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.asset.core-2.2.50.jar, entity=bundle:com.adobe.granite.asset.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.asset.core, Bundle-Version=2.2.50], digest=1515998757000) 15.01.2018 12:16:14.502 *INFO* [OsgiInstallerImpl] com.day.cq.cq-authhandler BundleEvent INSTALLED 15.01.2018 12:16:14.502 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-authhandler [190] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.auth.authhandler-5.6.72. jar, entity=bundle:com.day.cq.cq-authhandler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-authhandler, Bundle-Version=5.6.72], digest=1515998757000) 15.01.2018 12:16:14.575 *INFO* [OsgiInstallerImpl] com.adobe.granite.auth.cert BundleEvent INSTALLED 15.01.2018 12:16:14.575 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.auth.cert [191] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.auth.cert-0.0.16.jar, entity=bundle:com.adobe.granite.auth.cert, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.auth.cert, Bundle-Version=0.0.16], digest=1515998757000) 15.01.2018 12:16:14.591 *INFO* [OsgiInstallerImpl] com.adobe.granite.auth.oauth BundleEvent INSTALLED 15.01.2018 12:16:14.591 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.auth.oauth [192] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.auth.oauth-1.3.10.jar, entity=bundle:com.adobe.granite.auth.oauth, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.auth.oauth, Bundle-Version=1.3.10], digest=1515998757000) 15.01.2018 12:16:14.626 *INFO* [OsgiInstallerImpl] com.adobe.granite.auth.saml BundleEvent INSTALLED 15.01.2018 12:16:14.626 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.auth.saml [193] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.auth.saml-1.0.2.jar, entity=bundle:com.adobe.granite.auth.saml, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.auth.saml, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:14.723 *INFO* [OsgiInstallerImpl] com.adobe.granite.auth.sso BundleEvent INSTALLED 15.01.2018 12:16:14.723 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.auth.sso [194] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.auth.sso-0.0.28.jar, entity=bundle:com.adobe.granite.auth.sso, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.auth.sso, Bundle-Version=0.0.28], digest=1515998757000) 15.01.2018 12:16:14.859 *INFO* [OsgiInstallerImpl] com.adobe.granite.bundles.hc.impl BundleEvent INSTALLED 15.01.2018 12:16:14.859 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.bundles.hc.impl [195] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.bundles.hc.impl-1.0.38.j ar, entity=bundle:com.adobe.granite.bundles.hc.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.bundles.hc.impl, Bundle-Version=1.0.38], digest=1515998757000) 15.01.2018 12:16:14.907 *INFO* [OsgiInstallerImpl] com.adobe.granite.cloudsettings.core BundleEvent INSTALLED 15.01.2018 12:16:14.907 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.cloudsettings.core [196] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.cloudsettings.core-1.1.2 .jar, entity=bundle:com.adobe.granite.cloudsettings.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.cloudsettings.core, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:15.048 *INFO* [OsgiInstallerImpl] com.adobe.granite.comments BundleEvent INSTALLED 15.01.2018 12:16:15.048 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.comments [197] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.comments-1.0.24.jar, entity=bundle:com.adobe.granite.comments, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.comments, Bundle-Version=1.0.24], digest=1515998757000) 15.01.2018 12:16:15.098 *INFO* [OsgiInstallerImpl] com.adobe.granite.conf BundleEvent INSTALLED 15.01.2018 12:16:15.098 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.conf [198] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.conf-1.0.2.jar, entity=bundle:com.adobe.granite.conf, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.conf, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:15.223 *INFO* [OsgiInstallerImpl] com.adobe.granite.conf.ui.core BundleEvent INSTALLED 15.01.2018 12:16:15.223 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.conf.ui.core [199] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.conf.ui.core-0.0.24.jar, entity=bundle:com.adobe.granite.conf.ui.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.conf.ui.core, Bundle-Version=0.0.24], digest=1515998757000) 15.01.2018 12:16:15.323 *INFO* [OsgiInstallerImpl] com.adobe.granite.confmgr BundleEvent INSTALLED 15.01.2018 12:16:15.323 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.confmgr [200] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.confmgr-1.2.2.jar, entity=bundle:com.adobe.granite.confmgr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.confmgr, Bundle-Version=1.2.2], digest=1515998757000) 15.01.2018 12:16:15.336 *INFO* [OsgiInstallerImpl] com.adobe.granite.contexthub.commons BundleEvent INSTALLED 15.01.2018 12:16:15.336 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.contexthub.commons [201] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.contexthub.commons-0.1.3 0.jar, entity=bundle:com.adobe.granite.contexthub.commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.contexthub.commons, Bundle-Version=0.1.30], digest=1515998757000) 15.01.2018 12:16:15.398 *INFO* [OsgiInstallerImpl] com.adobe.granite.cors BundleEvent INSTALLED 15.01.2018 12:16:15.398 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.cors [202] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.cors-1.0.4.jar, entity=bundle:com.adobe.granite.cors, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.cors, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:15.418 *INFO* [OsgiInstallerImpl] com.adobe.granite.crx-explorer BundleEvent INSTALLED 15.01.2018 12:16:15.418 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crx-explorer [203] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crx-explorer-1.1.8.jar, entity=bundle:com.adobe.granite.crx-explorer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crx-explorer, Bundle-Version=1.1.8], digest=1515998757000) 15.01.2018 12:16:15.437 *INFO* [OsgiInstallerImpl] com.adobe.granite.crx-packagemgr BundleEvent INSTALLED 15.01.2018 12:16:15.437 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crx-packagemgr [204] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crx-packagemgr-1.2.26.ja r, entity=bundle:com.adobe.granite.crx-packagemgr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crx-packagemgr, Bundle-Version=1.2.26], digest=1515998757000) 15.01.2018 12:16:15.458 *INFO* [OsgiInstallerImpl] com.adobe.granite.crxde-lite BundleEvent INSTALLED 15.01.2018 12:16:15.458 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crxde-lite [205] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crxde-lite-1.1.14.jar, entity=bundle:com.adobe.granite.crxde-lite, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crxde-lite, Bundle-Version=1.1.14], digest=1515998757000) 15.01.2018 12:16:15.517 *INFO* [OsgiInstallerImpl] com.adobe.granite.crypto.extension BundleEvent INSTALLED 15.01.2018 12:16:15.517 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crypto.extension [206] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crypto.extension-0.0.2.j ar, entity=bundle:com.adobe.granite.crypto.extension, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crypto.extension, Bundle-Version=0.0.2], digest=1515998757000) 15.01.2018 12:16:15.573 *INFO* [OsgiInstallerImpl] com.adobe.granite.crypto.jcr BundleEvent INSTALLED 15.01.2018 12:16:15.573 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crypto.jcr [207] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crypto.jcr-0.0.6.jar, entity=bundle:com.adobe.granite.crypto.jcr, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crypto.jcr, Bundle-Version=0.0.6], digest=1515998757000) 15.01.2018 12:16:15.591 *INFO* [OsgiInstallerImpl] com.adobe.granite.crypto.keystore BundleEvent INSTALLED 15.01.2018 12:16:15.591 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.crypto.keystore [208] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.crypto.keystore-3.3.4.ja r, entity=bundle:com.adobe.granite.crypto.keystore, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.crypto.keystore, Bundle-Version=3.3.4], digest=1515998757000) 15.01.2018 12:16:15.660 *INFO* [OsgiInstallerImpl] com.adobe.granite.csrf BundleEvent INSTALLED 15.01.2018 12:16:15.660 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.csrf [209] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.csrf-1.0.16.jar, entity=bundle:com.adobe.granite.csrf, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.csrf, Bundle-Version=1.0.16], digest=1515998757000) 15.01.2018 12:16:15.778 *INFO* [OsgiInstallerImpl] com.adobe.granite.distribution.core BundleEvent INSTALLED 15.01.2018 12:16:15.778 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.distribution.core [210] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.distribution.core-0.2.10 .jar, entity=bundle:com.adobe.granite.distribution.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.distribution.core, Bundle-Version=0.2.10], digest=1515998757000) 15.01.2018 12:16:15.831 *INFO* [OsgiInstallerImpl] com.adobe.granite.frags.impl BundleEvent INSTALLED 15.01.2018 12:16:15.831 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.frags.impl [211] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.frags.impl-0.0.2.jar, entity=bundle:com.adobe.granite.frags.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.frags.impl, Bundle-Version=0.0.2], digest=1515998757000) 15.01.2018 12:16:15.992 *INFO* [OsgiInstallerImpl] com.adobe.granite.httpcache.core BundleEvent INSTALLED 15.01.2018 12:16:15.992 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.httpcache.core [212] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.httpcache.core-1.0.6.jar , entity=bundle:com.adobe.granite.httpcache.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.httpcache.core, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:16.142 *INFO* [OsgiInstallerImpl] com.day.cq.cq-i18n BundleEvent INSTALLED 15.01.2018 12:16:16.142 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-i18n [213] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.i18n-5.5.16.jar, entity=bundle:com.day.cq.cq-i18n, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-i18n, Bundle-Version=5.5.16], digest=1515998757000) 15.01.2018 12:16:16.196 *INFO* [OsgiInstallerImpl] com.adobe.granite.jetty.ssl BundleEvent INSTALLED 15.01.2018 12:16:16.196 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.jetty.ssl [214] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.jetty.ssl-0.0.14.jar, entity=bundle:com.adobe.granite.jetty.ssl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.jetty.ssl, Bundle-Version=0.0.14], digest=1515998757000) 15.01.2018 12:16:16.291 *INFO* [OsgiInstallerImpl] com.adobe.granite.logging BundleEvent INSTALLED 15.01.2018 12:16:16.291 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.logging [215] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.logging-1.0.22.jar, entity=bundle:com.adobe.granite.logging, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.logging, Bundle-Version=1.0.22], digest=1515998757000) 15.01.2018 12:16:16.303 *INFO* [OsgiInstallerImpl] com.adobe.granite.maintenance.core BundleEvent INSTALLED 15.01.2018 12:16:16.303 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.maintenance.core [216] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.maintenance.core-1.3.8.j ar, entity=bundle:com.adobe.granite.maintenance.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.maintenance.core, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:16.313 *INFO* [OsgiInstallerImpl] com.adobe.granite.monitoring.core BundleEvent INSTALLED 15.01.2018 12:16:16.313 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.monitoring.core [217] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.monitoring.core-1.0.0.ja r, entity=bundle:com.adobe.granite.monitoring.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.monitoring.core, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:16.397 *INFO* [OsgiInstallerImpl] com.adobe.granite.oauth.jwt BundleEvent INSTALLED 15.01.2018 12:16:16.397 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.oauth.jwt [218] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.oauth.jwt-0.1.0.jar, entity=bundle:com.adobe.granite.oauth.jwt, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.oauth.jwt, Bundle-Version=0.1.0], digest=1515998757000) 15.01.2018 12:16:16.409 *INFO* [OsgiInstallerImpl] com.adobe.granite.offloading.core BundleEvent INSTALLED 15.01.2018 12:16:16.409 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.offloading.core [219] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.offloading.core-1.0.56.j ar, entity=bundle:com.adobe.granite.offloading.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.offloading.core, Bundle-Version=1.0.56], digest=1515998757000) 15.01.2018 12:16:16.494 *INFO* [OsgiInstallerImpl] com.adobe.granite.offloading.workflow BundleEvent INSTALLED 15.01.2018 12:16:16.494 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.offloading.workflow [220] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.offloading.workflow-1.0. 12.jar, entity=bundle:com.adobe.granite.offloading.workflow, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.offloading.workflow, Bundle-Version=1.0.12], digest=1515998757000) 15.01.2018 12:16:16.642 *INFO* [OsgiInstallerImpl] com.adobe.granite.omnisearch.core BundleEvent INSTALLED 15.01.2018 12:16:16.642 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.omnisearch.core [221] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.omnisearch.core-1.0.68.j ar, entity=bundle:com.adobe.granite.omnisearch.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.omnisearch.core, Bundle-Version=1.0.68], digest=1515998757000) 15.01.2018 12:16:16.700 *INFO* [OsgiInstallerImpl] com.adobe.granite.optout BundleEvent INSTALLED 15.01.2018 12:16:16.700 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.optout [222] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.optout-1.0.0.jar, entity=bundle:com.adobe.granite.optout, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.optout, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:16.779 *INFO* [OsgiInstallerImpl] com.adobe.granite.queries BundleEvent INSTALLED 15.01.2018 12:16:16.779 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.queries [223] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.queries-1.0.34.jar, entity=bundle:com.adobe.granite.queries, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.queries, Bundle-Version=1.0.34], digest=1515998757000) 15.01.2018 12:16:16.842 *INFO* [OsgiInstallerImpl] com.adobe.granite.references.core BundleEvent INSTALLED 15.01.2018 12:16:16.842 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.references.core [224] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.references.core-1.1.0.ja r, entity=bundle:com.adobe.granite.references.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.references.core, Bundle-Version=1.1.0], digest=1515998757000) 15.01.2018 12:16:16.857 *INFO* [OsgiInstallerImpl] com.day.cq.cq-replication BundleEvent INSTALLED 15.01.2018 12:16:16.857 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-replication [225] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.replication.core-6.2.26. jar, entity=bundle:com.day.cq.cq-replication, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-replication, Bundle-Version=6.2.26], digest=1515998757000) 15.01.2018 12:16:16.932 *INFO* [OsgiInstallerImpl] com.adobe.granite.replication.hc.impl BundleEvent INSTALLED 15.01.2018 12:16:16.932 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.replication.hc.impl [226] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.replication.hc.impl-1.0. 20.jar, entity=bundle:com.adobe.granite.replication.hc.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.replication.hc.impl, Bundle-Version=1.0.20], digest=1515998757000) 15.01.2018 12:16:16.992 *INFO* [OsgiInstallerImpl] com.adobe.granite.repository.checker BundleEvent INSTALLED 15.01.2018 12:16:16.992 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.repository.checker [227] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.repository.checker-1.0.0 .jar, entity=bundle:com.adobe.granite.repository.checker, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.repository.checker, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:17.077 *INFO* [OsgiInstallerImpl] com.adobe.granite.repository.hc.impl BundleEvent INSTALLED 15.01.2018 12:16:17.077 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.repository.hc.impl [228] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.repository.hc.impl-1.0.4 2.jar, entity=bundle:com.adobe.granite.repository.hc.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.repository.hc.impl, Bundle-Version=1.0.42], digest=1515998757000) 15.01.2018 12:16:17.151 *INFO* [OsgiInstallerImpl] com.adobe.granite.requests.logging BundleEvent INSTALLED 15.01.2018 12:16:17.151 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.requests.logging [229] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.requests.logging-1.0.18. jar, entity=bundle:com.adobe.granite.requests.logging, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.requests.logging, Bundle-Version=1.0.18], digest=1515998757000) 15.01.2018 12:16:17.207 *INFO* [OsgiInstallerImpl] com.adobe.granite.resourceresolverhelper BundleEvent INSTALLED 15.01.2018 12:16:17.207 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.resourceresolverhelper [230] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.resourceresolverhelper-1 .0.4.jar, entity=bundle:com.adobe.granite.resourceresolverhelper, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.resourceresolverhelper, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:17.287 *INFO* [OsgiInstallerImpl] com.adobe.granite.resourcestatus BundleEvent INSTALLED 15.01.2018 12:16:17.287 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.resourcestatus [231] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.resourcestatus-1.0.2.jar , entity=bundle:com.adobe.granite.resourcestatus, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.resourcestatus, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:17.300 *INFO* [OsgiInstallerImpl] com.adobe.granite.rest.api BundleEvent INSTALLED 15.01.2018 12:16:17.300 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.rest.api [232] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.rest.api-1.0.82.jar, entity=bundle:com.adobe.granite.rest.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.rest.api, Bundle-Version=1.0.82], digest=1515998757000) 15.01.2018 12:16:17.310 *INFO* [OsgiInstallerImpl] com.adobe.granite.rest.assets BundleEvent INSTALLED 15.01.2018 12:16:17.311 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.rest.assets [233] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.rest.assets-1.0.48.jar, entity=bundle:com.adobe.granite.rest.assets, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.rest.assets, Bundle-Version=1.0.48], digest=1515998757000) 15.01.2018 12:16:17.321 *INFO* [OsgiInstallerImpl] com.adobe.granite.scribe BundleEvent INSTALLED 15.01.2018 12:16:17.321 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.scribe [234] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.scribe-1.3.8.jar, entity=bundle:com.adobe.granite.scribe, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.scribe, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:17.365 *INFO* [OsgiInstallerImpl] com.adobe.granite.security.installer BundleEvent INSTALLED 15.01.2018 12:16:17.365 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.security.installer [235] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.security.installer-0.0.6 .jar, entity=bundle:com.adobe.granite.security.installer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.security.installer, Bundle-Version=0.0.6], digest=1515998757000) 15.01.2018 12:16:17.376 *INFO* [OsgiInstallerImpl] com.adobe.granite.security.user BundleEvent INSTALLED 15.01.2018 12:16:17.376 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.security.user [236] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.security.user-0.2.62.jar , entity=bundle:com.adobe.granite.security.user, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.security.user, Bundle-Version=0.2.62], digest=1515998757000) 15.01.2018 12:16:17.387 *INFO* [OsgiInstallerImpl] com.adobe.granite.socialgraph BundleEvent INSTALLED 15.01.2018 12:16:17.387 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.socialgraph [237] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.socialgraph-0.1.0.jar, entity=bundle:com.adobe.granite.socialgraph, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.socialgraph, Bundle-Version=0.1.0], digest=1515998757000) 15.01.2018 12:16:17.399 *INFO* [OsgiInstallerImpl] com.adobe.granite.socketio BundleEvent INSTALLED 15.01.2018 12:16:17.399 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.socketio [238] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.socketio-0.0.6.jar, entity=bundle:com.adobe.granite.socketio, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.socketio, Bundle-Version=0.0.6], digest=1515998757000) 15.01.2018 12:16:17.468 *INFO* [OsgiInstallerImpl] com.adobe.granite.taskmanagement.api BundleEvent INSTALLED 15.01.2018 12:16:17.468 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.taskmanagement.api [239] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.taskmanagement.api-1.0.4 .jar, entity=bundle:com.adobe.granite.taskmanagement.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.taskmanagement.api, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:17.480 *INFO* [OsgiInstallerImpl] com.adobe.granite.taskmanagement.core BundleEvent INSTALLED 15.01.2018 12:16:17.480 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.taskmanagement.core [240] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.taskmanagement.core-1.0. 42.jar, entity=bundle:com.adobe.granite.taskmanagement.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.taskmanagement.core, Bundle-Version=1.0.42], digest=1515998757000) 15.01.2018 12:16:17.555 *INFO* [OsgiInstallerImpl] com.adobe.granite.taskmanagement.workflow BundleEvent INSTALLED 15.01.2018 12:16:17.555 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.taskmanagement.workflow [241] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.taskmanagement.workflow- 1.0.10.jar, entity=bundle:com.adobe.granite.taskmanagement.workflow, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.taskmanagement.workflow, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:17.649 *INFO* [OsgiInstallerImpl] com.adobe.granite.threaddump BundleEvent INSTALLED 15.01.2018 12:16:17.649 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.threaddump [242] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.threaddump-1.0.28.jar, entity=bundle:com.adobe.granite.threaddump, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.threaddump, Bundle-Version=1.0.28], digest=1515998757000) 15.01.2018 12:16:17.777 *INFO* [OsgiInstallerImpl] com.adobe.granite.timeline BundleEvent INSTALLED 15.01.2018 12:16:17.777 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.timeline [243] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.timeline-1.0.16.jar, entity=bundle:com.adobe.granite.timeline, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.timeline, Bundle-Version=1.0.16], digest=1515998757000) 15.01.2018 12:16:17.894 *INFO* [OsgiInstallerImpl] com.adobe.granite.translation.api BundleEvent INSTALLED 15.01.2018 12:16:17.894 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.translation.api [244] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.translation.api-1.2.0.ja r, entity=bundle:com.adobe.granite.translation.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.translation.api, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:17.905 *INFO* [OsgiInstallerImpl] com.adobe.granite.translation.connector.msft.core BundleEvent INSTALLED 15.01.2018 12:16:17.905 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.translation.connector.msft.core [245] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.translation.connector.ms ft.core-1.2.26.jar, entity=bundle:com.adobe.granite.translation.connector.msft.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.translation.connector.msft.core, Bundle-Version=1.2.26], digest=1515998757000) 15.01.2018 12:16:18.023 *INFO* [OsgiInstallerImpl] com.adobe.granite.translation.core BundleEvent INSTALLED 15.01.2018 12:16:18.023 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.translation.core [246] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.translation.core-1.1.40. jar, entity=bundle:com.adobe.granite.translation.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.translation.core, Bundle-Version=1.1.40], digest=1515998757000) 15.01.2018 12:16:18.037 *INFO* [OsgiInstallerImpl] com.adobe.granite.ui.clientlibs BundleEvent INSTALLED 15.01.2018 12:16:18.037 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.ui.clientlibs [247] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.ui.clientlibs-1.0.54.jar , entity=bundle:com.adobe.granite.ui.clientlibs, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.ui.clientlibs, Bundle-Version=1.0.54], digest=1515998757000) 15.01.2018 12:16:18.047 *INFO* [OsgiInstallerImpl] com.adobe.granite.ui.clientlibs.compiler.less BundleEvent INSTALLED 15.01.2018 12:16:18.047 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.ui.clientlibs.compiler.less [248] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.ui.clientlibs.compiler.l ess-1.0.6.jar, entity=bundle:com.adobe.granite.ui.clientlibs.compiler.less, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.ui.clientlibs.compiler.less, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:18.075 *INFO* [OsgiInstallerImpl] com.adobe.granite.ui.clientlibs.processor.gcc BundleEvent INSTALLED 15.01.2018 12:16:18.075 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.ui.clientlibs.processor.gcc [249] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.ui.clientlibs.processor. gcc-1.0.6.jar, entity=bundle:com.adobe.granite.ui.clientlibs.processor.gcc, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.ui.clientlibs.processor.gcc, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:18.086 *INFO* [OsgiInstallerImpl] com.adobe.granite.ui.commons BundleEvent INSTALLED 15.01.2018 12:16:18.086 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.ui.commons [250] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.ui.commons-5.7.6.jar, entity=bundle:com.adobe.granite.ui.commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.ui.commons, Bundle-Version=5.7.6], digest=1515998757000) 15.01.2018 12:16:18.337 *INFO* [OsgiInstallerImpl] com.adobe.granite.workflow.api BundleEvent INSTALLED 15.01.2018 12:16:18.337 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.workflow.api [251] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.workflow.api-1.0.14.jar, entity=bundle:com.adobe.granite.workflow.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.workflow.api, Bundle-Version=1.0.14], digest=1515998757000) 15.01.2018 12:16:18.348 *INFO* [OsgiInstallerImpl] com.adobe.granite.workflow.console BundleEvent INSTALLED 15.01.2018 12:16:18.348 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.granite.workflow.console [252] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.workflow.console-1.0.44. jar, entity=bundle:com.adobe.granite.workflow.console, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.granite.workflow.console, Bundle-Version=1.0.44], digest=1515998757000) 15.01.2018 12:16:18.378 *INFO* [OsgiInstallerImpl] com.day.cq.cq-xssprotection BundleEvent INSTALLED 15.01.2018 12:16:18.378 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-xssprotection [253] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.granite.xssprotection-5.6.0.jar, entity=bundle:com.day.cq.cq-xssprotection, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-xssprotection, Bundle-Version=5.6.0], digest=1515998757000) 15.01.2018 12:16:18.389 *INFO* [OsgiInstallerImpl] com.adobe.suitetech.nativecomm BundleEvent INSTALLED 15.01.2018 12:16:18.389 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.suitetech.nativecomm [254] from resource TaskResource(url=launchpad:resources/install/0/com.adobe.suitetech.nativecomm-2.0.8.jar, entity=bundle:com.adobe.suitetech.nativecomm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.suitetech.nativecomm, Bundle-Version=2.0.8], digest=1515998757000) 15.01.2018 12:16:18.474 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.commons-email BundleEvent INSTALLED 15.01.2018 12:16:18.474 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.osgi.wrapper.commons-email [255] from resource TaskResource(url=launchpad:resources/install/0/com.day.commons.osgi.wrapper.commons-email -1.2.0-0002.jar, entity=bundle:com.day.commons.osgi.wrapper.commons-email, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.osgi.wrapper.commons-email, Bundle-Version=1.2.0.0002], digest=1515998757000) 15.01.2018 12:16:18.570 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.fop BundleEvent INSTALLED 15.01.2018 12:16:18.571 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.osgi.wrapper.fop [256] from resource TaskResource(url=launchpad:resources/install/0/com.day.commons.osgi.wrapper.fop-1.11.jar, entity=bundle:com.day.commons.osgi.wrapper.fop, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.osgi.wrapper.fop, Bundle-Version=1.11.0], digest=1515998757000) 15.01.2018 12:16:18.584 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.simple-jndi BundleEvent INSTALLED 15.01.2018 12:16:18.585 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.commons.osgi.wrapper.simple-jndi [257] from resource TaskResource(url=launchpad:resources/install/0/com.day.commons.osgi.wrapper.simple-jndi-0 .11.14.1.0010.jar, entity=bundle:com.day.commons.osgi.wrapper.simple-jndi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.commons.osgi.wrapper.simple-jndi, Bundle-Version=0.11.14.1_0010], digest=1515998757000) 15.01.2018 12:16:18.643 *INFO* [OsgiInstallerImpl] com.day.cq.cq-widgets BundleEvent INSTALLED 15.01.2018 12:16:18.643 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-widgets [258] from resource TaskResource(url=launchpad:resources/install/0/com.day.cq.widget-6.0.0.jar, entity=bundle:com.day.cq.cq-widgets, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-widgets, Bundle-Version=6.0.0], digest=1515998757000) 15.01.2018 12:16:18.654 *INFO* [OsgiInstallerImpl] org.apache.commons.exec BundleEvent INSTALLED 15.01.2018 12:16:18.654 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.exec [259] from resource TaskResource(url=launchpad:resources/install/0/commons-exec-1.3.jar, entity=bundle:org.apache.commons.exec, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.exec, Bundle-Version=1.3.0], digest=1515998757000) 15.01.2018 12:16:18.669 *INFO* [OsgiInstallerImpl] org.apache.commons.commons-imaging BundleEvent INSTALLED 15.01.2018 12:16:18.669 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.commons-imaging [260] from resource TaskResource(url=launchpad:resources/install/0/commons-imaging-1.0-R1725432-B002.jar, entity=bundle:org.apache.commons.commons-imaging, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.commons-imaging, Bundle-Version=1.0.0.R1725432-B002], digest=1515998757000) 15.01.2018 12:16:18.685 *INFO* [OsgiInstallerImpl] org.apache.commons.math BundleEvent INSTALLED 15.01.2018 12:16:18.686 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.commons.math [261] from resource TaskResource(url=launchpad:resources/install/0/commons-math-2.2.jar, entity=bundle:org.apache.commons.math, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.commons.math, Bundle-Version=2.2], digest=1515998757000) 15.01.2018 12:16:18.696 *INFO* [OsgiInstallerImpl] com.adobe.cq.smartcontent-core BundleEvent INSTALLED 15.01.2018 12:16:18.696 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.smartcontent-core [262] from resource TaskResource(url=launchpad:resources/install/0/core-0.1.6.jar, entity=bundle:com.adobe.cq.smartcontent-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.smartcontent-core, Bundle-Version=0.1.6], digest=1515998757000) 15.01.2018 12:16:18.772 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-account BundleEvent INSTALLED 15.01.2018 12:16:18.772 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-account [263] from resource TaskResource(url=launchpad:resources/install/0/cq-account-1.1.4.jar, entity=bundle:com.adobe.cq.cq-account, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-account, Bundle-Version=1.1.4], digest=1515998757000) 15.01.2018 12:16:18.817 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-activitymap-integration BundleEvent INSTALLED 15.01.2018 12:16:18.817 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-activitymap-integration [264] from resource TaskResource(url=launchpad:resources/install/0/cq-activitymap-integration-1.0.6.jar, entity=bundle:com.adobe.cq.cq-activitymap-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-activitymap-integration, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:18.938 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-address BundleEvent INSTALLED 15.01.2018 12:16:18.938 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-address [265] from resource TaskResource(url=launchpad:resources/install/0/cq-address-1.3.2.jar, entity=bundle:com.adobe.cq.cq-address, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-address, Bundle-Version=1.3.2], digest=1515998757000) 15.01.2018 12:16:18.953 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-analytics-integration BundleEvent INSTALLED 15.01.2018 12:16:18.953 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-analytics-integration [266] from resource TaskResource(url=launchpad:resources/install/0/cq-analytics-integration-1.1.24.jar, entity=bundle:com.adobe.cq.cq-analytics-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-analytics-integration, Bundle-Version=1.1.24], digest=1515998757000) 15.01.2018 12:16:19.075 *INFO* [OsgiInstallerImpl] com.day.cq.cq-audit BundleEvent INSTALLED 15.01.2018 12:16:19.075 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-audit [267] from resource TaskResource(url=launchpad:resources/install/0/cq-audit-6.1.18.jar, entity=bundle:com.day.cq.cq-audit, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-audit, Bundle-Version=6.1.18], digest=1515998757000) 15.01.2018 12:16:19.171 *INFO* [OsgiInstallerImpl] com.day.cq.cq-chart BundleEvent INSTALLED 15.01.2018 12:16:19.171 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-chart [268] from resource TaskResource(url=launchpad:resources/install/0/cq-chart-5.10.2.jar, entity=bundle:com.day.cq.cq-chart, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-chart, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:19.236 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-cloudservices-provisioning BundleEvent INSTALLED 15.01.2018 12:16:19.236 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-cloudservices-provisioning [269] from resource TaskResource(url=launchpad:resources/install/0/cq-cloudservices-provisioning-1.0.6.jar, entity=bundle:com.adobe.cq.cq-cloudservices-provisioning, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-cloudservices-provisioning, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:19.249 *INFO* [OsgiInstallerImpl] com.adobe.cq.commerce.cq-commerce-core BundleEvent INSTALLED 15.01.2018 12:16:19.249 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.commerce.cq-commerce-core [270] from resource TaskResource(url=launchpad:resources/install/0/cq-commerce-core-5.15.48.jar, entity=bundle:com.adobe.cq.commerce.cq-commerce-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.commerce.cq-commerce-core, Bundle-Version=5.15.48], digest=1515998757000) 15.01.2018 12:16:19.263 *INFO* [OsgiInstallerImpl] com.adobe.cq.commerce.cq-commerce-pim BundleEvent INSTALLED 15.01.2018 12:16:19.263 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.commerce.cq-commerce-pim [271] from resource TaskResource(url=launchpad:resources/install/0/cq-commerce-pim-5.12.24.jar, entity=bundle:com.adobe.cq.commerce.cq-commerce-pim, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.commerce.cq-commerce-pim, Bundle-Version=5.12.24], digest=1515998757000) 15.01.2018 12:16:19.278 *INFO* [OsgiInstallerImpl] com.day.cq.cq-commons BundleEvent INSTALLED 15.01.2018 12:16:19.278 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-commons [272] from resource TaskResource(url=launchpad:resources/install/0/cq-commons-5.10.20.jar, entity=bundle:com.day.cq.cq-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-commons, Bundle-Version=5.10.20], digest=1515998757000) 15.01.2018 12:16:19.392 *INFO* [OsgiInstallerImpl] com.day.cq.cq-compat-commons-auth BundleEvent INSTALLED 15.01.2018 12:16:19.392 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-compat-commons-auth [273] from resource TaskResource(url=launchpad:resources/install/0/cq-compat-commons-auth-0.1.6.jar, entity=bundle:com.day.cq.cq-compat-commons-auth, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-compat-commons-auth, Bundle-Version=0.1.6], digest=1515998757000) 15.01.2018 12:16:19.496 *INFO* [OsgiInstallerImpl] com.day.cq.cq-connector BundleEvent INSTALLED 15.01.2018 12:16:19.496 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-connector [274] from resource TaskResource(url=launchpad:resources/install/0/cq-connector-5.10.2.jar, entity=bundle:com.day.cq.cq-connector, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-connector, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:19.614 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-content-insight BundleEvent INSTALLED 15.01.2018 12:16:19.614 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-content-insight [275] from resource TaskResource(url=launchpad:resources/install/0/cq-content-insight-1.3.2.jar, entity=bundle:com.adobe.cq.cq-content-insight, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-content-insight, Bundle-Version=1.3.2], digest=1515998757000) 15.01.2018 12:16:19.627 *INFO* [OsgiInstallerImpl] com.day.cq.cq-content-sync BundleEvent INSTALLED 15.01.2018 12:16:19.627 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-content-sync [276] from resource TaskResource(url=launchpad:resources/install/0/cq-content-sync-5.10.18.jar, entity=bundle:com.day.cq.cq-content-sync, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-content-sync, Bundle-Version=5.10.18], digest=1515998757000) 15.01.2018 12:16:19.671 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-contexthub-commons BundleEvent INSTALLED 15.01.2018 12:16:19.671 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-contexthub-commons [277] from resource TaskResource(url=launchpad:resources/install/0/cq-contexthub-commons-0.1.10.jar, entity=bundle:com.adobe.cq.cq-contexthub-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-contexthub-commons, Bundle-Version=0.1.10], digest=1515998757000) 15.01.2018 12:16:19.682 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-annotation-print BundleEvent INSTALLED 15.01.2018 12:16:19.682 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-annotation-print [278] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-annotation-print-0.0.12.jar, entity=bundle:com.day.cq.dam.cq-dam-annotation-print, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-annotation-print, Bundle-Version=0.0.12], digest=1515998757000) 15.01.2018 12:16:19.692 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-api BundleEvent INSTALLED 15.01.2018 12:16:19.692 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-api [279] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-api-5.10.50.jar, entity=bundle:com.day.cq.dam.cq-dam-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-api, Bundle-Version=5.10.50], digest=1515998757000) 