• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Export to Illustrator not possible
Community Beginner ,
Jan 12, 2018 Jan 12, 2018
I would like to export a certain drawing to Illustrator. Though I am logged in with the same Adobe Account the export to Illustrator doesn’t work.
Text of the alert:
„Fehler beim Senden. Senden an Desktop-Anwendung fehlgeschlagen. Versuchen Sie es erneut.“
Best regards,
Anna
Views
554
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Jan 16, 2018 Jan 16, 2018
Anna.
I'm going to email you at the .de email address associated with your forum profile. Watch out for an email from Adobe titled "Adobe Draw - Simplified."
Sue.
Votes
Translate
Translate
Adobe Employee ,
Hi Anna.
I'm sorry it's not working.
The first thing I'd like you to do is check to see that when you log in with your Adobe ID to https://assets.adobe.com/assets/mobile?filter=draw all the work that's on your device  is showing up there.
Then, a few questions:
* Are you having the trouble with one drawing or multiple drawings? If you've only tried one, can you draw something really simple and try sending that?
* If it's just the one drawing, is there anything unusual about it? Is it more complex? Does it have an Image Layer? Does it have a lot of layers?
* How is your wifi connection? When sending a complex drawing, if the connection is spotty or slow the transfer will time out. If you have access to one, please try using a different wifi network and see if you get the same result.
* Are you able to save a PDF of the drawing to CC Files (to check, tap the same Share icon in the upper nav but choose Send to CC Files as PDF)?
Let me know what you find and we'll go from there.
Sue.
Votes
Translate
Translate
Report
Report
Hi Sue,
thanks for your reply.
I checked already before – all my work is showing up there.
– I have trouble only with one drawing which is a little bit more complex. I tried with some VERY simple drawings, they worked.
– The concerned drawing has only one layer.
– My wifi connection is fine. I have no access to another wifi network. iPad and iMac have a distance of 20 cm.
– I saved the drawing already several times as png or jpg, but the resolution is too low and, what is more important, i want to change the drawing in Illustrator.
Anna.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
So it sounds like it's definitely the drawing then...
Please see if you're able to save it as a PDF (it's different from saving it as a .png). From the Share menu choose Send to CC Files as PDF. If it saves you'll be able to see it when you sign in with your Adobe ID to http://assets.adobe.com/files.
If that doesn't work, I'm probably going to need you to share the drawing with me.
Sue.
Votes
Translate
Translate
Report
Report
Sue.
Export to PDF is still running. I could send you an invitation for slack to check the drawing.
Anna
Votes
Translate
Translate
Report
Report
Sue.
Same alert for PDF as for export to Illustrator.
Link to the drawing:
[pulled]
Anna.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
That's what I figured. I've sent your drawing to one of our engineers. It needs to be simplified. I can see, just from the type of drawing it is, that there are too many strokes in it to send to the desktop.
I'll email you, at the email address that you use for the forums, as soon as I have a version of it that can be opened. Hopefully today...
Sue.
Votes
Translate
Translate
Report
Report
Thanks Sue.
The problem is that the drawing is not yet completed... I just needed to work with a first version.
Anna.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
Do you need to work on it in Illustrator? Or still in Draw?
Sue.
Votes
Translate
Translate
Report
Report
Sue.
I need to work on the drawing in Draw. So perhaps I first finish the drawing and then send it again to you?
Anna.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
Yes. Sure. That's totally fine.
One thing I want you to keep an eye on while you continue to work on it... Make sure it's syncing to Creative Cloud (sometimes as drawings get more and more complex, the changes stop syncing then there's an even bigger problem).
If at any point you notice that it's not syncing, please stop working on it.
You can email me a link to it through the in-app feedback (tap the Settings icon in the lower nav then Send Feedback) so you don't have to post that publicly.
Sue.
Votes
Translate
Translate
Report
Report
Hey Sue.
finally the drawing is finished, but as you expected syncing is difficult or not working. Here comes the link: [removed]
Is it working? I would be glad if your engineers could change it so that it can be opened in Illustrator.
But my question now: I recently bought iPad and Apple Pencil mainly in order to draw and work on it. But of course a reliable connection to Illustrator or Photoshop is essential. Will this be improved by Adobe?
Anna.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
I've got it. I'll send it to one of our engineers right now.
I'm not sure what the solution will end up being, but the Draw team is working on how to resolve this issue about work being too complex to send to the desktop.
Sue.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Anna.
Sue.
Votes
Translate
Translate
Report
Report
Jan 18, 2018 Jan 18, 2018
Sue.
Everything worked well. Thank you so much!
Anna
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
You're welcome Anna.
Sue.
Votes
Translate
Translate
Report
Report