15.01.2018 12:16:19.703 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-asset-usage BundleEvent INSTALLED 15.01.2018 12:16:19.704 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-asset-usage [280] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-asset-usage-0.1.18.jar, entity=bundle:com.day.cq.dam.cq-dam-asset-usage, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-asset-usage, Bundle-Version=0.1.18], digest=1515998757000) 15.01.2018 12:16:19.790 *INFO* [OsgiInstallerImpl] com.adobe.dam.cq-dam-cfm-api BundleEvent INSTALLED 15.01.2018 12:16:19.790 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.dam.cq-dam-cfm-api [281] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-cfm-api-1.1.4.jar, entity=bundle:com.adobe.dam.cq-dam-cfm-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.dam.cq-dam-cfm-api, Bundle-Version=1.1.4], digest=1515998757000) 15.01.2018 12:16:19.803 *INFO* [OsgiInstallerImpl] com.adobe.dam.cq-dam-cfm-impl BundleEvent INSTALLED 15.01.2018 12:16:19.803 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.dam.cq-dam-cfm-impl [282] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-cfm-impl-0.9.114.jar, entity=bundle:com.adobe.dam.cq-dam-cfm-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.dam.cq-dam-cfm-impl, Bundle-Version=0.9.114], digest=1515998757000) 15.01.2018 12:16:19.816 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-commons BundleEvent INSTALLED 15.01.2018 12:16:19.816 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-commons [283] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-commons-5.10.128.jar, entity=bundle:com.day.cq.dam.cq-dam-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-commons, Bundle-Version=5.10.128], digest=1515998757000) 15.01.2018 12:16:19.834 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-core BundleEvent INSTALLED 15.01.2018 12:16:19.834 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-core [284] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-core-5.10.214.jar, entity=bundle:com.day.cq.dam.cq-dam-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-core, Bundle-Version=5.10.214], digest=1515998757000) 15.01.2018 12:16:19.845 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-entitlement BundleEvent INSTALLED 15.01.2018 12:16:19.845 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-entitlement [285] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-entitlement-1.1.34.jar, entity=bundle:com.day.cq.dam.cq-dam-entitlement, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-entitlement, Bundle-Version=1.1.34], digest=1515998757000) 15.01.2018 12:16:19.861 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-handler BundleEvent INSTALLED 15.01.2018 12:16:19.861 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-handler [286] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-handler-5.10.26.jar, entity=bundle:com.day.cq.dam.cq-dam-handler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-handler, Bundle-Version=5.10.26], digest=1515998757000) 15.01.2018 12:16:19.874 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-indesign BundleEvent INSTALLED 15.01.2018 12:16:19.874 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-indesign [287] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-indesign-5.10.32.jar, entity=bundle:com.day.cq.dam.cq-dam-indesign, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-indesign, Bundle-Version=5.10.32], digest=1515998757000) 15.01.2018 12:16:19.955 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-dam-index-builder BundleEvent INSTALLED 15.01.2018 12:16:19.955 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-dam-index-builder [288] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-index-builder-1.2.26.jar, entity=bundle:com.adobe.cq.cq-dam-index-builder, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-dam-index-builder, Bundle-Version=1.2.26], digest=1515998757000) 15.01.2018 12:16:20.064 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-dam-mac-sync BundleEvent INSTALLED 15.01.2018 12:16:20.064 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-dam-mac-sync [289] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-mac-sync-1.3.8.jar, entity=bundle:com.adobe.cq.cq-dam-mac-sync, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-dam-mac-sync, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:20.075 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-dam-mac-sync-helper BundleEvent INSTALLED 15.01.2018 12:16:20.075 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-dam-mac-sync-helper [290] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-mac-sync-helper-1.3.10.jar, entity=bundle:com.adobe.cq.cq-dam-mac-sync-helper, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-dam-mac-sync-helper, Bundle-Version=1.3.10], digest=1515998757000) 15.01.2018 12:16:20.085 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-pim BundleEvent INSTALLED 15.01.2018 12:16:20.085 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-pim [291] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-pim-0.3.22.jar, entity=bundle:com.day.cq.dam.cq-dam-pim, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-pim, Bundle-Version=0.3.22], digest=1515998757000) 15.01.2018 12:16:20.134 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-rating BundleEvent INSTALLED 15.01.2018 12:16:20.134 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-rating [292] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-rating-1.0.0.jar, entity=bundle:com.day.cq.dam.cq-dam-rating, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-rating, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:20.152 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-s7dam BundleEvent INSTALLED 15.01.2018 12:16:20.152 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-s7dam [293] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-s7dam-5.10.102.jar, entity=bundle:com.day.cq.dam.cq-dam-s7dam, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-s7dam, Bundle-Version=5.10.102], digest=1515998757000) 15.01.2018 12:16:20.165 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-scene7 BundleEvent INSTALLED 15.01.2018 12:16:20.166 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-scene7 [294] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-scene7-5.10.86.jar, entity=bundle:com.day.cq.dam.cq-dam-scene7, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-scene7, Bundle-Version=5.10.86], digest=1515998757000) 15.01.2018 12:16:20.177 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-similaritysearch BundleEvent INSTALLED 15.01.2018 12:16:20.177 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-similaritysearch [295] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-similaritysearch-5.10.84.jar, entity=bundle:com.day.cq.dam.cq-dam-similaritysearch, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-similaritysearch, Bundle-Version=5.10.84], digest=1515998757000) 15.01.2018 12:16:20.198 *INFO* [OsgiInstallerImpl] com.adobe.cq.dam.cq-dam-svg-handler BundleEvent INSTALLED 15.01.2018 12:16:20.198 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.dam.cq-dam-svg-handler [296] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-svg-handler-0.2.6.jar, entity=bundle:com.adobe.cq.dam.cq-dam-svg-handler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.dam.cq-dam-svg-handler, Bundle-Version=0.2.6], digest=1515998757000) 15.01.2018 12:16:20.210 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-video BundleEvent INSTALLED 15.01.2018 12:16:20.210 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-video [297] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-video-5.10.14.jar, entity=bundle:com.day.cq.dam.cq-dam-video, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-video, Bundle-Version=5.10.14], digest=1515998757000) 15.01.2018 12:16:20.279 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-dam-word BundleEvent INSTALLED 15.01.2018 12:16:20.279 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-dam-word [298] from resource TaskResource(url=launchpad:resources/install/0/cq-dam-word-5.10.2.jar, entity=bundle:com.day.cq.dam.cq-dam-word, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-dam-word, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:20.346 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-dashboards BundleEvent INSTALLED 15.01.2018 12:16:20.346 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-dashboards [299] from resource TaskResource(url=launchpad:resources/install/0/cq-dashboards-5.9.2.jar, entity=bundle:com.adobe.cq.cq-dashboards, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-dashboards, Bundle-Version=5.9.2], digest=1515998757000) 15.01.2018 12:16:20.435 *INFO* [OsgiInstallerImpl] com.adobe.cq.dam.cq-delivery-api BundleEvent INSTALLED 15.01.2018 12:16:20.435 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.dam.cq-delivery-api [300] from resource TaskResource(url=launchpad:resources/install/0/cq-delivery-api-1.1.6.jar, entity=bundle:com.adobe.cq.dam.cq-delivery-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.dam.cq-delivery-api, Bundle-Version=1.1.6], digest=1515998757000) 15.01.2018 12:16:20.479 *INFO* [OsgiInstallerImpl] com.adobe.cq.dam.cq-delivery-internal-api BundleEvent INSTALLED 15.01.2018 12:16:20.479 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.dam.cq-delivery-internal-api [301] from resource TaskResource(url=launchpad:resources/install/0/cq-delivery-internal-api-1.1.2.jar, entity=bundle:com.adobe.cq.dam.cq-delivery-internal-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.dam.cq-delivery-internal-api, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:20.490 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-dtm BundleEvent INSTALLED 15.01.2018 12:16:20.490 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-dtm [302] from resource TaskResource(url=launchpad:resources/install/0/cq-dtm-0.3.10.jar, entity=bundle:com.adobe.cq.cq-dtm, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-dtm, Bundle-Version=0.3.10], digest=1515998757000) 15.01.2018 12:16:20.502 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-experience-fragments BundleEvent INSTALLED 15.01.2018 12:16:20.502 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-experience-fragments [303] from resource TaskResource(url=launchpad:resources/install/0/cq-experience-fragments-1.0.128.jar, entity=bundle:com.adobe.cq.cq-experience-fragments, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-experience-fragments, Bundle-Version=1.0.128], digest=1515998757000) 15.01.2018 12:16:20.584 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-experience-fragments-social BundleEvent INSTALLED 15.01.2018 12:16:20.584 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-experience-fragments-social [304] from resource TaskResource(url=launchpad:resources/install/0/cq-experience-fragments-social-1.0.30.jar, entity=bundle:com.adobe.cq.cq-experience-fragments-social, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-experience-fragments-social, Bundle-Version=1.0.30], digest=1515998757000) 15.01.2018 12:16:20.639 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-experiencelog BundleEvent INSTALLED 15.01.2018 12:16:20.639 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-experiencelog [305] from resource TaskResource(url=launchpad:resources/install/0/cq-experiencelog-1.2.8.jar, entity=bundle:com.adobe.cq.cq-experiencelog, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-experiencelog, Bundle-Version=1.2.8], digest=1515998757000) 15.01.2018 12:16:20.708 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-gfx BundleEvent INSTALLED 15.01.2018 12:16:20.708 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-gfx [306] from resource TaskResource(url=launchpad:resources/install/0/cq-gfx-1.0.0.jar, entity=bundle:com.adobe.cq.cq-gfx, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-gfx, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:20.757 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-healthcheck BundleEvent INSTALLED 15.01.2018 12:16:20.757 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-healthcheck [307] from resource TaskResource(url=launchpad:resources/install/0/cq-healthcheck-1.3.4.jar, entity=bundle:com.adobe.cq.cq-healthcheck, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-healthcheck, Bundle-Version=1.3.4], digest=1515998757000) 15.01.2018 12:16:20.873 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-history BundleEvent INSTALLED 15.01.2018 12:16:20.873 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-history [308] from resource TaskResource(url=launchpad:resources/install/0/cq-history-5.10.6.jar, entity=bundle:com.adobe.cq.cq-history, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-history, Bundle-Version=5.10.6], digest=1515998757000) 15.01.2018 12:16:20.885 *INFO* [OsgiInstallerImpl] com.adobe.cq.inbox.cq-inbox BundleEvent INSTALLED 15.01.2018 12:16:20.885 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.inbox.cq-inbox [309] from resource TaskResource(url=launchpad:resources/install/0/cq-inbox-1.0.60.jar, entity=bundle:com.adobe.cq.inbox.cq-inbox, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.inbox.cq-inbox, Bundle-Version=1.0.60], digest=1515998757000) 15.01.2018 12:16:20.950 *INFO* [OsgiInstallerImpl] com.adobe.cq.inbox.cq-inbox-ui BundleEvent INSTALLED 15.01.2018 12:16:20.950 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.inbox.cq-inbox-ui [310] from resource TaskResource(url=launchpad:resources/install/0/cq-inbox-ui-1.0.10.jar, entity=bundle:com.adobe.cq.inbox.cq-inbox-ui, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.inbox.cq-inbox-ui, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:21.023 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-launches-api BundleEvent INSTALLED 15.01.2018 12:16:21.023 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-launches-api [311] from resource TaskResource(url=launchpad:resources/install/0/cq-launches-api-5.9.10.jar, entity=bundle:com.adobe.cq.cq-launches-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-launches-api, Bundle-Version=5.9.10], digest=1515998757000) 15.01.2018 12:16:21.035 *INFO* [OsgiInstallerImpl] com.day.cq.cq-mailer BundleEvent INSTALLED 15.01.2018 12:16:21.035 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-mailer [312] from resource TaskResource(url=launchpad:resources/install/0/cq-mailer-5.11.2.jar, entity=bundle:com.day.cq.cq-mailer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-mailer, Bundle-Version=5.11.2], digest=1515998757000) 15.01.2018 12:16:21.049 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-campaign BundleEvent INSTALLED 15.01.2018 12:16:21.049 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-campaign [313] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-campaign-1.2.10.jar, entity=bundle:com.day.cq.mcm.cq-mcm-campaign, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-campaign, Bundle-Version=1.2.10], digest=1515998757000) 15.01.2018 12:16:21.061 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-core BundleEvent INSTALLED 15.01.2018 12:16:21.061 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-core [314] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-core-5.11.10.jar, entity=bundle:com.day.cq.mcm.cq-mcm-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-core, Bundle-Version=5.11.10], digest=1515998757000) 15.01.2018 12:16:21.220 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-emailprovider BundleEvent INSTALLED 15.01.2018 12:16:21.220 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-emailprovider [315] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-emailprovider-1.4.4.jar, entity=bundle:com.day.cq.mcm.cq-mcm-emailprovider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-emailprovider, Bundle-Version=1.4.4], digest=1515998757000) 15.01.2018 12:16:21.240 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-exacttarget-integration BundleEvent INSTALLED 15.01.2018 12:16:21.240 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-exacttarget-integration [316] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-exacttarget-integration-1.4.6.jar, entity=bundle:com.day.cq.mcm.cq-mcm-exacttarget-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-exacttarget-integration, Bundle-Version=1.4.6], digest=1515998757000) 15.01.2018 12:16:21.251 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-landingpage BundleEvent INSTALLED 15.01.2018 12:16:21.251 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-landingpage [317] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-landingpage-1.4.4.jar, entity=bundle:com.day.cq.mcm.cq-mcm-landingpage, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-landingpage, Bundle-Version=1.4.4], digest=1515998757000) 15.01.2018 12:16:21.361 *INFO* [OsgiInstallerImpl] com.day.cq.mcm.cq-mcm-salesforce BundleEvent INSTALLED 15.01.2018 12:16:21.361 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.mcm.cq-mcm-salesforce [318] from resource TaskResource(url=launchpad:resources/install/0/cq-mcm-salesforce-1.2.8.jar, entity=bundle:com.day.cq.mcm.cq-mcm-salesforce, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.mcm.cq-mcm-salesforce, Bundle-Version=1.2.8], digest=1515998757000) 15.01.2018 12:16:21.372 *INFO* [OsgiInstallerImpl] com.adobe.cq.media.cq-media-articles BundleEvent INSTALLED 15.01.2018 12:16:21.372 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.media.cq-media-articles [319] from resource TaskResource(url=launchpad:resources/install/0/cq-media-articles-5.9.6.jar, entity=bundle:com.adobe.cq.media.cq-media-articles, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.media.cq-media-articles, Bundle-Version=5.9.6], digest=1515998757000) 15.01.2018 12:16:21.456 *INFO* [OsgiInstallerImpl] com.adobe.cq.media.cq-media-publishing-dps-fp-api BundleEvent INSTALLED 15.01.2018 12:16:21.456 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.media.cq-media-publishing-dps-fp-api [320] from resource TaskResource(url=launchpad:resources/install/0/cq-media-publishing-dps-fp-api-5.10.6.jar, entity=bundle:com.adobe.cq.media.cq-media-publishing-dps-fp-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.media.cq-media-publishing-dps-fp-api, Bundle-Version=5.10.6], digest=1515998757000) 15.01.2018 12:16:21.467 *INFO* [OsgiInstallerImpl] com.adobe.cq.media.cq-media-publishing-dps-fp-core BundleEvent INSTALLED 15.01.2018 12:16:21.467 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.media.cq-media-publishing-dps-fp-core [321] from resource TaskResource(url=launchpad:resources/install/0/cq-media-publishing-dps-fp-core-5.10.6.jar , entity=bundle:com.adobe.cq.media.cq-media-publishing-dps-fp-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.media.cq-media-publishing-dps-fp-core, Bundle-Version=5.10.6], digest=1515998757000) 15.01.2018 12:16:21.480 *INFO* [OsgiInstallerImpl] com.adobe.cq.media.cq-media-publishing-dps-integration BundleEvent INSTALLED 15.01.2018 12:16:21.480 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.media.cq-media-publishing-dps-integration [322] from resource TaskResource(url=launchpad:resources/install/0/cq-media-publishing-dps-integration-5.10.1 8.jar, entity=bundle:com.adobe.cq.media.cq-media-publishing-dps-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.media.cq-media-publishing-dps-integration, Bundle-Version=5.10.18], digest=1515998757000) 15.01.2018 12:16:21.491 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-caas BundleEvent INSTALLED 15.01.2018 12:16:21.491 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-caas [323] from resource TaskResource(url=launchpad:resources/install/0/cq-mobile-caas-1.0.44.jar, entity=bundle:com.adobe.cq.mobile.cq-mobile-caas, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-caas, Bundle-Version=1.0.44], digest=1515998757000) 15.01.2018 12:16:21.505 *INFO* [OsgiInstallerImpl] com.adobe.cq.mobile.cq-mobile-core BundleEvent INSTALLED 15.01.2018 12:16:21.505 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.mobile.cq-mobile-core [324] from resource TaskResource(url=launchpad:resources/install/0/cq-mobile-core-6.3.110.jar, entity=bundle:com.adobe.cq.mobile.cq-mobile-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.mobile.cq-mobile-core, Bundle-Version=6.3.110], digest=1515998757000) 15.01.2018 12:16:21.603 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-msm-api BundleEvent INSTALLED 15.01.2018 12:16:21.603 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-msm-api [325] from resource TaskResource(url=launchpad:resources/install/0/cq-msm-api-5.9.2.jar, entity=bundle:com.day.cq.wcm.cq-msm-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-msm-api, Bundle-Version=5.9.2], digest=1515998757000) 15.01.2018 12:16:21.674 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-msm-commons BundleEvent INSTALLED 15.01.2018 12:16:21.675 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-msm-commons [326] from resource TaskResource(url=launchpad:resources/install/0/cq-msm-commons-1.1.2.jar, entity=bundle:com.day.cq.wcm.cq-msm-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-msm-commons, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:21.689 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-msm-core BundleEvent INSTALLED 15.01.2018 12:16:21.689 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-msm-core [327] from resource TaskResource(url=launchpad:resources/install/0/cq-msm-core-5.10.50.jar, entity=bundle:com.day.cq.wcm.cq-msm-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-msm-core, Bundle-Version=5.10.50], digest=1515998757000) 15.01.2018 12:16:21.735 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-multisite-targeting BundleEvent INSTALLED 15.01.2018 12:16:21.735 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-multisite-targeting [328] from resource TaskResource(url=launchpad:resources/install/0/cq-multisite-targeting-1.0.6.jar, entity=bundle:com.adobe.cq.cq-multisite-targeting, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-multisite-targeting, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:21.807 *INFO* [OsgiInstallerImpl] com.day.cq.cq-notifcation-api BundleEvent INSTALLED 15.01.2018 12:16:21.807 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-notifcation-api [329] from resource TaskResource(url=launchpad:resources/install/0/cq-notifcation-api-5.8.2.jar, entity=bundle:com.day.cq.cq-notifcation-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-notifcation-api, Bundle-Version=5.8.2], digest=1515998757000) 15.01.2018 12:16:21.887 *INFO* [OsgiInstallerImpl] com.day.cq.cq-notifcation-impl BundleEvent INSTALLED 15.01.2018 12:16:21.887 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-notifcation-impl [330] from resource TaskResource(url=launchpad:resources/install/0/cq-notifcation-impl-5.9.2.jar, entity=bundle:com.day.cq.cq-notifcation-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-notifcation-impl, Bundle-Version=5.9.2], digest=1515998757000) 15.01.2018 12:16:21.901 *INFO* [OsgiInstallerImpl] com.day.cq.cq-personalization BundleEvent INSTALLED 15.01.2018 12:16:21.901 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-personalization [331] from resource TaskResource(url=launchpad:resources/install/0/cq-personalization-5.10.60.jar, entity=bundle:com.day.cq.cq-personalization, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-personalization, Bundle-Version=5.10.60], digest=1515998757000) 15.01.2018 12:16:22.025 *INFO* [OsgiInstallerImpl] com.day.cq.cq-polling-importer BundleEvent INSTALLED 15.01.2018 12:16:22.025 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-polling-importer [332] from resource TaskResource(url=launchpad:resources/install/0/cq-polling-importer-5.10.8.jar, entity=bundle:com.day.cq.cq-polling-importer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-polling-importer, Bundle-Version=5.10.8], digest=1515998757000) 15.01.2018 12:16:22.074 *INFO* [OsgiInstallerImpl] com.day.cq.cq-replication-audit BundleEvent INSTALLED 15.01.2018 12:16:22.074 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-replication-audit [333] from resource TaskResource(url=launchpad:resources/install/0/cq-replication-audit-5.10.6.jar, entity=bundle:com.day.cq.cq-replication-audit, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-replication-audit, Bundle-Version=5.10.6], digest=1515998757000) 15.01.2018 12:16:22.086 *INFO* [OsgiInstallerImpl] com.day.cq.cq-reporting BundleEvent INSTALLED 15.01.2018 12:16:22.086 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-reporting [334] from resource TaskResource(url=launchpad:resources/install/0/cq-reporting-5.10.2.jar, entity=bundle:com.day.cq.cq-reporting, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-reporting, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:22.186 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-rest-sites BundleEvent INSTALLED 15.01.2018 12:16:22.186 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-rest-sites [335] from resource TaskResource(url=launchpad:resources/install/0/cq-rest-sites-1.2.2.jar, entity=bundle:com.adobe.cq.cq-rest-sites, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-rest-sites, Bundle-Version=1.2.2], digest=1515998757000) 15.01.2018 12:16:22.259 *INFO* [OsgiInstallerImpl] com.day.cq.cq-retriever BundleEvent INSTALLED 15.01.2018 12:16:22.259 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-retriever [336] from resource TaskResource(url=launchpad:resources/install/0/cq-retriever-5.8.2.jar, entity=bundle:com.day.cq.cq-retriever, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-retriever, Bundle-Version=5.8.2], digest=1515998757000) 15.01.2018 12:16:22.271 *INFO* [OsgiInstallerImpl] com.day.cq.cq-rewriter BundleEvent INSTALLED 15.01.2018 12:16:22.271 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-rewriter [337] from resource TaskResource(url=launchpad:resources/install/0/cq-rewriter-5.10.30.jar, entity=bundle:com.day.cq.cq-rewriter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-rewriter, Bundle-Version=5.10.30], digest=1515998757000) 15.01.2018 12:16:22.285 *INFO* [OsgiInstallerImpl] com.day.cq.dam.cq-scene7-api BundleEvent INSTALLED 15.01.2018 12:16:22.285 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.cq-scene7-api [338] from resource TaskResource(url=launchpad:resources/install/0/cq-scene7-api-1.0.6.jar, entity=bundle:com.day.cq.dam.cq-scene7-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.cq-scene7-api, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:22.475 *INFO* [OsgiInstallerImpl] com.adobe.cq.dam.cq-scene7-imaging BundleEvent INSTALLED 15.01.2018 12:16:22.475 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.dam.cq-scene7-imaging [339] from resource TaskResource(url=launchpad:resources/install/0/cq-scene7-imaging-1.3.56.jar, entity=bundle:com.adobe.cq.dam.cq-scene7-imaging, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.dam.cq-scene7-imaging, Bundle-Version=1.3.56], digest=1515998757000) 15.01.2018 12:16:22.574 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-scheduled-exporter BundleEvent INSTALLED 15.01.2018 12:16:22.574 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-scheduled-exporter [340] from resource TaskResource(url=launchpad:resources/install/0/cq-scheduled-exporter-5.10.2.jar, entity=bundle:com.adobe.cq.cq-scheduled-exporter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-scheduled-exporter, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:22.585 *INFO* [OsgiInstallerImpl] com.day.cq.cq-search BundleEvent INSTALLED 15.01.2018 12:16:22.586 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-search [341] from resource TaskResource(url=launchpad:resources/install/0/cq-search-5.10.14.jar, entity=bundle:com.day.cq.cq-search, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-search, Bundle-Version=5.10.14], digest=1515998757000) 15.01.2018 12:16:22.651 *INFO* [OsgiInstallerImpl] com.day.cq.cq-search-ext BundleEvent INSTALLED 15.01.2018 12:16:22.651 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-search-ext [342] from resource TaskResource(url=launchpad:resources/install/0/cq-search-ext-1.0.6.jar, entity=bundle:com.day.cq.cq-search-ext, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-search-ext, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:22.772 *INFO* [OsgiInstallerImpl] com.day.cq.cq-search-suggest BundleEvent INSTALLED 15.01.2018 12:16:22.772 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-search-suggest [343] from resource TaskResource(url=launchpad:resources/install/0/cq-search-suggest-5.10.2.jar, entity=bundle:com.day.cq.cq-search-suggest, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-search-suggest, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:22.783 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-searchpromote-integration BundleEvent INSTALLED 15.01.2018 12:16:22.783 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-searchpromote-integration [344] from resource TaskResource(url=launchpad:resources/install/0/cq-searchpromote-integration-5.10.4.jar, entity=bundle:com.adobe.cq.cq-searchpromote-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-searchpromote-integration, Bundle-Version=5.10.4], digest=1515998757000) 15.01.2018 12:16:22.795 *INFO* [OsgiInstallerImpl] com.day.cq.cq-security BundleEvent INSTALLED 15.01.2018 12:16:22.795 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-security [345] from resource TaskResource(url=launchpad:resources/install/0/cq-security-5.10.16.jar, entity=bundle:com.day.cq.cq-security, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-security, Bundle-Version=5.10.16], digest=1515998757000) 15.01.2018 12:16:22.901 *INFO* [OsgiInstallerImpl] com.day.cq.cq-security-api BundleEvent INSTALLED 15.01.2018 12:16:22.902 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-security-api [346] from resource TaskResource(url=launchpad:resources/install/0/cq-security-api-5.9.4.jar, entity=bundle:com.day.cq.cq-security-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-security-api, Bundle-Version=5.9.4], digest=1515998757000) 15.01.2018 12:16:23.002 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-security-hc BundleEvent INSTALLED 15.01.2018 12:16:23.002 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-security-hc [347] from resource TaskResource(url=launchpad:resources/install/0/cq-security-hc-1.3.8.jar, entity=bundle:com.adobe.cq.cq-security-hc, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-security-hc, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:23.014 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-activitystreams BundleEvent INSTALLED 15.01.2018 12:16:23.014 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-activitystreams [348] from resource TaskResource(url=launchpad:resources/install/0/cq-social-activitystreams-1.4.16.jar, entity=bundle:com.adobe.cq.social.cq-social-activitystreams, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-activitystreams, Bundle-Version=1.4.16], digest=1515998757000) 15.01.2018 12:16:23.024 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-as-provider BundleEvent INSTALLED 15.01.2018 12:16:23.024 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-as-provider [349] from resource TaskResource(url=launchpad:resources/install/0/cq-social-as-provider-1.3.14.jar, entity=bundle:com.adobe.cq.social.cq-social-as-provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-as-provider, Bundle-Version=1.3.14], digest=1515998757000) 15.01.2018 12:16:23.063 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-badging-api BundleEvent INSTALLED 15.01.2018 12:16:23.063 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-badging-api [350] from resource TaskResource(url=launchpad:resources/install/0/cq-social-badging-api-1.1.7.jar, entity=bundle:com.adobe.cq.social.cq-social-badging-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-badging-api, Bundle-Version=1.1.7], digest=1515998757000) 15.01.2018 12:16:23.104 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-badging-basic-impl BundleEvent INSTALLED 15.01.2018 12:16:23.104 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-badging-basic-impl [351] from resource TaskResource(url=launchpad:resources/install/0/cq-social-badging-basic-impl-1.1.2.jar, entity=bundle:com.adobe.cq.social.cq-social-badging-basic-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-badging-basic-impl, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:23.172 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-badging-impl BundleEvent INSTALLED 15.01.2018 12:16:23.172 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-badging-impl [352] from resource TaskResource(url=launchpad:resources/install/0/cq-social-badging-impl-1.1.16.jar, entity=bundle:com.adobe.cq.social.cq-social-badging-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-badging-impl, Bundle-Version=1.1.16], digest=1515998757000) 15.01.2018 12:16:23.248 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-calendar-api BundleEvent INSTALLED 15.01.2018 12:16:23.248 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-calendar-api [353] from resource TaskResource(url=launchpad:resources/install/0/cq-social-calendar-api-1.4.8.jar, entity=bundle:com.adobe.cq.social.cq-social-calendar-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-calendar-api, Bundle-Version=1.4.8], digest=1515998757000) 15.01.2018 12:16:23.262 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-calendar-impl BundleEvent INSTALLED 15.01.2018 12:16:23.262 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-calendar-impl [354] from resource TaskResource(url=launchpad:resources/install/0/cq-social-calendar-impl-1.4.11.jar, entity=bundle:com.adobe.cq.social.cq-social-calendar-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-calendar-impl, Bundle-Version=1.4.11], digest=1515998757000) 15.01.2018 12:16:23.276 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-commons BundleEvent INSTALLED 15.01.2018 12:16:23.276 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-commons [355] from resource TaskResource(url=launchpad:resources/install/0/cq-social-commons-1.7.87.jar, entity=bundle:com.adobe.cq.social.cq-social-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-commons, Bundle-Version=1.7.87], digest=1515998757000) 15.01.2018 12:16:23.362 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-commons-oauth BundleEvent INSTALLED 15.01.2018 12:16:23.362 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-commons-oauth [356] from resource TaskResource(url=launchpad:resources/install/0/cq-social-commons-oauth-1.5.12.jar, entity=bundle:com.adobe.cq.social.cq-social-commons-oauth, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-commons-oauth, Bundle-Version=1.5.12], digest=1515998757000) 15.01.2018 12:16:23.404 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-console BundleEvent INSTALLED 15.01.2018 12:16:23.404 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-console [357] from resource TaskResource(url=launchpad:resources/install/0/cq-social-console-1.2.85.jar, entity=bundle:com.adobe.cq.social.cq-social-console, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-console, Bundle-Version=1.2.85], digest=1515998757000) 15.01.2018 12:16:23.494 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-content-fragments-impl BundleEvent INSTALLED 15.01.2018 12:16:23.494 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-content-fragments-impl [358] from resource TaskResource(url=launchpad:resources/install/0/cq-social-content-fragments-impl-1.0.3.jar , entity=bundle:com.adobe.cq.social.cq-social-content-fragments-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-content-fragments-impl, Bundle-Version=1.0.3], digest=1515998757000) 15.01.2018 12:16:23.505 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-enablement-api BundleEvent INSTALLED 15.01.2018 12:16:23.505 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-enablement-api [359] from resource TaskResource(url=launchpad:resources/install/0/cq-social-enablement-api-2.0.32.jar, entity=bundle:com.adobe.cq.social.cq-social-enablement-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-enablement-api, Bundle-Version=2.0.32], digest=1515998757000) 15.01.2018 12:16:23.519 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-enablement-impl BundleEvent INSTALLED 15.01.2018 12:16:23.519 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-enablement-impl [360] from resource TaskResource(url=launchpad:resources/install/0/cq-social-enablement-impl-2.0.34.jar, entity=bundle:com.adobe.cq.social.cq-social-enablement-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-enablement-impl, Bundle-Version=2.0.34], digest=1515998757000) 15.01.2018 12:16:23.530 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-filelibrary BundleEvent INSTALLED 15.01.2018 12:16:23.530 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-filelibrary [361] from resource TaskResource(url=launchpad:resources/install/0/cq-social-filelibrary-1.2.12.jar, entity=bundle:com.adobe.cq.social.cq-social-filelibrary, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-filelibrary, Bundle-Version=1.2.12], digest=1515998757000) 15.01.2018 12:16:23.540 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-forum BundleEvent INSTALLED 15.01.2018 12:16:23.540 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-forum [362] from resource TaskResource(url=launchpad:resources/install/0/cq-social-forum-1.6.14.jar, entity=bundle:com.adobe.cq.social.cq-social-forum, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-forum, Bundle-Version=1.6.14], digest=1515998757000) 15.01.2018 12:16:23.602 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-gamification-api BundleEvent INSTALLED 15.01.2018 12:16:23.602 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-gamification-api [363] from resource TaskResource(url=launchpad:resources/install/0/cq-social-gamification-api-1.0.12.jar, entity=bundle:com.adobe.cq.social.cq-social-gamification-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-gamification-api, Bundle-Version=1.0.12], digest=1515998757000) 15.01.2018 12:16:23.709 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-gamification-impl BundleEvent INSTALLED 15.01.2018 12:16:23.709 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-gamification-impl [364] from resource TaskResource(url=launchpad:resources/install/0/cq-social-gamification-impl-1.0.17.jar, entity=bundle:com.adobe.cq.social.cq-social-gamification-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-gamification-impl, Bundle-Version=1.0.17], digest=1515998757000) 15.01.2018 12:16:23.783 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-graph-api BundleEvent INSTALLED 15.01.2018 12:16:23.783 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-graph-api [365] from resource TaskResource(url=launchpad:resources/install/0/cq-social-graph-api-1.2.3.jar, entity=bundle:com.adobe.cq.social.cq-social-graph-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-graph-api, Bundle-Version=1.2.3], digest=1515998757000) 15.01.2018 12:16:23.908 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-graph-impl BundleEvent INSTALLED 15.01.2018 12:16:23.908 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-graph-impl [366] from resource TaskResource(url=launchpad:resources/install/0/cq-social-graph-impl-1.2.3.jar, entity=bundle:com.adobe.cq.social.cq-social-graph-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-graph-impl, Bundle-Version=1.2.3], digest=1515998757000) 15.01.2018 12:16:23.921 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-group BundleEvent INSTALLED 15.01.2018 12:16:23.921 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-group [367] from resource TaskResource(url=launchpad:resources/install/0/cq-social-group-1.4.36.jar, entity=bundle:com.adobe.cq.social.cq-social-group, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-group, Bundle-Version=1.4.36], digest=1515998757000) 15.01.2018 12:16:23.941 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-handlebars BundleEvent INSTALLED 15.01.2018 12:16:23.941 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-handlebars [368] from resource TaskResource(url=launchpad:resources/install/0/cq-social-handlebars-1.7.13.jar, entity=bundle:com.adobe.cq.social.cq-social-handlebars, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-handlebars, Bundle-Version=1.7.13], digest=1515998757000) 15.01.2018 12:16:23.955 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ideation-api BundleEvent INSTALLED 15.01.2018 12:16:23.955 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ideation-api [369] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ideation-api-1.0.6.jar, entity=bundle:com.adobe.cq.social.cq-social-ideation-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ideation-api, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:23.969 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ideation-impl BundleEvent INSTALLED 15.01.2018 12:16:23.969 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ideation-impl [370] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ideation-impl-1.0.10.jar, entity=bundle:com.adobe.cq.social.cq-social-ideation-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ideation-impl, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:24.033 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-jcr-provider BundleEvent INSTALLED 15.01.2018 12:16:24.033 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-jcr-provider [371] from resource TaskResource(url=launchpad:resources/install/0/cq-social-jcr-provider-1.2.13.jar, entity=bundle:com.adobe.cq.social.cq-social-jcr-provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-jcr-provider, Bundle-Version=1.2.13], digest=1515998757000) 15.01.2018 12:16:24.044 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-jcr-provider-common BundleEvent INSTALLED 15.01.2018 12:16:24.044 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-jcr-provider-common [372] from resource TaskResource(url=launchpad:resources/install/0/cq-social-jcr-provider-common-1.2.8.jar, entity=bundle:com.adobe.cq.social.cq-social-jcr-provider-common, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-jcr-provider-common, Bundle-Version=1.2.8], digest=1515998757000) 15.01.2018 12:16:24.059 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-journal BundleEvent INSTALLED 15.01.2018 12:16:24.059 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-journal [373] from resource TaskResource(url=launchpad:resources/install/0/cq-social-journal-1.4.9.jar, entity=bundle:com.adobe.cq.social.cq-social-journal, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-journal, Bundle-Version=1.4.9], digest=1515998757000) 15.01.2018 12:16:24.095 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-livefyre BundleEvent INSTALLED 15.01.2018 12:16:24.095 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-livefyre [374] from resource TaskResource(url=launchpad:resources/install/0/cq-social-livefyre-1.1.9.jar, entity=bundle:com.adobe.cq.social.cq-social-livefyre, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-livefyre, Bundle-Version=1.1.9], digest=1515998757000) 15.01.2018 12:16:24.188 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-members-api BundleEvent INSTALLED 15.01.2018 12:16:24.188 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-members-api [375] from resource TaskResource(url=launchpad:resources/install/0/cq-social-members-api-1.1.11.jar, entity=bundle:com.adobe.cq.social.cq-social-members-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-members-api, Bundle-Version=1.1.11], digest=1515998757000) 15.01.2018 12:16:24.199 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-members-impl BundleEvent INSTALLED 15.01.2018 12:16:24.199 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-members-impl [376] from resource TaskResource(url=launchpad:resources/install/0/cq-social-members-impl-1.1.20.jar, entity=bundle:com.adobe.cq.social.cq-social-members-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-members-impl, Bundle-Version=1.1.20], digest=1515998757000) 15.01.2018 12:16:24.299 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-messaging-api BundleEvent INSTALLED 15.01.2018 12:16:24.299 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-messaging-api [377] from resource TaskResource(url=launchpad:resources/install/0/cq-social-messaging-api-1.4.12.jar, entity=bundle:com.adobe.cq.social.cq-social-messaging-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-messaging-api, Bundle-Version=1.4.12], digest=1515998757000) 15.01.2018 12:16:24.311 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-messaging-impl BundleEvent INSTALLED 15.01.2018 12:16:24.311 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-messaging-impl [378] from resource TaskResource(url=launchpad:resources/install/0/cq-social-messaging-impl-1.4.21.jar, entity=bundle:com.adobe.cq.social.cq-social-messaging-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-messaging-impl, Bundle-Version=1.4.21], digest=1515998757000) 15.01.2018 12:16:24.445 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-moderation BundleEvent INSTALLED 15.01.2018 12:16:24.445 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-moderation [379] from resource TaskResource(url=launchpad:resources/install/0/cq-social-moderation-2.2.16.jar, entity=bundle:com.adobe.cq.social.cq-social-moderation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-moderation, Bundle-Version=2.2.16], digest=1515998757000) 15.01.2018 12:16:24.524 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ms-provider BundleEvent INSTALLED 15.01.2018 12:16:24.524 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ms-provider [380] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ms-provider-1.0.18.jar, entity=bundle:com.adobe.cq.social.cq-social-ms-provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ms-provider, Bundle-Version=1.0.18], digest=1515998757000) 15.01.2018 12:16:24.535 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-notifications-api BundleEvent INSTALLED 15.01.2018 12:16:24.535 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-notifications-api [381] from resource TaskResource(url=launchpad:resources/install/0/cq-social-notifications-api-1.1.12.jar, entity=bundle:com.adobe.cq.social.cq-social-notifications-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-notifications-api, Bundle-Version=1.1.12], digest=1515998757000) 15.01.2018 12:16:24.592 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-notifications-channels-web BundleEvent INSTALLED 15.01.2018 12:16:24.592 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-notifications-channels-web [382] from resource TaskResource(url=launchpad:resources/install/0/cq-social-notifications-channels-web-1.1.1 9.jar, entity=bundle:com.adobe.cq.social.cq-social-notifications-channels-web, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-notifications-channels-web, Bundle-Version=1.1.19], digest=1515998757000) 15.01.2018 12:16:24.604 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-notifications-impl BundleEvent INSTALLED 15.01.2018 12:16:24.604 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-notifications-impl [383] from resource TaskResource(url=launchpad:resources/install/0/cq-social-notifications-impl-1.1.20.jar, entity=bundle:com.adobe.cq.social.cq-social-notifications-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-notifications-impl, Bundle-Version=1.1.20], digest=1515998757000) 15.01.2018 12:16:24.616 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-qna BundleEvent INSTALLED 15.01.2018 12:16:24.616 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-qna [384] from resource TaskResource(url=launchpad:resources/install/0/cq-social-qna-1.5.20.jar, entity=bundle:com.adobe.cq.social.cq-social-qna, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-qna, Bundle-Version=1.5.20], digest=1515998757000) 15.01.2018 12:16:24.627 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-rdb-provider BundleEvent INSTALLED 15.01.2018 12:16:24.627 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-rdb-provider [385] from resource TaskResource(url=launchpad:resources/install/0/cq-social-rdb-provider-1.1.19.jar, entity=bundle:com.adobe.cq.social.cq-social-rdb-provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-rdb-provider, Bundle-Version=1.1.19], digest=1515998757000) 15.01.2018 12:16:24.638 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-reporting-management BundleEvent INSTALLED 15.01.2018 12:16:24.638 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-reporting-management [386] from resource TaskResource(url=launchpad:resources/install/0/cq-social-reporting-management-1.1.23.jar, entity=bundle:com.adobe.cq.social.cq-social-reporting-management, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-reporting-management, Bundle-Version=1.1.23], digest=1515998757000) 15.01.2018 12:16:24.650 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-review BundleEvent INSTALLED 15.01.2018 12:16:24.650 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-review [387] from resource TaskResource(url=launchpad:resources/install/0/cq-social-review-1.4.4.jar, entity=bundle:com.adobe.cq.social.cq-social-review, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-review, Bundle-Version=1.4.4], digest=1515998757000) 15.01.2018 12:16:24.660 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-scf-api BundleEvent INSTALLED 15.01.2018 12:16:24.661 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-scf-api [388] from resource TaskResource(url=launchpad:resources/install/0/cq-social-scf-api-2.0.14.jar, entity=bundle:com.adobe.cq.social.cq-social-scf-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-scf-api, Bundle-Version=2.0.14], digest=1515998757000) 15.01.2018 12:16:24.671 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-scf-impl BundleEvent INSTALLED 15.01.2018 12:16:24.671 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-scf-impl [389] from resource TaskResource(url=launchpad:resources/install/0/cq-social-scf-impl-2.0.15.jar, entity=bundle:com.adobe.cq.social.cq-social-scf-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-scf-impl, Bundle-Version=2.0.15], digest=1515998757000) 15.01.2018 12:16:24.719 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-scoring-api BundleEvent INSTALLED 15.01.2018 12:16:24.719 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-scoring-api [390] from resource TaskResource(url=launchpad:resources/install/0/cq-social-scoring-api-2.1.9.jar, entity=bundle:com.adobe.cq.social.cq-social-scoring-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-scoring-api, Bundle-Version=2.1.9], digest=1515998757000) 15.01.2018 12:16:24.725 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-scoring-basic-impl BundleEvent INSTALLED 15.01.2018 12:16:24.725 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-scoring-basic-impl [391] from resource TaskResource(url=launchpad:resources/install/0/cq-social-scoring-basic-impl-1.1.3.jar, entity=bundle:com.adobe.cq.social.cq-social-scoring-basic-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-scoring-basic-impl, Bundle-Version=1.1.3], digest=1515998757000) 15.01.2018 12:16:24.781 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-scoring-impl BundleEvent INSTALLED 15.01.2018 12:16:24.781 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-scoring-impl [392] from resource TaskResource(url=launchpad:resources/install/0/cq-social-scoring-impl-2.1.13.jar, entity=bundle:com.adobe.cq.social.cq-social-scoring-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-scoring-impl, Bundle-Version=2.1.13], digest=1515998757000) 15.01.2018 12:16:24.816 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-serviceusers-api BundleEvent INSTALLED 15.01.2018 12:16:24.816 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-serviceusers-api [393] from resource TaskResource(url=launchpad:resources/install/0/cq-social-serviceusers-api-1.3.5.jar, entity=bundle:com.adobe.cq.social.cq-social-serviceusers-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-serviceusers-api, Bundle-Version=1.3.5], digest=1515998757000) 15.01.2018 12:16:24.865 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-serviceusers-impl BundleEvent INSTALLED 15.01.2018 12:16:24.866 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-serviceusers-impl [394] from resource TaskResource(url=launchpad:resources/install/0/cq-social-serviceusers-impl-1.3.5.jar, entity=bundle:com.adobe.cq.social.cq-social-serviceusers-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-serviceusers-impl, Bundle-Version=1.3.5], digest=1515998757000) 15.01.2018 12:16:24.877 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-srp-api BundleEvent INSTALLED 15.01.2018 12:16:24.877 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-srp-api [395] from resource TaskResource(url=launchpad:resources/install/0/cq-social-srp-api-1.2.29.jar, entity=bundle:com.adobe.cq.social.cq-social-srp-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-srp-api, Bundle-Version=1.2.29], digest=1515998757000) 15.01.2018 12:16:24.917 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-srp-impl BundleEvent INSTALLED 15.01.2018 12:16:24.917 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-srp-impl [396] from resource TaskResource(url=launchpad:resources/install/0/cq-social-srp-impl-1.2.36.jar, entity=bundle:com.adobe.cq.social.cq-social-srp-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-srp-impl, Bundle-Version=1.2.36], digest=1515998757000) 15.01.2018 12:16:24.927 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-sync BundleEvent INSTALLED 15.01.2018 12:16:24.928 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-sync [397] from resource TaskResource(url=launchpad:resources/install/0/cq-social-sync-1.1.6.jar, entity=bundle:com.adobe.cq.social.cq-social-sync, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-sync, Bundle-Version=1.1.6], digest=1515998757000) 15.01.2018 12:16:24.938 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-tally BundleEvent INSTALLED 15.01.2018 12:16:24.939 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-tally [398] from resource TaskResource(url=launchpad:resources/install/0/cq-social-tally-1.4.7.jar, entity=bundle:com.adobe.cq.social.cq-social-tally, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-tally, Bundle-Version=1.4.7], digest=1515998757000) 15.01.2018 12:16:24.950 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-translation BundleEvent INSTALLED 15.01.2018 12:16:24.950 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-translation [399] from resource TaskResource(url=launchpad:resources/install/0/cq-social-translation-1.3.8.jar, entity=bundle:com.adobe.cq.social.cq-social-translation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-translation, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:24.964 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ugc-search-collections BundleEvent INSTALLED 15.01.2018 12:16:24.965 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ugc-search-collections [400] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ugc-search-collections-2.2.22.ja r, entity=bundle:com.adobe.cq.social.cq-social-ugc-search-collections, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ugc-search-collections, Bundle-Version=2.2.22], digest=1515998757000) 15.01.2018 12:16:25.147 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ugcbase-api BundleEvent INSTALLED 15.01.2018 12:16:25.147 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ugcbase-api [401] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ugcbase-api-2.2.12.jar, entity=bundle:com.adobe.cq.social.cq-social-ugcbase-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ugcbase-api, Bundle-Version=2.2.12], digest=1515998757000) 15.01.2018 12:16:25.158 *INFO* [OsgiInstallerImpl] com.adobe.cq.social.cq-social-ugcbase-impl BundleEvent INSTALLED 15.01.2018 12:16:25.158 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.social.cq-social-ugcbase-impl [402] from resource TaskResource(url=launchpad:resources/install/0/cq-social-ugcbase-impl-2.2.21.jar, entity=bundle:com.adobe.cq.social.cq-social-ugcbase-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.social.cq-social-ugcbase-impl, Bundle-Version=2.2.21], digest=1515998757000) 15.01.2018 12:16:25.272 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-socialmedia-integration BundleEvent INSTALLED 15.01.2018 12:16:25.272 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-socialmedia-integration [403] from resource TaskResource(url=launchpad:resources/install/0/cq-socialmedia-integration-1.0.24.jar, entity=bundle:com.adobe.cq.cq-socialmedia-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-socialmedia-integration, Bundle-Version=1.0.24], digest=1515998757000) 15.01.2018 12:16:25.373 *INFO* [OsgiInstallerImpl] com.day.cq.cq-spellchecker BundleEvent INSTALLED 15.01.2018 12:16:25.373 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-spellchecker [404] from resource TaskResource(url=launchpad:resources/install/0/cq-spellchecker-5.10.2.jar, entity=bundle:com.day.cq.cq-spellchecker, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-spellchecker, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:25.383 *INFO* [OsgiInstallerImpl] com.day.cq.cq-statistics BundleEvent INSTALLED 15.01.2018 12:16:25.384 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-statistics [405] from resource TaskResource(url=launchpad:resources/install/0/cq-statistics-5.10.6.jar, entity=bundle:com.day.cq.cq-statistics, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-statistics, Bundle-Version=5.10.6], digest=1515998757000) 15.01.2018 12:16:25.394 *INFO* [OsgiInstallerImpl] com.day.cq.cq-tagging BundleEvent INSTALLED 15.01.2018 12:16:25.394 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-tagging [406] from resource TaskResource(url=launchpad:resources/install/0/cq-tagging-5.10.20.jar, entity=bundle:com.day.cq.cq-tagging, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-tagging, Bundle-Version=5.10.20], digest=1515998757000) 15.01.2018 12:16:25.411 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-target-integration BundleEvent INSTALLED 15.01.2018 12:16:25.411 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-target-integration [407] from resource TaskResource(url=launchpad:resources/install/0/cq-target-integration-1.1.46.jar, entity=bundle:com.adobe.cq.cq-target-integration, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-target-integration, Bundle-Version=1.1.46], digest=1515998757000) 15.01.2018 12:16:25.421 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-targetrecommendations BundleEvent INSTALLED 15.01.2018 12:16:25.422 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.cq-targetrecommendations [408] from resource TaskResource(url=launchpad:resources/install/0/cq-targetrecommendations-1.1.22.jar, entity=bundle:com.adobe.cq.cq-targetrecommendations, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.cq-targetrecommendations, Bundle-Version=1.1.22], digest=1515998757000) 15.01.2018 12:16:25.432 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-api BundleEvent INSTALLED 15.01.2018 12:16:25.432 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-api [409] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-api-5.11.26.jar, entity=bundle:com.day.cq.wcm.cq-wcm-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-api, Bundle-Version=5.11.26], digest=1515998757000) 15.01.2018 12:16:25.546 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-commons BundleEvent INSTALLED 15.01.2018 12:16:25.546 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-commons [410] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-commons-5.10.12.jar, entity=bundle:com.day.cq.wcm.cq-wcm-commons, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-commons, Bundle-Version=5.10.12], digest=1515998757000) 15.01.2018 12:16:25.648 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-content-sync BundleEvent INSTALLED 15.01.2018 12:16:25.648 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-content-sync [411] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-content-sync-5.10.4.jar, entity=bundle:com.day.cq.wcm.cq-wcm-content-sync, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-content-sync, Bundle-Version=5.10.4], digest=1515998757000) 15.01.2018 12:16:25.665 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-core BundleEvent INSTALLED 15.01.2018 12:16:25.665 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-core [412] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-core-5.10.248.jar, entity=bundle:com.day.cq.wcm.cq-wcm-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-core, Bundle-Version=5.10.248], digest=1515998757000) 15.01.2018 12:16:25.676 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-designimporter BundleEvent INSTALLED 15.01.2018 12:16:25.677 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-designimporter [413] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-designimporter-1.4.8.jar, entity=bundle:com.day.cq.wcm.cq-wcm-designimporter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-designimporter, Bundle-Version=1.4.8], digest=1515998757000) 15.01.2018 12:16:25.750 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-emulator BundleEvent INSTALLED 15.01.2018 12:16:25.750 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-emulator [414] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-emulator-5.8.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-emulator, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-emulator, Bundle-Version=5.8.2], digest=1515998757000) 15.01.2018 12:16:25.763 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-foundation BundleEvent INSTALLED 15.01.2018 12:16:25.763 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-foundation [415] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-foundation-5.10.78.jar, entity=bundle:com.day.cq.wcm.cq-wcm-foundation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-foundation, Bundle-Version=5.10.78], digest=1515998757000) 15.01.2018 12:16:25.775 *INFO* [OsgiInstallerImpl] com.adobe.cq.wcm.cq-wcm-launches-core BundleEvent INSTALLED 15.01.2018 12:16:25.776 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.wcm.cq-wcm-launches-core [416] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-launches-core-5.11.10.jar, entity=bundle:com.adobe.cq.wcm.cq-wcm-launches-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.wcm.cq-wcm-launches-core, Bundle-Version=5.11.10], digest=1515998757000) 15.01.2018 12:16:25.882 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-mobile-api BundleEvent INSTALLED 15.01.2018 12:16:25.882 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-mobile-api [417] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-mobile-api-5.7.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-mobile-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-mobile-api, Bundle-Version=5.7.2], digest=1515998757000) 15.01.2018 12:16:25.894 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-mobile-core BundleEvent INSTALLED 15.01.2018 12:16:25.894 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-mobile-core [418] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-mobile-core-5.10.10.jar, entity=bundle:com.day.cq.wcm.cq-wcm-mobile-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-mobile-core, Bundle-Version=5.10.10], digest=1515998757000) 15.01.2018 12:16:25.904 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-mobile-qrcode BundleEvent INSTALLED 15.01.2018 12:16:25.904 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-mobile-qrcode [419] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-mobile-qrcode-5.9.6.jar, entity=bundle:com.day.cq.wcm.cq-wcm-mobile-qrcode, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-mobile-qrcode, Bundle-Version=5.9.6], digest=1515998757000) 15.01.2018 12:16:25.915 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-notification BundleEvent INSTALLED 15.01.2018 12:16:25.915 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-notification [420] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-notification-5.10.10.jar, entity=bundle:com.day.cq.wcm.cq-wcm-notification, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-notification, Bundle-Version=5.10.10], digest=1515998757000) 15.01.2018 12:16:25.929 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-offline BundleEvent INSTALLED 15.01.2018 12:16:25.929 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-offline [421] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-offline-5.10.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-offline, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-offline, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:25.970 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-resource-details BundleEvent INSTALLED 15.01.2018 12:16:25.970 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-resource-details [422] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-resource-details-0.2.10.jar, entity=bundle:com.day.cq.wcm.cq-wcm-resource-details, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-resource-details, Bundle-Version=0.2.10], digest=1515998757000) 15.01.2018 12:16:26.025 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-scripting-support BundleEvent INSTALLED 15.01.2018 12:16:26.025 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-scripting-support [423] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-scripting-support-1.0.8.jar, entity=bundle:com.day.cq.wcm.cq-wcm-scripting-support, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-scripting-support, Bundle-Version=1.0.8], digest=1515998757000) 15.01.2018 12:16:26.122 *INFO* [OsgiInstallerImpl] com.adobe.cq.sightly.cq-wcm-sightly-extension BundleEvent INSTALLED 15.01.2018 12:16:26.122 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.sightly.cq-wcm-sightly-extension [424] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-sightly-extension-1.4.28.jar, entity=bundle:com.adobe.cq.sightly.cq-wcm-sightly-extension, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.sightly.cq-wcm-sightly-extension, Bundle-Version=1.4.28], digest=1515998757000) 15.01.2018 12:16:26.199 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-taglib BundleEvent INSTALLED 15.01.2018 12:16:26.200 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-taglib [425] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-taglib-5.12.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-taglib, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-taglib, Bundle-Version=5.12.2], digest=1515998757000) 15.01.2018 12:16:26.213 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-translation BundleEvent INSTALLED 15.01.2018 12:16:26.214 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-translation [426] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-translation-1.3.114.jar, entity=bundle:com.day.cq.wcm.cq-wcm-translation, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-translation, Bundle-Version=1.3.114], digest=1515998757000) 15.01.2018 12:16:26.289 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-undo BundleEvent INSTALLED 15.01.2018 12:16:26.289 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-undo [427] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-undo-5.10.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-undo, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-undo, Bundle-Version=5.10.2], digest=1515998757000) 15.01.2018 12:16:26.299 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-webservice-support BundleEvent INSTALLED 15.01.2018 12:16:26.300 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-webservice-support [428] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-webservice-support-5.10.12.jar, entity=bundle:com.day.cq.wcm.cq-wcm-webservice-support, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-webservice-support, Bundle-Version=5.10.12], digest=1515998757000) 15.01.2018 12:16:26.310 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-workflow BundleEvent INSTALLED 15.01.2018 12:16:26.310 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-workflow [429] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-workflow-5.10.22.jar, entity=bundle:com.day.cq.wcm.cq-wcm-workflow, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-workflow, Bundle-Version=5.10.22], digest=1515998757000) 15.01.2018 12:16:26.350 *INFO* [OsgiInstallerImpl] com.day.cq.wcm.cq-wcm-workflow-api BundleEvent INSTALLED 15.01.2018 12:16:26.350 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.wcm.cq-wcm-workflow-api [430] from resource TaskResource(url=launchpad:resources/install/0/cq-wcm-workflow-api-5.9.2.jar, entity=bundle:com.day.cq.wcm.cq-wcm-workflow-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.wcm.cq-wcm-workflow-api, Bundle-Version=5.9.2], digest=1515998757000) 15.01.2018 12:16:26.464 *INFO* [OsgiInstallerImpl] com.day.cq.cq-widgets-ext BundleEvent INSTALLED 15.01.2018 12:16:26.464 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.cq-widgets-ext [431] from resource TaskResource(url=launchpad:resources/install/0/cq-widgets-ext-5.8.4.jar, entity=bundle:com.day.cq.cq-widgets-ext, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.cq-widgets-ext, Bundle-Version=5.8.4], digest=1515998757000) 15.01.2018 12:16:26.644 *INFO* [OsgiInstallerImpl] com.day.cq.workflow.cq-workflow-api BundleEvent INSTALLED 15.01.2018 12:16:26.644 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.workflow.cq-workflow-api [432] from resource TaskResource(url=launchpad:resources/install/0/cq-workflow-api-6.0.4.jar, entity=bundle:com.day.cq.workflow.cq-workflow-api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.workflow.cq-workflow-api, Bundle-Version=6.0.4], digest=1515998757000) 15.01.2018 12:16:26.734 *INFO* [OsgiInstallerImpl] com.day.cq.workflow.cq-workflow-console BundleEvent INSTALLED 15.01.2018 12:16:26.734 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.workflow.cq-workflow-console [433] from resource TaskResource(url=launchpad:resources/install/0/cq-workflow-console-6.1.2.jar, entity=bundle:com.day.cq.workflow.cq-workflow-console, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.workflow.cq-workflow-console, Bundle-Version=6.1.2], digest=1515998757000) 15.01.2018 12:16:26.746 *INFO* [OsgiInstallerImpl] com.day.cq.workflow.cq-workflow-impl BundleEvent INSTALLED 15.01.2018 12:16:26.746 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.workflow.cq-workflow-impl [434] from resource TaskResource(url=launchpad:resources/install/0/cq-workflow-impl-6.1.22.jar, entity=bundle:com.day.cq.workflow.cq-workflow-impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.workflow.cq-workflow-impl, Bundle-Version=6.1.22], digest=1515998757000) 15.01.2018 12:16:26.757 *INFO* [OsgiInstallerImpl] com.day.crx.sling.crx-auth-token BundleEvent INSTALLED 15.01.2018 12:16:26.757 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.crx.sling.crx-auth-token [435] from resource TaskResource(url=launchpad:resources/install/0/crx-auth-token-2.5.30.jar, entity=bundle:com.day.crx.sling.crx-auth-token, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.crx.sling.crx-auth-token, Bundle-Version=2.5.30], digest=1515998757000) 15.01.2018 12:16:26.835 *INFO* [OsgiInstallerImpl] com.day.cq.dam.dam-webdav-support BundleEvent INSTALLED 15.01.2018 12:16:26.835 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.day.cq.dam.dam-webdav-support [436] from resource TaskResource(url=launchpad:resources/install/0/dam-webdav-support-1.2.16.jar, entity=bundle:com.day.cq.dam.dam-webdav-support, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.day.cq.dam.dam-webdav-support, Bundle-Version=1.2.16], digest=1515998757000) 15.01.2018 12:16:26.845 *INFO* [OsgiInstallerImpl] day-commons-diff BundleEvent INSTALLED 15.01.2018 12:16:26.845 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-diff [437] from resource TaskResource(url=launchpad:resources/install/0/day-commons-diff-1.1.6.jar, entity=bundle:day-commons-diff, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-diff, Bundle-Version=1.1.6], digest=1515998757000) 15.01.2018 12:16:26.932 *INFO* [OsgiInstallerImpl] day-commons-durbo BundleEvent INSTALLED 15.01.2018 12:16:26.932 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-durbo [438] from resource TaskResource(url=launchpad:resources/install/0/day-commons-durbo-2.1.6.jar, entity=bundle:day-commons-durbo, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-durbo, Bundle-Version=2.1.6], digest=1515998757000) 15.01.2018 12:16:26.944 *INFO* [OsgiInstallerImpl] day-commons-gfx BundleEvent INSTALLED 15.01.2018 12:16:26.944 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-gfx [439] from resource TaskResource(url=launchpad:resources/install/0/day-commons-gfx-2.1.46.jar, entity=bundle:day-commons-gfx, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-gfx, Bundle-Version=2.1.46], digest=1515998757000) 15.01.2018 12:16:27.050 *INFO* [OsgiInstallerImpl] day-commons-io BundleEvent INSTALLED 15.01.2018 12:16:27.051 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-io [440] from resource TaskResource(url=launchpad:resources/install/0/day-commons-io-1.1.8.jar, entity=bundle:day-commons-io, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-io, Bundle-Version=1.1.8], digest=1515998757000) 15.01.2018 12:16:27.064 *INFO* [OsgiInstallerImpl] day-commons-jrawio BundleEvent INSTALLED 15.01.2018 12:16:27.064 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-jrawio [441] from resource TaskResource(url=launchpad:resources/install/0/day-commons-jrawio-1.5.0.006.jar, entity=bundle:day-commons-jrawio, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-jrawio, Bundle-Version=1.5.0.006], digest=1515998757000) 15.01.2018 12:16:27.076 *INFO* [OsgiInstallerImpl] day-commons-jstl BundleEvent INSTALLED 15.01.2018 12:16:27.076 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-jstl [442] from resource TaskResource(url=launchpad:resources/install/0/day-commons-jstl-1.1.4.jar, entity=bundle:day-commons-jstl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-jstl, Bundle-Version=1.1.4], digest=1515998757000) 15.01.2018 12:16:27.200 *INFO* [OsgiInstallerImpl] day-commons-misc BundleEvent INSTALLED 15.01.2018 12:16:27.201 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day-commons-misc [443] from resource TaskResource(url=launchpad:resources/install/0/day-commons-misc-1.1.2.jar, entity=bundle:day-commons-misc, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day-commons-misc, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:27.212 *INFO* [OsgiInstallerImpl] day.commons.datasource.jdbcpool BundleEvent INSTALLED 15.01.2018 12:16:27.212 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day.commons.datasource.jdbcpool [444] from resource TaskResource(url=launchpad:resources/install/0/day.commons.datasource.jdbcpool-1.0.24.jar , entity=bundle:day.commons.datasource.jdbcpool, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day.commons.datasource.jdbcpool, Bundle-Version=1.0.24], digest=1515998757000) 15.01.2018 12:16:27.269 *INFO* [OsgiInstallerImpl] day.commons.datasource.poolservice BundleEvent INSTALLED 15.01.2018 12:16:27.269 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle day.commons.datasource.poolservice [445] from resource TaskResource(url=launchpad:resources/install/0/day.commons.datasource.poolservice-1.0.10. jar, entity=bundle:day.commons.datasource.poolservice, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=day.commons.datasource.poolservice, Bundle-Version=1.0.10], digest=1515998757000) 15.01.2018 12:16:27.316 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.host BundleEvent INSTALLED 15.01.2018 12:16:27.316 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.host [446] from resource TaskResource(url=launchpad:resources/install/0/files.host-1.0.6.jar, entity=bundle:com.adobe.xmp.worker.files.host, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.host, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:27.344 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.native.fragment.solaris-intel BundleEvent INSTALLED 15.01.2018 12:16:27.344 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.native.fragment.solaris-intel [447] from resource TaskResource(url=launchpad:resources/install/0/files.native.fragment-1.0.4-solaris-intel. jar, entity=bundle:com.adobe.xmp.worker.files.native.fragment.solaris-intel, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.native.fragment.solaris-intel, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:27.379 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.native.fragment.solaris-sparc BundleEvent INSTALLED 15.01.2018 12:16:27.379 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.native.fragment.solaris-sparc [448] from resource TaskResource(url=launchpad:resources/install/0/files.native.fragment-1.0.4-solaris-sparc. jar, entity=bundle:com.adobe.xmp.worker.files.native.fragment.solaris-sparc, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.native.fragment.solaris-sparc, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:27.413 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.native.fragment.linux BundleEvent INSTALLED 15.01.2018 12:16:27.413 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.native.fragment.linux [449] from resource TaskResource(url=launchpad:resources/install/0/files.native.fragment-1.0.6-linux.jar, entity=bundle:com.adobe.xmp.worker.files.native.fragment.linux, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.native.fragment.linux, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:27.474 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.native.fragment.macosx BundleEvent INSTALLED 15.01.2018 12:16:27.474 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.native.fragment.macosx [450] from resource TaskResource(url=launchpad:resources/install/0/files.native.fragment-1.0.6-macosx.jar, entity=bundle:com.adobe.xmp.worker.files.native.fragment.macosx, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.native.fragment.macosx, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:27.493 *INFO* [OsgiInstallerImpl] com.adobe.xmp.worker.files.native.fragment.win BundleEvent INSTALLED 15.01.2018 12:16:27.493 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.xmp.worker.files.native.fragment.win [451] from resource TaskResource(url=launchpad:resources/install/0/files.native.fragment-1.0.6-win.jar, entity=bundle:com.adobe.xmp.worker.files.native.fragment.win, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.xmp.worker.files.native.fragment.win, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:27.504 *INFO* [OsgiInstallerImpl] forms-foundation-bundle BundleEvent INSTALLED 15.01.2018 12:16:27.504 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle forms-foundation-bundle [452] from resource TaskResource(url=launchpad:resources/install/0/forms-foundation-bundle-2.0.56.jar, entity=bundle:forms-foundation-bundle, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=forms-foundation-bundle, Bundle-Version=2.0.56], digest=1515998757000) 15.01.2018 12:16:27.553 *INFO* [OsgiInstallerImpl] org.apache.geronimo.specs.geronimo-atinject_1.0_spec BundleEvent INSTALLED 15.01.2018 12:16:27.553 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.geronimo.specs.geronimo-atinject_1.0_spec [453] from resource TaskResource(url=launchpad:resources/install/0/geronimo-atinject_1.0_spec-1.0.jar, entity=bundle:org.apache.geronimo.specs.geronimo-atinject_1.0_spec, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.geronimo.specs.geronimo-atinject_1.0_spec, Bundle-Version=1.0], digest=1515998757000) 15.01.2018 12:16:27.566 *INFO* [OsgiInstallerImpl] org.apache.jackrabbit.jackrabbit-webdav BundleEvent INSTALLED 15.01.2018 12:16:27.566 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.jackrabbit.jackrabbit-webdav [454] from resource TaskResource(url=launchpad:resources/install/0/jackrabbit-webdav-2.14.0.jar, entity=bundle:org.apache.jackrabbit.jackrabbit-webdav, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.jackrabbit.jackrabbit-webdav, Bundle-Version=2.14.0], digest=1515998757000) 15.01.2018 12:16:27.576 *INFO* [OsgiInstallerImpl] com.fasterxml.jackson.core.jackson-annotations BundleEvent INSTALLED 15.01.2018 12:16:27.577 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.fasterxml.jackson.core.jackson-annotations [455] from resource TaskResource(url=launchpad:resources/install/0/jackson-annotations-2.8.4.jar, entity=bundle:com.fasterxml.jackson.core.jackson-annotations, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.fasterxml.jackson.core.jackson-annotations, Bundle-Version=2.8.4], digest=1515998757000) 15.01.2018 12:16:27.589 *INFO* [OsgiInstallerImpl] com.fasterxml.jackson.core.jackson-core BundleEvent INSTALLED 15.01.2018 12:16:27.589 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.fasterxml.jackson.core.jackson-core [456] from resource TaskResource(url=launchpad:resources/install/0/jackson-core-2.8.4.jar, entity=bundle:com.fasterxml.jackson.core.jackson-core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.fasterxml.jackson.core.jackson-core, Bundle-Version=2.8.4], digest=1515998757000) 15.01.2018 12:16:27.608 *INFO* [OsgiInstallerImpl] com.fasterxml.jackson.core.jackson-databind BundleEvent INSTALLED 15.01.2018 12:16:27.608 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.fasterxml.jackson.core.jackson-databind [457] from resource TaskResource(url=launchpad:resources/install/0/jackson-databind-2.8.4.jar, entity=bundle:com.fasterxml.jackson.core.jackson-databind, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.fasterxml.jackson.core.jackson-databind, Bundle-Version=2.8.4], digest=1515998757000) 15.01.2018 12:16:27.622 *INFO* [OsgiInstallerImpl] javax.mail BundleEvent INSTALLED 15.01.2018 12:16:27.622 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle javax.mail [458] from resource TaskResource(url=launchpad:resources/install/0/mail-1.5.0-b01.jar, entity=bundle:javax.mail, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=javax.mail, Bundle-Version=1.5.0.b01], digest=1515998757000) 15.01.2018 12:16:27.634 *INFO* [OsgiInstallerImpl] com.adobe.cq.myspell BundleEvent INSTALLED 15.01.2018 12:16:27.634 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.cq.myspell [459] from resource TaskResource(url=launchpad:resources/install/0/myspell-1.6.jar, entity=bundle:com.adobe.cq.myspell, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.cq.myspell, Bundle-Version=1.6.0], digest=1515998757000) 15.01.2018 12:16:27.653 *INFO* [OsgiInstallerImpl] org.apache.opennlp.tools BundleEvent INSTALLED 15.01.2018 12:16:27.653 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.opennlp.tools [460] from resource TaskResource(url=launchpad:resources/install/0/opennlp-tools-1.6.0.jar, entity=bundle:org.apache.opennlp.tools, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.opennlp.tools, Bundle-Version=1.6.0], digest=1515998757000) 15.01.2018 12:16:27.704 *INFO* [OsgiInstallerImpl] org.apache.oltu.commons.encodedtoken BundleEvent INSTALLED 15.01.2018 12:16:27.705 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.commons.encodedtoken [461] from resource TaskResource(url=launchpad:resources/install/0/org.apache.oltu.commons.encodedtoken-1.0.1 .jar, entity=bundle:org.apache.oltu.commons.encodedtoken, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.commons.encodedtoken, Bundle-Version=1.0.1], digest=1515998757000) 15.01.2018 12:16:27.747 *INFO* [OsgiInstallerImpl] org.apache.oltu.commons.json BundleEvent INSTALLED 15.01.2018 12:16:27.747 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.commons.json [462] from resource TaskResource(url=launchpad:resources/install/0/org.apache.oltu.commons.json-1.0.0.jar, entity=bundle:org.apache.oltu.commons.json, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.commons.json, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:27.844 *INFO* [OsgiInstallerImpl] org.apache.oltu.jose.jws BundleEvent INSTALLED 15.01.2018 12:16:27.844 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.jose.jws [463] from resource TaskResource(url=launchpad:resources/install/0/org.apache.oltu.jose.jws-1.0.1.jar, entity=bundle:org.apache.oltu.jose.jws, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.jose.jws, Bundle-Version=1.0.1], digest=1515998757000) 15.01.2018 12:16:27.929 *INFO* [OsgiInstallerImpl] org.apache.oltu.oauth2.jwt BundleEvent INSTALLED 15.01.2018 12:16:27.929 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.oltu.oauth2.jwt [464] from resource TaskResource(url=launchpad:resources/install/0/org.apache.oltu.oauth2.jwt-1.0.3.jar, entity=bundle:org.apache.oltu.oauth2.jwt, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.oltu.oauth2.jwt, Bundle-Version=1.0.3], digest=1515998757000) 15.01.2018 12:16:28.064 *INFO* [OsgiInstallerImpl] org.apache.sling.atom.taglib BundleEvent INSTALLED 15.01.2018 12:16:28.064 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.atom.taglib [465] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.atom.taglib-0.9.0-R988585 .jar, entity=bundle:org.apache.sling.atom.taglib, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.atom.taglib, Bundle-Version=0.9.0.R988585], digest=1515998757000) 15.01.2018 12:16:28.166 *INFO* [OsgiInstallerImpl] org.apache.sling.bundleresource.impl BundleEvent INSTALLED 15.01.2018 12:16:28.166 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.bundleresource.impl [466] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.bundleresource.impl-2.2.0 .jar, entity=bundle:org.apache.sling.bundleresource.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.bundleresource.impl, Bundle-Version=2.2.0], digest=1515998757000) 15.01.2018 12:16:28.229 *INFO* [OsgiInstallerImpl] org.apache.sling.caconfig.api BundleEvent INSTALLED 15.01.2018 12:16:28.229 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.caconfig.api [467] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.caconfig.api-1.1.0.jar, entity=bundle:org.apache.sling.caconfig.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.caconfig.api, Bundle-Version=1.1.0], digest=1515998757000) 15.01.2018 12:16:28.241 *INFO* [OsgiInstallerImpl] org.apache.sling.caconfig.impl BundleEvent INSTALLED 15.01.2018 12:16:28.241 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.caconfig.impl [468] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.caconfig.impl-1.2.0.jar, entity=bundle:org.apache.sling.caconfig.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.caconfig.impl, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:28.338 *INFO* [OsgiInstallerImpl] org.apache.sling.caconfig.spi BundleEvent INSTALLED 15.01.2018 12:16:28.338 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.caconfig.spi [469] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.caconfig.spi-1.2.0.jar, entity=bundle:org.apache.sling.caconfig.spi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.caconfig.spi, Bundle-Version=1.2.0], digest=1515998757000) 15.01.2018 12:16:28.355 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.compiler BundleEvent INSTALLED 15.01.2018 12:16:28.355 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.compiler [470] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.commons.compiler-2.3.0.ja r, entity=bundle:org.apache.sling.commons.compiler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.compiler, Bundle-Version=2.3.0], digest=1515998757000) 15.01.2018 12:16:28.416 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.contentdetection BundleEvent INSTALLED 15.01.2018 12:16:28.416 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.contentdetection [471] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.commons.contentdetection- 1.0.2.jar, entity=bundle:org.apache.sling.commons.contentdetection, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.contentdetection, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:28.509 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.fsclassloader BundleEvent INSTALLED 15.01.2018 12:16:28.509 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.fsclassloader [472] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.commons.fsclassloader-1.0 .4.jar, entity=bundle:org.apache.sling.commons.fsclassloader, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.fsclassloader, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:28.519 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.html BundleEvent INSTALLED 15.01.2018 12:16:28.520 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.commons.html [473] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.commons.html-1.0.0.jar, entity=bundle:org.apache.sling.commons.html, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.commons.html, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:28.597 *INFO* [OsgiInstallerImpl] org.apache.sling.distribution.api BundleEvent INSTALLED 15.01.2018 12:16:28.598 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.distribution.api [474] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.distribution.api-0.3.0.ja r, entity=bundle:org.apache.sling.distribution.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.distribution.api, Bundle-Version=0.3.0], digest=1515998757000) 15.01.2018 12:16:28.611 *INFO* [OsgiInstallerImpl] org.apache.sling.distribution.core BundleEvent INSTALLED 15.01.2018 12:16:28.611 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.distribution.core [475] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.distribution.core-0.2.6.j ar, entity=bundle:org.apache.sling.distribution.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.distribution.core, Bundle-Version=0.2.6], digest=1515998757000) 15.01.2018 12:16:28.624 *INFO* [OsgiInstallerImpl] org.apache.sling.engine BundleEvent INSTALLED 15.01.2018 12:16:28.624 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.engine [476] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.engine-2.6.6.jar, entity=bundle:org.apache.sling.engine, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.engine, Bundle-Version=2.6.6], digest=1515998757000) 15.01.2018 12:16:28.636 *INFO* [OsgiInstallerImpl] org.apache.sling.event BundleEvent INSTALLED 15.01.2018 12:16:28.637 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.event [477] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.event-4.2.0.jar, entity=bundle:org.apache.sling.event, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.event, Bundle-Version=4.2.0], digest=1515998757000) 15.01.2018 12:16:28.718 *INFO* [OsgiInstallerImpl] org.apache.sling.event.dea BundleEvent INSTALLED 15.01.2018 12:16:28.718 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.event.dea [478] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.event.dea-1.1.0.jar, entity=bundle:org.apache.sling.event.dea, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.event.dea, Bundle-Version=1.1.0], digest=1515998757000) 15.01.2018 12:16:28.843 *INFO* [OsgiInstallerImpl] org.apache.sling.hapi BundleEvent INSTALLED 15.01.2018 12:16:28.843 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.hapi [479] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.hapi-1.0.0.jar, entity=bundle:org.apache.sling.hapi, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.hapi, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:28.854 *INFO* [OsgiInstallerImpl] org.apache.sling.hc.core BundleEvent INSTALLED 15.01.2018 12:16:28.854 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.hc.core [480] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.hc.core-1.2.4.jar, entity=bundle:org.apache.sling.hc.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.hc.core, Bundle-Version=1.2.4], digest=1515998757000) 15.01.2018 12:16:28.916 *INFO* [OsgiInstallerImpl] org.apache.sling.hc.webconsole BundleEvent INSTALLED 15.01.2018 12:16:28.916 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.hc.webconsole [481] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.hc.webconsole-1.1.2.jar, entity=bundle:org.apache.sling.hc.webconsole, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.hc.webconsole, Bundle-Version=1.1.2], digest=1515998757000) 15.01.2018 12:16:28.927 *INFO* [OsgiInstallerImpl] org.apache.sling.i18n BundleEvent INSTALLED 15.01.2018 12:16:28.927 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.i18n [482] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.i18n-2.5.6.jar, entity=bundle:org.apache.sling.i18n, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.i18n, Bundle-Version=2.5.6], digest=1515998757000) 15.01.2018 12:16:28.939 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.davex BundleEvent INSTALLED 15.01.2018 12:16:28.939 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.davex [483] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.jcr.davex-1.3.8.jar, entity=bundle:org.apache.sling.jcr.davex, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.davex, Bundle-Version=1.3.8], digest=1515998757000) 15.01.2018 12:16:28.998 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.resourcesecurity BundleEvent INSTALLED 15.01.2018 12:16:28.998 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.resourcesecurity [484] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.jcr.resourcesecurity-1.0. 2.jar, entity=bundle:org.apache.sling.jcr.resourcesecurity, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.resourcesecurity, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:29.009 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.webdav BundleEvent INSTALLED 15.01.2018 12:16:29.010 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jcr.webdav [485] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.jcr.webdav-2.3.8.jar, entity=bundle:org.apache.sling.jcr.webdav, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jcr.webdav, Bundle-Version=2.3.8], digest=1515998757000) 15.01.2018 12:16:29.106 *INFO* [OsgiInstallerImpl] org.apache.sling.jmx.provider BundleEvent INSTALLED 15.01.2018 12:16:29.107 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.jmx.provider [486] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.jmx.provider-1.0.2.jar, entity=bundle:org.apache.sling.jmx.provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.jmx.provider, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:29.288 *INFO* [OsgiInstallerImpl] org.apache.sling.models.api BundleEvent INSTALLED 15.01.2018 12:16:29.289 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.models.api [487] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.models.api-1.3.2.jar, entity=bundle:org.apache.sling.models.api, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.models.api, Bundle-Version=1.3.2], digest=1515998757000) 15.01.2018 12:16:29.301 *INFO* [OsgiInstallerImpl] org.apache.sling.models.impl BundleEvent INSTALLED 15.01.2018 12:16:29.301 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.models.impl [488] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.models.impl-1.3.9-r178496 0.jar, entity=bundle:org.apache.sling.models.impl, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.models.impl, Bundle-Version=1.3.9.r1784960], digest=1515998757000) 15.01.2018 12:16:29.444 *INFO* [OsgiInstallerImpl] org.apache.sling.models.jacksonexporter BundleEvent INSTALLED 15.01.2018 12:16:29.444 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.models.jacksonexporter [489] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.models.jacksonexporter-1. 0.6.jar, entity=bundle:org.apache.sling.models.jacksonexporter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.models.jacksonexporter, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:29.508 *INFO* [OsgiInstallerImpl] org.apache.sling.resource.inventory BundleEvent INSTALLED 15.01.2018 12:16:29.508 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.resource.inventory [490] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.resource.inventory-1.0.6. jar, entity=bundle:org.apache.sling.resource.inventory, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.resource.inventory, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:29.579 *INFO* [OsgiInstallerImpl] org.apache.sling.resourcecollection BundleEvent INSTALLED 15.01.2018 12:16:29.579 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.resourcecollection [491] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.resourcecollection-1.0.0. jar, entity=bundle:org.apache.sling.resourcecollection, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.resourcecollection, Bundle-Version=1.0.0], digest=1515998757000) 15.01.2018 12:16:29.718 *INFO* [OsgiInstallerImpl] org.apache.sling.resourcemerger BundleEvent INSTALLED 15.01.2018 12:16:29.718 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.resourcemerger [492] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.resourcemerger-1.3.0.jar, entity=bundle:org.apache.sling.resourcemerger, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.resourcemerger, Bundle-Version=1.3.0], digest=1515998757000) 15.01.2018 12:16:29.729 *INFO* [OsgiInstallerImpl] org.apache.sling.rewriter BundleEvent INSTALLED 15.01.2018 12:16:29.729 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.rewriter [493] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.rewriter-1.2.1-R1777332.j ar, entity=bundle:org.apache.sling.rewriter, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.rewriter, Bundle-Version=1.2.1.R1777332], digest=1515998757000) 15.01.2018 12:16:29.740 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.core BundleEvent INSTALLED 15.01.2018 12:16:29.740 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.core [494] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.core-2.0.44.jar , entity=bundle:org.apache.sling.scripting.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.core, Bundle-Version=2.0.44], digest=1515998757000) 15.01.2018 12:16:29.843 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.java BundleEvent INSTALLED 15.01.2018 12:16:29.843 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.java [495] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.java-2.1.2.jar, entity=bundle:org.apache.sling.scripting.java, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.java, Bundle-Version=2.1.2], digest=1515998757000) 15.01.2018 12:16:29.862 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.javascript BundleEvent INSTALLED 15.01.2018 12:16:29.862 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.javascript [496] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.javascript-2.0. 30.jar, entity=bundle:org.apache.sling.scripting.javascript, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.javascript, Bundle-Version=2.0.30], digest=1515998757000) 15.01.2018 12:16:29.878 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.jsp BundleEvent INSTALLED 15.01.2018 12:16:29.878 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.jsp [497] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.jsp-2.2.6.jar, entity=bundle:org.apache.sling.scripting.jsp, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.jsp, Bundle-Version=2.2.6], digest=1515998757000) 15.01.2018 12:16:29.892 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.jsp.taglib BundleEvent INSTALLED 15.01.2018 12:16:29.892 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.jsp.taglib [498] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.jsp.taglib-2.2. 6.jar, entity=bundle:org.apache.sling.scripting.jsp.taglib, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.jsp.taglib, Bundle-Version=2.2.6], digest=1515998757000) 15.01.2018 12:16:29.910 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.jst BundleEvent INSTALLED 15.01.2018 12:16:29.910 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.jst [499] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.jst-2.0.6.jar, entity=bundle:org.apache.sling.scripting.jst, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.jst, Bundle-Version=2.0.6], digest=1515998757000) 15.01.2018 12:16:29.922 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.sightly BundleEvent INSTALLED 15.01.2018 12:16:29.922 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.sightly [500] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.sightly-1.0.32. jar, entity=bundle:org.apache.sling.scripting.sightly, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.sightly, Bundle-Version=1.0.32], digest=1515998757000) 15.01.2018 12:16:29.935 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.sightly.compiler BundleEvent INSTALLED 15.01.2018 12:16:29.935 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.sightly.compiler [501] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.sightly.compile r-1.0.8.jar, entity=bundle:org.apache.sling.scripting.sightly.compiler, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.sightly.compiler, Bundle-Version=1.0.8], digest=1515998757000) 15.01.2018 12:16:29.946 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.sightly.compiler.java BundleEvent INSTALLED 15.01.2018 12:16:29.946 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.sightly.compiler.java [502] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.sightly.compile r.java-1.0.8.jar, entity=bundle:org.apache.sling.scripting.sightly.compiler.java, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.sightly.compiler.java, Bundle-Version=1.0.8], digest=1515998757000) 15.01.2018 12:16:29.957 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.sightly.js.provider BundleEvent INSTALLED 15.01.2018 12:16:29.957 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.sightly.js.provider [503] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.sightly.js.prov ider-1.0.18.jar, entity=bundle:org.apache.sling.scripting.sightly.js.provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.sightly.js.provider, Bundle-Version=1.0.18], digest=1515998757000) 15.01.2018 12:16:30.011 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.sightly.models.provider BundleEvent INSTALLED 15.01.2018 12:16:30.012 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.scripting.sightly.models.provider [504] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.scripting.sightly.models. provider-1.0.6.jar, entity=bundle:org.apache.sling.scripting.sightly.models.provider, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.scripting.sightly.models.provider, Bundle-Version=1.0.6], digest=1515998757000) 15.01.2018 12:16:30.077 *INFO* [OsgiInstallerImpl] org.apache.sling.servlets.compat BundleEvent INSTALLED 15.01.2018 12:16:30.077 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.servlets.compat [505] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.servlets.compat-1.0.0-Rev ision1200172.jar, entity=bundle:org.apache.sling.servlets.compat, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.servlets.compat, Bundle-Version=1.0.0.Revision1200172], digest=1515998757000) 15.01.2018 12:16:30.088 *INFO* [OsgiInstallerImpl] org.apache.sling.servlets.get BundleEvent INSTALLED 15.01.2018 12:16:30.088 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.servlets.get [506] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.servlets.get-2.1.22.jar, entity=bundle:org.apache.sling.servlets.get, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.servlets.get, Bundle-Version=2.1.22], digest=1515998757000) 15.01.2018 12:16:30.099 *INFO* [OsgiInstallerImpl] org.apache.sling.servlets.post BundleEvent INSTALLED 15.01.2018 12:16:30.099 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.servlets.post [507] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.servlets.post-2.3.15-r178 0096.jar, entity=bundle:org.apache.sling.servlets.post, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.servlets.post, Bundle-Version=2.3.15.r1780096], digest=1515998757000) 15.01.2018 12:16:30.109 *INFO* [OsgiInstallerImpl] org.apache.sling.servlets.resolver BundleEvent INSTALLED 15.01.2018 12:16:30.109 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.servlets.resolver [508] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.servlets.resolver-2.4.10. jar, entity=bundle:org.apache.sling.servlets.resolver, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.servlets.resolver, Bundle-Version=2.4.10], digest=1515998757000) 15.01.2018 12:16:30.236 *INFO* [OsgiInstallerImpl] org.apache.sling.tenant BundleEvent INSTALLED 15.01.2018 12:16:30.236 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.tenant [509] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.tenant-1.1.0.jar, entity=bundle:org.apache.sling.tenant, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.tenant, Bundle-Version=1.1.0], digest=1515998757000) 15.01.2018 12:16:30.246 *INFO* [OsgiInstallerImpl] org.apache.sling.tracer BundleEvent INSTALLED 15.01.2018 12:16:30.247 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sling.tracer [510] from resource TaskResource(url=launchpad:resources/install/0/org.apache.sling.tracer-1.0.2.jar, entity=bundle:org.apache.sling.tracer, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sling.tracer, Bundle-Version=1.0.2], digest=1515998757000) 15.01.2018 12:16:30.268 *INFO* [OsgiInstallerImpl] PDFServices_manipulations BundleEvent INSTALLED 15.01.2018 12:16:30.268 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle PDFServices_manipulations [511] from resource TaskResource(url=launchpad:resources/install/0/pdfservices_manipulation-3.0.577161.jar, entity=bundle:PDFServices_manipulations, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=PDFServices_manipulations, Bundle-Version=3.0.577161], digest=1515998757000) 15.01.2018 12:16:30.294 *INFO* [OsgiInstallerImpl] PDFServices_security BundleEvent INSTALLED 15.01.2018 12:16:30.294 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle PDFServices_security [512] from resource TaskResource(url=launchpad:resources/install/0/pdfservices_security-3.0.577161.jar, entity=bundle:PDFServices_security, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=PDFServices_security, Bundle-Version=3.0.577161], digest=1515998757000) 15.01.2018 12:16:30.309 *INFO* [OsgiInstallerImpl] org.apache.sanselan.sanselan BundleEvent INSTALLED 15.01.2018 12:16:30.309 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle org.apache.sanselan.sanselan [513] from resource TaskResource(url=launchpad:resources/install/0/sanselan-0.97-incubator.jar, entity=bundle:org.apache.sanselan.sanselan, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=org.apache.sanselan.sanselan, Bundle-Version=0.97.0.incubator], digest=1515998757000) 15.01.2018 12:16:30.401 *INFO* [OsgiInstallerImpl] com.adobe.reef.siren.core BundleEvent INSTALLED 15.01.2018 12:16:30.402 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle com.adobe.reef.siren.core [514] from resource TaskResource(url=launchpad:resources/install/0/siren-core-1.0.4.jar, entity=bundle:com.adobe.reef.siren.core, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=com.adobe.reef.siren.core, Bundle-Version=1.0.4], digest=1515998757000) 15.01.2018 12:16:30.434 *INFO* [OsgiInstallerImpl] xtg BundleEvent INSTALLED 15.01.2018 12:16:30.434 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Installed bundle xtg [515] from resource TaskResource(url=launchpad:resources/install/0/xfa-3.0.1.jar, entity=bundle:xtg, state=INSTALL, attributes=[org.apache.sling.installer.api.tasks.ResourceTransformer=:25:22:, Bundle-SymbolicName=xtg, Bundle-Version=3.0], digest=1515998757000) 15.01.2018 12:16:30.435 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Refreshing 1 bundles: [com.adobe.xmp.worker.files.host [446]] 15.01.2018 12:16:30.435 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Waiting up to 90 seconds for bundles refresh 15.01.2018 12:16:30.437 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Done refreshing 1 bundles 15.01.2018 12:16:30.437 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent PACKAGES REFRESHED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.felix.http.servlet-api BundleEvent RESOLVED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.threads BundleEvent RESOLVED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.sling.hc.core BundleEvent RESOLVED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.sling.discovery.api BundleEvent RESOLVED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.json BundleEvent RESOLVED 15.01.2018 12:16:30.455 *INFO* [OsgiInstallerImpl] org.apache.felix.eventadmin BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.aries.transaction.manager BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.felix.metatype BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] com.day.commons.osgi.wrapper.commons-lang2 BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.felix.scr BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.scheduler BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.sling.jcr.jcr-wrapper BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.sling.commons.osgi BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.felix.http.jetty BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.sling.api BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] org.apache.sling.scripting.api BundleEvent RESOLVED 15.01.2018 12:16:30.456 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall BundleEvent STARTING 15.01.2018 12:16:30.457 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall Service [AttachAPIResolver for Sun JVMs,32, [com.adobe.cq.deserfw.api.AttachAPIResolver]] ServiceEvent REGISTERED 15.01.2018 12:16:30.458 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall Service [AttachAPIResolver for IBM JVMs,33, [com.adobe.cq.deserfw.api.AttachAPIResolver]] ServiceEvent REGISTERED 15.01.2018 12:16:30.458 *INFO* [OsgiInstallerImpl] com.adobe.cq.cq-deserialization-firewall BundleEvent STARTED 15.01.2018 12:16:30.458 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-deserialization-firewall [21] 15.01.2018 12:16:30.462 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-compat-configupdate [22] 15.01.2018 12:16:30.465 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.aries.jmx.api [23] 15.01.2018 12:16:30.469 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.aries.jmx.core [24] 15.01.2018 12:16:30.472 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.aries.jmx.whiteboard [25] 15.01.2018 12:16:30.475 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.aries.transaction.manager [26] 15.01.2018 12:16:30.478 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.discovery.api [27] 15.01.2018 12:16:30.481 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.provisioning.model [28] 15.01.2018 12:16:30.484 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.eventadmin [29] 15.01.2018 12:16:30.488 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.metatype [30] 15.01.2018 12:16:30.491 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.scr [31] 15.01.2018 12:16:30.494 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.joda-time [32] 15.01.2018 12:16:30.497 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.webconsole.plugins [33] 15.01.2018 12:16:30.500 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.fileupload [34] 15.01.2018 12:16:30.503 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.lang3 [35] 15.01.2018 12:16:30.506 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.httpcomponents.httpclient [36] 15.01.2018 12:16:30.509 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.httpcomponents.httpcore [37] 15.01.2018 12:16:30.512 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.bundles.json [38] 15.01.2018 12:16:30.515 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.http.jetty [39] 15.01.2018 12:16:30.518 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.http.servlet-api [40] 15.01.2018 12:16:30.521 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.http.whiteboard [41] 15.01.2018 12:16:30.524 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.inventory [42] 15.01.2018 12:16:30.526 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.org.apache.felix.threaddump [43] 15.01.2018 12:16:30.529 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.webconsole [44] 15.01.2018 12:16:30.532 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.webconsole.plugins.ds [45] 15.01.2018 12:16:30.535 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.webconsole.plugins.event [46] 15.01.2018 12:16:30.538 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.webconsole.plugins.memoryusage [47] 15.01.2018 12:16:30.541 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.webconsole.plugins.packageadmin [48] 15.01.2018 12:16:30.544 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.log.webconsole [49] 15.01.2018 12:16:30.547 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.installer.console [50] 15.01.2018 12:16:30.550 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.security [51] 15.01.2018 12:16:30.553 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.startupfilter [52] 15.01.2018 12:16:30.556 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.jaas [53] 15.01.2018 12:16:30.559 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.datasource [54] 15.01.2018 12:16:30.562 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.dropwizard.metrics [55] 15.01.2018 12:16:30.565 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.osgi.wrapper.commons-lang2 [56] 15.01.2018 12:16:30.568 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.collections [57] 15.01.2018 12:16:30.570 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-compat-runmode [58] 15.01.2018 12:16:30.573 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-pre-upgrade-backup [60] 15.01.2018 12:16:30.576 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-pre-upgrade-cleanup [61] 15.01.2018 12:16:30.579 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-product-info-provider [62] 15.01.2018 12:16:30.582 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.felix.http.sslfilter [63] 15.01.2018 12:16:30.585 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.metrics [64] 15.01.2018 12:16:30.588 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.osgi [65] 15.01.2018 12:16:30.591 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.serviceusermapper [66] 15.01.2018 12:16:30.594 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.infocollector [67] 15.01.2018 12:16:30.597 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.license [68] 15.01.2018 12:16:30.600 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.api [69] 15.01.2018 12:16:30.603 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle afe [70] 15.01.2018 12:16:30.606 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle AGL_min [71] 15.01.2018 12:16:30.609 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.gibson [72] 15.01.2018 12:16:30.612 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.poi [73] 15.01.2018 12:16:30.615 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.rngom [74] 15.01.2018 12:16:30.617 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.tagsoup [75] 15.01.2018 12:16:30.620 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.codec [76] 15.01.2018 12:16:30.623 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.compress [77] 15.01.2018 12:16:30.626 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.core [78] 15.01.2018 12:16:30.629 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.schema.model [79] 15.01.2018 12:16:30.633 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle pdfcore [80] 15.01.2018 12:16:30.635 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle pdfencryption [81] 15.01.2018 12:16:30.639 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle PDFServices_extraction [82] 15.01.2018 12:16:30.642 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle rideau [83] 15.01.2018 12:16:30.644 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.schema.rngparser [84] 15.01.2018 12:16:30.647 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.schema.service [85] 15.01.2018 12:16:30.650 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.tika.core [86] 15.01.2018 12:16:30.653 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.tika.parsers [87] 15.01.2018 12:16:30.656 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.xmpcore [88] 15.01.2018 12:16:30.659 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.osgi.wrapper.guava [89] 15.01.2018 12:16:30.662 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.repository [90] 15.01.2018 12:16:30.665 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.h2.mvstore [91] 15.01.2018 12:16:30.668 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-data [92] 15.01.2018 12:16:30.671 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.mongodb.mongo-java-driver [93] 15.01.2018 12:16:30.674 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-auth-external [94] 15.01.2018 12:16:30.677 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-auth-ldap [95] 15.01.2018 12:16:30.680 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-authorization-cug [96] 15.01.2018 12:16:30.683 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-blob [97] 15.01.2018 12:16:30.686 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-commons [98] 15.01.2018 12:16:30.689 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-core [99] 15.01.2018 12:16:30.692 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-jcr [100] 15.01.2018 12:16:30.695 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-lucene [101] 15.01.2018 12:16:30.697 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-segment-tar [102] 15.01.2018 12:16:30.700 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.oak-solr-osgi [103] 15.01.2018 12:16:30.703 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.jmx [104] 15.01.2018 12:16:30.706 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.crx.crx-api [105] 15.01.2018 12:16:30.709 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.day-commons-text [106] 15.01.2018 12:16:30.712 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.forms.foundation-forms-foundation-base [107] 15.01.2018 12:16:30.715 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-api [108] 15.01.2018 12:16:30.718 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-jcr-commons [109] 15.01.2018 12:16:30.721 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-jcr-rmi [110] 15.01.2018 12:16:30.724 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.json [111] 15.01.2018 12:16:30.727 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.mime [112] 15.01.2018 12:16:30.730 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.threads [113] 15.01.2018 12:16:30.733 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.extensions.webconsolesecurityprovider [114] 15.01.2018 12:16:30.735 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.api [115] 15.01.2018 12:16:30.738 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.base [116] 15.01.2018 12:16:30.741 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.jcr-wrapper [117] 15.01.2018 12:16:30.744 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.registration [118] 15.01.2018 12:16:30.747 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.repoinit [119] 15.01.2018 12:16:30.750 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.repoinit.parser [120] 15.01.2018 12:16:30.753 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.installer.factory.packages [121] 15.01.2018 12:16:30.755 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-jcrclustersupport [122] 15.01.2018 12:16:30.758 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-spi [123] 15.01.2018 12:16:30.761 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-spi-commons [124] 15.01.2018 12:16:30.764 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.vault [125] 15.01.2018 12:16:30.767 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.installer.provider.jcr [126] 15.01.2018 12:16:30.770 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.contentloader [127] 15.01.2018 12:16:30.773 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.workflow.core [128] 15.01.2018 12:16:30.776 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.osgi.wrapper.commons-httpclient [129] 15.01.2018 12:16:30.778 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.adapter [130] 15.01.2018 12:16:30.781 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.auth.core [131] 15.01.2018 12:16:30.784 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.classloader [132] 15.01.2018 12:16:30.787 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.scheduler [133] 15.01.2018 12:16:30.790 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.discovery.base [134] 15.01.2018 12:16:30.793 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.discovery.commons [135] 15.01.2018 12:16:30.796 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.discovery.oak [136] 15.01.2018 12:16:30.799 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.discovery.support [137] 15.01.2018 12:16:30.801 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.featureflags [138] 15.01.2018 12:16:30.804 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.resource [139] 15.01.2018 12:16:30.807 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.resourceaccesssecurity [140] 15.01.2018 12:16:30.810 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.resourceresolver [141] 15.01.2018 12:16:30.813 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.api [142] 15.01.2018 12:16:30.816 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-compat-codeupgrade [143] 15.01.2018 12:16:30.819 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-upgrades-executor [144] 15.01.2018 12:16:30.823 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.pre-upgrade-tasks [145] 15.01.2018 12:16:30.826 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.startupfilter.disabler [146] 15.01.2018 12:16:30.830 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-dps [147] 15.01.2018 12:16:30.833 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-index-builder [148] 15.01.2018 12:16:30.836 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-phonegap-build [149] 15.01.2018 12:16:30.839 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-ui [150] 15.01.2018 12:16:30.843 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.maintenance.oak [151] 15.01.2018 12:16:30.846 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.oauth.server [152] 15.01.2018 12:16:30.849 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.oauth2.authzserver [153] 15.01.2018 12:16:30.852 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.oauth2.common [154] 15.01.2018 12:16:30.855 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.oauth2.resourceserver [155] 15.01.2018 12:16:30.858 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.client [156] 15.01.2018 12:16:30.861 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.core [157] 15.01.2018 12:16:30.864 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.extensions-media [158] 15.01.2018 12:16:30.867 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.extensions-opensearch [159] 15.01.2018 12:16:30.870 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.i18n [160] 15.01.2018 12:16:30.873 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.parser [161] 15.01.2018 12:16:30.875 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.abdera.server [162] 15.01.2018 12:16:30.879 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.aemds.formsmanager.adobe-aemds-formsanddocuments-core [163] 15.01.2018 12:16:30.881 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.adobe-dam-idsprint [164] 15.01.2018 12:16:30.884 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.livecycle.formsportal-bundle [165] 15.01.2018 12:16:30.887 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.forms.common.adobe-xfaforms-common [166] 15.01.2018 12:16:30.890 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.adobe-xmp [167] 15.01.2018 12:16:30.893 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.aemds.guide.aemds-guide-core [168] 15.01.2018 12:16:30.896 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.aemds.guide.aemds-guide-core-impl [169] 15.01.2018 12:16:30.899 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.aemfd.expeditor.aemfd-expeditor-utils-bundle [170] 15.01.2018 12:16:30.902 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle afml [171] 15.01.2018 12:16:30.905 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cdn.cdn-rewriter [172] 15.01.2018 12:16:30.908 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.cocoon.cocoon-xml [173] 15.01.2018 12:16:30.911 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.editor [174] 15.01.2018 12:16:30.914 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.gson [175] 15.01.2018 12:16:30.917 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.msm.ui [176] 15.01.2018 12:16:30.920 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.projects.api [177] 15.01.2018 12:16:30.923 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.projects.core [178] 15.01.2018 12:16:30.926 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.projects.ui [179] 15.01.2018 12:16:30.929 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.projects.wcm.core [180] 15.01.2018 12:16:30.932 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.screens.com.adobe.cq.screens [181] 15.01.2018 12:16:30.935 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.screens.com.adobe.cq.screens.dcc [182] 15.01.2018 12:16:30.938 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.screens.com.adobe.cq.screens.sessions [183] 15.01.2018 12:16:30.941 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.sites.ui [184] 15.01.2018 12:16:30.944 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.com.adobe.cq.ui.commons [185] 15.01.2018 12:16:30.947 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.activitystreams [186] 15.01.2018 12:16:30.950 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.apicontroller [187] 15.01.2018 12:16:30.953 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.asset.api [188] 15.01.2018 12:16:30.956 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.asset.core [189] 15.01.2018 12:16:30.959 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-authhandler [190] 15.01.2018 12:16:30.962 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.auth.cert [191] 15.01.2018 12:16:30.965 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.auth.oauth [192] 15.01.2018 12:16:30.968 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.auth.saml [193] 15.01.2018 12:16:30.971 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.auth.sso [194] 15.01.2018 12:16:30.974 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.bundles.hc.impl [195] 15.01.2018 12:16:30.976 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.cloudsettings.core [196] 15.01.2018 12:16:30.979 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.comments [197] 15.01.2018 12:16:30.982 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.conf [198] 15.01.2018 12:16:30.985 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.conf.ui.core [199] 15.01.2018 12:16:30.988 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.confmgr [200] 15.01.2018 12:16:30.991 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.contexthub.commons [201] 15.01.2018 12:16:30.994 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.cors [202] 15.01.2018 12:16:30.996 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crx-explorer [203] 15.01.2018 12:16:30.999 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crx-packagemgr [204] 15.01.2018 12:16:31.002 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crxde-lite [205] 15.01.2018 12:16:31.005 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crypto.extension [206] 15.01.2018 12:16:31.008 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crypto.jcr [207] 15.01.2018 12:16:31.011 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.crypto.keystore [208] 15.01.2018 12:16:31.014 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.csrf [209] 15.01.2018 12:16:31.017 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.distribution.core [210] 15.01.2018 12:16:31.020 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.frags.impl [211] 15.01.2018 12:16:31.023 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.httpcache.core [212] 15.01.2018 12:16:31.027 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-i18n [213] 15.01.2018 12:16:31.030 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.jetty.ssl [214] 15.01.2018 12:16:31.033 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.logging [215] 15.01.2018 12:16:31.036 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.maintenance.core [216] 15.01.2018 12:16:31.040 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.monitoring.core [217] 15.01.2018 12:16:31.043 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.oauth.jwt [218] 15.01.2018 12:16:31.046 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.offloading.core [219] 15.01.2018 12:16:31.049 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.offloading.workflow [220] 15.01.2018 12:16:31.052 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.omnisearch.core [221] 15.01.2018 12:16:31.055 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.optout [222] 15.01.2018 12:16:31.058 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.queries [223] 15.01.2018 12:16:31.061 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.references.core [224] 15.01.2018 12:16:31.064 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-replication [225] 15.01.2018 12:16:31.067 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.replication.hc.impl [226] 15.01.2018 12:16:31.070 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.repository.checker [227] 15.01.2018 12:16:31.073 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.repository.hc.impl [228] 15.01.2018 12:16:31.076 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.requests.logging [229] 15.01.2018 12:16:31.079 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.resourceresolverhelper [230] 15.01.2018 12:16:31.082 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.resourcestatus [231] 15.01.2018 12:16:31.085 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.rest.api [232] 15.01.2018 12:16:31.088 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.rest.assets [233] 15.01.2018 12:16:31.091 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.scribe [234] 15.01.2018 12:16:31.094 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.security.installer [235] 15.01.2018 12:16:31.097 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.security.user [236] 15.01.2018 12:16:31.100 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.socialgraph [237] 15.01.2018 12:16:31.103 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.socketio [238] 15.01.2018 12:16:31.105 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.taskmanagement.api [239] 15.01.2018 12:16:31.109 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.taskmanagement.core [240] 15.01.2018 12:16:31.112 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.taskmanagement.workflow [241] 15.01.2018 12:16:31.115 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.threaddump [242] 15.01.2018 12:16:31.118 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.timeline [243] 15.01.2018 12:16:31.121 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.translation.api [244] 15.01.2018 12:16:31.125 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.translation.connector.msft.core [245] 15.01.2018 12:16:31.128 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.translation.core [246] 15.01.2018 12:16:31.131 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.ui.clientlibs [247] 15.01.2018 12:16:31.134 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.ui.clientlibs.compiler.less [248] 15.01.2018 12:16:31.137 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.ui.clientlibs.processor.gcc [249] 15.01.2018 12:16:31.140 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.ui.commons [250] 15.01.2018 12:16:31.142 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.workflow.api [251] 15.01.2018 12:16:31.145 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.granite.workflow.console [252] 15.01.2018 12:16:31.148 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-xssprotection [253] 15.01.2018 12:16:31.152 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.suitetech.nativecomm [254] 15.01.2018 12:16:31.155 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.osgi.wrapper.commons-email [255] 15.01.2018 12:16:31.158 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.osgi.wrapper.fop [256] 15.01.2018 12:16:31.161 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.commons.osgi.wrapper.simple-jndi [257] 15.01.2018 12:16:31.164 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-widgets [258] 15.01.2018 12:16:31.167 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.exec [259] 15.01.2018 12:16:31.170 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.commons-imaging [260] 15.01.2018 12:16:31.173 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.commons.math [261] 15.01.2018 12:16:31.176 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.smartcontent-core [262] 15.01.2018 12:16:31.179 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-account [263] 15.01.2018 12:16:31.182 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-activitymap-integration [264] 15.01.2018 12:16:31.185 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-address [265] 15.01.2018 12:16:31.188 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-analytics-integration [266] 15.01.2018 12:16:31.191 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-audit [267] 15.01.2018 12:16:31.194 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-chart [268] 15.01.2018 12:16:31.196 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-cloudservices-provisioning [269] 15.01.2018 12:16:31.218 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.commerce.cq-commerce-core [270] 15.01.2018 12:16:31.221 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.commerce.cq-commerce-pim [271] 15.01.2018 12:16:31.224 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-commons [272] 15.01.2018 12:16:31.227 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-compat-commons-auth [273] 15.01.2018 12:16:31.230 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-connector [274] 15.01.2018 12:16:31.233 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-content-insight [275] 15.01.2018 12:16:31.236 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-content-sync [276] 15.01.2018 12:16:31.240 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-contexthub-commons [277] 15.01.2018 12:16:31.243 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-annotation-print [278] 15.01.2018 12:16:31.246 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-api [279] 15.01.2018 12:16:31.249 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-asset-usage [280] 15.01.2018 12:16:31.252 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.dam.cq-dam-cfm-api [281] 15.01.2018 12:16:31.255 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.dam.cq-dam-cfm-impl [282] 15.01.2018 12:16:31.258 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-commons [283] 15.01.2018 12:16:31.261 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-core [284] 15.01.2018 12:16:31.265 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-entitlement [285] 15.01.2018 12:16:31.268 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-handler [286] 15.01.2018 12:16:31.271 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-indesign [287] 15.01.2018 12:16:31.274 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-dam-index-builder [288] 15.01.2018 12:16:31.277 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-dam-mac-sync [289] 15.01.2018 12:16:31.281 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-dam-mac-sync-helper [290] 15.01.2018 12:16:31.284 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-pim [291] 15.01.2018 12:16:31.286 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-rating [292] 15.01.2018 12:16:31.289 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-s7dam [293] 15.01.2018 12:16:31.292 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-scene7 [294] 15.01.2018 12:16:31.296 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-similaritysearch [295] 15.01.2018 12:16:31.299 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.dam.cq-dam-svg-handler [296] 15.01.2018 12:16:31.302 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-video [297] 15.01.2018 12:16:31.304 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-dam-word [298] 15.01.2018 12:16:31.307 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-dashboards [299] 15.01.2018 12:16:31.310 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.dam.cq-delivery-api [300] 15.01.2018 12:16:31.313 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.dam.cq-delivery-internal-api [301] 15.01.2018 12:16:31.316 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-dtm [302] 15.01.2018 12:16:31.318 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-experience-fragments [303] 15.01.2018 12:16:31.322 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-experience-fragments-social [304] 15.01.2018 12:16:31.324 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-experiencelog [305] 15.01.2018 12:16:31.327 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-gfx [306] 15.01.2018 12:16:31.330 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-healthcheck [307] 15.01.2018 12:16:31.333 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-history [308] 15.01.2018 12:16:31.335 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.inbox.cq-inbox [309] 15.01.2018 12:16:31.338 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.inbox.cq-inbox-ui [310] 15.01.2018 12:16:31.341 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-launches-api [311] 15.01.2018 12:16:31.344 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-mailer [312] 15.01.2018 12:16:31.347 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-campaign [313] 15.01.2018 12:16:31.349 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-core [314] 15.01.2018 12:16:31.352 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-emailprovider [315] 15.01.2018 12:16:31.355 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-exacttarget-integration [316] 15.01.2018 12:16:31.358 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-landingpage [317] 15.01.2018 12:16:31.361 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.mcm.cq-mcm-salesforce [318] 15.01.2018 12:16:31.364 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.media.cq-media-articles [319] 15.01.2018 12:16:31.368 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.media.cq-media-publishing-dps-fp-api [320] 15.01.2018 12:16:31.371 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.media.cq-media-publishing-dps-fp-core [321] 15.01.2018 12:16:31.374 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.media.cq-media-publishing-dps-integration [322] 15.01.2018 12:16:31.377 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-caas [323] 15.01.2018 12:16:31.380 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.mobile.cq-mobile-core [324] 15.01.2018 12:16:31.383 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-msm-api [325] 15.01.2018 12:16:31.386 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-msm-commons [326] 15.01.2018 12:16:31.388 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-msm-core [327] 15.01.2018 12:16:31.391 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-multisite-targeting [328] 15.01.2018 12:16:31.394 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-notifcation-api [329] 15.01.2018 12:16:31.397 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-notifcation-impl [330] 15.01.2018 12:16:31.400 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-personalization [331] 15.01.2018 12:16:31.403 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-polling-importer [332] 15.01.2018 12:16:31.406 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-replication-audit [333] 15.01.2018 12:16:31.409 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-reporting [334] 15.01.2018 12:16:31.412 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-rest-sites [335] 15.01.2018 12:16:31.415 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-retriever [336] 15.01.2018 12:16:31.418 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-rewriter [337] 15.01.2018 12:16:31.421 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.cq-scene7-api [338] 15.01.2018 12:16:31.424 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.dam.cq-scene7-imaging [339] 15.01.2018 12:16:31.427 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-scheduled-exporter [340] 15.01.2018 12:16:31.430 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-search [341] 15.01.2018 12:16:31.433 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-search-ext [342] 15.01.2018 12:16:31.436 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-search-suggest [343] 15.01.2018 12:16:31.439 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-searchpromote-integration [344] 15.01.2018 12:16:31.442 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-security [345] 15.01.2018 12:16:31.445 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-security-api [346] 15.01.2018 12:16:31.448 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-security-hc [347] 15.01.2018 12:16:31.451 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-activitystreams [348] 15.01.2018 12:16:31.454 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-as-provider [349] 15.01.2018 12:16:31.457 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-badging-api [350] 15.01.2018 12:16:31.460 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-badging-basic-impl [351] 15.01.2018 12:16:31.463 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-badging-impl [352] 15.01.2018 12:16:31.466 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-calendar-api [353] 15.01.2018 12:16:31.470 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-calendar-impl [354] 15.01.2018 12:16:31.473 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-commons [355] 15.01.2018 12:16:31.475 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-commons-oauth [356] 15.01.2018 12:16:31.478 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-console [357] 15.01.2018 12:16:31.481 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-content-fragments-impl [358] 15.01.2018 12:16:31.484 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-enablement-api [359] 15.01.2018 12:16:31.487 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-enablement-impl [360] 15.01.2018 12:16:31.490 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-filelibrary [361] 15.01.2018 12:16:31.493 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-forum [362] 15.01.2018 12:16:31.497 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-gamification-api [363] 15.01.2018 12:16:31.499 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-gamification-impl [364] 15.01.2018 12:16:31.502 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-graph-api [365] 15.01.2018 12:16:31.505 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-graph-impl [366] 15.01.2018 12:16:31.508 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-group [367] 15.01.2018 12:16:31.511 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-handlebars [368] 15.01.2018 12:16:31.514 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ideation-api [369] 15.01.2018 12:16:31.517 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ideation-impl [370] 15.01.2018 12:16:31.520 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-jcr-provider [371] 15.01.2018 12:16:31.523 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-jcr-provider-common [372] 15.01.2018 12:16:31.526 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-journal [373] 15.01.2018 12:16:31.529 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-livefyre [374] 15.01.2018 12:16:31.532 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-members-api [375] 15.01.2018 12:16:31.535 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-members-impl [376] 15.01.2018 12:16:31.537 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-messaging-api [377] 15.01.2018 12:16:31.540 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-messaging-impl [378] 15.01.2018 12:16:31.543 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-moderation [379] 15.01.2018 12:16:31.546 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ms-provider [380] 15.01.2018 12:16:31.549 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-notifications-api [381] 15.01.2018 12:16:31.552 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-notifications-channels-web [382] 15.01.2018 12:16:31.555 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-notifications-impl [383] 15.01.2018 12:16:31.558 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-qna [384] 15.01.2018 12:16:31.561 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-rdb-provider [385] 15.01.2018 12:16:31.563 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-reporting-management [386] 15.01.2018 12:16:31.566 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-review [387] 15.01.2018 12:16:31.569 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-scf-api [388] 15.01.2018 12:16:31.572 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-scf-impl [389] 15.01.2018 12:16:31.575 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-scoring-api [390] 15.01.2018 12:16:31.578 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-scoring-basic-impl [391] 15.01.2018 12:16:31.582 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-scoring-impl [392] 15.01.2018 12:16:31.584 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-serviceusers-api [393] 15.01.2018 12:16:31.587 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-serviceusers-impl [394] 15.01.2018 12:16:31.590 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-srp-api [395] 15.01.2018 12:16:31.593 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-srp-impl [396] 15.01.2018 12:16:31.596 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-sync [397] 15.01.2018 12:16:31.599 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-tally [398] 15.01.2018 12:16:31.602 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-translation [399] 15.01.2018 12:16:31.605 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ugc-search-collections [400] 15.01.2018 12:16:31.607 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ugcbase-api [401] 15.01.2018 12:16:31.610 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.social.cq-social-ugcbase-impl [402] 15.01.2018 12:16:31.613 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-socialmedia-integration [403] 15.01.2018 12:16:31.616 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-spellchecker [404] 15.01.2018 12:16:31.619 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-statistics [405] 15.01.2018 12:16:31.622 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-tagging [406] 15.01.2018 12:16:31.625 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-target-integration [407] 15.01.2018 12:16:31.627 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.cq-targetrecommendations [408] 15.01.2018 12:16:31.630 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-api [409] 15.01.2018 12:16:31.633 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-commons [410] 15.01.2018 12:16:31.636 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-content-sync [411] 15.01.2018 12:16:31.639 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-core [412] 15.01.2018 12:16:31.642 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-designimporter [413] 15.01.2018 12:16:31.645 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-emulator [414] 15.01.2018 12:16:31.647 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-foundation [415] 15.01.2018 12:16:31.650 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.wcm.cq-wcm-launches-core [416] 15.01.2018 12:16:31.653 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-mobile-api [417] 15.01.2018 12:16:31.656 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-mobile-core [418] 15.01.2018 12:16:31.659 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-mobile-qrcode [419] 15.01.2018 12:16:31.662 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-notification [420] 15.01.2018 12:16:31.664 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-offline [421] 15.01.2018 12:16:31.667 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-resource-details [422] 15.01.2018 12:16:31.670 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-scripting-support [423] 15.01.2018 12:16:31.673 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.sightly.cq-wcm-sightly-extension [424] 15.01.2018 12:16:31.676 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-taglib [425] 15.01.2018 12:16:31.679 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-translation [426] 15.01.2018 12:16:31.681 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-undo [427] 15.01.2018 12:16:31.684 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-webservice-support [428] 15.01.2018 12:16:31.687 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-workflow [429] 15.01.2018 12:16:31.690 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.wcm.cq-wcm-workflow-api [430] 15.01.2018 12:16:31.693 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.cq-widgets-ext [431] 15.01.2018 12:16:31.696 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.workflow.cq-workflow-api [432] 15.01.2018 12:16:31.698 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.workflow.cq-workflow-console [433] 15.01.2018 12:16:31.701 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.workflow.cq-workflow-impl [434] 15.01.2018 12:16:31.704 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.crx.sling.crx-auth-token [435] 15.01.2018 12:16:31.707 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.day.cq.dam.dam-webdav-support [436] 15.01.2018 12:16:31.710 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-diff [437] 15.01.2018 12:16:31.713 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-durbo [438] 15.01.2018 12:16:31.716 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-gfx [439] 15.01.2018 12:16:31.719 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-io [440] 15.01.2018 12:16:31.721 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-jrawio [441] 15.01.2018 12:16:31.724 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-jstl [442] 15.01.2018 12:16:31.727 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day-commons-misc [443] 15.01.2018 12:16:31.730 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day.commons.datasource.jdbcpool [444] 15.01.2018 12:16:31.733 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle day.commons.datasource.poolservice [445] 15.01.2018 12:16:31.736 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.xmp.worker.files.host [446] 15.01.2018 12:16:31.739 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle forms-foundation-bundle [452] 15.01.2018 12:16:31.741 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.geronimo.specs.geronimo-atinject_1.0_spec [453] 15.01.2018 12:16:31.744 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.jackrabbit.jackrabbit-webdav [454] 15.01.2018 12:16:31.747 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.fasterxml.jackson.core.jackson-annotations [455] 15.01.2018 12:16:31.750 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.fasterxml.jackson.core.jackson-core [456] 15.01.2018 12:16:31.753 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.fasterxml.jackson.core.jackson-databind [457] 15.01.2018 12:16:31.756 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle javax.mail [458] 15.01.2018 12:16:31.759 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.cq.myspell [459] 15.01.2018 12:16:31.761 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.opennlp.tools [460] 15.01.2018 12:16:31.764 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.commons.encodedtoken [461] 15.01.2018 12:16:31.767 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.commons.json [462] 15.01.2018 12:16:31.770 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.jose.jws [463] 15.01.2018 12:16:31.773 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.oltu.oauth2.jwt [464] 15.01.2018 12:16:31.776 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.atom.taglib [465] 15.01.2018 12:16:31.779 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.bundleresource.impl [466] 15.01.2018 12:16:31.781 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.caconfig.api [467] 15.01.2018 12:16:31.784 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.caconfig.impl [468] 15.01.2018 12:16:31.787 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.caconfig.spi [469] 15.01.2018 12:16:31.790 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.compiler [470] 15.01.2018 12:16:31.793 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.contentdetection [471] 15.01.2018 12:16:31.796 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.fsclassloader [472] 15.01.2018 12:16:31.799 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.commons.html [473] 15.01.2018 12:16:31.802 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.distribution.api [474] 15.01.2018 12:16:31.804 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.distribution.core [475] 15.01.2018 12:16:31.807 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.engine [476] 15.01.2018 12:16:31.810 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.event [477] 15.01.2018 12:16:31.813 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.event.dea [478] 15.01.2018 12:16:31.816 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.hapi [479] 15.01.2018 12:16:31.819 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.hc.core [480] 15.01.2018 12:16:31.822 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.hc.webconsole [481] 15.01.2018 12:16:31.824 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.i18n [482] 15.01.2018 12:16:31.827 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.davex [483] 15.01.2018 12:16:31.830 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.resourcesecurity [484] 15.01.2018 12:16:31.833 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jcr.webdav [485] 15.01.2018 12:16:31.836 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.jmx.provider [486] 15.01.2018 12:16:31.839 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.models.api [487] 15.01.2018 12:16:31.841 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.models.impl [488] 15.01.2018 12:16:31.844 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.models.jacksonexporter [489] 15.01.2018 12:16:31.847 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.resource.inventory [490] 15.01.2018 12:16:31.850 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.resourcecollection [491] 15.01.2018 12:16:31.853 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.resourcemerger [492] 15.01.2018 12:16:31.855 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.rewriter [493] 15.01.2018 12:16:31.858 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.core [494] 15.01.2018 12:16:31.861 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.java [495] 15.01.2018 12:16:31.864 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.javascript [496] 15.01.2018 12:16:31.867 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.jsp [497] 15.01.2018 12:16:31.870 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.jsp.taglib [498] 15.01.2018 12:16:31.873 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.jst [499] 15.01.2018 12:16:31.875 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.sightly [500] 15.01.2018 12:16:31.878 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.sightly.compiler [501] 15.01.2018 12:16:31.881 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.sightly.compiler.java [502] 15.01.2018 12:16:31.884 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.sightly.js.provider [503] 15.01.2018 12:16:31.887 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.scripting.sightly.models.provider [504] 15.01.2018 12:16:31.890 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.servlets.compat [505] 15.01.2018 12:16:31.893 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.servlets.get [506] 15.01.2018 12:16:31.896 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.servlets.post [507] 15.01.2018 12:16:31.899 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.servlets.resolver [508] 15.01.2018 12:16:31.902 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.tenant [509] 15.01.2018 12:16:31.905 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sling.tracer [510] 15.01.2018 12:16:31.908 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle PDFServices_manipulations [511] 15.01.2018 12:16:31.911 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle PDFServices_security [512] 15.01.2018 12:16:31.914 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle org.apache.sanselan.sanselan [513] 15.01.2018 12:16:31.917 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle com.adobe.reef.siren.core [514] 15.01.2018 12:16:31.919 *INFO* [OsgiInstallerImpl] org.apache.sling.audit.osgi.installer Started bundle xtg [515] 15.01.2018 12:16:31.981 *INFO* [FelixStartLevel] com.day.cq.cq-compat-configupdate BundleEvent RESOLVED 15.01.2018 12:16:31.981 *INFO* [FelixStartLevel] com.day.cq.cq-compat-configupdate BundleEvent STARTING 15.01.2018 12:16:31.983 *INFO* [FelixStartLevel] com.day.cq.cq-compat-configupdate BundleEvent STARTED 15.01.2018 12:16:31.987 *INFO* [FelixStartLevel] org.apache.aries.jmx.api BundleEvent RESOLVED 15.01.2018 12:16:31.987 *INFO* [FelixStartLevel] org.apache.aries.jmx.api BundleEvent STARTING 15.01.2018 12:16:31.987 *INFO* [FelixStartLevel] org.apache.aries.jmx.api BundleEvent STARTED 15.01.2018 12:16:31.991 *INFO* [FelixStartLevel] org.apache.aries.jmx.core BundleEvent RESOLVED 15.01.2018 12:16:31.992 *INFO* [FelixStartLevel] org.apache.aries.jmx.core BundleEvent STARTING 15.01.2018 12:16:31.993 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Service [org.apache.aries.jmx.framework.StateConfig,34, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:31.995 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Starting JMX OSGi agent 15.01.2018 12:16:32.009 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering MBean with ObjectName [osgi.compendium:service=cm,version=1.3,framework=org.apache.felix.framework,uuid=602a337 a-c1fb-4ce8-a377-300c6438df0c] for service with service.id [11] 15.01.2018 12:16:32.010 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.framework.ServiceStateMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.core:type=serviceState,version=1.7,framework=org.apache.felix.framework,uuid=602a337 a-c1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.011 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.framework.FrameworkMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.core:type=framework,version=1.7,framework=org.apache.felix.framework,uuid=602a337a-c 1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.012 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.framework.wiring.BundleWiringStateMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.core:type=wiringState,version=1.1,framework=org.apache.felix.framework,uuid=602a337a -c1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.012 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.framework.PackageStateMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.core:type=packageState,version=1.5,framework=org.apache.felix.framework,uuid=602a337 a-c1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.012 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.framework.BundleStateMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.core:type=bundleState,version=1.7,framework=org.apache.felix.framework,uuid=602a337a -c1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.012 *INFO* [FelixStartLevel] org.apache.aries.jmx.core Registering org.osgi.jmx.service.cm.ConfigurationAdminMBean to MBeanServer com.sun.jmx.mbeanserver.JmxMBeanServer@6d78f375 with name osgi.compendium:service=cm,version=1.3,framework=org.apache.felix.framework,uuid=602a337a -c1fb-4ce8-a377-300c6438df0c 15.01.2018 12:16:32.012 *INFO* [FelixStartLevel] org.apache.aries.jmx.core BundleEvent STARTED 15.01.2018 12:16:32.016 *INFO* [FelixStartLevel] org.apache.aries.jmx.whiteboard BundleEvent RESOLVED 15.01.2018 12:16:32.016 *INFO* [FelixStartLevel] org.apache.aries.jmx.whiteboard BundleEvent STARTING 15.01.2018 12:16:32.020 *INFO* [FelixStartLevel] org.apache.aries.jmx.whiteboard BundleEvent STARTED 15.01.2018 12:16:32.020 *INFO* [FelixStartLevel] org.apache.aries.transaction.manager BundleEvent STARTING 15.01.2018 12:16:32.028 *INFO* [FelixStartLevel] org.apache.aries.transaction.manager Service [35, [org.apache.aries.transaction.AriesTransactionManager, javax.transaction.TransactionManager, javax.transaction.TransactionSynchronizationRegistry, javax.transaction.UserTransaction, org.apache.geronimo.transaction.manager.RecoverableTransactionManager]] ServiceEvent REGISTERED 15.01.2018 12:16:32.029 *INFO* [FelixStartLevel] org.apache.aries.transaction.manager Service [org.apache.aries.transaction,36, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:32.029 *INFO* [FelixStartLevel] org.apache.aries.transaction.manager BundleEvent STARTED 15.01.2018 12:16:32.029 *INFO* [FelixStartLevel] org.apache.sling.discovery.api BundleEvent STARTING 15.01.2018 12:16:32.029 *INFO* [FelixStartLevel] org.apache.sling.discovery.api BundleEvent STARTED 15.01.2018 12:16:32.034 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.aries.transaction])] org.apache.aries.transaction.manager Service [35, [org.apache.aries.transaction.AriesTransactionManager, javax.transaction.TransactionManager, javax.transaction.TransactionSynchronizationRegistry, javax.transaction.UserTransaction, org.apache.geronimo.transaction.manager.RecoverableTransactionManager]] ServiceEvent UNREGISTERING 15.01.2018 12:16:32.035 *INFO* [FelixStartLevel] org.apache.sling.provisioning.model BundleEvent RESOLVED 15.01.2018 12:16:32.035 *INFO* [FelixStartLevel] org.apache.sling.provisioning.model BundleEvent STARTING 15.01.2018 12:16:32.036 *INFO* [FelixStartLevel] org.apache.sling.provisioning.model BundleEvent STARTED 15.01.2018 12:16:32.036 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.aries.transaction])] org.apache.aries.transaction.manager Service [37, [org.apache.aries.transaction.AriesTransactionManager, javax.transaction.TransactionManager, javax.transaction.TransactionSynchronizationRegistry, javax.transaction.UserTransaction, org.apache.geronimo.transaction.manager.RecoverableTransactionManager]] ServiceEvent REGISTERED 15.01.2018 12:16:32.494 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 3 15.01.2018 12:16:32.900 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 3 15.01.2018 12:16:34.495 *INFO* [FelixStartLevel] org.apache.felix.eventadmin BundleEvent STARTING 15.01.2018 12:16:34.520 *INFO* [FelixStartLevel] org.apache.felix.eventadmin Service [38, [org.osgi.service.event.EventAdmin]] ServiceEvent REGISTERED 15.01.2018 12:16:34.525 *INFO* [FelixStartLevel] org.apache.felix.eventadmin Service [org.apache.felix.eventadmin.impl.EventAdmin,39, [org.osgi.service.cm.ManagedService, org.osgi.service.metatype.MetaTypeProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:34.525 *INFO* [FelixStartLevel] org.apache.felix.eventadmin BundleEvent STARTED 15.01.2018 12:16:34.525 *INFO* [FelixStartLevel] org.apache.felix.metatype BundleEvent STARTING 15.01.2018 12:16:34.536 *INFO* [FelixStartLevel] org.apache.felix.metatype Service [org.apache.felix.metatype.MetaTypeService,40, [org.osgi.service.metatype.MetaTypeService]] ServiceEvent REGISTERED 15.01.2018 12:16:34.536 *INFO* [FelixStartLevel] org.apache.felix.metatype BundleEvent STARTED 15.01.2018 12:16:34.536 *INFO* [FelixStartLevel] org.apache.felix.scr BundleEvent STARTING 15.01.2018 12:16:34.546 *INFO* [FelixStartLevel] org.apache.felix.scr Service [41, [org.osgi.service.component.runtime.ServiceComponentRuntime]] ServiceEvent REGISTERED 15.01.2018 12:16:34.567 *INFO* [FelixStartLevel] org.apache.felix.configadmin Service [Declarative Services Configuration Support Listener,42, [org.osgi.service.cm.ConfigurationListener]] ServiceEvent REGISTERED 15.01.2018 12:16:34.588 *INFO* [FelixStartLevel] com.adobe.cq.cq-deserialization-firewall Service [com.adobe.cq.deserfw.impl.healthcheck.DeserializationAgentVMClassCheck,44, [org.apache.sling.hc.api.HealthCheck]] ServiceEvent REGISTERED 15.01.2018 12:16:34.588 *INFO* [FelixStartLevel] com.adobe.cq.cq-deserialization-firewall Service [com.adobe.cq.deserfw.impl.healthcheck.DeserializationAgentLoadedCheck,45, [org.apache.sling.hc.api.HealthCheck]] ServiceEvent REGISTERED 15.01.2018 12:16:34.589 *INFO* [FelixStartLevel] com.adobe.cq.cq-deserialization-firewall Service [com.adobe.cq.deserfw.impl.healthcheck.DeserializationAgentFunctionalCheck,46, [org.apache.sling.hc.api.HealthCheck]] ServiceEvent REGISTERED 15.01.2018 12:16:34.589 *INFO* [FelixStartLevel] com.adobe.cq.cq-deserialization-firewall Service [com.adobe.cq.deserfw.impl.DeserializationFirewallImpl,43, [com.adobe.cq.deserfw.impl.intapi.DeserializationFirewallStatus]] ServiceEvent REGISTERED 15.01.2018 12:16:34.600 *INFO* [FelixStartLevel] com.adobe.cq.deserfw.impl.DeserializationFirewallImpl Selected agent jar file D:\Software\AEM-RDB\crx-quickstart\opt\notsoserial\notsoserial.jar 15.01.2018 12:16:34.601 *INFO* [FelixStartLevel] com.adobe.cq.deserfw.api.AttachAPIResolver IBM Attach API not found. 15.01.2018 12:16:34.601 *ERROR* [FelixStartLevel] com.adobe.cq.deserfw.impl.DeserializationFirewallImpl Unable to load Attach API. Unable to dynamically load deserialization protection agent. This usually happens when running a JRE (instead of a JDK) or a JVM that doesn't provide the Attach API. Please review the AEM Java Deserialization Firewall documentation for how to load the deserialization agent via JVM command line arguments. 15.01.2018 12:16:34.604 *INFO* [FelixStartLevel] org.apache.felix.scr Service [SCR Gogo Shell Support,47, [org.apache.felix.scr.impl.ScrGogoCommand]] ServiceEvent REGISTERED 15.01.2018 12:16:34.604 *INFO* [FelixStartLevel] org.apache.felix.scr Service [org.apache.felix.scr.ScrService,48, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:34.605 *INFO* [FelixStartLevel] org.apache.felix.scr BundleEvent STARTED 15.01.2018 12:16:34.661 *INFO* [FelixStartLevel] com.adobe.granite.joda-time BundleEvent RESOLVED 15.01.2018 12:16:34.661 *INFO* [FelixStartLevel] com.adobe.granite.joda-time BundleEvent STARTING 15.01.2018 12:16:34.661 *INFO* [FelixStartLevel] com.adobe.granite.joda-time BundleEvent STARTED 15.01.2018 12:16:34.670 *INFO* [FelixStartLevel] org.apache.commons.fileupload BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] org.apache.sling.scripting.jsp BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] org.apache.sling.commons.compiler BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] com.day.cq.cq-xssprotection BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] org.apache.sling.jcr.api BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] com.adobe.granite.webconsole.plugins BundleEvent RESOLVED 15.01.2018 12:16:34.671 *INFO* [FelixStartLevel] org.apache.felix.webconsole BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] javax.mail BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] com.adobe.granite.bundles.json BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] org.apache.commons.codec BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] com.day.commons.osgi.wrapper.commons-httpclient BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] org.apache.sling.commons.classloader BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] org.apache.commons.collections BundleEvent RESOLVED 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] com.adobe.granite.webconsole.plugins BundleEvent STARTING 15.01.2018 12:16:34.672 *INFO* [FelixStartLevel] com.adobe.granite.webconsole.plugins BundleEvent STARTED 15.01.2018 12:16:34.675 *INFO* [FelixStartLevel] com.adobe.granite.webconsole.plugins Service [com.adobe.granite.webconsole.plugins.impl.ProfilerPlugin,49, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.676 *INFO* [FelixStartLevel] org.apache.commons.fileupload BundleEvent STARTING 15.01.2018 12:16:34.676 *INFO* [FelixStartLevel] org.apache.commons.fileupload BundleEvent STARTED 15.01.2018 12:16:34.679 *INFO* [FelixStartLevel] org.apache.commons.lang3 BundleEvent RESOLVED 15.01.2018 12:16:34.679 *INFO* [FelixStartLevel] org.apache.commons.lang3 BundleEvent STARTING 15.01.2018 12:16:34.679 *INFO* [FelixStartLevel] org.apache.commons.lang3 BundleEvent STARTED 15.01.2018 12:16:34.786 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpclient BundleEvent RESOLVED 15.01.2018 12:16:34.786 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpcore BundleEvent RESOLVED 15.01.2018 12:16:34.786 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpclient BundleEvent STARTING 15.01.2018 12:16:34.788 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpclient Service [org.apache.http.proxyconfigurator,50, [org.osgi.service.cm.ManagedServiceFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpclient Service [org.apache.http.proxyconfigurator,51, [org.apache.http.osgi.services.HttpClientBuilderFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpclient BundleEvent STARTED 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpcore BundleEvent STARTING 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] org.apache.httpcomponents.httpcore BundleEvent STARTED 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] com.adobe.granite.bundles.json BundleEvent STARTING 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] com.adobe.granite.bundles.json BundleEvent STARTED 15.01.2018 12:16:34.790 *INFO* [FelixStartLevel] org.apache.felix.http.jetty BundleEvent STARTING 15.01.2018 12:16:34.804 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [Metatype provider for Jetty Http Service,52, [org.osgi.service.metatype.MetaTypeProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:34.814 *INFO* [FelixStartLevel] org.eclipse.jetty.util.log Logging initialized @39615ms 15.01.2018 12:16:34.839 *INFO* [FelixStartLevel] org.eclipse.jetty.server.Server jetty-9.2.19.v20160908 15.01.2018 12:16:34.859 *INFO* [FelixStartLevel] org.eclipse.jetty.server.handler.ContextHandler Started o.e.j.s.ServletContextHandler@6e32a3f0{/,null,AVAILABLE} 15.01.2018 12:16:34.859 *INFO* [FelixStartLevel] org.eclipse.jetty.server.Server Started @39660ms 15.01.2018 12:16:34.875 *INFO* [FelixStartLevel] org.eclipse.jetty.server.ServerConnector Started ServerConnector@753b255c{HTTP/1.1}{0.0.0.0:4502} 15.01.2018 12:16:34.876 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Started Jetty 9.2.19.v20160908 at port(s) HTTP:4502 on context path / [minThreads=8,maxThreads=200,acceptors=1,selectors=2] 15.01.2018 12:16:34.916 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [53, [org.osgi.service.http.HttpService, org.apache.felix.http.api.ExtHttpService]] ServiceEvent REGISTERED 15.01.2018 12:16:34.916 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [54, [org.osgi.service.http.runtime.HttpServiceRuntime]] ServiceEvent REGISTERED 15.01.2018 12:16:34.918 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [55, [org.osgi.service.http.context.ServletContextHelper]] ServiceEvent REGISTERED 15.01.2018 12:16:34.923 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [HTTP Service Web Console Plugin,56, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.923 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [org.apache.felix.http,57, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:34.925 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [Load Balancer Customizer Factory for Jetty Http Service,58, [org.apache.felix.http.jetty.LoadBalancerCustomizerFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:34.926 *INFO* [FelixStartLevel] org.apache.felix.http.jetty Service [org.apache.felix.http,59, [org.osgi.service.cm.ManagedServiceFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:34.926 *INFO* [FelixStartLevel] org.apache.felix.http.jetty BundleEvent STARTED 15.01.2018 12:16:34.926 *INFO* [FelixStartLevel] org.apache.felix.http.servlet-api BundleEvent STARTING 15.01.2018 12:16:34.926 *INFO* [FelixStartLevel] org.apache.felix.http.servlet-api BundleEvent STARTED 15.01.2018 12:16:34.930 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [53, [org.osgi.service.http.HttpService, org.apache.felix.http.api.ExtHttpService]] ServiceEvent UNREGISTERING 15.01.2018 12:16:34.930 *INFO* [FelixStartLevel] org.apache.felix.http.whiteboard BundleEvent RESOLVED 15.01.2018 12:16:34.931 *INFO* [FelixStartLevel] org.apache.felix.http.whiteboard BundleEvent STARTING 15.01.2018 12:16:34.932 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [HTTP Service Web Console Plugin,56, [javax.servlet.Servlet]] ServiceEvent UNREGISTERING 15.01.2018 12:16:34.934 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [55, [org.osgi.service.http.context.ServletContextHelper]] ServiceEvent UNREGISTERING 15.01.2018 12:16:34.934 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [54, [org.osgi.service.http.runtime.HttpServiceRuntime]] ServiceEvent UNREGISTERING 15.01.2018 12:16:34.937 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.ServerConnector Stopped ServerConnector@753b255c{HTTP/1.1}{0.0.0.0:4502} 15.01.2018 12:16:34.938 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.handler.ContextHandler Stopped o.e.j.s.ServletContextHandler@6e32a3f0{/,null,UNAVAILABLE} 15.01.2018 12:16:34.938 *INFO* [FelixStartLevel] org.apache.felix.http.whiteboard Service [Felix Http Whiteboard WebConsole Plugin and Configuration Printer,60, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.939 *INFO* [FelixStartLevel] org.apache.felix.http.whiteboard Http service whiteboard started 15.01.2018 12:16:34.939 *INFO* [FelixStartLevel] org.apache.felix.http.whiteboard BundleEvent STARTED 15.01.2018 12:16:34.940 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Stopped Jetty. 15.01.2018 12:16:34.940 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.Server jetty-9.2.19.v20160908 15.01.2018 12:16:34.942 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.handler.ContextHandler Started o.e.j.s.ServletContextHandler@9ffecd2{/,null,AVAILABLE} 15.01.2018 12:16:34.942 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.Server Started @39743ms 15.01.2018 12:16:34.944 *INFO* [FelixStartLevel] org.apache.felix.inventory BundleEvent RESOLVED 15.01.2018 12:16:34.944 *INFO* [FelixStartLevel] org.apache.felix.inventory BundleEvent STARTING 15.01.2018 12:16:34.945 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.eclipse.jetty.server.ServerConnector Started ServerConnector@5a14609f{HTTP/1.1}{0.0.0.0:4502} 15.01.2018 12:16:34.945 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Started Jetty 9.2.19.v20160908 at port(s) HTTP:4502 on context path / [minThreads=8,maxThreads=200,acceptors=1,selectors=2] 15.01.2018 12:16:34.951 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [61, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.951 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [62, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.952 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [63, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.952 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [64, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.958 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [65, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.959 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [66, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.959 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [67, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.960 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [68, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.960 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [69, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.961 *INFO* [FelixStartLevel] org.apache.felix.inventory BundleEvent STARTED 15.01.2018 12:16:34.964 *INFO* [FelixStartLevel] org.apache.felix.org.apache.felix.threaddump BundleEvent RESOLVED 15.01.2018 12:16:34.965 *INFO* [FelixStartLevel] org.apache.felix.org.apache.felix.threaddump BundleEvent STARTING 15.01.2018 12:16:34.967 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [71, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.967 *INFO* [FelixStartLevel] org.apache.felix.org.apache.felix.threaddump Service [Apache Felix Thread Dump,70, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.967 *INFO* [FelixStartLevel] org.apache.felix.org.apache.felix.threaddump BundleEvent STARTED 15.01.2018 12:16:34.967 *INFO* [FelixStartLevel] org.apache.felix.webconsole BundleEvent STARTING 15.01.2018 12:16:34.975 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [74, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.975 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [73, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.975 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [72, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.977 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [75, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.978 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [78, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.978 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [77, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.978 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [76, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.979 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [79, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.981 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [82, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.981 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [81, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.981 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [80, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.982 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [85, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.982 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [84, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.982 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [83, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.984 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [88, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:34.984 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [87, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.984 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [86, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:34.994 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.whiteboard Detected extended HttpService. Filters enabled. 15.01.2018 12:16:34.995 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [89, [org.osgi.service.http.HttpService, org.apache.felix.http.api.ExtHttpService]] ServiceEvent REGISTERED 15.01.2018 12:16:34.997 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [90, [org.osgi.service.http.runtime.HttpServiceRuntime]] ServiceEvent REGISTERED 15.01.2018 12:16:34.997 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [91, [org.osgi.service.http.context.ServletContextHelper]] ServiceEvent REGISTERED 15.01.2018 12:16:35.003 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.inventory Service [95, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.004 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [97, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.004 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [96, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.004 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.inventory Service [94, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.004 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [92, [org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.004 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http])] org.apache.felix.http.jetty Service [HTTP Service Web Console Plugin,93, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.006 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [98, [org.apache.felix.webconsole.bundleinfo.BundleInfoProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:35.015 *INFO* [FelixStartLevel] org.apache.felix.webconsole Service [org.apache.felix.webconsole.internal.servlet.OsgiManager,99, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:35.018 *INFO* [FelixStartLevel] org.apache.felix.webconsole BundleEvent STARTED 15.01.2018 12:16:35.022 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds BundleEvent RESOLVED 15.01.2018 12:16:35.022 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds BundleEvent STARTING 15.01.2018 12:16:35.025 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds Service [100, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.026 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [102, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.026 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds Service [101, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.027 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds Service [103, [org.apache.felix.webconsole.bundleinfo.BundleInfoProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:35.027 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.ds BundleEvent STARTED 15.01.2018 12:16:35.030 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event BundleEvent RESOLVED 15.01.2018 12:16:35.030 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event BundleEvent STARTING 15.01.2018 12:16:35.037 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event Service [Event handler for the Apache Felix Web Console,104, [org.osgi.service.event.EventHandler]] ServiceEvent REGISTERED 15.01.2018 12:16:35.039 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event Service [org.apache.felix.webconsole.plugins.event.internal.PluginServlet,105, [org.osgi.service.cm.ManagedService, org.osgi.service.cm.ConfigurationListener]] ServiceEvent REGISTERED 15.01.2018 12:16:35.040 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event Service [Event Plugin for the Apache Felix Web Console,106, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.040 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.event BundleEvent STARTED 15.01.2018 12:16:35.043 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage BundleEvent RESOLVED 15.01.2018 12:16:35.043 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage BundleEvent STARTING 15.01.2018 12:16:35.047 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Storing Memory Dumps in D:\Software\AEM-RDB\crx-quickstart\launchpad\felix\bundle47\data\dumps 15.01.2018 12:16:35.047 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Setting Automatic Memory Dump Threshold to 0% for pools [Code Cache, Compressed Class Space, Metaspace, PS Old Gen] 15.01.2018 12:16:35.047 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Automatic Memory Dump cannot be set for pools [PS Eden Space, PS Survivor Space] 15.01.2018 12:16:35.048 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Setting Automatic Memory Dump Interval to 21600 seconds 15.01.2018 12:16:35.048 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Service [Memory Usage (org.apache.felix.shell.Command),107, [org.apache.felix.shell.Command]] ServiceEvent REGISTERED 15.01.2018 12:16:35.054 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Service [Memory Usage (javax.servlet.Servlet),108, [javax.servlet.Servlet, org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.055 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage Service [org.apache.felix.webconsole.plugins.memoryusage.internal.MemoryUsageConfigurator,109, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:35.058 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.memoryusage BundleEvent STARTED 15.01.2018 12:16:35.058 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.webconsole.plugins.memoryusage.internal.MemoryUsageConfigurator])] org.apache.felix.webconsole.plugins.memoryusage Setting Automatic Memory Dump Threshold to 0% for pools [Code Cache, Compressed Class Space, Metaspace, PS Old Gen] 15.01.2018 12:16:35.058 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.webconsole.plugins.memoryusage.internal.MemoryUsageConfigurator])] org.apache.felix.webconsole.plugins.memoryusage Automatic Memory Dump cannot be set for pools [PS Eden Space, PS Survivor Space] 15.01.2018 12:16:35.058 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.webconsole.plugins.memoryusage.internal.MemoryUsageConfigurator])] org.apache.felix.webconsole.plugins.memoryusage Setting Automatic Memory Dump Interval to 21600 seconds 15.01.2018 12:16:35.058 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.webconsole.plugins.memoryusage.internal.MemoryUsageConfigurator])] org.apache.felix.webconsole.plugins.memoryusage Storing Memory Dumps in D:\Software\AEM-RDB\crx-quickstart\launchpad\felix\bundle47\data\dumps 15.01.2018 12:16:35.061 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 5 15.01.2018 12:16:35.061 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.packageadmin BundleEvent RESOLVED 15.01.2018 12:16:35.061 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.packageadmin BundleEvent STARTING 15.01.2018 12:16:35.064 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.packageadmin Service [110, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.065 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [112, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.065 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.packageadmin Service [111, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.065 *INFO* [FelixStartLevel] org.apache.felix.webconsole.plugins.packageadmin BundleEvent STARTED 15.01.2018 12:16:35.069 *INFO* [FelixStartLevel] org.apache.sling.commons.log.webconsole BundleEvent RESOLVED 15.01.2018 12:16:35.069 *INFO* [FelixStartLevel] org.apache.sling.commons.log.webconsole BundleEvent STARTING 15.01.2018 12:16:35.071 *INFO* [FelixStartLevel] org.apache.sling.commons.log.webconsole Service [113, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.071 *INFO* [FelixStartLevel] org.apache.sling.commons.log.webconsole BundleEvent STARTED 15.01.2018 12:16:35.075 *INFO* [FelixStartLevel] org.apache.sling.installer.console BundleEvent RESOLVED 15.01.2018 12:16:35.075 *INFO* [FelixStartLevel] org.apache.sling.installer.console BundleEvent STARTING 15.01.2018 12:16:35.075 *INFO* [FelixStartLevel] org.apache.sling.installer.console BundleEvent STARTED 15.01.2018 12:16:35.080 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [116, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.080 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [115, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.080 *INFO* [FelixStartLevel] org.apache.sling.installer.console Service [org.apache.sling.installer.core.impl.console.OsgiInstallerWebConsolePlugin,114, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.087 *INFO* [FelixStartLevel] org.apache.sling.security BundleEvent RESOLVED 15.01.2018 12:16:35.087 *INFO* [FelixStartLevel] org.apache.sling.security BundleEvent STARTING 15.01.2018 12:16:35.087 *INFO* [FelixStartLevel] org.apache.sling.security BundleEvent STARTED 15.01.2018 12:16:35.090 *INFO* [FelixStartLevel] org.apache.sling.security Service [117, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:35.117 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Software Loopback Interface 1 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Realtek PCIe GBE Family Controller 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IPv6) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:VirtualBox Host-Only Ethernet Adapter 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (Network Monitor) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (SSTP) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IP) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (PPPOE) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Microsoft Wi-Fi Direct Virtual Adapter 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Teredo Tunneling Pseudo-Interface 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IKEv2) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (L2TP) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (PPTP) 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Realtek RTL8188EU Wireless LAN 802.11n USB 2.0 Network Adapter 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Microsoft Wi-Fi Direct Virtual Adapter #3 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Microsoft Wi-Fi Direct Virtual Adapter #2 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Microsoft Kernel Debug Network Adapter 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Realtek PCIe GBE Family Controller-WFP Native MAC Layer LightWeight Filter-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Realtek PCIe GBE Family Controller-QoS Packet Scheduler-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:Realtek PCIe GBE Family Controller-WFP 802.3 MAC Layer LightWeight Filter-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IP)-WFP Native MAC Layer LightWeight Filter-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IP)-QoS Packet Scheduler-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IPv6)-WFP Native MAC Layer LightWeight Filter-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (IPv6)-QoS Packet Scheduler-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (Network Monitor)-WFP Native MAC Layer LightWeight Filter-0000 15.01.2018 12:16:35.118 *INFO* [FelixStartLevel] org.apache.sling.security.impl.ReferrerFilter Adding Allowed referers for Interface:WAN Miniport (Network Monitor)-QoS Packet Scheduler-0000 15.01.2018 12:16:35.120 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [121, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:35.121 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [120, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.121 *INFO* [FelixStartLevel] org.apache.sling.security Service [Apache Sling Referrer Filter Configuration Printer,119, [java.lang.Object]] ServiceEvent REGISTERED 15.01.2018 12:16:35.122 *INFO* [FelixStartLevel] org.apache.sling.security Service [org.apache.sling.security.impl.ReferrerFilter,118, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.122 *INFO* [FelixStartLevel] org.apache.sling.security Service [org.apache.sling.security.impl.ContentDispositionFilter,122, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.178 *INFO* [FelixStartLevel] org.apache.sling.startupfilter BundleEvent RESOLVED 15.01.2018 12:16:35.179 *INFO* [FelixStartLevel] org.apache.sling.startupfilter BundleEvent STARTING 15.01.2018 12:16:35.179 *INFO* [FelixStartLevel] org.apache.sling.startupfilter BundleEvent STARTED 15.01.2018 12:16:35.181 *INFO* [FelixStartLevel] org.apache.sling.startupfilter Service [org.apache.sling.startupfilter.impl.StartupFilterImpl,123, [org.apache.sling.startupfilter.StartupFilter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.183 *INFO* [FelixStartLevel] org.apache.sling.startupfilter Service [124, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:35.184 *INFO* [FelixStartLevel] org.apache.sling.startupfilter.impl.StartupFilterImpl Registered StartupFilterImpl: enabled as a servlet filter service with pattern / 15.01.2018 12:16:35.184 *INFO* [FelixStartLevel] org.apache.sling.startupfilter.impl.StartupFilterImpl Activated, enabled=true, managerRoot=/system/console 15.01.2018 12:16:35.526 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 6 15.01.2018 12:16:35.944 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 7 15.01.2018 12:16:36.349 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 7 15.01.2018 12:16:38.353 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 8 15.01.2018 12:16:39.953 *INFO* [FelixStartLevel] org.apache.felix.jaas BundleEvent RESOLVED 15.01.2018 12:16:39.953 *INFO* [FelixStartLevel] org.apache.felix.jaas BundleEvent STARTING 15.01.2018 12:16:39.958 *INFO* [FelixStartLevel] org.apache.felix.jaas Service [org.apache.felix.jaas.Configuration.factory,125, [org.osgi.service.cm.ManagedServiceFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:39.984 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.felix.jaas.Configuration.factory])] org.apache.felix.jaas Service [126, [org.apache.felix.jaas.LoginModuleFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:40.006 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.felix.jaas.Configuration.factory])] org.apache.felix.jaas Service [127, [org.apache.felix.jaas.LoginModuleFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:40.016 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.felix.jaas.Configuration.factory])] org.apache.felix.jaas Service [128, [org.apache.felix.jaas.LoginModuleFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:40.032 *INFO* [FelixStartLevel] org.apache.felix.jaas Registered provider FelixJaasProvider for managing JAAS config with type JavaLoginConfig 15.01.2018 12:16:40.033 *INFO* [FelixStartLevel] org.apache.felix.jaas Service [org.apache.felix.jaas.ConfigurationSpi,129, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:40.033 *INFO* [FelixStartLevel] org.apache.felix.jaas Service [130, [org.apache.felix.jaas.LoginContextFactory]] ServiceEvent REGISTERED 15.01.2018 12:16:40.036 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [133, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:40.036 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [132, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:40.037 *INFO* [FelixStartLevel] org.apache.felix.jaas Service [JAAS Web Console Plugin,131, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:40.038 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModuleFactory ConfigLoginModuleProvider{flag=LoginModuleControlFlag: sufficient, ranking=200, realmName='null', className='org.apache.jackrabbit.oak.security.authentication.token.TokenLoginModule'} 15.01.2018 12:16:40.040 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.jaas.ConfigurationSpi])] org.apache.felix.jaas Removed provider FelixJaasProvider type JavaLoginConfig from Security providers list 15.01.2018 12:16:40.040 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.jaas.ConfigurationSpi])] org.apache.felix.jaas Registered provider FelixJaasProvider for managing JAAS config with type JavaLoginConfig 15.01.2018 12:16:40.040 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.jaas.ConfigurationSpi])] org.apache.felix.jaas Replacing the global JAAS configuration with OSGi based proxy configuration. It would look first in the OSGi based configuration and if not found would use the default global configuration 15.01.2018 12:16:40.040 *INFO* [FelixStartLevel] org.apache.felix.jaas Service [134, [javax.security.auth.login.ConfigurationSpi]] ServiceEvent REGISTERED 15.01.2018 12:16:40.040 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModuleFactory ConfigLoginModuleProvider{flag=LoginModuleControlFlag: optional, ranking=300, realmName='null', className='org.apache.jackrabbit.oak.spi.security.authentication.GuestLoginModule'} 15.01.2018 12:16:40.040 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModuleFactory ConfigLoginModuleProvider{flag=LoginModuleControlFlag: sufficient, ranking=100, realmName='null', className='org.apache.jackrabbit.oak.security.authentication.user.LoginModuleImpl'} 15.01.2018 12:16:40.040 *INFO* [FelixStartLevel] org.apache.felix.jaas BundleEvent STARTED 15.01.2018 12:16:40.043 *INFO* [FelixStartLevel] org.apache.sling.datasource BundleEvent RESOLVED 15.01.2018 12:16:40.043 *INFO* [FelixStartLevel] org.apache.sling.datasource BundleEvent STARTING 15.01.2018 12:16:40.043 *INFO* [FelixStartLevel] org.apache.sling.datasource BundleEvent STARTED 15.01.2018 12:16:40.046 *INFO* [FelixStartLevel] org.apache.sling.datasource Service [org.apache.sling.datasource.internal.DriverRegistry,135, [org.apache.sling.datasource.internal.DriverRegistry]] ServiceEvent REGISTERED 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] com.adobe.granite.dropwizard.metrics BundleEvent RESOLVED 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] com.adobe.granite.dropwizard.metrics BundleEvent STARTING 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] com.adobe.granite.dropwizard.metrics BundleEvent STARTED 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] com.day.commons.osgi.wrapper.commons-lang2 BundleEvent STARTING 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] com.day.commons.osgi.wrapper.commons-lang2 BundleEvent STARTED 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] org.apache.commons.collections BundleEvent STARTING 15.01.2018 12:16:40.049 *INFO* [FelixStartLevel] org.apache.commons.collections BundleEvent STARTED 15.01.2018 12:16:40.052 *INFO* [FelixStartLevel] com.day.cq.cq-compat-runmode BundleEvent RESOLVED 15.01.2018 12:16:40.052 *INFO* [FelixStartLevel] com.day.cq.cq-compat-runmode BundleEvent STARTING 15.01.2018 12:16:40.052 *INFO* [FelixStartLevel] com.day.cq.cq-compat-runmode BundleEvent STARTED 15.01.2018 12:16:40.054 *INFO* [FelixStartLevel] com.day.cq.cq-compat-runmode Service [org.apache.sling.runmode.impl.RunModeImpl,136, [org.apache.sling.runmode.RunMode]] ServiceEvent REGISTERED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] com.adobe.granite.osgi.wrapper.guava BundleEvent RESOLVED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup BundleEvent RESOLVED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] org.apache.geronimo.specs.geronimo-atinject_1.0_spec BundleEvent RESOLVED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-commons BundleEvent RESOLVED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-api BundleEvent RESOLVED 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup BundleEvent STARTING 15.01.2018 12:16:40.060 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup BundleEvent STARTED 15.01.2018 12:16:40.063 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup Service [com.adobe.cq.upgrades.backup.impl.BackupConfigImpl,137, [com.adobe.cq.upgrades.backup.BackupConfig]] ServiceEvent REGISTERED 15.01.2018 12:16:40.064 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup Service [com.adobe.cq.upgrades.backup.impl.UpgradeBackup,138, [org.apache.sling.jcr.api.SlingRepositoryInitializer]] ServiceEvent REGISTERED 15.01.2018 12:16:40.064 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-backup Service [com.adobe.cq.upgrades.backup.impl.UpgradeBackupMergerImpl,139, [com.adobe.cq.upgrades.backup.UpgradeBackupMerger]] ServiceEvent REGISTERED 15.01.2018 12:16:40.067 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup BundleEvent RESOLVED 15.01.2018 12:16:40.068 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup BundleEvent STARTING 15.01.2018 12:16:40.068 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup BundleEvent STARTED 15.01.2018 12:16:40.070 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup Service [140, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:40.071 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup Service [com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.a84521e9-4f1a-4136-ac24-8556cde 92d1b,141, [org.apache.sling.jcr.api.SlingRepositoryInitializer]] ServiceEvent REGISTERED 15.01.2018 12:16:40.071 *INFO* [FelixStartLevel] com.adobe.cq.cq-pre-upgrade-cleanup Service [com.adobe.cq.upgrades.cleanup.impl.UpgradeContentCleanup.1e346cdc-e924-425b-9cc7-3fbc057 3637c,142, [org.apache.sling.jcr.api.SlingRepositoryInitializer]] ServiceEvent REGISTERED 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.adobe.cq.cq-product-info-provider BundleEvent RESOLVED 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.day.cq.cq-licensebranding BundleEvent RESOLVED 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.adobe.granite.license BundleEvent RESOLVED 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.day.cq.cq-licensebranding BundleEvent RESOLVED 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.adobe.cq.cq-product-info-provider BundleEvent STARTING 15.01.2018 12:16:40.076 *INFO* [FelixStartLevel] com.adobe.cq.cq-product-info-provider BundleEvent STARTED 15.01.2018 12:16:40.078 *INFO* [FelixStartLevel] com.adobe.cq.cq-product-info-provider Service [com.adobe.cq.product.info.impl.CQProductInfoProvider,143, [com.adobe.granite.license.ProductInfoProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:40.082 *INFO* [FelixStartLevel] org.apache.felix.http.sslfilter BundleEvent RESOLVED 15.01.2018 12:16:40.082 *INFO* [FelixStartLevel] org.apache.felix.http.sslfilter BundleEvent STARTING 15.01.2018 12:16:40.085 *INFO* [FelixStartLevel] org.apache.felix.http.sslfilter Service [org.apache.felix.http.sslfilter.SslFilter,144, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:40.086 *INFO* [CM Configuration Updater (ManagedService Update: pid=[org.apache.felix.http.sslfilter.SslFilter])] org.apache.felix.http.sslfilter SSL filter (re)configured with: SSL forward header = 'X-Forwarded-SSL'; SSL forward value = 'on'; SSL certificate header = 'X-Forwarded-SSL-Certificate'. 15.01.2018 12:16:40.086 *INFO* [FelixStartLevel] org.apache.felix.http.sslfilter Service [Apache Felix HTTP SSL Filter,145, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:40.087 *INFO* [FelixStartLevel] org.apache.felix.http.sslfilter BundleEvent STARTED 15.01.2018 12:16:40.095 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics BundleEvent RESOLVED 15.01.2018 12:16:40.095 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics BundleEvent STARTING 15.01.2018 12:16:40.095 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics BundleEvent STARTED 15.01.2018 12:16:40.101 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [147, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:40.101 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics Service [org.apache.sling.commons.metrics.internal.MetricWebConsolePlugin,146, [org.apache.felix.inventory.InventoryPrinter, javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:40.110 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics Service [Apache Sling Metrics Service,148, [org.apache.sling.commons.metrics.MetricsService]] ServiceEvent REGISTERED 15.01.2018 12:16:40.110 *INFO* [FelixStartLevel] org.apache.sling.commons.metrics Service [Apache Sling Metrics Registry,149, [com.codahale.metrics.MetricRegistry]] ServiceEvent REGISTERED 15.01.2018 12:16:40.111 *INFO* [FelixStartLevel] org.apache.sling.commons.osgi BundleEvent STARTING 15.01.2018 12:16:40.111 *INFO* [FelixStartLevel] org.apache.sling.commons.osgi BundleEvent STARTED 15.01.2018 12:16:40.113 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper BundleEvent RESOLVED 15.01.2018 12:16:40.113 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper BundleEvent STARTING 15.01.2018 12:16:40.113 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper BundleEvent STARTED 15.01.2018 12:16:40.116 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [150, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:40.123 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMappedBundleFilter,151, [org.osgi.framework.hooks.service.EventListenerHook, org.osgi.framework.hooks.service.FindHook]] ServiceEvent REGISTERED 15.01.2018 12:16:40.129 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [154, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:40.130 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.MappingInventoryPrinter,153, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:40.130 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl,152, [org.apache.sling.serviceusermapping.ServiceUserMapper, org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl]] ServiceEvent REGISTERED 15.01.2018 12:16:40.132 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.8ae923af-6580-4a9 3-9dd7-9fcc29cf4347,156, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.134 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.89c46e54-fb0a-475 3-b48d-60250718d6c1,157, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.135 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c8fbe2a5-b2fc-402 8-8bbb-05d348e56ada,158, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.136 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.239f46fa-fe6f-4c9 c-b323-8d16c930fa7f,162, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.137 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.be1a6938-ab0c-472 9-935d-e59c48fe481f,168, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.137 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.91e95d6c-e6bc-4c7 f-9082-7873299c771d,170, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.138 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.31d53c12-58ed-4ea 6-a1a8-ff8d670b9566,174, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.138 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.bb11e0a1-efcf-44f 8-8e76-db04201b8e43,176, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.139 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.87671407-ce38-496 b-8e60-05abaa177304,180, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.139 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.090e77f6-dd1a-460 9-b0ac-71944009ca48,182, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.140 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.985a0264-8da7-4ad 8-b9ea-b1e7d37714a4,186, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.140 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.03bf9e41-9d6f-4a6 d-82db-493700eba29e,187, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.141 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9f9fe721-c9ce-4ae d-be57-0804f425b4cd,188, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.141 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.a1204272-2ba3-4de 4-9e3e-aa77807b75eb,189, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.141 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6bf3083a-ce8b-441 2-8470-6e6dd5ed71d4,190, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.143 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2d44c26c-30b0-4ac c-beb4-88d8ab933456,191, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.143 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.dd3524fe-e132-46b 5-b275-bdcc6e3d41a7,192, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.144 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.84593fdf-9c7d-466 f-864d-4300e0709045,194, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.144 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.e4d09b98-ae17-4b5 d-88f5-de87acc8552a,195, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.145 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1b34a99-346a-42f 9-82bf-aa1609ff7aba,196, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.145 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3b255a96-b268-473 6-a1a7-7e4f559e6cd9,197, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.147 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.a7e5b84d-1282-4d5 5-bfa7-f6ef1f295038,199, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.147 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1b6d4f08-aa08-44d 1-8112-425b4c387e36,212, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.148 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1d83466d-3931-49f 2-817a-cdfa087a20f3,217, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.148 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.68246c6b-49dd-46f c-b715-de9684b0281a,220, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.149 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.fb49b179-4515-4e8 0-b324-56b043363678,224, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.149 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3968f32a-8e4b-44b 4-ad01-97e00b6dbb45,231, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.150 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.040e2c0c-3e1b-402 0-b404-a6915a6c484f,235, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.150 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f5245b1b-d0ee-425 b-97f1-519fa834dd38,240, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.151 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c3593723-47f8-48a 8-9695-d95c846dc1f5,246, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.151 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f47a17a3-3615-4d5 b-a70a-92d019267d63,252, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.152 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.b8333d27-ff44-46b 2-83f8-f07e76238f45,257, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.152 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.501e87b6-a917-400 1-99d4-20f762b3c357,263, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.153 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.29ba025c-0a4a-4df 6-800f-3dfe74064d91,267, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.153 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.569440f1-5879-4c4 7-9b4c-ca388f8020d4,271, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.154 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.341b5455-aa3e-4f9 e-9a2f-4bc1f29ac507,276, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.154 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.631aca08-e2ba-448 0-a1aa-8318836eeb2b,281, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.154 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9878420b-428f-4c0 a-b790-454b3881951c,286, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.155 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.94f497e8-9ff3-4b7 5-9048-9694a4211aa4,292, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.164 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.b7c693b6-4cfa-420 3-9ab3-e4bc55702eb0,300, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.167 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3b2063ef-315d-44d 1-a3e6-fe7bc97c797c,387, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.169 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2c456444-c01a-486 3-9037-951d0b071b67,392, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.173 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.53ac22f2-2127-4f1 4-a453-56634190a259,412, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.174 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.613c54ac-4287-400 b-a375-96c5f5c28366,425, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.175 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6fca6e5e-5dd0-4f5 f-b74f-b7a0f6c535df,432, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.178 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1425718-5f88-41e b-99c7-fc1af7819a14,453, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.180 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.2e24940e-6946-466 7-9044-c03e2bbd9043,471, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.181 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.794a8e6f-7d5f-4d7 0-9022-1420a4a7d5a2,476, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.182 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.01ae22cf-d74a-420 3-95d4-f9b0252ad384,481, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.183 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.5c8b8056-57b7-4a6 8-b838-718605814c82,486, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.184 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.4ccd7a51-07fd-4b5 1-8ce6-a142d3eaa21d,493, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.185 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.8e848940-20cd-47f 7-91a8-daa771f87e9e,504, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.187 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.e32ce7b9-721d-4da a-a2db-f33dc3c4ced0,523, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.188 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.5152051c-2bb2-49e 8-9d50-ac8bbc47406f,531, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.189 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.ab4f09f0-65ab-45b 8-8ffb-169b793fbde4,541, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.190 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.7d0f49b9-fd4a-41a b-9c34-f7ee8e30cf4d,542, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.192 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.aec6a034-ed86-4b4 a-9aa8-754ff27ed8c5,573, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.193 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.9e1a4e62-c527-4b7 4-b795-e8d826a68b97,574, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.194 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.55b3d89f-6725-4cc a-bcd8-c9b05c133096,584, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.195 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.6f122b33-17db-418 e-bda8-0c15e3528123,591, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.196 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.3d1ee316-72fe-4ec a-800a-177abeb47dfa,604, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.197 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.0ba8f83a-9400-413 0-ae19-9958a2400fee,610, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.197 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.d670a670-3d31-40e 6-a844-2f7e31232776,611, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.198 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.143f9583-246a-4c3 0-833f-77c2c2410652,631, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.200 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.f0450926-5c30-412 e-b034-65e36997a20e,641, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.200 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.1855d1b7-38c9-42a 5-b903-28486ad04763,643, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.201 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.00c2e906-a62a-46a b-aed7-180975e406f5,648, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.202 *INFO* [FelixStartLevel] org.apache.sling.serviceusermapper Service [org.apache.sling.serviceusermapping.impl.ServiceUserMapperImpl.amended.c1f9d2f6-546f-443 8-b051-d8b235aa06f7,655, [org.apache.sling.serviceusermapping.impl.MappingConfigAmendment]] ServiceEvent REGISTERED 15.01.2018 12:16:40.612 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 10 15.01.2018 12:16:40.993 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 10 15.01.2018 12:16:43.019 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 11 15.01.2018 12:16:44.621 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault BundleEvent RESOLVED 15.01.2018 12:16:44.621 *INFO* [FelixStartLevel] com.adobe.granite.infocollector BundleEvent RESOLVED 15.01.2018 12:16:44.622 *INFO* [FelixStartLevel] com.adobe.granite.infocollector BundleEvent STARTING 15.01.2018 12:16:44.622 *INFO* [FelixStartLevel] com.adobe.granite.infocollector BundleEvent STARTED 15.01.2018 12:16:44.636 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [673, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:44.636 *INFO* [FelixStartLevel] com.adobe.granite.infocollector Service [com.adobe.granite.infocollector.InfoCollector,672, [org.apache.felix.inventory.InventoryPrinter, org.apache.felix.inventory.ZipAttachmentProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:44.637 *INFO* [FelixStartLevel] com.adobe.granite.license BundleEvent STARTING 15.01.2018 12:16:44.637 *INFO* [FelixStartLevel] com.adobe.granite.license BundleEvent STARTED 15.01.2018 12:16:44.672 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.LicenseContext,674, [org.osgi.service.http.context.ServletContextHelper]] ServiceEvent REGISTERED 15.01.2018 12:16:44.673 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.LicenseProvider,675, [com.adobe.granite.license.impl.LicenseProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:44.680 *INFO* [FelixStartLevel] com.adobe.granite.license.impl.LicenseProvider Adobe Experience Manager 6.3.0 licensed by Adobe 15.01.2018 12:16:44.680 *INFO* [FelixStartLevel] com.adobe.granite.license.impl.LicenseProvider DownloadID:cafebabe-cafe-0246-8756-0ddcce804709 15.01.2018 12:16:44.680 *INFO* [FelixStartLevel] com.adobe.granite.license.impl.ProductInfoServiceImpl Bound new product info provider: [com.adobe.cq.product.info.impl.CQProductInfoProvider@1c1a9900] - providers: [1] 15.01.2018 12:16:44.685 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.LicenseCheckFilter,677, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:44.689 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.LicenseServlet,678, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:44.691 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [681, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:16:44.691 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [680, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:44.691 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.ProductInfoConsolePlugin,679, [javax.servlet.Servlet, org.apache.felix.webconsole.BrandingPlugin, org.apache.felix.webconsole.ConfigurationPrinter]] ServiceEvent REGISTERED 15.01.2018 12:16:44.691 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.ProductInfoServiceImpl,676, [com.adobe.granite.license.ProductInfoService]] ServiceEvent REGISTERED 15.01.2018 12:16:44.692 *INFO* [FelixStartLevel] com.adobe.granite.license Service [com.adobe.granite.license.impl.WebConsoleLinkFilter,682, [javax.servlet.Filter]] ServiceEvent REGISTERED 15.01.2018 12:16:44.692 *INFO* [FelixStartLevel] org.apache.sling.api BundleEvent STARTING 15.01.2018 12:16:44.692 *INFO* [FelixStartLevel] org.apache.sling.api BundleEvent STARTED 15.01.2018 12:16:45.104 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 13 15.01.2018 12:16:45.509 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 13 15.01.2018 12:16:47.110 *INFO* [FelixStartLevel] rideau BundleEvent RESOLVED 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] AGL_min BundleEvent RESOLVED 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] afe BundleEvent RESOLVED 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] afe BundleEvent STARTING 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] afe BundleEvent STARTED 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] AGL_min BundleEvent STARTING 15.01.2018 12:16:47.111 *INFO* [FelixStartLevel] AGL_min BundleEvent STARTED 15.01.2018 12:16:47.129 *INFO* [FelixStartLevel] PDFServices_extraction BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] org.apache.tika.core BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] com.adobe.granite.gibson BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] com.adobe.xmp.xmpcore BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] pdfencryption BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] pdfcore BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] PDFServices_manipulations BundleEvent RESOLVED 15.01.2018 12:16:47.130 *INFO* [FelixStartLevel] com.adobe.granite.gibson BundleEvent STARTING 15.01.2018 12:16:47.249 *INFO* [FelixStartLevel] com.adobe.granite.gibson Service [683, [org.apache.tika.parser.Parser]] ServiceEvent REGISTERED 15.01.2018 12:16:47.249 *INFO* [FelixStartLevel] com.adobe.granite.gibson BundleEvent STARTED 15.01.2018 12:16:47.253 *INFO* [FelixStartLevel] com.day.cq.dam.adobe-xmp BundleEvent RESOLVED 15.01.2018 12:16:47.254 *INFO* [FelixStartLevel] com.adobe.granite.poi BundleEvent RESOLVED 15.01.2018 12:16:47.254 *INFO* [FelixStartLevel] com.adobe.granite.poi BundleEvent STARTING 15.01.2018 12:16:47.254 *INFO* [FelixStartLevel] com.adobe.granite.poi BundleEvent STARTED 15.01.2018 12:16:47.256 *INFO* [FelixStartLevel] com.adobe.granite.rngom BundleEvent RESOLVED 15.01.2018 12:16:47.256 *INFO* [FelixStartLevel] com.adobe.granite.rngom BundleEvent STARTING 15.01.2018 12:16:47.256 *INFO* [FelixStartLevel] com.adobe.granite.rngom BundleEvent STARTED 15.01.2018 12:16:47.259 *INFO* [FelixStartLevel] com.adobe.granite.tagsoup BundleEvent RESOLVED 15.01.2018 12:16:47.259 *INFO* [FelixStartLevel] com.adobe.granite.tagsoup BundleEvent STARTING 15.01.2018 12:16:47.259 *INFO* [FelixStartLevel] com.adobe.granite.tagsoup BundleEvent STARTED 15.01.2018 12:16:47.259 *INFO* [FelixStartLevel] org.apache.commons.codec BundleEvent STARTING 15.01.2018 12:16:47.259 *INFO* [FelixStartLevel] org.apache.commons.codec BundleEvent STARTED 15.01.2018 12:16:47.262 *INFO* [FelixStartLevel] org.apache.commons.compress BundleEvent RESOLVED 15.01.2018 12:16:47.262 *INFO* [FelixStartLevel] org.apache.commons.compress BundleEvent STARTING 15.01.2018 12:16:47.262 *INFO* [FelixStartLevel] org.apache.commons.compress BundleEvent STARTED 15.01.2018 12:16:47.264 *INFO* [FelixStartLevel] com.adobe.xmp.core BundleEvent RESOLVED 15.01.2018 12:16:47.264 *INFO* [FelixStartLevel] com.adobe.xmp.core BundleEvent STARTING 15.01.2018 12:16:47.264 *INFO* [FelixStartLevel] com.adobe.xmp.core BundleEvent STARTED 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] com.adobe.xmp.schema.model BundleEvent RESOLVED 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] com.adobe.xmp.schema.model BundleEvent STARTING 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] com.adobe.xmp.schema.model BundleEvent STARTED 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] pdfcore BundleEvent STARTING 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] pdfcore BundleEvent STARTED 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] pdfencryption BundleEvent STARTING 15.01.2018 12:16:47.266 *INFO* [FelixStartLevel] pdfencryption BundleEvent STARTED 15.01.2018 12:16:47.267 *INFO* [FelixStartLevel] PDFServices_extraction BundleEvent STARTING 15.01.2018 12:16:47.269 *INFO* [FelixStartLevel] PDFServices_extraction Service [684, [org.apache.tika.parser.Parser]] ServiceEvent REGISTERED 15.01.2018 12:16:47.269 *INFO* [FelixStartLevel] PDFServices_extraction BundleEvent STARTED 15.01.2018 12:16:47.269 *INFO* [FelixStartLevel] rideau BundleEvent STARTING 15.01.2018 12:16:47.269 *INFO* [FelixStartLevel] rideau BundleEvent STARTED 15.01.2018 12:16:47.271 *INFO* [FelixStartLevel] com.adobe.xmp.schema.rngparser BundleEvent RESOLVED 15.01.2018 12:16:47.272 *INFO* [FelixStartLevel] com.adobe.xmp.schema.rngparser BundleEvent STARTING 15.01.2018 12:16:47.272 *INFO* [FelixStartLevel] com.adobe.xmp.schema.rngparser BundleEvent STARTED 15.01.2018 12:16:47.278 *INFO* [FelixStartLevel] com.adobe.xmp.schema.service BundleEvent RESOLVED 15.01.2018 12:16:47.278 *INFO* [FelixStartLevel] com.adobe.xmp.schema.service BundleEvent STARTING 15.01.2018 12:16:47.278 *INFO* [FelixStartLevel] com.adobe.xmp.schema.service BundleEvent STARTED 15.01.2018 12:16:47.278 *INFO* [FelixStartLevel] org.apache.tika.core BundleEvent STARTING 15.01.2018 12:16:47.281 *INFO* [FelixStartLevel] org.apache.tika.core BundleEvent STARTED 15.01.2018 12:16:47.287 *INFO* [FelixStartLevel] org.apache.opennlp.tools BundleEvent RESOLVED 15.01.2018 12:16:47.287 *INFO* [FelixStartLevel] org.apache.tika.parsers BundleEvent RESOLVED 15.01.2018 12:16:47.287 *INFO* [FelixStartLevel] com.adobe.cq.gson BundleEvent RESOLVED 15.01.2018 12:16:47.288 *INFO* [FelixStartLevel] org.apache.commons.exec BundleEvent RESOLVED 15.01.2018 12:16:47.288 *INFO* [FelixStartLevel] org.apache.tika.parsers BundleEvent STARTING 15.01.2018 12:16:47.359 *INFO* [FelixStartLevel] org.apache.tika.parsers Service [685, [org.apache.tika.detect.Detector]] ServiceEvent REGISTERED 15.01.2018 12:16:47.428 *INFO* [FelixStartLevel] org.apache.tika.parsers Service [686, [org.apache.tika.parser.Parser]] ServiceEvent REGISTERED 15.01.2018 12:16:47.428 *INFO* [FelixStartLevel] org.apache.tika.parsers BundleEvent STARTED 15.01.2018 12:16:47.428 *INFO* [FelixStartLevel] com.adobe.xmp.xmpcore BundleEvent STARTING 15.01.2018 12:16:47.428 *INFO* [FelixStartLevel] com.adobe.xmp.xmpcore BundleEvent STARTED 15.01.2018 12:16:47.480 *INFO* [FelixStartLevel] com.adobe.granite.osgi.wrapper.guava BundleEvent STARTING 15.01.2018 12:16:47.480 *INFO* [FelixStartLevel] com.adobe.granite.osgi.wrapper.guava BundleEvent STARTED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-data BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-blob BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.mongodb.mongo-java-driver BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-jcr BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.sling.jcr.base BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-rmi BundleEvent RESOLVED 15.01.2018 12:16:47.490 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-commons BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] com.adobe.granite.jmx BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] com.day.crx.crx-api BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] com.adobe.granite.repository BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] org.h2.mvstore BundleEvent RESOLVED 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] com.adobe.granite.repository BundleEvent STARTING 15.01.2018 12:16:47.491 *INFO* [FelixStartLevel] com.adobe.granite.repository BundleEvent STARTED 15.01.2018 12:16:47.495 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [687, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:47.499 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.impl.CommitStatsConfig,688, [com.adobe.granite.repository.impl.CommitStatsConfig]] ServiceEvent REGISTERED 15.01.2018 12:16:47.500 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.ServiceUserConfiguration.304949fd-98d5-4d6e-9142-6eb7e62e28 f4,689, [com.adobe.granite.repository.impl.ServiceUsersConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.500 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.ServiceUserConfiguration.458fb765-3ef0-4ee7-a308-718d80d292 7d,690, [com.adobe.granite.repository.impl.ServiceUsersConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.500 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.ServiceUserConfiguration.0f64f3bf-6fe4-4689-9ea2-f7bfa84a03 50,691, [com.adobe.granite.repository.impl.ServiceUsersConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.501 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.impl.CommitStats,692, [com.adobe.granite.repository.impl.CommitStats]] ServiceEvent REGISTERED 15.01.2018 12:16:47.506 *INFO* [FelixStartLevel] CommitStats updateConfig: CommitStats is disabled. 15.01.2018 12:16:47.507 *INFO* [FelixStartLevel] CommitStats updateConfig: CommitStats is enabled. 15.01.2018 12:16:47.507 *INFO* [FelixStartLevel] CommitStats updateConfig: restarting background thread due to interval config change. 15.01.2018 12:16:47.508 *INFO* [FelixStartLevel] CommitStats updateConfig: CommitStats is enabled. 15.01.2018 12:16:47.509 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.day.crx.sling.server.impl.jmx.SecureNodeStoreAccess,693, [org.osgi.framework.hooks.service.FindHook]] ServiceEvent REGISTERED 15.01.2018 12:16:47.509 *INFO* [CommitStats] CommitStats run: commit stats logger [#2] started. 15.01.2018 12:16:47.515 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.adobe.granite.repository.impl.ServiceUsersConfigurationManager,694, [com.adobe.granite.repository.impl.ServiceUsersConfigurationManager]] ServiceEvent REGISTERED 15.01.2018 12:16:47.518 *INFO* [FelixStartLevel] com.adobe.granite.repository Service [com.day.crx.sling.server.impl.jmx.SecureContentRepositoryAccess,695, [org.osgi.framework.hooks.service.FindHook]] ServiceEvent REGISTERED 15.01.2018 12:16:47.518 *INFO* [FelixStartLevel] org.h2.mvstore BundleEvent STARTING 15.01.2018 12:16:47.518 *INFO* [FelixStartLevel] org.h2.mvstore BundleEvent STARTED 15.01.2018 12:16:47.518 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-data BundleEvent STARTING 15.01.2018 12:16:47.518 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-data BundleEvent STARTED 15.01.2018 12:16:47.519 *INFO* [FelixStartLevel] org.mongodb.mongo-java-driver BundleEvent STARTING 15.01.2018 12:16:47.519 *INFO* [FelixStartLevel] org.mongodb.mongo-java-driver BundleEvent STARTED 15.01.2018 12:16:47.522 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external BundleEvent RESOLVED 15.01.2018 12:16:47.522 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external BundleEvent STARTING 15.01.2018 12:16:47.522 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external BundleEvent STARTED 15.01.2018 12:16:47.526 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external Service [org.apache.jackrabbit.oak.spi.security.authentication.external.impl.SyncManagerImpl,696, [org.apache.jackrabbit.oak.spi.security.authentication.external.SyncManager]] ServiceEvent REGISTERED 15.01.2018 12:16:47.534 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external Service [org.apache.jackrabbit.oak.spi.security.authentication.external.impl.principal.ExternalPr incipalConfiguration,697, [org.apache.jackrabbit.oak.spi.security.principal.PrincipalConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.538 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-external Service [org.apache.jackrabbit.oak.spi.security.authentication.external.impl.ExternalIDPManagerIm pl,698, [org.apache.jackrabbit.oak.spi.security.authentication.external.ExternalIdentityProviderM anager]] ServiceEvent REGISTERED 15.01.2018 12:16:47.542 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-ldap BundleEvent RESOLVED 15.01.2018 12:16:47.542 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-ldap BundleEvent STARTING 15.01.2018 12:16:47.542 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-auth-ldap BundleEvent STARTED 15.01.2018 12:16:47.607 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-authorization-cug BundleEvent RESOLVED 15.01.2018 12:16:47.607 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-authorization-cug BundleEvent STARTING 15.01.2018 12:16:47.607 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-authorization-cug BundleEvent STARTED 15.01.2018 12:16:47.609 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-authorization-cug Service [699, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:47.610 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-authorization-cug Service [org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration,700, [org.apache.jackrabbit.oak.spi.security.authorization.AuthorizationConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.610 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-blob BundleEvent STARTING 15.01.2018 12:16:47.610 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-blob BundleEvent STARTED 15.01.2018 12:16:47.612 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-commons BundleEvent STARTING 15.01.2018 12:16:47.612 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-commons BundleEvent STARTED 15.01.2018 12:16:47.612 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core BundleEvent STARTING 15.01.2018 12:16:47.613 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModule class [org.apache.jackrabbit.oak.spi.security.authentication.GuestLoginModule] from Bundle org.apache.jackrabbit.oak-core [99] 15.01.2018 12:16:47.614 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModule class [org.apache.jackrabbit.oak.security.authentication.user.LoginModuleImpl] from Bundle org.apache.jackrabbit.oak-core [99] 15.01.2018 12:16:47.615 *INFO* [FelixStartLevel] org.apache.felix.jaas Registering LoginModule class [org.apache.jackrabbit.oak.security.authentication.token.TokenLoginModule] from Bundle org.apache.jackrabbit.oak-core [99] 15.01.2018 12:16:47.615 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core BundleEvent STARTED 15.01.2018 12:16:47.638 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [701, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:16:47.656 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.commit.ConflictValidatorProvider,702, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.661 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.metric.StatisticsProviderFactory Using MetricsStatisticsProvider 15.01.2018 12:16:47.677 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [703, [com.codahale.metrics.MetricRegistry]] ServiceEvent REGISTERED 15.01.2018 12:16:47.677 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [704, [org.apache.jackrabbit.oak.stats.StatisticsProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.678 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.name.NamespaceEditorProvider,705, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.679 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.user.UserConfigurationImpl,706, [org.apache.jackrabbit.oak.spi.security.user.UserConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.679 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.counter.NodeCounterEditorProvider,707, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.680 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.observation.ChangeCollectorProvider,708, [org.apache.jackrabbit.oak.spi.commit.ValidatorProvider, org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.681 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.observation.ChangeCollectorProvider activate: maxItems=50, maxPathDepth=9, enabled=true 15.01.2018 12:16:47.682 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.name.NameValidatorProvider,709, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.684 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.authentication.AuthenticationConfigurationImpl,710, [org.apache.jackrabbit.oak.spi.security.authentication.AuthenticationConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:16:47.686 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.multiplex.MountInfoProviderService No mount config provided. Mounting would be disabled 15.01.2018 12:16:47.687 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.property.PropertyIndexProvider,712, [org.apache.jackrabbit.oak.spi.query.QueryIndexProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.687 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.nodetype.NodeTypeIndexProvider,713, [org.apache.jackrabbit.oak.spi.query.QueryIndexProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.688 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.reference.ReferenceEditorProvider,714, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.688 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [711, [org.apache.jackrabbit.oak.spi.mount.MountInfoProvider]] ServiceEvent REGISTERED 15.01.2018 12:16:47.777 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService Starting DocumentNodeStore with host=[localhost:27017], db=oak, cache size (MB)=256, persistentCache=D:\Software\AEM-RDB\crx-quickstart\repository\cache,binary=0, journalCache=D:\Software\AEM-RDB\crx-quickstart\repository\diff-cache, blobCacheSize (MB)=16, maxReplicationLagInSecs=21600 15.01.2018 12:16:47.830 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 15 15.01.2018 12:16:47.898 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService Mongo Connection details MongoClientOptions{connectionsPerHost=100, connectTimeout=10000, socketTimeout=0, socketKeepAlive=false, maxWaitTime=120000, threadsAllowedToBlockForConnectionMultiplier=5, readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, fsync=null, journal=null} 15.01.2018 12:16:47.944 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=10000, description='MongoConnection for Oak DocumentMK'} 15.01.2018 12:16:47.970 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster description not yet available. Waiting for 30000 ms before timing out 15.01.2018 12:16:48.983 *INFO* [cluster-ClusterId{value='5a5c4e57ab73d90e74728293', description='MongoConnection for Oak DocumentMK'}-localhost:27017] org.mongodb.driver.cluster Exception in monitor thread while connecting to server localhost:27017 com.mongodb.MongoSocketOpenException: Exception opening socket at com.mongodb.connection.SocketStream.open(SocketStream.java:63) at com.mongodb.connection.InternalStreamConnection.open(InternalStreamConnection.java:115) at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonito r.java:113) at java.lang.Thread.run(Unknown Source) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) at java.net.AbstractPlainSocketImpl.connect(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at com.mongodb.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:57) at com.mongodb.connection.SocketStream.open(SocketStream.java:58) ... 3 common frames omitted 15.01.2018 12:17:17.972 *ERROR* [FelixStartLevel] org.apache.jackrabbit.oak-core [org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService(133)] The activate method has thrown an exception (com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}]) com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}] at com.mongodb.connection.BaseCluster.getDescription(BaseCluster.java:163) at com.mongodb.Mongo.getClusterDescription(Mongo.java:411) at com.mongodb.Mongo.getReplicaSetStatus(Mongo.java:448) at org.apache.jackrabbit.oak.plugins.document.util.MongoConnection.getDefaultWriteConcern(Mo ngoConnection.java:164) at org.apache.jackrabbit.oak.plugins.document.DocumentMK$Builder.setMongoDB(DocumentMK.java: 617) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStore(Doc umentNodeStoreService.java:516) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStoreIfPo ssible(DocumentNodeStoreService.java:416) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.activate(DocumentNode StoreService.java:400) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224) at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617) at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501) at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:302) at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:294) at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(Singl eComponentManager.java:298) at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentM anager.java:109) at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManage r.java:906) at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleCompone ntManager.java:879) at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractCompo nentManager.java:749) at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractCompone ntManager.java:675) at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManage r.java:430) at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(Configurab leComponentHolder.java:657) at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator .java:341) at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:25 9) at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232 ) at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatc her.java:916) at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java :835) at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:517) at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4542) at org.apache.felix.framework.Felix.startBundle(Felix.java:2173) at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1372) at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308) at java.lang.Thread.run(Unknown Source) 15.01.2018 12:17:17.973 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.atomic.AtomicCounterEditorProvider,715, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:17.973 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.property.OrderedPropertyIndexEditorProvider,716, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:17.974 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.reference.ReferenceIndexProvider,717, [org.apache.jackrabbit.oak.spi.query.QueryIndexProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:17.974 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider,718 , [org.apache.jackrabbit.oak.spi.security.user.action.AuthorizableActionProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:17.975 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.user.UserAuthenticationFactoryImpl,719, [org.apache.jackrabbit.oak.spi.security.user.UserAuthenticationFactory]] ServiceEvent REGISTERED 15.01.2018 12:17:17.976 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.itemsave.ItemSaveValidatorProvider,720, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:17.976 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl,721, [org.apache.jackrabbit.oak.spi.security.authentication.token.TokenConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:17:17.984 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [722, [org.apache.jackrabbit.oak.api.jmx.ConsolidatedCacheStatsMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:17.985 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.principal.PrincipalConfigurationImpl,723, [org.apache.jackrabbit.oak.spi.security.principal.PrincipalConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:17:17.986 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName,724, [org.apache.jackrabbit.oak.spi.security.user.AuthorizableNodeName]] ServiceEvent REGISTERED 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.003 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.004 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.004 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: no BundleContext is available 15.01.2018 12:17:18.004 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.004 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: preconditions are not satisfied: Preconditions(preconditions = [org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl, org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider, org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration, org.apache.jackrabbit.oak.security.user.UserAuthenticationFactoryImpl, org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationImpl, org.apache.jackrabbit.oak.spi.security.authentication.external.impl.principal.ExternalPri ncipalConfiguration, org.apache.jackrabbit.oak.security.principal.PrincipalConfigurationImpl, org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName, org.apache.jackrabbit.oak.security.authorization.restriction.RestrictionProviderImpl], candidates = [org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration, org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl, org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider, org.apache.jackrabbit.oak.security.user.UserAuthenticationFactoryImpl, org.apache.jackrabbit.oak.spi.security.authentication.external.impl.principal.ExternalPri ncipalConfiguration, org.apache.jackrabbit.oak.security.principal.PrincipalConfigurationImpl, org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName]) 15.01.2018 12:17:18.004 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.privilege.PrivilegeConfigurationImpl,725, [org.apache.jackrabbit.oak.spi.security.privilege.PrivilegeConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:17:18.005 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.version.VersionHook,726, [org.apache.jackrabbit.oak.spi.commit.CommitHook]] ServiceEvent REGISTERED 15.01.2018 12:17:18.006 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.index.property.PropertyIndexEditorProvider,727, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.013 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.013 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: preconditions are not satisfied: Preconditions(preconditions = [org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl, org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider, org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration, org.apache.jackrabbit.oak.security.user.UserAuthenticationFactoryImpl, org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationImpl, org.apache.jackrabbit.oak.spi.security.authentication.external.impl.principal.ExternalPri ncipalConfiguration, org.apache.jackrabbit.oak.security.principal.PrincipalConfigurationImpl, org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName, org.apache.jackrabbit.oak.security.authorization.restriction.RestrictionProviderImpl], candidates = [org.apache.jackrabbit.oak.spi.security.authorization.cug.impl.CugConfiguration, org.apache.jackrabbit.oak.security.authentication.token.TokenConfigurationImpl, org.apache.jackrabbit.oak.spi.security.user.action.DefaultAuthorizableActionProvider, org.apache.jackrabbit.oak.security.user.UserAuthenticationFactoryImpl, org.apache.jackrabbit.oak.spi.security.authentication.external.impl.principal.ExternalPri ncipalConfiguration, org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationImpl, org.apache.jackrabbit.oak.security.principal.PrincipalConfigurationImpl, org.apache.jackrabbit.oak.security.user.RandomAuthorizableNodeName]) 15.01.2018 12:17:18.013 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.authorization.AuthorizationConfigurationImpl,728, [org.apache.jackrabbit.oak.spi.security.authorization.AuthorizationConfiguration, org.apache.jackrabbit.oak.spi.security.SecurityConfiguration]] ServiceEvent REGISTERED 15.01.2018 12:17:18.014 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.plugins.nodetype.TypeEditorProvider,729, [org.apache.jackrabbit.oak.spi.commit.EditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.020 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.023 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [731, [org.apache.jackrabbit.oak.spi.security.SecurityProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.023 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration SecurityProvider instance registered 15.01.2018 12:17:18.023 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-core Service [org.apache.jackrabbit.oak.security.authorization.restriction.RestrictionProviderImpl,730 , [org.apache.jackrabbit.oak.spi.security.authorization.restriction.RestrictionProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.023 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-jcr BundleEvent STARTING 15.01.2018 12:17:18.024 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-jcr BundleEvent STARTED 15.01.2018 12:17:18.031 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-jcr Service [732, [org.apache.jackrabbit.oak.jcr.observation.jmx.ConsolidatedListenerMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.032 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene BundleEvent STARTING 15.01.2018 12:17:18.032 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene BundleEvent STARTED 15.01.2018 12:17:18.043 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [733, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:17:18.051 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [org.apache.jackrabbit.oak.plugins.index.lucene.IndexAugmentorFactory,734, [org.apache.jackrabbit.oak.plugins.index.lucene.IndexAugmentorFactory]] ServiceEvent REGISTERED 15.01.2018 12:17:18.122 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [736, [org.apache.jackrabbit.oak.api.jmx.CacheStatsMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.122 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Extracted text caching enabled with maxSize 20 MB, expiry time 300 secs 15.01.2018 12:17:18.122 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Prefetching of index files enabled. Index would be opened after copying all new files locally 15.01.2018 12:17:18.134 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [737, [org.apache.jackrabbit.oak.plugins.index.lucene.CopyOnReadStatsMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.135 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Enabling CopyOnRead support. Index files would be copied under D:\Software\AEM-RDB\crx-quickstart\repository\index 15.01.2018 12:17:18.136 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.hybrid.NRTIndexFactory Refresh delta set to 1 secs 15.01.2018 12:17:18.137 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.BadIndexTracker Bad Index recheck interval set to 900 seconds 15.01.2018 12:17:18.139 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [738, [org.apache.jackrabbit.oak.spi.query.QueryIndexProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.143 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [739, [org.apache.jackrabbit.oak.spi.commit.BackgroundObserverMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.144 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Registering the LuceneIndexProvider as a BackgroundObserver 15.01.2018 12:17:18.144 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [740, [org.apache.jackrabbit.oak.spi.commit.Observer]] ServiceEvent REGISTERED 15.01.2018 12:17:18.150 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [741, [org.apache.jackrabbit.oak.spi.commit.Observer]] ServiceEvent REGISTERED 15.01.2018 12:17:18.151 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [742, [org.apache.jackrabbit.oak.plugins.document.spi.JournalPropertyService]] ServiceEvent REGISTERED 15.01.2018 12:17:18.152 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Configured JournalPropertyBuilder with max size 5000 and backed by BackgroundObserver with queue size 1000 15.01.2018 12:17:18.153 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [743, [org.apache.jackrabbit.oak.spi.commit.Observer]] ServiceEvent REGISTERED 15.01.2018 12:17:18.153 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [744, [org.apache.jackrabbit.oak.spi.commit.BackgroundObserverMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.154 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Hybrid indexing enabled for configured indexes with queue size of 10000 15.01.2018 12:17:18.154 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexProviderService Enabling CopyOnWrite support. Index files would be copied under D:\Software\AEM-RDB\crx-quickstart\repository\index 15.01.2018 12:17:18.155 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [745, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.155 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [746, [org.apache.jackrabbit.oak.plugins.index.lucene.TextExtractionStatsMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.162 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [747, [org.apache.jackrabbit.oak.plugins.index.lucene.LuceneIndexMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.165 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [748, [org.apache.jackrabbit.oak.spi.gc.GCMonitor]] ServiceEvent REGISTERED 15.01.2018 12:17:18.165 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-lucene Service [org.apache.jackrabbit.oak.plugins.index.lucene.score.impl.ScorerProviderFactoryImpl,735, [org.apache.jackrabbit.oak.plugins.index.lucene.score.ScorerProviderFactory]] ServiceEvent REGISTERED 15.01.2018 12:17:18.169 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-segment-tar BundleEvent RESOLVED 15.01.2018 12:17:18.169 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-segment-tar BundleEvent STARTING 15.01.2018 12:17:18.169 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-segment-tar BundleEvent STARTED 15.01.2018 12:17:18.220 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi BundleEvent RESOLVED 15.01.2018 12:17:18.221 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi BundleEvent STARTING 15.01.2018 12:17:18.221 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi BundleEvent STARTED 15.01.2018 12:17:18.236 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [org.apache.jackrabbit.oak.plugins.index.solr.osgi.SolrServerProviderService,750, [org.apache.jackrabbit.oak.plugins.index.solr.server.SolrServerProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.240 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [org.apache.jackrabbit.oak.plugins.index.solr.osgi.EmbeddedSolrServerConfigurationProvide r,749, [org.apache.jackrabbit.oak.plugins.index.solr.configuration.SolrServerConfigurationProvid er]] ServiceEvent REGISTERED 15.01.2018 12:17:18.242 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [org.apache.jackrabbit.oak.plugins.index.solr.osgi.RemoteSolrServerConfigurationProvider, 751, [org.apache.jackrabbit.oak.plugins.index.solr.configuration.SolrServerConfigurationProvid er]] ServiceEvent REGISTERED 15.01.2018 12:17:18.246 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [753, [org.apache.jackrabbit.oak.spi.query.QueryIndexProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.246 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [org.apache.jackrabbit.oak.plugins.index.solr.osgi.SolrIndexEditorProviderService,754, [org.apache.jackrabbit.oak.plugins.index.IndexEditorProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.247 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak-solr-osgi Service [org.apache.jackrabbit.oak.plugins.index.solr.osgi.OakSolrConfigurationProviderService,75 2, [org.apache.jackrabbit.oak.plugins.index.solr.configuration.OakSolrConfigurationProvider] ] ServiceEvent REGISTERED 15.01.2018 12:17:18.249 *INFO* [FelixStartLevel] com.adobe.granite.jmx BundleEvent STARTING 15.01.2018 12:17:18.250 *INFO* [FelixStartLevel] com.adobe.granite.jmx BundleEvent STARTED 15.01.2018 12:17:18.251 *INFO* [FelixStartLevel] com.adobe.granite.jmx Service [com.adobe.granite.jmx.internal.JMXConsolePlugin,755, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:17:18.251 *INFO* [FelixStartLevel] com.day.crx.crx-api BundleEvent STARTING 15.01.2018 12:17:18.251 *INFO* [FelixStartLevel] com.day.crx.crx-api BundleEvent STARTED 15.01.2018 12:17:18.255 *INFO* [FelixStartLevel] com.day.commons.day-commons-text BundleEvent RESOLVED 15.01.2018 12:17:18.255 *INFO* [FelixStartLevel] com.day.commons.day-commons-text BundleEvent STARTING 15.01.2018 12:17:18.255 *INFO* [FelixStartLevel] com.day.commons.day-commons-text BundleEvent STARTED 15.01.2018 12:17:18.259 *INFO* [FelixStartLevel] com.adobe.forms.foundation-forms-foundation-base BundleEvent RESOLVED 15.01.2018 12:17:18.259 *INFO* [FelixStartLevel] com.adobe.forms.foundation-forms-foundation-base BundleEvent STARTING 15.01.2018 12:17:18.259 *INFO* [FelixStartLevel] com.adobe.forms.foundation-forms-foundation-base BundleEvent STARTED 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Trying to register a SecurityProvider... 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.oak.security.internal.SecurityProviderRegistration Aborting: a SecurityProvider is already registered 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] com.adobe.forms.foundation-forms-foundation-base Service [com.adobe.aemfd.formsfoundation.oak.restrictions.impl.FormsConditionRestrictionProvider, 756, [org.apache.jackrabbit.oak.spi.security.authorization.restriction.RestrictionProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-api BundleEvent STARTING 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-api BundleEvent STARTED 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-commons BundleEvent STARTING 15.01.2018 12:17:18.262 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-commons BundleEvent STARTED 15.01.2018 12:17:18.263 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-rmi BundleEvent STARTING 15.01.2018 12:17:18.263 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-jcr-rmi BundleEvent STARTED 15.01.2018 12:17:18.263 *INFO* [FelixStartLevel] org.apache.sling.commons.json BundleEvent STARTING 15.01.2018 12:17:18.263 *INFO* [FelixStartLevel] org.apache.sling.commons.json BundleEvent STARTED 15.01.2018 12:17:18.266 *INFO* [FelixStartLevel] org.apache.sling.commons.mime BundleEvent RESOLVED 15.01.2018 12:17:18.266 *INFO* [FelixStartLevel] org.apache.sling.commons.mime BundleEvent STARTING 15.01.2018 12:17:18.293 *INFO* [FelixStartLevel] org.apache.sling.commons.mime Service [Apache Tika MIME Type Provider,757, [org.apache.sling.commons.mime.MimeTypeProvider]] ServiceEvent REGISTERED 15.01.2018 12:17:18.294 *INFO* [FelixStartLevel] org.apache.sling.commons.mime BundleEvent STARTED 15.01.2018 12:17:18.296 *INFO* [FelixStartLevel] org.apache.sling.commons.mime Service [org.apache.sling.commons.mime.internal.MimeTypeServiceImpl,758, [org.apache.sling.commons.mime.MimeTypeService]] ServiceEvent REGISTERED 15.01.2018 12:17:18.297 *INFO* [FelixStartLevel] org.apache.sling.commons.threads BundleEvent STARTING 15.01.2018 12:17:18.299 *INFO* [FelixStartLevel] org.apache.sling.commons.threads.impl.DefaultThreadPoolManager Started Apache Sling Thread Pool Manager 15.01.2018 12:17:18.299 *INFO* [FelixStartLevel] org.apache.sling.commons.threads Service [org.apache.sling.commons.threads.impl.DefaultThreadPool.factory,759, [org.apache.sling.commons.threads.ThreadPoolManager, org.osgi.service.cm.ManagedServiceFactory]] ServiceEvent REGISTERED 15.01.2018 12:17:18.301 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [762, [javax.servlet.Servlet]] ServiceEvent REGISTERED 15.01.2018 12:17:18.301 *INFO* [FelixStartLevel] org.apache.felix.inventory Service [761, [org.apache.felix.inventory.InventoryPrinter]] ServiceEvent REGISTERED 15.01.2018 12:17:18.301 *INFO* [FelixStartLevel] org.apache.sling.commons.threads Service [Apache Sling Thread Pool Configuration Printer,760, [org.apache.sling.commons.threads.impl.WebConsolePrinter]] ServiceEvent REGISTERED 15.01.2018 12:17:18.302 *INFO* [FelixStartLevel] org.apache.sling.commons.threads BundleEvent STARTED 15.01.2018 12:17:18.316 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.sling.commons.threads.impl.DefaultThreadPool.factory])] org.apache.sling.commons.threads Service [763, [org.apache.sling.commons.threads.jmx.ThreadPoolMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.317 *INFO* [FelixStartLevel] org.apache.sling.extensions.webconsolesecurityprovider BundleEvent RESOLVED 15.01.2018 12:17:18.317 *INFO* [FelixStartLevel] org.apache.sling.extensions.webconsolesecurityprovider BundleEvent STARTING 15.01.2018 12:17:18.319 *INFO* [FelixStartLevel] org.apache.sling.extensions.webconsolesecurityprovider Service [764, [org.apache.sling.launchpad.api.StartupListener]] ServiceEvent REGISTERED 15.01.2018 12:17:18.320 *INFO* [FelixStartLevel] org.apache.sling.extensions.webconsolesecurityprovider BundleEvent STARTED 15.01.2018 12:17:18.320 *INFO* [FelixStartLevel] org.apache.sling.jcr.api BundleEvent STARTING 15.01.2018 12:17:18.320 *INFO* [FelixStartLevel] org.apache.sling.jcr.api BundleEvent STARTED 15.01.2018 12:17:18.320 *INFO* [FelixStartLevel] org.apache.sling.jcr.base BundleEvent STARTING 15.01.2018 12:17:18.320 *INFO* [FelixStartLevel] org.apache.sling.jcr.base BundleEvent STARTED 15.01.2018 12:17:18.323 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [765, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:17:18.326 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist,766, [org.apache.sling.jcr.base.internal.LoginAdminWhitelist]] ServiceEvent REGISTERED 15.01.2018 12:17:18.327 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.7488eef6-1937-43b9-aa57- 7890289e2291,767, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.327 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cae930f2-d2b6-4abe-944d- b683a97877bd,768, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.327 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.8531486d-fca9-4270-a779- c6d4afeaeba7,769, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.328 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.e72661f9-cdc4-429c-bb84- e40fb8731b49,770, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.328 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.3f87bee4-5643-4ad0-be6c- 2398d982523b,771, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.328 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.e616d9a8-b1bc-4526-a986- 40215fc9dceb,772, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.329 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.fd7d1973-5e21-42e2-9d69- b6210165832b,773, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.329 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.cd20bd1f-c694-475b-81fa- 1c0bfd7ce963,774, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.329 *INFO* [FelixStartLevel] org.apache.sling.jcr.base Service [org.apache.sling.jcr.base.internal.LoginAdminWhitelist.fragment.df1246d9-22ef-4925-b650- f590b6a97ac6,775, [org.apache.sling.jcr.base.internal.WhitelistFragment]] ServiceEvent REGISTERED 15.01.2018 12:17:18.329 *INFO* [FelixStartLevel] org.apache.sling.jcr.jcr-wrapper BundleEvent STARTING 15.01.2018 12:17:18.329 *INFO* [FelixStartLevel] org.apache.sling.jcr.jcr-wrapper BundleEvent STARTED 15.01.2018 12:17:18.337 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.sling.commons.threads.impl.DefaultThreadPool.factory])] org.apache.sling.commons.threads Service [776, [org.apache.sling.commons.threads.jmx.ThreadPoolMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.346 *INFO* [CM Configuration Updater (ManagedServiceFactory Update: factoryPid=[org.apache.sling.commons.threads.impl.DefaultThreadPool.factory])] org.apache.sling.commons.threads Service [777, [org.apache.sling.commons.threads.jmx.ThreadPoolMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.351 *INFO* [FelixStartLevel] org.apache.sling.jcr.registration BundleEvent RESOLVED 15.01.2018 12:17:18.351 *INFO* [FelixStartLevel] org.apache.sling.jcr.registration BundleEvent STARTING 15.01.2018 12:17:18.351 *INFO* [FelixStartLevel] org.apache.sling.jcr.registration BundleEvent STARTED 15.01.2018 12:17:18.361 *INFO* [FelixStartLevel] org.apache.sling.repoinit.parser BundleEvent RESOLVED 15.01.2018 12:17:18.361 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit BundleEvent RESOLVED 15.01.2018 12:17:18.361 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit BundleEvent STARTING 15.01.2018 12:17:18.361 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit BundleEvent STARTED 15.01.2018 12:17:18.363 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit Service [778, [org.osgi.service.cm.ManagedService]] ServiceEvent REGISTERED 15.01.2018 12:17:18.364 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit Service [org.apache.sling.jcr.repoinit.impl.JcrRepoInitOpsProcessorImpl,779, [org.apache.sling.jcr.repoinit.JcrRepoInitOpsProcessor]] ServiceEvent REGISTERED 15.01.2018 12:17:18.364 *INFO* [FelixStartLevel] org.apache.sling.repoinit.parser BundleEvent STARTING 15.01.2018 12:17:18.364 *INFO* [FelixStartLevel] org.apache.sling.repoinit.parser BundleEvent STARTED 15.01.2018 12:17:18.366 *INFO* [FelixStartLevel] org.apache.sling.repoinit.parser Service [org.apache.sling.repoinit.parser.impl.RepoInitParserService,780, [org.apache.sling.repoinit.parser.RepoInitParser]] ServiceEvent REGISTERED 15.01.2018 12:17:18.366 *INFO* [FelixStartLevel] org.apache.sling.jcr.repoinit Service [org.apache.sling.jcr.repoinit.impl.RepositoryInitializer,781, [org.apache.sling.jcr.api.SlingRepositoryInitializer]] ServiceEvent REGISTERED 15.01.2018 12:17:18.424 *INFO* [FelixStartLevel] com.adobe.granite.installer.factory.packages BundleEvent RESOLVED 15.01.2018 12:17:18.424 *INFO* [FelixStartLevel] com.adobe.granite.installer.factory.packages BundleEvent STARTING 15.01.2018 12:17:18.424 *INFO* [FelixStartLevel] com.adobe.granite.installer.factory.packages BundleEvent STARTED 15.01.2018 12:17:18.430 *INFO* [FelixStartLevel] com.day.cq.cq-jcrclustersupport BundleEvent RESOLVED 15.01.2018 12:17:18.430 *INFO* [FelixStartLevel] com.day.cq.cq-jcrclustersupport BundleEvent STARTING 15.01.2018 12:17:18.430 *INFO* [FelixStartLevel] com.day.cq.cq-jcrclustersupport BundleEvent STARTED 15.01.2018 12:17:18.434 *INFO* [FelixStartLevel] com.day.cq.jcrclustersupport.impl.JcrClusterSupport activate: Cluster Master Observer thread started 15.01.2018 12:17:18.465 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi BundleEvent RESOLVED 15.01.2018 12:17:18.465 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi BundleEvent STARTING 15.01.2018 12:17:18.465 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi BundleEvent STARTED 15.01.2018 12:17:18.468 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi-commons BundleEvent RESOLVED 15.01.2018 12:17:18.468 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi-commons BundleEvent STARTING 15.01.2018 12:17:18.468 *INFO* [FelixStartLevel] org.apache.jackrabbit.jackrabbit-spi-commons BundleEvent STARTED 15.01.2018 12:17:18.468 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault BundleEvent STARTING 15.01.2018 12:17:18.468 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault BundleEvent STARTED 15.01.2018 12:17:18.644 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault Service [org.apache.jackrabbit.vault.packaging.events.impl.PackageEventDispatcherImpl,782, [org.apache.jackrabbit.vault.packaging.events.impl.PackageEventDispatcher]] ServiceEvent REGISTERED 15.01.2018 12:17:18.646 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault Service [org.apache.jackrabbit.vault.packaging.impl.ActivityLog,783, [org.apache.jackrabbit.vault.packaging.events.PackageEventListener]] ServiceEvent REGISTERED 15.01.2018 12:17:18.646 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault.packaging.impl.ActivityLog Package Activity Log Started 15.01.2018 12:17:18.647 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault Service [org.apache.jackrabbit.vault.packaging.impl.PackageManagerMBeanImpl,784, [javax.management.DynamicMBean]] ServiceEvent REGISTERED 15.01.2018 12:17:18.650 *INFO* [FelixStartLevel] org.apache.jackrabbit.vault Service [org.apache.jackrabbit.vault.packaging.impl.PackagingImpl,785, [org.apache.jackrabbit.vault.packaging.Packaging]] ServiceEvent REGISTERED 15.01.2018 12:17:18.789 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 16 15.01.2018 12:17:19.183 *INFO* [FelixDispatchQueue] org.apache.felix.framework FrameworkEvent STARTLEVEL CHANGED to 16
            • 3. Re: RDB over TarMK in AEM 6.3
              onkarh71407069 Level 1
              Specifically this is error.
              Regards,
              Onkar Hattekar.
              15.01.2018 15:15:59.612 *INFO* [cluster-ClusterId{value='5a5c7856ab73d91d58e95f70', description='MongoConnection for Oak DocumentMK'}-localhost:27017] org.mongodb.driver.cluster Exception in monitor thread while connecting to server localhost:27017
              at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:113)
              15.01.2018 15:16:28.600 *ERROR* [FelixStartLevel] org.apache.jackrabbit.oak-core [org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService(133)] The activate method has thrown an exception (com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}])
              at org.apache.jackrabbit.oak.plugins.document.util.MongoConnection.getDefaultWriteConcern(MongoConnection.java:164)
              at org.apache.jackrabbit.oak.plugins.document.DocumentMK$Builder.setMongoDB(DocumentMK.java:617)
              at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStore(DocumentNodeStoreService.java:516)
              at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStoreIfPossible(DocumentNodeStoreService.java:416)
              at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.activate(DocumentNodeStoreService.java:400)
              at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298)
              at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109)
              at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)
              at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)
              at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749)
              at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675)
              at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430)
              at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)
              at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)
              at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)
              at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)
              at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:916)
              at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:835)
              • 4. Re: RDB over TarMK in AEM 6.3
                Jörg Hoh Adobe Employee
                looks like the mongo connection is being started instead of the RDB. Which documentation are you using for setup?
                Jörg
                • 5. Re: RDB over TarMK in AEM 6.3
                  I am trying it with the help of  RDBMS Support in AEM 6.3
                  • 6. Re: RDB over TarMK in AEM 6.3
                    can you suggest me any site?
                    • 7. Re: RDB over TarMK in AEM 6.3
                      Opkar Gill Adobe Employee
                      what is in your config file: org.apache.sling.datasource.DataSourceFactory-oak.config
                      Regards,
                      Opkar
                      • 8. Re: RDB over TarMK in AEM 6.3
                        Hi Opkar,
                        I am referring this site RDBMS Support in AEM 6.3
                        1.At first I only created org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.config file with mysql driver in install folder.It has follwing data.
                            datasource.name="rdbdatasource"
                            url="jdbc:mysql://localhost:3306/oak"
                            driverClassName="com.mysql.jdbc.Driver"
                            username="root"
                            password="root"
                        2. Now I created org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.config as well as org.apache.sling.datasource.DataSourceFactory-oak.config and copy above data in second file.First file is empty now.
                        Still it has error like,
                        Regards,
                        Onkar Hattekar.
                        16.01.2018 14:42:39.380 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=10000, description='MongoConnection for Oak DocumentMK'} 16.01.2018 14:42:39.408 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster description not yet available. Waiting for 30000 ms before timing out 16.01.2018 14:42:40.423 *INFO* [cluster-ClusterId{value='5a5dc207ab73d90b045a1347', description='MongoConnection for Oak DocumentMK'}-localhost:27017] org.mongodb.driver.cluster Exception in monitor thread while connecting to server localhost:27017 com.mongodb.MongoSocketOpenException: Exception opening socket at com.mongodb.connection.SocketStream.open(SocketStream.java:63) at com.mongodb.connection.InternalStreamConnection.open(InternalStreamConnection.java:115) at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonito r.java:113) at java.lang.Thread.run(Unknown Source) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) at java.net.AbstractPlainSocketImpl.connect(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at com.mongodb.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:57) at com.mongodb.connection.SocketStream.open(SocketStream.java:58) ... 3 common frames omitted 16.01.2018 14:43:09.410 *ERROR* [FelixStartLevel] org.apache.jackrabbit.oak-core [org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService(134)] The activate method has thrown an exception (com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}]) com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}] at com.mongodb.connection.BaseCluster.getDescription(BaseCluster.java:163) at com.mongodb.Mongo.getClusterDescription(Mongo.java:411) at com.mongodb.Mongo.getReplicaSetStatus(Mongo.java:448) at org.apache.jackrabbit.oak.plugins.document.util.MongoConnection.getDefaultWriteConcern(Mo ngoConnection.java:164) at org.apache.jackrabbit.oak.plugins.document.DocumentMK$Builder.setMongoDB(DocumentMK.java: 617) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStore(Doc umentNodeStoreService.java:516) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.registerNodeStoreIfPo ssible(DocumentNodeStoreService.java:416) at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.activate(DocumentNode StoreService.java:400) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224) at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617) at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501) at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:302) at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:294) at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(Singl eComponentManager.java:298) at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentM anager.java:109) at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManage r.java:906) at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleCompone ntManager.java:879) at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractCompo nentManager.java:749) at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractCompone ntManager.java:675) at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManage r.java:430) at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(Configurab leComponentHolder.java:657) at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator .java:341) at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:25 9) at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232 ) at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatc her.java:916) at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java :835) at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:517) at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4542) at org.apache.felix.framework.Felix.startBundle(Felix.java:2173) at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1372) at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308) at java.lang.Thread.run(Unknown Source)
                        • 9. Re: RDB over TarMK in AEM 6.3
                          smacdonald2008 Adobe Employee
                          Do you have the Database Driver file in an OSGi bundle and deployed in an Active State.
                          • 10. Re: RDB over TarMK in AEM 6.3
                            No,it is in resolved state.I used different version of mysql-connector-java.jar for every new instance.Even I convert that jar in OSGi and used it.Still it is in resolved state.
                            Onkar
                            • 11. Re: RDB over TarMK in AEM 6.3
                                 Now bundle is in active state;I updated version of mysql jar file.
                              Still it encounter an error:
                              18.01.2018 15:23:58.315 *INFO* [cluster-ClusterId{value='5a606eb5ab73d92d84b919fc', description='MongoConnection for Oak DocumentMK'}-localhost:27017] org.mongodb.driver.cluster Exception in monitor thread while connecting to server localhost:27017
                              18.01.2018 15:24:27.302 *ERROR* [FelixStartLevel] org.apache.jackrabbit.oak-core [org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService(134)] The activate method has thrown an exception (com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}])
                              • 12. Re: RDB over TarMK in AEM 6.3
                                The problem is still: You are triggering the connection to MongoDB. Have you configured the runmode "crx3rdb"?
                                Kind regards,
                                Jörg
                                • 13. Re: RDB over TarMK in AEM 6.3
                                  Yes,I am using this command,
                                  java -jar aem-author-4502.jar -r author,crx3,crx3rdb -gui
                                  Regards,
                                  Onkar
                                  • 14. Re: RDB over TarMK in AEM 6.3
                                    hi,
                                    How could I solve this problem?
                                    • 15. Re: RDB over TarMK in AEM 6.3
                                      KhushwantSingh Employee Moderator
                                      Kindly confirm that the mysql instance name is rdbdatasource and not oak.
                                      • 16. Re: RDB over TarMK in AEM 6.3
                                             I am saying each procedure.Please tell me;is there anything wrong?I am referring RDBMS Support in AEM 6.3
                                        I unpacked my jar file using  java -jar aem-author-4502.jar -unpack this command.
                                        Then I created install folder.It has two configuration files and a folder named as 9.Folder 9 contains mysql driver jar as mysql-connector-java-5.1.45-bin.jar.
                                        Configuration files are
                                        1. org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService.config
                                                       <empty conf file>
                                        2. org.apache.sling.datasource.DataSourceFactory-oak.config
                                        url="jdbc:mysql://localhost:3306/rdbdatasource"
                                        username="root"
                                        password="root"
                                             I used java -jar aem-author-4502.jar -r author,crx3,crx3rdb -gui this command to install AEM.It stucks in between.MySql instance name is rdbdatastore as said.
                                        The Mysql bundle is in Active state.
                                        Apache Sling Connection DataSourcePool is filled with given configuration as sees.
                                        Still it encounters error as follows:
                                        25.01.2018 14:31:34.664 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=10000, description='MongoConnection for Oak DocumentMK'}
                                        25.01.2018 14:31:34.809 *INFO* [FelixStartLevel] org.mongodb.driver.cluster Cluster description not yet available. Waiting for 30000 ms before timing out
                                        25.01.2018 14:31:35.696 *INFO* [cluster-ClusterId{value='5a699ceeab73d907a46aa089', description='MongoConnection for Oak DocumentMK'}-localhost:27017] org.mongodb.driver.cluster Exception in monitor thread while connecting to server localhost:27017
                                        25.01.2018 14:32:04.811 *ERROR* [FelixStartLevel] org.apache.jackrabbit.oak-core [org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService(134)] The activate method has thrown an exception (com.mongodb.MongoTimeoutException: Timed out after 30000 ms while waiting to connect. Client view of cluster state is {type=UNKNOWN, servers=[{address=localhost:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.ConnectException: Connection refused: connect}}])
                                                   Please tell me what to do?
                                        Regards,
                                        onkar Hattekar
                                        • 17. Re: RDB over TarMK in AEM 6.3
                                          The problem is still that the system wants to connect to a MongoDB. That's the first and most important issue right now.
                                          • 18. Re: RDB over TarMK in AEM 6.3
                                            Then what is solution for that?
                                            • 19. Re: RDB over TarMK in AEM 6.3
                                              Please log a ticket for this - looks like you have done all suggestions made by the community. You may need a hotfix.
